  3. Problem with Wind Speed sensor
53 Posts 6 Posters 19.4k Views 7 Watching
  • AWIA AWI
    @rnollen If you keep the voltage at 5v you can directy connect to the arduino pin. You still need a pull-up/down resistor though.
    pin D13 on the nano has a LED connected to it. It may help you in observing what is going on. A LED is much faster than a volt meter..
    rnollenR
    rnollenR
    rnollen
    wrote on last edited by rnollen
    Sorry for all the questions :) But I am a noob on this matter. I do know something of scripting, but electronics is not something where I am familiar with.
    But to summarize then how to connect it; The yellow line, will go through a resistor (which one?) and that is connected to D13. Black is Ground, Red is 5 Volt? Is this correct? And is this setup only for testing or also as the final solution later on, because the D13 is also used for the radio? Problem is: I don't know exactly what a LED is in you're example :)
    Edit-> Also send questions to the supplier. Maybe he can gives me an answer if it is PNP or NPN device. Also asked for schematics and how to calculate the pulses.
    • rnollenR
      rnollenR
      rnollen
      When I use the volt meter and I rotate, then the volts are pretty much the same. Rotating faster, doesn't give me higher values.
      As a test I have attached it to my Arduino nano using a 10k Pullup resistor. Found a little example sketch regarding the LED on the arduino site. As the very first test I can see the light bling on the arduino when I rotate the windmeter. Rotating it harder will make the light bling faster, rotating slower and it blings slowly. So the pulses seems to come through.
      But now, I need a vary small and basic way to start counting the pulses when it rotates. I have tried to create a very small sketch (using an example of the Arduino website). But that is not working OK. Tried to modify the examples for powermeter and watermeter which are also pulse sketches, but at this stage it has too much code.
      Does anyone have a very small example sketch to start with for my setup?
      • AWIA AWI
        @rnollen Hi, the manual is a bit confusing in that it mentions a "serial protocol" and also a table is mentioned with voltages and wind speed. As yours iw 3 wire we can assume it is not a RS485 output.
        Then there are you need to dertermine what kind of output it is either NPN or PNP. : PNP needs a "pull down" resistor. NPN needs a "pull up". resistor..Best thing is to test the different options with the volt meter.
        According to the table the "average" voltage should vary with the rotating spreed.
        Note that I make a lot of assumptions.... but: If you get a voltage on your meter that changes with the rotating spreed than it is time to connect the nan. With the assumption that there are pulses, best thing is to write a routine which counts the pulses in a certain time frame e.g 10 secs. (connect the nano with a either a digital or analog pin, but read with digitalread(),. There should be many examples on the web.
        Have fun
        rnollenR
        rnollenR
        rnollen
        @AWI said:
        ..... There should be many examples on the web.
        Have fun
        Unfortunately I cannot find any working example code. Found all kind of stuff on the internet, but nothing that will give me some valuable data.
        I think that the examples on the internet mostly uses an pull up anemometer, as far as I can see the Arduino Nano also have a internal one which you can activate on the sketch. But basically, when I use a resistor, which is connected on the yellow and red wire, I am still stuck on the sketch I cannot find something desent (and small), that gives me something valuable. I now know why the windmeter is not an example on the Mysensors site :) Way to difficult :).
        AWIA 1 Reply Last reply
        • rnollenR rnollen
          Have fun
          AWIA
          AWIA
          AWI
          wrote on last edited by AWI
          @rnollen It shouldn't be so complicated.. there are a many ways to do it. Start in the learning curve with the most simple method of counting pulses using the arduino builtin method pulseIn(). (non MySensors, basic arduino). You should be able to see the pulse frequency on the serial port when turning the rotor.
          const int anemometerPin = 4 ; // wherever you connected the anemometer
          unsigned long timePeriod = 0;
          unsigned long timeon = 0;
          unsigned long timeoff =0;
          { pinMode(anemometerPin, INPUT_PULLUP);
            Serial.begin(9600);
             timeon = pulseIn(anemometerPin,HIGH); // Measured Time On
             timeoff = pulseIn(anemometerPin,LOW); // Measure Time Off
             timePeriod = timeon + timeoff; // total period = on + off
             float frequency  = 1000000.0/timePeriod; // calculate the frequency
             Serial.println(frequency);
             delay(1000);
          • rnollenR
            rnollenR
            rnollen
            @AWI Thanks, I will give it a try. Today I also received some additional info. The device is a NPN model. Type 12CM, according to the supplier it is 12 pulses for 1m/s per second. But the manual says that this model is 10 pulses for 1m/s.
