  2. Announcements
  3. Converting a sketch from 1.5.x to 2.0.x
52 Posts 21 Posters 37.9k Views 26 Watching
  • Maurizio ColluM Maurizio Collu
    Dear all, I'm a bit lost.
    I upgraded the library in Arduino to 2.0.0 and now I am having big problems.
    I downloaded the sketch for the relay from the MySensors website:
    https://www.mysensors.org/build/relay
    but I suppose this is still for 1.5
    I tried to modify the sketch as suggested - I do not receive any compiling error, but the skectch simply does not do anything. If I use the "monitor" in Arduino IDE, I do not see anything 0_1469262004446_RelayActuator2.ino
    There must be something fundamentally wrong in my code, can anyone help?
    @Maurizio-Collu the examples for 2.0 are included in the library. They can be opened directly fromthe Examples menu in the Arduino IDE. It is also possible to fetch the examples from github, see https://github.com/mysensors/MySensors/tree/development/examples/RelayActuator For the relay example.
    Maurizio ColluM 1 Reply Last reply
      Boots33B
      Boots33B
      Boots33
      @Maurizio-Collu
      You have a few mistakes in your sketch, Download the V2 sketch that @mfalkvidd has pointed you to and compare the two side by side. you will soon see where you have gone wrong. don't forget you will need to update your gateway to V2 as well, a version 1.5 gateway will not connect with a version 2 node.
        Maurizio ColluM
        Maurizio ColluM
        Maurizio Collu
        @mfalkvidd @Boots33
        Thanks a lot, I knew I was missing something basic. For the newbies like me, it would be good to mention this somewhere (if you have not done so already and I missed it).
        In the Home Assistant website it is mentioned that they only support 1.4 and 1.5. I'm trying with 2.0.
        Thanks Again
          @mfalkvidd @Boots33
          Thanks Again
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Maurizio-Collu
          2.0 should work with home assistant, but all new features of 2.0 are not supported yet. WIP.
          • rchampR
            rchampR
            rchamp
            wrote on last edited by rchamp
            #32
            I'm trying to upgrade my gateway to 2.0, but every time I go to upload, I get a 'error' not in sync.
            I'm using just a standard nano w/ NRF24.
            Note, my hardware profile is set properly to nano, 328p and proper com.
            I restart app, and switched to my APM hardware profile and loaded my new 2.0 sensor code into my new APM node (DHT11 + motion) and was able to upload no problem.
            Is there something i'm missing for the gateway?
            Idon'tunderstandwhatwouldcauseittostopbeingabletocommunicate,
              Are you able to upload some other sketch to the nano?
              Or has something bad happen to the FTDI chip on your nano perhaps?
              rchampR 1 Reply Last reply
                moskovskiy82
                Just for clarification. V2.0 gateway (MQTT client esp8266) - will it work with the 1.5/1.6 sensors? Or everything needs to be flashed as soon as possible?
                  rchampR
                  rchampR
                  rchamp
                  @hek it's actually a close nano with an FTDI board connected via serial inputs. I had this directly connected to my Vera, and communication with my old sensors was working just fine.
                  EDIT: Fixed. All in all, it was user error. I was trying to connect through FTDI adapter. I unplugged FTDI board, connected USB directly to nano clone, and upload worked fine.
                  Do I need to update mysensors plugin as well on Vera UI5?
                    No, shouldn't be necessary.
                      You could try, but the recommendation is to update the nodes as well.
                        @Maurizio-Collu
                        Maurizio ColluM
                        Maurizio ColluM
                        Maurizio Collu
                        @martinhjelmare
                        Thanks Martin.
                        I uploaded the GatewaySerial to the arduino working as gateway, but if I upload the sketch and I open the monitor, I obtain this error:
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;!TSM:RADIO:FAIL
                        0;255;3;0;9;!TSM:FAILURE
                        0;255;3;0;9;TSM:PDT
                        What does it mean?
                        Maurizio ColluM martinhjelmareM 2 Replies Last reply
                          @martinhjelmare
                          Thanks Martin.
                          0;255;3;0;9;TSM:PDT
                          What does it mean?
