  3. AC IR code decrypting
42 Posts 8 Posters 25.1k Views 8 Watching
  • dpressleD dpressle
    @Nca78 can you please explain why do you add 0101 to the checksum in the temperature example?
    wrote on last edited by Nca78
    #22
    @dpressle
    I add it because it is the initial value of the checksum when temperature is 16°C = 0000
    I just wanted to show than an increase of 1 in temperature was producing an increase of 1 in checksum.
    I think your minus sign (= 19ms pause ?) is in wrong position as it is supposed to be after the 6 (and not 8 ) first words ?
    Please take some values by changing the horizontal and vertical swing so we can try to change the second part of the message. After that try some other functions if you have (anything like "eco"/"quiet"/"turbo" options for example) and also if you have it the timer.
    dpressleD 1 Reply Last reply
    • Nca78N Nca78
      @dpressle
      dpressleD
      dpressleD
      dpressle
      @Nca78 OK, i will generate more commands and see if it makes more sense, Thanks for your help.
      • P pjr
        Gree is the most largest manufacturer of AC devices and Tadiran outdoor unit looks quite a lot like Gree.. at least I'd try that first.
        e: Oh. Looks like Carrier also has some relation with Tadiran.
        ToniA
        @dpressle said:
        @ToniA can you elaborate?
        Yes, on my AC IR decoder sketch I have decoder modules for different heatpumps. Like this:
        https://github.com/ToniA/Raw-IR-decoder-for-Arduino/blob/master/MitsubishiElectric.cpp
        So, write a new one, and add a call to it into https://github.com/ToniA/Raw-IR-decoder-for-Arduino/blob/master/rawirdecode.ino#L315. First you need to write a condition to recognize the protocol (like, from the first bytes + length etc). Then just start adding functionality, like decoding the temperature, then operating mode etc.
        • T ToniA
          dpressleD
          dpressleD
          dpressle
          @ToniA i got you, but the problem is i still dont know the checksum value, working on it...
          • Nca78N
            @dpressle could you please also post a picture of the back of your remote control ? I would like to confirm it's the one I quoted above, would be very interesting as it seems this RC/protocol is shared with a loooot of brands and models.
            It's a very interesting case for this reason but also because it's using a checksum based on 4 bits words and excluding some of the "data" bits (at least the fan speed), it's the first time I see this.
            • Nca78N Nca78
              dpressleD
              dpressleD
              dpressle
              @Nca78 yes it is YB1FA
                A Former User
                In case you are still interested, here is the full description of this code:
                0_1469565492669_Gree.pdf
                Nca78N dpressleD 2 Replies Last reply
                • ? A Former User
                  @joker_mkd That's a fraction of a VERY interesting document you have posted here
                  I suppose the other 180 pages are not freely available ? :D
                  ? 1 Reply Last reply
                  • ? A Former User
                    dpressleD
                    dpressleD
                    dpressle
                    Thanks, this is great looks like exactly what i need, all the relevant information is there.
                    I will now write some code to implement this.
                    • Nca78N Nca78
                      A Former User
                      @Nca78 Unfortunately not. This is a part of the document which we use to define IR codes for our product called PebbleAIR . These codes are implemented in the Android and iOS app. It took me a lot of time, money and effort to decode all the different brands and remotes. I often browse the forums and if I see that someone is stuck or in a need, I share remote data from time to time. If you desperately need data for a certain brand od model feel free to PM me, and I might help you.
                      • ? A Former User
                        @joker_mkd I understand, it's very nice from you to share these pages already !
                        You have a nice product, I love the flashing function I will have to try that just for the fun of it :)
                        • ? A Former User
                          dpressleD
                          dpressleD
                          dpressle
                          wrote on last edited by dpressle
                          #33
                          @joker_mkd product looks great, did you ever thought of making these units smaller (so can be attached on an AC for example) and have some kind of API exposed so any Home Automation can use them? MySensors ZWave Wifi http etc...
                            A Former User
                            @dpressle We are in the process of making an API, because several companies have asked us for this. I was not involved in the process of hardware design, and I agree that the unit could have been made smaller, probably in the next revision.
                            • ? A Former User
                              dpressleD
                              dpressleD
                              dpressle
                              @joker_mkd Sounds wonderful, good luck, i will be watching you :wink:
                              • T
                                ToniA
                                This is what I have done as a hobby so far: https://www.openhardware.io/view/41/Heatpump-airconditioner-controller
                                There's no Gree support in the HeatpumpIR library, though.
                                • T ToniA
                                  dpressleD
                                  dpressleD
                                  dpressle
                                  @ToniA i know, i will try to add it to your library (if no one will beat me to it)
                                  Nca78N 1 Reply Last reply
                                    Not me :p
                                    I'll implement it in my own library if I manage to make something valuable.
                                    • Nca78N Nca78
                                      Not me :p
                                      dpressleD
                                      dpressleD
                                      dpressle
                                      @Nca78 said:
                                      Not me :p
                                      Let me know if you get it done please!
                                      • frishrashF
                                        frishrashF
                                        frishrash
                                        Hi all,
                                        This post is great. I started writing a similar library myself for Electra AC, I might just add it on top of @ToniA's library.
                                        Quick question: can anyone recommend MySensors compatible controller that supports temperature/fan commands ?
                                        The only thing I came across so far is this modification for Vera UI7 thermostat: https://forum.mysensors.org/topic/3606/redesigned-vera-ui7-thermostat-with-heat-cool-setpoint-hvac-state-fan-status-energy-mode
                                        • dpressleD
                                          dpressleD
                                          dpressle
                                          So i ended up implementing it in my own library, still under tests, i will publish it here once i push it to github.