            So basically I could now connect the device as NPN, only I need to find out how :)
            • rnollenR rnollen
              AWIA
              AWIA
              AWI
              @rnollen good news. Npn needs a pull-up so the sketch above should be able to do it. It uses the internal pull-up of the Arduino. I am curious to the outcome.
              rnollenR 1 Reply Last reply
              • AWIA AWI
                rnollenR
                rnollenR
                rnollen
                #22
                It does not work entirely correct I think. In the serial Monitor I see "Inf" as outcome of the sketch :( Don't see exactly where that is coming from :)
                Maybe something wrong with the wiring? I Attached the 12V DC to red and blue. The Yellow, connected it to the breadboard and a cable from the D7 also to this connection. I took a 4.7K resistor, connected also to this group and the other side of this resistor I connected to the 5V of the Arduino? Is that correct?
                When I remove the resistor: then this is my outcome of the sketch:
                12.82
                inf
                inf
                3.36
                1.88
                55.06
                inf
                37037.03
                inf
                333333.34
                30.95
                17.43
                inf
                142857.14
                inf
                125000.00
                500000.00
                500000.00
                90909.10
                500000.00
                39.47
                inf
                250000.00
                500000.00
                inf
                20.54
                45.67
                58823.53
                inf
                9.88
                inf
                inf
                9.17
                inf
                Then I got some numbers, but what they mean :) The very high numbers are when rotating..
                • rnollenR rnollen
                  12.82
                  inf
                  inf
                  3.36
                  1.88
                  55.06
                  inf
                  37037.03
                  inf
                  333333.34
                  30.95
                  17.43
                  inf
                  142857.14
                  inf
                  125000.00
                  500000.00
                  500000.00
                  90909.10
                  500000.00
                  39.47
                  inf
                  250000.00
                  500000.00
                  inf
                  20.54
                  45.67
                  58823.53
                  inf
                  9.88
                  inf
                  inf
                  9.17
                  inf
                  AWIA
                  AWIA
                  AWI
                  #23
                  @rnollen the "inf" means infinite and is caused by a 0 division. You can try to remove the line starting with 'float' and print the time values.
                  I assume you changed the anemometer pin in the sketch to d7...?
                  And connected the gnd of 12v and 5v together?
                  • AWIA AWI
                    rnollenR
                    rnollenR
                    rnollen
                    I have did some additional testing. The DC12 is wrong I think, when I use that then the whole sketch does not give any values back. Now used the 5V of the arduino, then I got something readings using this sketch. I have added some additional serial print lines for logging. But when times are zero, then the frequency is INF and that happens when I don't rotate, so that looks OK I think
                    Timeon: 0
                    Timeoff: 0
                    TimePeriod: 0
                    Frequency: inf
                    Timeon: 0
                    Timeoff: 87951
                    TimePeriod: 87951
                    Frequency: 11.37
                    Timeon: 24222
                    Timeoff: 22899
                    TimePeriod: 47121
                    Frequency: 21.22
                    Timeon: 24960
                    Timeoff: 27680
                    TimePeriod: 52640
                    Frequency: 19.00
                    Timeon: 27545
                    Timeoff: 28273
                    TimePeriod: 55818
                    Frequency: 17.92
                    Timeon: 63310
                    Timeoff: 0
                    TimePeriod: 63310
                    Frequency: 15.80
                    The serial.print lines:
                    Serial.print("Timeon: ");
                    Serial.println(timeon);
                    Serial.print("Timeoff: ");
                    Serial.println(timeoff);
                    Serial.print("TimePeriod: ");
                    Serial.println(timePeriod);
                    Serial.print("Frequency: ");
                    But any idea, because I am still lost don't know exactly what the conclusion of this is :)
                    AWIA 2 Replies Last reply
                    • rnollenR rnollen
                      Timeon: 0
                      Timeoff: 0
                      TimePeriod: 0
                      Frequency: inf
                      Timeon: 0
                      Timeoff: 87951
                      TimePeriod: 87951
                      Frequency: 11.37
                      Timeon: 24222
                      Timeoff: 22899
                      TimePeriod: 47121
                      Frequency: 21.22
                      Timeon: 24960
                      Timeoff: 27680
                      TimePeriod: 52640
                      Frequency: 19.00
                      Timeon: 27545
                      Timeoff: 28273
                      TimePeriod: 55818
                      Frequency: 17.92
                      Timeon: 63310
                      Timeoff: 0
                      TimePeriod: 63310
                      Frequency: 15.80
                      AWIA
                      AWIA
                      AWI
                      @rnollen this looks much better. You get frequencies in the 10 to 20 range when rotating. The inf when you're not rotating are caused by timer overflow so nothing wrong there.
                      Now it is time for a more dedicated measurement. Basically replace the standard arduino routines with your own version. It is middle of the night here so I have to leave it for tomorrow...
                      • rnollenR rnollen
                        Timeon: 0
                        Timeoff: 0
                        TimePeriod: 0
                        Frequency: inf
                        Timeon: 0
                        Timeoff: 87951
                        TimePeriod: 87951
                        Frequency: 11.37
                        Timeon: 24222
                        Timeoff: 22899
                        TimePeriod: 47121
                        Frequency: 21.22
                        Timeon: 24960
                        Timeoff: 27680
                        TimePeriod: 52640
                        Frequency: 19.00
                        Timeon: 27545
                        Timeoff: 28273
                        TimePeriod: 55818
                        Frequency: 17.92
                        Timeon: 63310
                        Timeoff: 0
                        TimePeriod: 63310
                        Frequency: 15.80
                        AWIA
                        AWIA
                        AWI
                        @rnollen time for "Take 2" I created it in Codebender to make sure it compiles. Could not test functionality yet.
