  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 331.3k Views 52 Watching
  • L Lars65
    @Ngwpower I use this one which is earlier in this thread, an it works with my domoticz.
    MySprinkler for MySensors
    Arduino Multi-Zone Sprinkler Control
    May 31, 2015
    *** Version 2.0
    * LED status indicator
    PARTS LIST:
    * Relays (8 channel)
    * NRF24L01 Radio
    * Arduino (I used a Pro Mini)
    * Capacitors (10uf and .1uf)
    * 3.3v voltage regulator
    * Resistors (270 & 10K)
    * Female Dupont Cables
    * LED
    * Push button
    * Shift Register (SN74HC595)
    * 18 gauge wire (for relay)
    INSTRUCTIONS:
      on the serial monitor.
    #include <Time.h>
    #include <LiquidCrystal.h>
    #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
    #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
    #define SKETCH_NAME "MySprinkler Domoticz"
    #define SKETCH_VERSION "2.0"
    #define CHILD_ID_SPRINKLER 0
    //#define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #define ALL_VALVES_OFF 0xFFFF
    #define ALL_VALVES_OFF 0U
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    SprinklerStates lastState;
    byte menuState = 0;
    unsigned long menuTimer;
    byte countDownTime = 10;
    int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
    int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
    int valveNumber;
    int lastValve;
    unsigned long startMillis;
    const int ledPin = 5;
    const int waterButtonPin = 3;
    boolean buttonPushed = false;
    boolean showTime = true;
    boolean clockUpdating = false;
    boolean recentUpdate = true;
    const char *dayOfWeek[] = {
    String valveNickName[17] = {
    time_t lastTimeRun = 0;
    //Setup Shift Register...
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin  = 7;
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
      SERIAL_START(115200);
      pinMode(latchPin, OUTPUT);
      pinMode(clockPin, OUTPUT);
      pinMode(dataPin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
      digitalWrite (ledPin, HIGH);
      updateRelays(ALL_VALVES_OFF);
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      lcd.createChar(0, clock);
      lcd.createChar(1, raindrop);
      delay(500);
      if (gw.loadState(0) == 0xFF); // EEPROM flag
        for (int i = 0; i < 4 ; i++)
          lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
      gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
        gw.present(i, S_LIGHT);
      digitalWrite (ledPin, LOW);
      DEBUG_PRINTLN(F("Ready..."));
      lcd.setCursor(0, 0);
      lcd.setCursor(15, 0);
      lcd.write(byte(0));
      lcd.setCursor(0, 1);
      int clockCounter = 0;
        gw.requestTime(receiveTime);
        delay(1000);
        lcd.print(".");
        clockCounter++;
        if (clockCounter > 16)
          lcd.clear();
          delay(2000);
      lcd.clear();
        lcd.print(F(" Updating  "));
        lcd.print(i);
        boolean flashIcon = false;
        DEBUG_PRINT(i);
        DEBUG_PRINTLN(F(" Data..."));
        while (gw.process() == false)
          flashIcon = !flashIcon;
          gw.request(i, V_VAR1);
          delay(100);
          gw.request(i, V_VAR2);
          delay(100);
          gw.request(i, V_VAR3);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      //goGetValveTimes();
      if (buttonPushed)
        menuTimer = millis();
          state = ZONE_SELECT_MENU;
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
        if (state != lastState)
            delay(50);
            gw.send(msg1valve.setSensor(i).set(false), false);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        if (lastValve != valveNumber)
              gw.send(msg1valve.setSensor(i).set(true), false);
        lastValve = valveNumber;
        fastToggleLed();
          valveNumber = 1;
          startMillis = millis();
          valveNumber++;
            state = CYCLE_COMPLETE;
            lastValve = -1;
            lastTimeRun = now();
            DEBUG_PRINT(F("State = "));
            DEBUG_PRINTLN(state);
        fastToggleLed();
          DEBUG_PRINT(F("Zone: "));
          DEBUG_PRINTLN(valveNumber);
          fastToggleLed();
      else if (state = ZONE_SELECT_MENU)
        displayMenu();
      lastState = state;
    void displayMenu(void)
