  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 212.8k Views 36 Watching
  • W wergeld
    @tbowmo
    What would be required to get the RPi gateway up and running? Having single controller/gateway is great.
    GertSandersG
    GertSandersG
    GertSanders
    @wergeld
    Probably porting the Arduino lib to Raspberry and compiling again ?
    W 1 Reply Last reply
    • GertSandersG GertSanders
      @tbowmo
      I was afraid of that. In my enthusiasm I updated to 2.0.0, but now my new nodes play dead.
      At least I know why.
      Time to make that old ethernet gateway functional again.
      Since Breda meetup is this weekend, I will have no more time to figure this out (if I could ever, this is UNIX). Maybe after I can try something.
      GertSandersG
      GertSandersG
      GertSanders
      @tbowmo
      Is the last 2.0.0-dev version (before the new 2.0.0 official release) still available somewhere ?
      That DEV version seemed to still work with my Raspi GW.
        @wergeld
        W
        W
        wergeld
        @GertSanders
        Time to start reading up on converting the lib! Might have a go at it in week or so. Work is holding me hostage at the moment.
        • GertSandersG
          GertSandersG
          GertSanders
          Praise Apple for making TimeMachine. I was able to set back the last version of MySensors lib I know was working with my gateway in a bout 1 minute.
          Back in business now. Upgrading the gateway and nodes to full 2.0.0 is for later.
          • tbowmoT
            tbowmoT
            tbowmo
            #134
            @wergeld
            you need to port the mysensors core library.. It is however filled with arduino specifics at the moment (we have had some talks about removing arduino dependencies, but it's not made yet).
            Ideally someone should make a raspberry pi port, that we can merge into the main repository, so the same codebase can be build for both raspberryPi and arduino based hardware.
            @GertSanders
            A 2.0.0 GW should be compatible with 1.5.x nodes, but 2.0.0 nodes require a 2.0.0 GW.. (I can't remember the specifics in what the changes are, @tekka is the brain behind that stuff). That said, we do recommend that both nodes and GW will be updated to same mysensors versions, as to avoid any problems.
            • tbowmoT tbowmo
              @wergeld
              @GertSanders
              #135
              @tbowmo @wergeld @GertSanders a port is already available, see https://forum.mysensors.org/topic/2759/mysensors-raspberry-port-suggestions/11 (and github)
              It would be awesome if someone could merge that great work with the MySensors repo.
              • tbowmoT
                tbowmoT
                tbowmo
                @mfalkvidd
                Ok, didn't know that it was updated to 2.0.0 "final", thanks for the hint :+1:
                • Sander TeunissenS
                  Sander TeunissenS
                  Sander Teunissen
                  Would it be safe to say a RPI gateway 2.0 is not available yet for beginners ? (like the instructions @mfalkvidd made are not usable for this ?)
                  • Sander TeunissenS Sander Teunissen
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @Sander-Teunissen
                    At the moment I would advise beginners to use a separate GW for the official 2.0.0 (ethernet or serial based). I found the ethernet based gateway the easiest to use in various setups, espcially since Domoticz (my controller of choice) supported this.
                    Sander TeunissenS 1 Reply Last reply
                      @Sander-Teunissen
                      Sander TeunissenS
                      Sander TeunissenS
                      Sander Teunissen
                      wrote on last edited by Sander Teunissen
                      #139
                      @GertSanders Thanks Gert !
                      I did a quick build of the serial gateway using an arduino which I connect to my RPI. Pretty easy. I'll be watching this when I can switch back to the RPI built gateway...
                        Note: This guide is only applicable to MySensors 1.x. For MySensors 2, use this guide.
                        I noticed that a step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway was listed in the document for MySensors 1.6.
                        Since I have three gateways configured this way, and I need to set up 3 more for covering different offices around the world, and I had already written the instructions in Swedish for Datormagazin, I thought I'd help out.
                        This is the first draft. Any feedback is welcome.
                        INTRODUCTION
                        The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi. The bridge between NRF24L01+ nodes and the "computer world" is called a Gateway. You can use other types of gateways, but connecting the NRF24L01+ module directly to the Raspberry Pi is a simple and cheap alternative.