                        The "take 2" code implements a non-blocking measurement of the frequency of the anemometer (pulses per second). It should be safe for overflow.
                        Take 3 could be to translate it to m/s windspeed according to your type of anemometer and finally:
                        Take 4 MySensors' ise it!!
                        https://codebender.cc/sketch:347690
                        • rnollenR
                          rnollenR
                          rnollen
                          #27
                          @AWI Hmm.. I see this:
                          1000.00
                          1000.00
                          1000.00
                          1000.00
                          1000.00
                          1000.00
                          1000.00
                          1000.00
                          1000.00
                          500.00
                          1000.00
                          0.00
                          inf
                          1000.00
                          0.00
                          0.00
                          Don't think that this is correct right? Am I doing something wrong, or does these numbers say anything to you :)
                          • rnollenR rnollen
                            1000.00
                            1000.00
                            1000.00
                            1000.00
                            1000.00
                            1000.00
                            1000.00
                            1000.00
                            1000.00
                            500.00
                            1000.00
                            0.00
                            inf
                            1000.00
                            0.00
                            0.00
                            AWIA
                            AWIA
                            AWI
                            #28
                            @rnollen was a short night... :sweat:
                            Forgot the return lastFrequencyI changed the sketch in last post. No guarantee that it works, don't have the hardware.
                            • rnollenR
                              rnollenR
                              rnollen
                              @AWI Sorry for the late reply, I got the flu :( But did test the sketch, but I got the same results basically.. Mostly 1000, inf and sometimes a 500? So what can be wrong here?
                              Thanks for all you're efforts so far!! Really appreciate it :)
                              • rnollenR rnollen
                                AWIA
                                AWIA
                                AWI
                                #30
                                @rnollen No problem, I hope you recovered well. Haven't looked at the sketch until now and discovered that I must have been suffering from something too... I added a missing line but still can't test it. Please give it a try..
                                • rnollenR
                                  rnollenR
                                  rnollen
                                  @AWI I am still ill, while doing this :) Hopefully tomorrow will be better, Hahaha.. :)
                                  But, the results looks promising and OK I guess :)
                                  8.13
                                  10.87
                                  14.08
                                  20.00
                                  27.78
                                  23.81
                                  25.64
                                  10.75
                                  0.00
                                  1.81
                                  12.66
                                  11.49
                                  10.75
                                  10.00
                                  9.35
                                  8.85
                                  8.33
                                  7.87
                                  It's 0 when I am not turning it around, so that is OK. Low number, when rotating it slowly. High number when rotating it fast :)
                                  • rnollenR rnollen
                                    8.13
                                    10.87
                                    14.08
                                    20.00
                                    27.78
                                    23.81
                                    25.64
                                    10.75
                                    0.00
                                    1.81
                                    12.66
                                    11.49
                                    10.75
                                    10.00
                                    9.35
                                    8.85
                                    8.33
                                    7.87
                                    AWIA
                                    AWIA
                                    AWI
                                    @rnollen take care.. This is how it should be (with the anemometer) I will post the MySensors version tomorrow (need some sleep now)
                                    • AWIA AWI
                                      rnollenR
                                      rnollenR
                                      rnollen
                                      #33
                                      @AWI ..Awesome ☺ Thanks so far ☺
                                      • rnollenR rnollen
                                        AWIA
                                        AWIA
                                        AWI
                                        #34
                                        @rnollen I made the sketch but forgot to post it... Have a look here
                                        https://codebender.cc/sketch:347770
                                        I does not compile in codebender.cc yet because of v2 MySensor but it should in the IDE.
                                        Have fun and let me know the results
                                        TheoLT 1 Reply Last reply
                                        • AWIA AWI
                                          TheoLT
                                          TheoLT
                                          TheoL
                                          @AWI Great job. I'm planning to make my own anemometer, just because it's fun to do. And was already thinking about the problems that might occur. Hardware wise it's easy. Just use a hall sensor to detect pulses and a rotating magnet.
                                          When the diameter of the magnet will be around 9cm, the magnet will reach the Hall sensor within 3ms or less if there's a Hurricane. That can be a problem because the sensor might think that the magnet isn't moving.
                                          Because of that I was thinking about counting the pulses in a interrupt handler (pin 2 or 3) . And just let the loop periodically read the values and send them to the gateway if necessary.
                                          Now comes my question for you. I was thinking of using some kind of decade counter IC. And let the IC handle the pulse counting. That way I only have to read and reset the counter IC. Do you happen to know a good counter IC that I can connect to the Arduino? It would make the project much easier.