      static int lastSecond;
        lcd.clear();
        lcd.print(F("Starting"));
        lcd.print(F("."));
        Serial.print(".");
      lastSecond = thisSecond;
        if (menuState == 0)
          valveNumber = 1;
          state = RUN_ALL_ZONES;
          valveNumber = menuState;
          state = RUN_SINGLE_ZONE;
      lastMenuState = menuState;
    void updateRelays(int value)
      digitalWrite(latchPin, LOW);
      digitalWrite(latchPin, HIGH);
        buttonPushed = true;
    void fastToggleLed()
        fastLedTimer = millis ();
    void slowToggleLED ()
        slowLedTimer = millis ();
      boolean zoneTimeUpdate = false;
      if (message.isAck())
        if (message.sensor == i)
          if (message.type == V_LIGHT)
            if (switchState == 0)
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" = "));
            DEBUG_PRINTLN(variable1);
              allZoneTime[i] = variable1;
              zoneTimeUpdate = true;
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(variable2);
              valveSoloTime[i] = variable2;
            if (newMessage.length() == 0)
              DEBUG_PRINTLN(i);
            if (newMessage.length() > 16)
              newMessage.substring(0, 16);
            valveNickName[i] = "";
            DEBUG_PRINT(F("Recieved new name for zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" and it is now called: "));
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(F("Zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(allZoneTime[i]);
        recentUpdate = false;
    void updateDisplay()
      static boolean displayToggle = false;
        switch (state) {
          case STAND_BY_ALL_OFF:
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(hourFormat12());
              lcd.print(minute());
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              lcd.print(year() % 100);
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.setCursor(11, 1);
              lcd.print(day(lastTimeRun));
          case RUN_SINGLE_ZONE:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Zone:"));
              lcd.print(valveNumber);
              lcd.print(F(" Active"));
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print(F(" Active "));
              lcd.print("min");
              lcd.print("sec  ");
          case CYCLE_COMPLETE:
            if (displayToggle)
              int totalTimeRan = 0;
              lcd.print(totalTimeRan);
              lcd.print(" Minutes   ");
        lastUpdateTime = millis();
      lastDisplayState = state;
      int lastSecond = second();
      int lastMinute = minute();
      int lastHour = hour();
      setTime(newTime);
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute());
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        clockUpdating = true;
        lastVeraGetTime = millis();
      if (gw.loadState(0) != 0xFF)
        gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
      for (int i = 1; i < 5; i++)
        gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
    void goGetValveTimes()
      static byte valveIndex = 1;
      if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
        DEBUG_PRINTLN(F("Calling for Valve Data..."));
        lcd.write(byte(1)); //lcd.write(1);
        gw.request(valveIndex, V_VAR1);
        gw.request(valveIndex, V_VAR2);
        gw.request(valveIndex, V_VAR3);
        valveUpdateTime = millis();
        valveIndex++;
        if (valveIndex > NUMBER_OF_VALVES + 1)
          valveIndex = 1;
     Take away the three dots in the bottom.
    Sergio RiusS
    Sergio RiusS
    Sergio Rius
    @Lars65
    As you also use it from Domoticz, your controller notices the changes in valves? I mean, when the IC is cycling through zones, Domoticz correctly changes states or you must refresh the page for it to show?
    L 1 Reply Last reply
    • Sergio RiusS Sergio Rius
      @Lars65
      L
      L
      Lars65
      @Sergio-Rius yes, I can turn them on/off, and the switch is also shifting from on/off.
        @petewill
        Thank you very much. Unfortunately those are not the libraries I've problems with. The problem are the built-in ones. The ones that come with the Arduino IDE.
        What version of the IDE are you running? I guess you use the Mysensors 1.4.2 libs.
