  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 213.1k Views 36 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    Did anyone setup rfm69 successfully on the raspberry pi
    • GertSandersG
      GertSandersG
      GertSanders
      Has anyone used the Raspberry GW software in combination with nodes that run the new 2.0.0 MySensors code ?
      • tbowmoT
        tbowmoT
        tbowmo
        @GertSanders
        It's not supported, 2.0.0 nodes require a 2.0.0 GW. And the raspberry pi port is not updated to 2.0.0 (and unfortunately there is currently no one in the core group that uses the rpi gw.. We all use serial / ethernet gw's of some sort)
        GertSandersG W 2 Replies Last reply
        • tbowmoT tbowmo
          @GertSanders
          GertSandersG
          GertSandersG
          GertSanders
          @tbowmo
          I was afraid of that. In my enthusiasm I updated to 2.0.0, but now my new nodes play dead.
          At least I know why.
          Time to make that old ethernet gateway functional again.
          Since Breda meetup is this weekend, I will have no more time to figure this out (if I could ever, this is UNIX). Maybe after I can try something.
          • tbowmoT tbowmo
            @GertSanders
            W
            W
            wergeld
            @tbowmo
            What would be required to get the RPi gateway up and running? Having single controller/gateway is great.
            • GertSandersG
              GertSandersG
              GertSanders
              @tbowmo
              Is a 2.0.0 based gateway backward compatible with nodes in an older version ?
              • W wergeld
                @tbowmo
                GertSandersG
                GertSandersG
                GertSanders
                @wergeld
                Probably porting the Arduino lib to Raspberry and compiling again ?
                W 1 Reply Last reply
                • GertSandersG GertSanders
                  @tbowmo
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @tbowmo
                  Is the last 2.0.0-dev version (before the new 2.0.0 official release) still available somewhere ?
                  That DEV version seemed to still work with my Raspi GW.
                    @wergeld
                    W
                    W
                    wergeld
                    @GertSanders
                    Time to start reading up on converting the lib! Might have a go at it in week or so. Work is holding me hostage at the moment.
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      Praise Apple for making TimeMachine. I was able to set back the last version of MySensors lib I know was working with my gateway in a bout 1 minute.
                      Back in business now. Upgrading the gateway and nodes to full 2.0.0 is for later.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #134
                        @wergeld
                        you need to port the mysensors core library.. It is however filled with arduino specifics at the moment (we have had some talks about removing arduino dependencies, but it's not made yet).
                        Ideally someone should make a raspberry pi port, that we can merge into the main repository, so the same codebase can be build for both raspberryPi and arduino based hardware.
                        @GertSanders
                        A 2.0.0 GW should be compatible with 1.5.x nodes, but 2.0.0 nodes require a 2.0.0 GW.. (I can't remember the specifics in what the changes are, @tekka is the brain behind that stuff). That said, we do recommend that both nodes and GW will be updated to same mysensors versions, as to avoid any problems.
                        • tbowmoT tbowmo
                          @wergeld
                          @GertSanders
                          #135
                          @tbowmo @wergeld @GertSanders a port is already available, see https://forum.mysensors.org/topic/2759/mysensors-raspberry-port-suggestions/11 (and github)
                          It would be awesome if someone could merge that great work with the MySensors repo.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @mfalkvidd
                            Ok, didn't know that it was updated to 2.0.0 "final", thanks for the hint :+1:
                            • Sander TeunissenS
                              Sander TeunissenS
                              Sander Teunissen
                              Would it be safe to say a RPI gateway 2.0 is not available yet for beginners ? (like the instructions @mfalkvidd made are not usable for this ?)
                              • Sander TeunissenS Sander Teunissen
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @Sander-Teunissen
                                At the moment I would advise beginners to use a separate GW for the official 2.0.0 (ethernet or serial based). I found the ethernet based gateway the easiest to use in various setups, espcially since Domoticz (my controller of choice) supported this.