                        Wiring Things Up
                        Connect the NRF20L01+ radio module to the Raspberry Pi like this:
                        Raspberry Pi NRF24L01+ Color
                        6 / GND GND Black
                        1 / 3.3V DC VCC Red
                        22 / GPIO25 CE Orange
                        24 / GPIO 8 CSN/CS Yellow
                        23 / GPIO11 / SPI_CLK SCK Green
                        19 / GPIO10 / SPI_MOSI MOSI Blue
                        21 / GPIO9 / SPI_MISO MISO Violet
                        The IRQ pin on NRF24L01 is not currently used.
                        For a comprehensive view of the Raspberry Pi pins, see http://pinout.xyz/
                        You should also connect a decoupling capacitor to the radio. See this guide.
                        COMPILING THE GATEWAY
                        Login to your Raspberry Pi (using SSH or open a terminal on the graphical console) and run these commands:
                        git clone https://github.com/TMRh20/RF24.git
                        cd RF24
                        make all && sudo make install
                        cd ..
                        git clone https://github.com/mysensors/Raspberry.git
                        cd Raspberry
                        If you get the following error:
                        pi@raspberrypi ~/RF24 $ make all && sudo make install
                        g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c RF24.cpp
                        gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c bcm2835.c
                        bcm2835.c: In function ‘bcm2835_init’:
                        bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
                        You've probably run into the problem discussed in this thread. People have had luck with different solutions. The simplest is to make the following change to ~/Raspberry/librf24-bcm/Makefile
                        #IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
                        IOBASE := 3F000000
                        VERIFY THE GATEWAY
                        Run sudo /usr/local/sbin/PiGatewaySerial. The output should look like this:
                        pi@raspberrypi ~/Raspberry $ sudo /usr/local/sbin/PiGatewaySerial
                        Starting PiGatewaySerial...
                        Protocol version - 1.4
                        Created PTY '/dev/pts/1'
                        Gateway tty: /dev/ttyMySensorsGateway
                        ================ SPI Configuration ================
                        CSN Pin          = CE0 (PI Hardware Driven)
                        CE Pin           = Custom GPIO25
                        Clock Speed      = 8 Mhz
                        ================ NRF Configuration ================
                        STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                        RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
                        RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
                        TX_ADDR          = 0xe7e7e7e7e7
                        RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
                        EN_AA            = 0x3b
                        EN_RXADDR        = 0x07
                        RF_CH            = 0x4c
                        RF_SETUP         = 0x23
                        CONFIG           = 0x0e
                        DYNPD/FEATURE    = 0x3f 0x06
                        Data Rate        = 250KBPS
                        Model            = nRF24L01+
                        CRC Length       = 16 bits
                        PA Power         = PA_LOW
                        If the NRF24L01+ isn't correctly wired, the following error will be shown
                        pi@raspberrypi ~ $ sudo /usr/local/sbin/PiGatewaySerial
                        Created PTY '/dev/pts/2'
                        check wires
                        If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
                        sudo killall PiGatewaySerial
                        to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
                        If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
                        sudo /etc/init.d/PiGatewaySerial start
                        to start the gateway as a background process. Verify that it started correctly by running
                        sudo cat /dev/ttyMySensorsGateway
                        You should see the message "Gateway startup complete". Exit by typing Ctrl+C.
                        MAKE THE GATEWAY AUTOSTART
                        To make sure the Gateway is started when your Raspberry Pi boots up, run the following command:
                        sudo make enable-gwserial
                        Enable the gateway for use with Domoticz
                        Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
                        sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                        And change /etc/rc.local from this
                        exit 0
                        to this
                        exit 0
                        OTHER NOTES
                        • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required. If you use an external power source gnd must be connected to the Raspberry Pi's gnd.
                        • Connecting the NRF24L01+ directly to your Raspberry Pi will prevent you from using the Raspberry Pi's gpio ports for other things, like a Z-wave board.
                        • A user experienced slow data transfer compared to USB-to-Serial(ttl)<-->MySensors Gateway connection, especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
                        As always, I stand on the shoulders of giants. Related posts:
                        • http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                        • http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
                        TROUBLESHOOTING
                        If you get this error
                        pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
                        [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
                         failed!