        I installed Arduino IDE 1.6.9 and using your libraries, those are the errors shown:
        W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
         #include <../Wire/Wire.h>
        compilation terminated.
        Multiple libraries were found for "Wire.h"
         Used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\Wire
         Not used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\hardware\arduino\avr\libraries\Wire
        Multiple libraries were found for "LiquidCrystal.h"
         Used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\LiquidCrystal
         Not used: W:\Domotica\MySensors_Arduino\arduino-1.6.9\libraries\LiquidCrystal
        exit status 1
        As you can appreciate, the Wire library is at the ../Wire path, so that error is meaningless.
        I told you that I hate java environments? I still haven't found one that works out of the developer computer without issues. X)
        EDIT: So the problem is that the Wire library has been updated, but we are still using an old version of the LiquidCrystal. This last one expects the .h files been on the root library folder but this has been changed in newer versions. Built-in libraries have their code in "src" subfolder.
        I moved it to parent folder and it compiles, but I don't know what will happen with other dependencies.
        Better would be updating the sketch.
        L
        L
        Lars65
        @Sergio-Rius Those can you download from internet. About Liquidcrystal is there a newer version called NewLiquidCrystal, that is also possible to download.
        That one worked for me.
        I deleted all my duplicates, it is anoying when you get those messeges in the arduino ide.
        Also the fatal error you get is ../wire/wire.h.
        seems like you have #include <../Wire/Wire.h
        What happens if you just write #include Wire.h
        • L Lars65
          Sergio RiusS
          Sergio RiusS
          Sergio Rius
          @Lars65
          Thanks. No, I finally made it work.
          I only have to find why my Domoticz don't update the switch status.
            @petewill
            exit status 1
            AWIA
            AWIA
            AWI
            @Sergio-Rius you can change the reference in the display library files. Just remove the path to the wire.h library.
            • L Lars65
              May 31, 2015
              *** Version 2.0
              PARTS LIST:
              * NRF24L01 Radio
              * LED
              * Push button
              INSTRUCTIONS:
              #include <Time.h>
              #ifdef ACTIVE_LOW
              #ifdef DEBUG_ON
              typedef enum {
              SprinklerStates;
              byte menuState = 0;
              int valveNumber;
              int lastValve;
                //delay(5000);
                lcd.clear();
                lcd.backlight();
                delay(500);
                lcd.write(byte(0));
                  delay(1000);
                  lcd.print(".");
                  clockCounter++;
                    lcd.clear();
                    delay(2000);
                lcd.clear();
                  lcd.print(i);
                  DEBUG_PRINT(i);
                    delay(100);
                    delay(100);
                    delay(100);
                lcd.clear();
                updateClock();
                updateDisplay();
                if (buttonPushed)
                    menuState = 0;
                    menuState++;
                      menuState = 0;
                  slowToggleLED ();
                      delay(50);
                    lcd.clear();
                    lcd.setCursor(0,0);
                    lcd.setCursor(0,1);
                    delay(2000);
                    lastValve = -1;
                  fastToggleLed();
                    valveNumber = 1;
                    valveNumber++;
                      lastValve = -1;
                  fastToggleLed();
                    fastToggleLed();
                  displayMenu();
                lastState = state;
                  lcd.clear();
                  lcd.print(F("."));
                  Serial.print(".");
                  if (menuState == 0)
                    valveNumber = 1;
                        if (i == 0)
                          valveNumber = 1;
                          valveNumber = i;
                          DEBUG_PRINTLN(i);
                      DEBUG_PRINT(i);
                      DEBUG_PRINT(i);
                        DEBUG_PRINTLN(i);
                      DEBUG_PRINT(i);
                if (zoneTimeUpdate)
                    if (i != 0)
                      DEBUG_PRINT(i);
                  switch (state) {
                      fastClear();
                      if (displayToggle)
                        if (clockUpdating)
                          lcd.write(byte(0));
                        lcd.print(month());
                        lcd.print(day());
                        lcd.print(F("/"));
                        if (clockUpdating)
                          lcd.write(byte(0));
                      fastClear();
                      if (displayToggle)
                          lcd.print("min");
                          lcd.print("sec  ");
                    case RUN_ALL_ZONES:
                      fastClear();
                      if (displayToggle)
                        lcd.print("min");
                        lcd.print("sec  ");
                      if (displayToggle)
                setTime(newTime);
                  DEBUG_PRINT(day());
                  showTime = false;
              void fastClear()
              void updateClock()
                  lcd.write(byte(0));
                  valveIndex++;
                    valveIndex = 1;
              A Former User
              @Lars65
              Tried your sketch as well as a few of my own adjustments, still getting
              Yard_Sprinklers_revised_7-20.ino:85:18: fatal error: Time.h: No such file or directory.