                          Maurizio ColluM
                          Maurizio ColluM
                          Maurizio Collu
                          @martinhjelmare
                          Plus, when starting home assistant, I get this error
                          16-07-26 23:03:44 homeassistant.bootstrap: Error during setup of component mysensors
                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 62, in setup_gateway
                          socket.inet_aton(device)
                          OSError: illegal IP address string passed to inet_aton
                          During handling of the above exception, another exception occurred:
                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/bootstrap.py", line 150, in _setup_component
                          if not component.setup(hass, config):
                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 109, in setup
                          device, persistence_file, baud_rate, tcp_port)
                          File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 73, in setup_gateway
                          baud=baud_rate)
                          File "/home/pi/.homeassistant/deps/mysensors/mysensors.py", line 326, in init
                          persistence_file, protocol_version)
                          File "/home/pi/.homeassistant/deps/mysensors/mysensors.py", line 40, in init
                          self.const = _const
                          UnboundLocalError: local variable '_const' referenced before assignment
                            @martinhjelmare
                            baud=baud_rate)
                            self.const = _const
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            #40
                            @Maurizio-Collu
                            Regarding the error in home assistant, that's a bug, due to specifying mysensors version other than 1.4 or 1.5. Use 1.5 and you should be fine. The bug is fixed in the dev branch of pymysensors and will be fixed in home assistant when real mysensors 2.0 support is merged. WIP.
                            Please post home assistant topics in the home assistant category under controllers. This is off topic in this thread.
                              @martinhjelmare
                              Thanks Martin.
                              0;255;3;0;9;TSM:PDT
                              What does it mean?
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @Maurizio-Collu said:
                              @martinhjelmare
                              Thanks Martin.
                              0;255;3;0;9;TSM:PDT
                              What does it mean?
                              @tekka knows this best, and he wrote a post explaining some of those messages here:
                              https://forum.mysensors.org/topic/4347/can-t-get-sensors-talking/3
                                @martinhjelmare
                                Thanks Martin.
                                0;255;3;0;9;TSM:PDT
                                What does it mean?
                                Maurizio ColluM
                                Maurizio ColluM
                                Maurizio Collu
                                @martinhjelmare Thanks a ot.
                                Is there any guide/manual where all these messages are explained?
                                Plus, is there anywhere written what all these terms mean?
                                TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                                Kind Regards
                                mfalkviddM tekkaT 2 Replies Last reply
                                  Kind Regards
                                  @Maurizio-Collu do you mean except the link martinhjelmare provided?
                                    Maurizio ColluM
                                    Maurizio ColluM
                                    Maurizio Collu
                                    @mfalkvidd Yes, basically this part (I'm sure it is explained somewhere, but I can't find where)
                                    SOrry for my newbieness...
                                      Kind Regards
                                      tekkaT
                                      tekkaT
                                      tekka
                                      wrote on last edited by tekka
                                      #45
                                      @Maurizio-Collu Yes, the doc is in preparation, the meaning of these messages is described here (this is a PR that harmonizes the log message and will be pushed to 2.0.1).
                                      In brief:
                                      TSP:MSG:SEND refers to message sending function in the transport state machine
                                      255-255-0-0 is the routing information, i.e. sender-last-next-destination
                                      • s=sensor ID (255 = internal)
                                      • c=command (3 = C_INTERNAL)
                                      • t=type (3 = I_ID_REQUEST)
                                      • pt=payload type (0 = P_STRING)
                                      • l=message length (0)
                                      • sg=signature flag (0 = not signed)
                                      • ft=failed transmission counter (0 = no failed uplink transmission at this* oint)
                                      • st=send status (OK)
                                      • : actual message (empty)
                                      => Your node has no assigned ID (=255) and is requesting a new ID from the controller.
                                      Please refer to the serial protocol or API for additional information.
                                      Good luck!
                                      • pndgt0P
                                        pndgt0P
                                        pndgt0
                                        I was trying to implement the irrigation controller but realized that was not migrated to MySensors 2.0.
                                        I followed the instructions provided in the first post and arrived to a version that compiles with no errors. Nonetheless, as I am newbie, I would appreciate if someone could review some changes that I am not sure about. Those changes are related with the original sketch which has direct calls to process() in several while statements. First I tried to change the process() with _process() but several errors appeared, so finally I removed all the calls to process() but am not sure. I have the modified code here IrrigationController.ino in which I commented the lines added / deleted / modified. Any help / direction would be greatly appreciated.
                                        Boots33B 1 Reply Last reply
                                        • pndgt0P pndgt0
                                          Boots33B
                                          Boots33B
                                          Boots33
                                          @pndgt0
                                          The sketches that require external libraries are not included in the V2 install anymore but they are available here in the new V2 format. You will find the irrigation sketch there.
                                          pndgt0P 1 Reply Last reply
