  3. Problem with Wind Speed sensor
53 Posts 6 Posters 19.4k Views 7 Watching
  • AWIA AWI
    @rnollen can you get it to a stable less than 3v when rotating.? If you can not get it stable than I there is a chance a serial protocol like "onewire" is used. Then you need a clue from the supplier. If you have stable outputs when rotating very slowly it is probably a pulse train which you can count.
    rnollenR
    rnollenR
    rnollen
    Yes, It is stable when you rotate it. Around the 3V. But how can I count it then?
    AWIA 1 Reply Last reply
    • rnollenR rnollen
      AWIA
      AWIA
      AWI
      @rnollen I would expect a low high signal transition when you rotate slowly.
      0_1468496891675_upload-6bd65600-8754-4568-9dff-120fd20da85c
      If that is not the case it is hard to determine from here what kind of signal you get.. (is assume you don't have access to an oscilloscope.. ;-)
      • rnollenR
        rnollenR
        rnollen
        wrote on last edited by rnollen
        Thanks; but how to go further from here then :) Is there a way to create a sketch for this device? And how to attach it to a Nano board?
        I got a manual from the supplier: https://1drv.ms/w/s!AmsPyx0xoB6jjYo0PZZRazdA3-vPpw for this device. But I already see a difference with the wires :) But to give it a start then, according to the manual it counts the pulses and that gives a windspeed :)
        • rnollenR rnollen
          AWIA
          AWIA
          AWI
          @rnollen Hi, the manual is a bit confusing in that it mentions a "serial protocol" and also a table is mentioned with voltages and wind speed. As yours iw 3 wire we can assume it is not a RS485 output.
          Then there are you need to dertermine what kind of output it is either NPN or PNP. : PNP needs a "pull down" resistor. NPN needs a "pull up". resistor..Best thing is to test the different options with the volt meter.
          According to the table the "average" voltage should vary with the rotating spreed.
          Note that I make a lot of assumptions.... but: If you get a voltage on your meter that changes with the rotating spreed than it is time to connect the nan. With the assumption that there are pulses, best thing is to write a routine which counts the pulses in a certain time frame e.g 10 secs. (connect the nano with a either a digital or analog pin, but read with digitalread(),. There should be many examples on the web.
          Have fun
          rnollenR 1 Reply Last reply
          • rnollenR
            rnollenR
            rnollen
            @AWI . I will try to find out. But for the record later, can I simply connect the 5V, ground and the Yellow dataline directly to the arduino ? Or do I still need a resistor somewhere?
            Then I will try to find I sketch to read the digital pin. Can i maybe use other pulse sketches as an example?
            I will do the Volt test, I know that the volt test remains the same when I rotate on the same speed. Don't know for sure, if I rotate faster if the volt's are the same then as before. I thought not, but I will test later tonight.
            • rnollenR rnollen
              AWIA
              AWIA
              AWI
              wrote on last edited by AWI
              @rnollen If you keep the voltage at 5v you can directy connect to the arduino pin. You still need a pull-up/down resistor though.
              pin D13 on the nano has a LED connected to it. It may help you in observing what is going on. A LED is much faster than a volt meter..
              • AWIA AWI
                rnollenR
                rnollenR
                rnollen
                Sorry for all the questions :) But I am a noob on this matter. I do know something of scripting, but electronics is not something where I am familiar with.
                But to summarize then how to connect it; The yellow line, will go through a resistor (which one?) and that is connected to D13. Black is Ground, Red is 5 Volt? Is this correct? And is this setup only for testing or also as the final solution later on, because the D13 is also used for the radio? Problem is: I don't know exactly what a LED is in you're example :)
                Edit-> Also send questions to the supplier. Maybe he can gives me an answer if it is PNP or NPN device. Also asked for schematics and how to calculate the pulses.
                • rnollenR
                  rnollenR
                  rnollen
                  When I use the volt meter and I rotate, then the volts are pretty much the same. Rotating faster, doesn't give me higher values.
                  As a test I have attached it to my Arduino nano using a 10k Pullup resistor. Found a little example sketch regarding the LED on the arduino site. As the very first test I can see the light bling on the arduino when I rotate the windmeter. Rotating it harder will make the light bling faster, rotating slower and it blings slowly. So the pulses seems to come through.
                  But now, I need a vary small and basic way to start counting the pulses when it rotates. I have tried to create a very small sketch (using an example of the Arduino website). But that is not working OK. Tried to modify the examples for powermeter and watermeter which are also pulse sketches, but at this stage it has too much code.
                  Does anyone have a very small example sketch to start with for my setup?
                  • AWIA AWI
                    Have fun
                    rnollenR
                    rnollenR
                    rnollen
                    @AWI said:
                    ..... There should be many examples on the web.