              At a loss of where I missed this in the library!
              Rather be riding my scooter! got to get it done!
              • AWIA AWI
                Sergio RiusS
                Sergio RiusS
                Sergio Rius
                @AWI
                I'll try it.
                @Ngwpower
                Don't drop the towel. Just install the library from the libraries manager.
                ? 1 Reply Last reply
                  @AWI
                  I'll try it.
                  @Ngwpower
                  A Former User
                  @Sergio-Rius Really confused found these in AVR libraries on my computer. 0_1469044384924_upload-b0e77311-082b-4d33-9473-c59ef1302d37
                  Am I looking in the wrong place?
                  Thank You for the help!
                  • ? A Former User
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    #192
                    @Ngwpower
                    ArduinoIDE Menu->Program->Include Library->Library manager
                    0_1469044814353_upload-bdb3d59c-30bb-4c2e-8345-9aa060d3d67e
                    I'm currently looking at converting the sketch to v2.0
                      A Former User
                      • PaweMedP
                        PaweMedP
                        PaweMed
                        Hello, is there anyone who can explain to me step by step how to deal with these libraries ? I received this error when compiling :
                        "C:\Users\witkowski.med\Downloads\IrrigationController\IrrigationController\IrrigationController.ino:85:22: fatal error: MySensor.h: No such file or directory
                        exit status 1"
                        I have installed the various library and it doesnt help. My IDE version is 1.6.10.
                        • PaweMedP PaweMed
                          exit status 1"
                          Sergio RiusS
                          Sergio RiusS
                          Sergio Rius
                          @PaweMed
                          If you've done a new installation, perhaps you installed Mysensors libraries from the IDE lib manager. In that case you could have installed v2.0.
                          In the newer version the library has changed to Mysensors.h, please read the documentation carefully as this is not a minor upgrade:
                          https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
                          • PaweMedP
                            PaweMedP
                            PaweMed
                            wrote on last edited by PaweMed
                            #196
                            • rechin304R rechin304
                              Pictures of the case project and how is arranged inside. Not yet on the final location, still testing.
                              5_1461396298101_IMG_3866.JPG 4_1461396298101_IMG_3865.JPG 3_1461396298101_IMG_3863.JPG 1_1461396298101_IMG_3861.JPG 0_1461396298101_IMG_3860.JPG
                              k5mapK
                              k5mapK
                              k5map
                              @rechin304 - that's a great case/box. Where did you purchase it?
                              rechin304R 1 Reply Last reply
                              • k5mapK k5map
                                rechin304R
                                rechin304R
                                rechin304
                                @k5map From here http://www.ebay.com/itm/2PCS-Waterproof-Plastic-Cover-Project-Electronic-Case-Enclosure-Box-125-80-32mm-/321803320255?hash=item4aecf8fbbf
                                • dbemowskD
                                  dbemowskD
                                  I am in the process of building this controller and in reading the comments here where some were asking about a master valve and how to control it. This is the concept that I am going to try with my setup.