                                Sander TeunissenS 1 Reply Last reply
                                  @Sander-Teunissen
                                  Sander TeunissenS
                                  Sander TeunissenS
                                  Sander Teunissen
                                  wrote on last edited by Sander Teunissen
                                  #139
                                  @GertSanders Thanks Gert !
                                  I did a quick build of the serial gateway using an arduino which I connect to my RPI. Pretty easy. I'll be watching this when I can switch back to the RPI built gateway...
                                    Note: This guide is only applicable to MySensors 1.x. For MySensors 2, use this guide.
                                    I noticed that a step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway was listed in the document for MySensors 1.6.
                                    Since I have three gateways configured this way, and I need to set up 3 more for covering different offices around the world, and I had already written the instructions in Swedish for Datormagazin, I thought I'd help out.
                                    This is the first draft. Any feedback is welcome.
                                    INTRODUCTION
                                    The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi. The bridge between NRF24L01+ nodes and the "computer world" is called a Gateway. You can use other types of gateways, but connecting the NRF24L01+ module directly to the Raspberry Pi is a simple and cheap alternative.
                                    Wiring Things Up
                                    Connect the NRF20L01+ radio module to the Raspberry Pi like this:
                                    Raspberry Pi NRF24L01+ Color
                                    6 / GND GND Black
                                    1 / 3.3V DC VCC Red
                                    22 / GPIO25 CE Orange
                                    24 / GPIO 8 CSN/CS Yellow
                                    23 / GPIO11 / SPI_CLK SCK Green
                                    19 / GPIO10 / SPI_MOSI MOSI Blue
                                    21 / GPIO9 / SPI_MISO MISO Violet
                                    The IRQ pin on NRF24L01 is not currently used.
                                    For a comprehensive view of the Raspberry Pi pins, see http://pinout.xyz/
                                    You should also connect a decoupling capacitor to the radio. See this guide.
                                    COMPILING THE GATEWAY
                                    Login to your Raspberry Pi (using SSH or open a terminal on the graphical console) and run these commands:
                                    git clone https://github.com/TMRh20/RF24.git
                                    cd RF24
                                    make all && sudo make install
                                    cd ..
                                    git clone https://github.com/mysensors/Raspberry.git
                                    cd Raspberry
                                    If you get the following error:
                                    pi@raspberrypi ~/RF24 $ make all && sudo make install
                                    g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c RF24.cpp
                                    gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c bcm2835.c
                                    bcm2835.c: In function ‘bcm2835_init’:
                                    bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
                                    You've probably run into the problem discussed in this thread. People have had luck with different solutions. The simplest is to make the following change to ~/Raspberry/librf24-bcm/Makefile
                                    #IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
                                    IOBASE := 3F000000
                                    VERIFY THE GATEWAY
                                    Run sudo /usr/local/sbin/PiGatewaySerial. The output should look like this:
                                    pi@raspberrypi ~/Raspberry $ sudo /usr/local/sbin/PiGatewaySerial
                                    Starting PiGatewaySerial...
                                    Protocol version - 1.4
                                    Created PTY '/dev/pts/1'
                                    Gateway tty: /dev/ttyMySensorsGateway
                                    ================ SPI Configuration ================
                                    CSN Pin          = CE0 (PI Hardware Driven)
                                    CE Pin           = Custom GPIO25
                                    Clock Speed      = 8 Mhz
                                    ================ NRF Configuration ================
                                    STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                                    RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
                                    RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                                    TX_ADDR          = 0xe7e7e7e7e7
                                    RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
                                    EN_AA            = 0x3b
                                    EN_RXADDR        = 0x07
                                    RF_CH            = 0x4c
                                    RF_SETUP         = 0x23
                                    CONFIG           = 0x0e
                                    DYNPD/FEATURE    = 0x3f 0x06
                                    Data Rate        = 250KBPS
                                    Model            = nRF24L01+
                                    CRC Length       = 16 bits
                                    PA Power         = PA_LOW
                                    If the NRF24L01+ isn't correctly wired, the following error will be shown
                                    pi@raspberrypi ~ $ sudo /usr/local/sbin/PiGatewaySerial
                                    Created PTY '/dev/pts/2'
                                    check wires
                                    If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
                                    sudo killall PiGatewaySerial
                                    to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
                                    If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
                                    sudo /etc/init.d/PiGatewaySerial start
                                    to start the gateway as a background process. Verify that it started correctly by running
                                    sudo cat /dev/ttyMySensorsGateway
                                    You should see the message "Gateway startup complete". Exit by typing Ctrl+C.