                    Have fun
                    Unfortunately I cannot find any working example code. Found all kind of stuff on the internet, but nothing that will give me some valuable data.
                    I think that the examples on the internet mostly uses an pull up anemometer, as far as I can see the Arduino Nano also have a internal one which you can activate on the sketch. But basically, when I use a resistor, which is connected on the yellow and red wire, I am still stuck on the sketch I cannot find something desent (and small), that gives me something valuable. I now know why the windmeter is not an example on the Mysensors site :) Way to difficult :).
                    • rnollenR rnollen
                      Have fun
                      AWIA
                      AWIA
                      AWI
                      @rnollen It shouldn't be so complicated.. there are a many ways to do it. Start in the learning curve with the most simple method of counting pulses using the arduino builtin method pulseIn(). (non MySensors, basic arduino). You should be able to see the pulse frequency on the serial port when turning the rotor.
                      const int anemometerPin = 4 ; // wherever you connected the anemometer
                      unsigned long timePeriod = 0;
                      unsigned long timeon = 0;
                      unsigned long timeoff =0;
                      { pinMode(anemometerPin, INPUT_PULLUP);
                        Serial.begin(9600);
                         timeon = pulseIn(anemometerPin,HIGH); // Measured Time On
                         timeoff = pulseIn(anemometerPin,LOW); // Measure Time Off
                         timePeriod = timeon + timeoff; // total period = on + off
                         float frequency  = 1000000.0/timePeriod; // calculate the frequency
                         Serial.println(frequency);
                         delay(1000);
                      • rnollenR
                        rnollenR
                        rnollen
                        @AWI Thanks, I will give it a try. Today I also received some additional info. The device is a NPN model. Type 12CM, according to the supplier it is 12 pulses for 1m/s per second. But the manual says that this model is 10 pulses for 1m/s.
                        So basically I could now connect the device as NPN, only I need to find out how :)
                        • rnollenR rnollen
                          AWIA
                          AWIA
                          AWI
                          @rnollen good news. Npn needs a pull-up so the sketch above should be able to do it. It uses the internal pull-up of the Arduino. I am curious to the outcome.
                          • AWIA AWI
                            rnollenR
                            rnollenR
                            rnollen
                            #22
                            It does not work entirely correct I think. In the serial Monitor I see "Inf" as outcome of the sketch :( Don't see exactly where that is coming from :)
                            Maybe something wrong with the wiring? I Attached the 12V DC to red and blue. The Yellow, connected it to the breadboard and a cable from the D7 also to this connection. I took a 4.7K resistor, connected also to this group and the other side of this resistor I connected to the 5V of the Arduino? Is that correct?
                            When I remove the resistor: then this is my outcome of the sketch:
                            12.82
                            inf
                            inf
                            3.36
                            1.88
                            55.06
                            inf
                            37037.03
                            inf
                            333333.34
                            30.95
                            17.43
                            inf
                            142857.14
                            inf
                            125000.00
                            500000.00
                            500000.00
                            90909.10
                            500000.00
                            39.47
                            inf
                            250000.00
                            500000.00
                            inf
                            20.54
                            45.67
                            58823.53
                            inf
                            9.88
                            inf
                            inf
                            9.17
                            inf
                            Then I got some numbers, but what they mean :) The very high numbers are when rotating..
                            • rnollenR rnollen
                              12.82
                              inf
                              inf
                              3.36
                              1.88
                              55.06
                              inf
                              37037.03
                              inf
                              333333.34
                              30.95
                              17.43
                              inf
                              142857.14
                              inf
                              125000.00
                              500000.00
                              500000.00
                              90909.10
                              500000.00
                              39.47
                              inf
                              250000.00
                              500000.00
                              inf
                              20.54
                              45.67
                              58823.53
                              inf
                              9.88
                              inf
                              inf
                              9.17
                              inf
                              AWIA
                              AWIA
                              AWI
                              #23
                              @rnollen the "inf" means infinite and is caused by a 0 division. You can try to remove the line starting with 'float' and print the time values.
                              I assume you changed the anemometer pin in the sketch to d7...?
                              And connected the gnd of 12v and 5v together?