                                  I only have 4 zones to control, so with the 8 channel relay board that I have, I am going to use channel 8 as my pump start relay control. The idea is that when any one channel is on, the diodes will activate the master valve, but keep the signal from back-feeding into another relay channel.
                                  Hope that helps some people out there.
                                  • dbemowskD
                                    dbemowskD
                                    #200
                                    So I figured I would share my progress with my version of this project. The majority of the build was done to the schematic from the build section of the site. The only changes I am making are eliminating the use of Q0 on the shift register, and wiring in diodes like I mentioned in my previous post to control my pump start relay using relay channel 8 when any zone is turned on. I may even add a connection for one more digital line for a pump only startup, but will have to see about the code mods to do that.
                                    One of my hurdles that I wanted to overcome was what kind of case I would be building this in. I searched on ebay a bit, but couldn't find what I wanted. I was digging through some old stuff one day and found an old composite video A/V switcher that I no longer use.
                                    A/V switcher front
                                    A/V switcher back
                                    Rather than recycling it, I figured, why not up-cycle it. The case was the perfect size for the 8 channel relay board. I even kept the back portion of the original circuit board to re-use the old DC in jack and build my regulator circuit on using an AMS1117 3.3v regulator. The output of the power board is Ground (black), +5V (red) and +3.3V (yellow).
                                    relay/power boards
                                    AMS1117 regulator
                                    I cut a slot in the front of the case to allow access to the relay connections.
                                    front cutout
                                    The connections came out just enough to allow access to the screw terminals. You can also see the mouning of the LCD, push button and status LED.
                                    screw terminals
                                    main board
                                    I designed the circuit board so that it could plug directly on top of the 8 channel relay board. Notice the header connector strip between the pro mini and the shift register. There is just enough room above the blue 3 input power connector to attach the FTDI cable for programming the pro mini. The last thing I need to add to the board is the 8 diodes to control the pump start relay which will be channel 8 on the relay board. Currently the code uses outputs Q0 thru Q7 of the shift register to control relays 1 thru 8. I will need to make a slight change to the code to use Q1 thru Q7 as the first 7 relays as it was easier to connect it that way to the header connector. I am eliminating the use of Q0 in the circuit.
                                    I am having a few issues with compiling the code to upload to the pro mini. It is telling me that it can't find the LiquidCrystal.h file, and I have the library in my arduino library folder. The folder has both the LiquidCrystal.h and LiquidCrystal_I2C.h files, so I am not sure what is up there. I hope to have it figured out soon so I can test the assembly.
                                    Thanks for reviewing.
                                    • dbemowskD
                                      dbemowskD
                                      I am trying to use this controller with Domoticz and I am wondering how to set the valve times. Is there anyone that is using this controller with Domoticz that can help?
                                      • HuczasH
                                        HuczasH
                                        Huczas
                                        Hi, in original code is written to work with Vera - this is similar to Domoticz. But I same like you have Domoticz on my RPi0. Some time ago I changed some lines in this code that it is working now with Domoticz.