                        or this error
                        sudo: /usr/local/sbin/PiGatewaySerial: command not found
                        you have probably forgotten to run sudo make install. Read the instructions again, and follow them this time :-) User @sineverba reported that a reboot of the Pi after running make install helped.
                        F
                        F
                        flopp
                        @mfalkvidd said:
                        OTHER NOTES
                        Nice guide thanks.
                        when using external power supply i think it is best to connect Ground from Rpi and ext power supply. Maybe write that in the guide?
                        alexsh1A 1 Reply Last reply
                        • F flopp
                          @mfalkvidd said:
                          OTHER NOTES
                          Nice guide thanks.
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @flopp the best would be to use Raspberry's 5V rail and reduce it to 3.3V via the LDO like @GertSanders did in his board.
                          There is one member using 3.3V rail for powering PA+LNA Tranceiver without any issues - check out the latest open hardware. I have not tried it personally
                          • alexsh1A alexsh1
                            @alexsh1 I wouldn't want a guide to recommend a solution that is way outside the specifications even if users might not experience problems. Strange problems usually happen outside specs, they are a pain to troubleshoot and in this case might lead to frying someone's Raspberry Pi.
                            @flopp thanks for your suggestion, I've amended to guide.
                              INTRODUCTION
                              Wiring Things Up
                              6 / GND GND Black
                              1 / 3.3V DC VCC Red
                              cd RF24
                              cd ..
                              cd Raspberry
                              IOBASE := 3F000000
                              VERIFY THE GATEWAY
                              Clock Speed      = 8 Mhz
                              EN_AA            = 0x3b
                              EN_RXADDR        = 0x07
                              RF_CH            = 0x4c
                              RF_SETUP         = 0x23
                              CONFIG           = 0x0e
                              Data Rate        = 250KBPS
                              Model            = nRF24L01+
                              PA Power         = PA_LOW
                              check wires
                              exit 0
                              to this
                              exit 0
                              OTHER NOTES
                              TROUBLESHOOTING
                               failed!
                              or this error
                              SeanMarshS
                              SeanMarshS
                              SeanMarsh
                              @mfalkvidd I"m confused. I noticed the instructions below is for 1.5X or below and will not work with 2.0. The link for 2.0 that is posted doesn't make any sense to me at all. It also takes me to a thread where I start reading the information from the middle of a thread. I'm coming to the conclusion that it doesn't work yet..... Am I right?
                              SUPER New here. sorry
                              • SeanMarshS SeanMarsh
                                @SeanMarsh I don't know anything more than what's stated in that thread, sorry. That's also why it is the last option of the alternatives. Go with a serial, wifi or ethernet gateway if you can.
                                • tlpeterT
                                  tlpeterT
                                  tlpeter
                                  I also have a serial gateway next to my raspberry (3 in this case) with Domoticz on it.
                                  If there is an issue than at least a part is still running without breaking everything.
                                  I am using zwave at most and mysensors now for playing.
                                  I cannot break the current zwave implementation so for me a serial gateway is the best solution.
                                  For playing around you might just try as i imaging it could be fun to do it.
                                  • W
                                    W
                                    wergeld
                                    How can we update the gateway to v1.5? I just tried to rebuild from github today and I am getting really odd errors now that I did not get before:
                                    cc1: error: bad value (cortex-a7)
                                    What I could find online states I need to update the gcc compiler on my rPi - it is currently version 4 and latest is 5...but apt-get update gcc says I am already at latest version.
                                    I am trying to get my slimNodes up and running using v1.5 of mysensors.
                                    • T
                                      Toyman
                                      wrote on last edited by Toyman
                                      #147
                                      How can I use "PA power HIGH" with this setup?
                                      • R
                                        R
                                        Reza
                                        i can not add device to domoticz controller with serial gateway(1.4)
                                        MySensors Gateway USB
                                        Version: 1.4 Setup
                                        • R
                                          R
                                          Reza
                                          is this true ?
                                          pi@raspberrypi:~$ sudo make enable-gwserial
                                          make: *** No rule to make target 'enable-gwserial'.  Stop.