                              • AWIA AWI
                                rnollenR
                                rnollenR
                                rnollen
                                I have did some additional testing. The DC12 is wrong I think, when I use that then the whole sketch does not give any values back. Now used the 5V of the arduino, then I got something readings using this sketch. I have added some additional serial print lines for logging. But when times are zero, then the frequency is INF and that happens when I don't rotate, so that looks OK I think
                                Timeon: 0
                                Timeoff: 0
                                TimePeriod: 0
                                Frequency: inf
                                Timeon: 0
                                Timeoff: 87951
                                TimePeriod: 87951
                                Frequency: 11.37
                                Timeon: 24222
                                Timeoff: 22899
                                TimePeriod: 47121
                                Frequency: 21.22
                                Timeon: 24960
                                Timeoff: 27680
                                TimePeriod: 52640
                                Frequency: 19.00
                                Timeon: 27545
                                Timeoff: 28273
                                TimePeriod: 55818
                                Frequency: 17.92
                                Timeon: 63310
                                Timeoff: 0
                                TimePeriod: 63310
                                Frequency: 15.80
                                The serial.print lines:
                                Serial.print("Timeon: ");
                                Serial.println(timeon);
                                Serial.print("Timeoff: ");
                                Serial.println(timeoff);
                                Serial.print("TimePeriod: ");
                                Serial.println(timePeriod);
                                Serial.print("Frequency: ");
                                But any idea, because I am still lost don't know exactly what the conclusion of this is :)
                                AWIA 2 Replies Last reply
                                • rnollenR rnollen
                                  Timeon: 0
                                  Timeoff: 0
                                  TimePeriod: 0
                                  Frequency: inf
                                  Timeon: 0
                                  Timeoff: 87951
                                  TimePeriod: 87951
                                  Frequency: 11.37
                                  Timeon: 24222
                                  Timeoff: 22899
                                  TimePeriod: 47121
                                  Frequency: 21.22
                                  Timeon: 24960
                                  Timeoff: 27680
                                  TimePeriod: 52640
                                  Frequency: 19.00
                                  Timeon: 27545
                                  Timeoff: 28273
                                  TimePeriod: 55818
                                  Frequency: 17.92
                                  Timeon: 63310
                                  Timeoff: 0
                                  TimePeriod: 63310
                                  Frequency: 15.80
                                  AWIA
                                  AWIA
                                  AWI
                                  @rnollen this looks much better. You get frequencies in the 10 to 20 range when rotating. The inf when you're not rotating are caused by timer overflow so nothing wrong there.
                                  Now it is time for a more dedicated measurement. Basically replace the standard arduino routines with your own version. It is middle of the night here so I have to leave it for tomorrow...
                                  • rnollenR rnollen
                                    Timeon: 0
                                    Timeoff: 0
                                    TimePeriod: 0
                                    Frequency: inf
                                    Timeon: 0
                                    Timeoff: 87951
                                    TimePeriod: 87951
                                    Frequency: 11.37
                                    Timeon: 24222
                                    Timeoff: 22899
                                    TimePeriod: 47121
                                    Frequency: 21.22
                                    Timeon: 24960
                                    Timeoff: 27680
                                    TimePeriod: 52640
                                    Frequency: 19.00
                                    Timeon: 27545
                                    Timeoff: 28273
                                    TimePeriod: 55818
                                    Frequency: 17.92
                                    Timeon: 63310
                                    Timeoff: 0
                                    TimePeriod: 63310
                                    Frequency: 15.80
                                    AWIA
                                    AWIA
                                    AWI
                                    @rnollen time for "Take 2" I created it in Codebender to make sure it compiles. Could not test functionality yet.
                                    The "take 2" code implements a non-blocking measurement of the frequency of the anemometer (pulses per second). It should be safe for overflow.
                                    Take 3 could be to translate it to m/s windspeed according to your type of anemometer and finally:
                                    Take 4 MySensors' ise it!!
                                    https://codebender.cc/sketch:347690
                                    • rnollenR
                                      rnollenR
                                      rnollen
                                      #27
                                      @AWI Hmm.. I see this:
                                      1000.00
                                      1000.00
                                      1000.00
                                      1000.00
                                      1000.00
                                      1000.00
                                      1000.00
                                      1000.00
                                      1000.00
                                      500.00
                                      1000.00
                                      0.00
                                      inf
                                      1000.00
                                      0.00
                                      0.00
                                      Don't think that this is correct right? Am I doing something wrong, or does these numbers say anything to you :)
                                      • rnollenR rnollen
                                        1000.00
                                        1000.00
                                        1000.00
                                        1000.00
                                        1000.00
                                        1000.00
                                        1000.00
                                        1000.00
                                        1000.00
                                        500.00
                                        1000.00
                                        0.00
                                        inf
                                        1000.00
                                        0.00
                                        0.00
                                        AWIA
                                        AWIA
                                        AWI
                                        #28
                                        @rnollen was a short night... :sweat:
                                        Forgot the return lastFrequencyI changed the sketch in last post. No guarantee that it works, don't have the hardware.
                                        • rnollenR
                                          rnollenR
                                          rnollen
                                          @AWI Sorry for the late reply, I got the flu :( But did test the sketch, but I got the same results basically.. Mostly 1000, inf and sometimes a 500? So what can be wrong here?
                                          Thanks for all you're efforts so far!! Really appreciate it :)