                                        May 31, 2015
                                        *** Version 2.0
                                        PARTS LIST:
                                        * NRF24L01 Radio
                                        * LED
                                        * Push button
                                        INSTRUCTIONS:
                                        #include <Time.h>
                                        #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
                                        #ifdef ACTIVE_LOW
                                        #ifdef DEBUG_ON
                                        typedef enum {
                                        SprinklerStates;
                                        byte menuState = 0;
                                        int allZoneTime [NUMBER_OF_VALVES + 1];
                                        int valveSoloTime [NUMBER_OF_VALVES + 1];
                                        int valveNumber;
                                        int lastValve;
                                          "All Zones", "Zone 1", "Podlewanie 1", "Podlewanie 2", "Podlewanie 3", "Podlewanie 4", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
                                          //delay(5000);
                                          lcd.clear();
                                          lcd.backlight();
                                          delay(500);
                                          lcd.write(byte(0));
                                            delay(1000);
                                            lcd.print(".");
                                            clockCounter++;
                                              lcd.clear();
                                              delay(2000);
                                          lcd.clear();
                                            lcd.print(i);
                                            DEBUG_PRINT(i);
                                              delay(100);
                                              delay(100);
                                              delay(100);
                                          lcd.clear();
                                          updateClock();
                                          updateDisplay();
                                          goGetValveTimes();
                                          if (buttonPushed)
                                              menuState = 0;
                                              menuState++;
                                                menuState = 0;
                                            slowToggleLED ();
                                                delay(50);
                                              lcd.clear();
                                              lcd.setCursor(0,0);
                                              lcd.setCursor(0,1);
                                              delay(2000);
                                              lastValve = -1;
                                            fastToggleLed();
                                              valveNumber = 1;
                                              valveNumber++;
                                                lastValve = -1;
                                            fastToggleLed();
                                              fastToggleLed();
                                            displayMenu();
                                          lastState = state;
                                            lcd.clear();
                                            lcd.print(F("."));
                                            Serial.print(".");
                                            if (menuState == 0)
                                              valveNumber = 1;
                                                  if (i == 0)
                                                    valveNumber = 1;
                                                    valveNumber = i;
                                                    DEBUG_PRINTLN(i);
                                                int variable1 = 15; // atoi(message.data);// RUN_ALL_ZONES time
                                                DEBUG_PRINT(i);
                                                int variable2 = 10; //atoi(message.data);// RUN_SINGLE_ZONE time
                                                DEBUG_PRINT(i);
                                                  DEBUG_PRINTLN(i);
                                                DEBUG_PRINT(i);
                                          if (zoneTimeUpdate)
                                              if (i != 0)
                                                DEBUG_PRINT(i);
                                            switch (state) {
                                                fastClear();
                                                if (displayToggle)
                                                  if (clockUpdating)
                                                    lcd.write(byte(0));
                                                  lcd.print(hour() < 10 ? F(" ") : F(""));
                                                  lcd.print(hour());
                                                  //lcd.print(isAM() ? F("am") : F("pm"));
                                                  lcd.setCursor(7, 1);
                                                  lcd.print(day() < 10 ? F(" 0") : F(" "));
                                                  lcd.print(day());
                                                  lcd.print(month() < 10 ? F("/0") : F("/"));
                                                  lcd.print(month());
                                                  lcd.print(F("/"));
                                                  if (clockUpdating)
                                                    lcd.write(byte(0));
                                                  lcd.setCursor(10, 1);
                                                  lcd.print(day(lastTimeRun) < 10 ? F(" 0") : F(""));
                                                  lcd.print(month(lastTimeRun) < 10 ? F("/0") : F("/"));
                                                fastClear();
                                                if (displayToggle)
                                                    lcd.print("min");
                                                    lcd.print("sec  ");
                                              case RUN_ALL_ZONES:
                                                fastClear();
                                                if (displayToggle)
                                                  lcd.print("min");
                                                  lcd.print("sec  ");
                                                if (displayToggle)
                                          setTime(newTime);
                                            DEBUG_PRINT(day());
                                            showTime = false;
                                        void fastClear()
                                        void updateClock()
                                            lcd.write(byte(0));
                                            valveIndex++;
                                              valveIndex = 1;
                                        Ok, originally time - how long relay is triggered was downloaded from Vera, I commented out this two lines and specify time there. When you power on arduino - program is trying to connect to Vera and download all data but it obviously fail at it. After a while it's just get date and time from Domoticz. So no names of zones or how long water them. All is hard coded in Arduino.
                                        Now there is 15 minutes if you trigger all zones and 10 minutes if you choose specific single zone.
                                        If you want change it you need burn it again on Arduino - so it is not the best solution, but it works :) And it is about 1 week with testing all with laptop and FTDI connected to this controller. After that - you can leave it forever.