                                    MAKE THE GATEWAY AUTOSTART
                                    To make sure the Gateway is started when your Raspberry Pi boots up, run the following command:
                                    sudo make enable-gwserial
                                    Enable the gateway for use with Domoticz
                                    Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
                                    sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                                    And change /etc/rc.local from this
                                    exit 0
                                    to this
                                    exit 0
                                    OTHER NOTES
                                    • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required. If you use an external power source gnd must be connected to the Raspberry Pi's gnd.
                                    • Connecting the NRF24L01+ directly to your Raspberry Pi will prevent you from using the Raspberry Pi's gpio ports for other things, like a Z-wave board.
                                    • A user experienced slow data transfer compared to USB-to-Serial(ttl)<-->MySensors Gateway connection, especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
                                    As always, I stand on the shoulders of giants. Related posts:
                                    • http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                                    • http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
                                    TROUBLESHOOTING
                                    If you get this error
                                    pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
                                    [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
                                     failed!
                                    or this error
                                    sudo: /usr/local/sbin/PiGatewaySerial: command not found
                                    you have probably forgotten to run sudo make install. Read the instructions again, and follow them this time :-) User @sineverba reported that a reboot of the Pi after running make install helped.
                                    F
                                    F
                                    flopp
                                    @mfalkvidd said:
                                    OTHER NOTES
                                    Nice guide thanks.
                                    when using external power supply i think it is best to connect Ground from Rpi and ext power supply. Maybe write that in the guide?
                                    alexsh1A 1 Reply Last reply
                                    • F flopp
                                      @mfalkvidd said:
                                      OTHER NOTES
                                      Nice guide thanks.
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @flopp the best would be to use Raspberry's 5V rail and reduce it to 3.3V via the LDO like @GertSanders did in his board.
                                      There is one member using 3.3V rail for powering PA+LNA Tranceiver without any issues - check out the latest open hardware. I have not tried it personally
                                      • alexsh1A alexsh1
                                        @alexsh1 I wouldn't want a guide to recommend a solution that is way outside the specifications even if users might not experience problems. Strange problems usually happen outside specs, they are a pain to troubleshoot and in this case might lead to frying someone's Raspberry Pi.
                                        @flopp thanks for your suggestion, I've amended to guide.
                                          INTRODUCTION
                                          Wiring Things Up
                                          6 / GND GND Black
                                          1 / 3.3V DC VCC Red
                                          cd RF24
                                          cd ..
                                          cd Raspberry
                                          IOBASE := 3F000000
                                          VERIFY THE GATEWAY
                                          Clock Speed      = 8 Mhz
                                          EN_AA            = 0x3b
                                          EN_RXADDR        = 0x07
                                          RF_CH            = 0x4c
                                          RF_SETUP         = 0x23
                                          CONFIG           = 0x0e
                                          Data Rate        = 250KBPS
                                          Model            = nRF24L01+
                                          PA Power         = PA_LOW
                                          check wires
                                          exit 0
                                          to this
                                          exit 0
                                          OTHER NOTES
                                          TROUBLESHOOTING
                                           failed!
                                          or this error
                                          SeanMarshS
                                          SeanMarshS
                                          SeanMarsh
                                          @mfalkvidd I"m confused. I noticed the instructions below is for 1.5X or below and will not work with 2.0. The link for 2.0 that is posted doesn't make any sense to me at all. It also takes me to a thread where I start reading the information from the middle of a thread. I'm coming to the conclusion that it doesn't work yet..... Am I right?
                                          SUPER New here. sorry