                                        PS, also I changed date and time - it is 24h and DD/MM/YY - so more European friendly :)
                                        dbemowskD 1 Reply Last reply
                                        • HuczasH Huczas
                                          May 31, 2015
                                          *** Version 2.0
                                          PARTS LIST:
                                          * NRF24L01 Radio
                                          * LED
                                          * Push button
                                          INSTRUCTIONS:
                                          #include <Time.h>
                                          #ifdef ACTIVE_LOW
                                          #ifdef DEBUG_ON
                                          typedef enum {
                                          SprinklerStates;
                                          byte menuState = 0;
                                          int valveNumber;
                                          int lastValve;
                                            //delay(5000);
                                            lcd.clear();
                                            lcd.backlight();
                                            delay(500);
                                            lcd.write(byte(0));
                                              delay(1000);
                                              lcd.print(".");
                                              clockCounter++;
                                                lcd.clear();
                                                delay(2000);
                                            lcd.clear();
                                              lcd.print(i);
                                              DEBUG_PRINT(i);
                                                delay(100);
                                                delay(100);
                                                delay(100);
                                            lcd.clear();
                                            updateClock();
                                            updateDisplay();
                                            goGetValveTimes();
                                            if (buttonPushed)
                                                menuState = 0;
                                                menuState++;
                                                  menuState = 0;
                                              slowToggleLED ();
                                                  delay(50);
                                                lcd.clear();
                                                lcd.setCursor(0,0);
                                                lcd.setCursor(0,1);
                                                delay(2000);
                                                lastValve = -1;
                                              fastToggleLed();
                                                valveNumber = 1;
                                                valveNumber++;
                                                  lastValve = -1;
                                              fastToggleLed();
                                                fastToggleLed();
                                              displayMenu();
                                            lastState = state;
                                              lcd.clear();
                                              lcd.print(F("."));
                                              Serial.print(".");
                                              if (menuState == 0)
                                                valveNumber = 1;
                                                    if (i == 0)
                                                      valveNumber = 1;
                                                      valveNumber = i;
                                                      DEBUG_PRINTLN(i);
                                                  DEBUG_PRINT(i);
                                                  DEBUG_PRINT(i);
                                                    DEBUG_PRINTLN(i);
                                                  DEBUG_PRINT(i);
                                            if (zoneTimeUpdate)
                                                if (i != 0)
                                                  DEBUG_PRINT(i);
                                              switch (state) {
                                                  fastClear();
                                                  if (displayToggle)
                                                    if (clockUpdating)
                                                      lcd.write(byte(0));
                                                    lcd.print(hour());
                                                    lcd.print(day());
                                                    lcd.print(month());
                                                    lcd.print(F("/"));
                                                    if (clockUpdating)
                                                      lcd.write(byte(0));
                                                  fastClear();
                                                  if (displayToggle)
                                                      lcd.print("min");
                                                      lcd.print("sec  ");
                                                case RUN_ALL_ZONES:
                                                  fastClear();
                                                  if (displayToggle)
                                                    lcd.print("min");
                                                    lcd.print("sec  ");
                                                  if (displayToggle)
                                            setTime(newTime);
                                              DEBUG_PRINT(day());
                                              showTime = false;
                                          void fastClear()
                                          void updateClock()
                                              lcd.write(byte(0));
                                              valveIndex++;
                                                valveIndex = 1;
                                          dbemowskD
                                          dbemowskD
                                          @Huczas One of the main things I wanted with this project was the ability to change the watering times in the automation software using a script. If I have to reprogram the arduino every time I want to change a time it seems pointless . I am looking into a few ideas with this to make it work in Domoticz. If I come up with something, it is most likely going to be a hack workaround.
                                          I have a post also in the Domoticz forum on a more generalized solution that would cover this situation. Seems though that this is something that the Domoticz team will need to implement. Hopefully I can figure out some kind of workaround to get this going for now.
                                          HuczasH 1 Reply Last reply
