  3. AC IR code decrypting
42 Posts 8 Posters 25.1k Views 8 Watching
  • T ToniA
    How about writing a new decode module into Raw-IR-decoder-for-Arduino? I find it very useful in trying to figure out how a certain A/C protocol works.
    dpressleD
    dpressleD
    dpressle
    @ToniA can you elaborate?
    Nca78N 1 Reply Last reply
    • dpressleD dpressle
      From wikipedia :
      "Tadiran Appliances (also known as Tadiran Air Conditioners), was acquired by the Carrier Corporation, the world’s largest manufacturer and distributor of heating, ventilating and air conditioning (HVAC) systems, itself a subsidiary of United Technologies Corporation (UTC) of the USA and a constitute of Dow Jones Industrial Average. Carrier initially acquired 26%of the company in 1997 and took full ownership of it in 2004.[2]"
      So looking for Carrier AC infrared should probably help.
      Is the reference of your remote control (on the sticker at the back) YB1FA ? As it seems to be shared by gree/carrier/tadiran/ferroli/condor
      • Nca78N
        wrote on last edited by Nca78
        From the temperature codes, the checksum is obviously a sum, you have to reverse the bits before you sum, the MSB is on the right in both data bits and checksum.
        16° 0000 checksum 0101
        17° 0001 checksum 0110 = 0101 + 0001
        18° 0010 checksum 0111 = 0101 + 0010
        19° 0011 checksum 1000 = 0101 + 0011
        20° 0100 checksum 1001 = 0101 + 0100
        27° 1101 checksum 0000 because 0101 + 1101 = 10000 and you keep only the last 4 bits
        Now we just need to understand what bits are included or not in the sum, it seems the fan speed is not, but we need more messages in different modes and with different settings to be able to know which bits are used or not in the calculation.
        I take your example code :
        100100000101000000000110000 19 ms space 0101001000000000000001000000000000001111
        Split in 4 bits words :
        1001
        0000
        0101
        0000
        0000
        0110
        000 19 ms space => I ignore this part as it's not matching the 4 bits words, and only 0s anyway
        0101
        0010
        0000
        0000
        0000
        0100
        0000
        0000
        0000
        1111
        Invert bit order and try to guess what words are included or not.
        If you make the sum of included words with binary calculator, it matches the checksum but we must validate with more parameters changed, try with horizontal/vertical swing if you have these on the remote control, then any other specific function.
        1001 => on + mode, included as it's the only one with LSB = 1 and we have LSB = 1 in checksum
        0000 => fan speed, not included as shown in your examples on fan speed
        1010 => temp 16°C + value, included as shown in your examples of temperature
        0000 => ??? cannot know because 0
        0110 => I think included else I don't have the right checksum
        1010 => I think not included else I don't have the right checksum
        0100 => I think included else I don't have the right checksum
        1111 => binary sum of all included words, only the 4 LSB bits are kept
        dpressleD 2 Replies Last reply
        • Nca78N Nca78
          1001
          0000
          0101
          0000
          0000
          0110
          0101
          0010
          0000
          0000
          0000
          0100
          0000
          0000
          0000
          1111
          dpressleD
          dpressleD
          dpressle
          @Nca78 I think you are on to something, thanks a lot. I will investigate it further, but in the mean time here is some more data that i took:
          mode fan temp
          cold auto 26
          1001 0000 0101 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1111
          cold auto 25
          1001 0000 1001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0111
          cold auto 24
          1001 0000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
          cold fan1 24
          1001 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
          cold fan2 24
          1001 0100 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
          cold fan3 24
          1001 1100 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1011
          dry fan1 24
          0101 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0111
          air fan1 24
          1101 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1111
          heat fan1 24
          0011 1000 0001 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 0000
          OFF cold auto 26
          1000 0000 0101 0000 0000 0110 0000 1010 010 - 0000 0000 0000 0100 0000 0000 0000 1110
          • Nca78N Nca78
            1001
            0000
            0101
            0000
            0000
            0110
            0101
            0010
            0000
            0000
            0000
            0100
            0000
            0000
            0000
            1111
            dpressleD
            dpressleD
            dpressle
            @Nca78 can you please explain why do you add 0101 to the checksum in the temperature example?
              #22
              @dpressle
              I add it because it is the initial value of the checksum when temperature is 16°C = 0000
              I just wanted to show than an increase of 1 in temperature was producing an increase of 1 in checksum.
              I think your minus sign (= 19ms pause ?) is in wrong position as it is supposed to be after the 6 (and not 8 ) first words ?
              Please take some values by changing the horizontal and vertical swing so we can try to change the second part of the message. After that try some other functions if you have (anything like "eco"/"quiet"/"turbo" options for example) and also if you have it the timer.
              dpressleD 1 Reply Last reply
              • Nca78N Nca78
                @dpressle
                dpressleD
                dpressleD
                dpressle
                @Nca78 OK, i will generate more commands and see if it makes more sense, Thanks for your help.
                • P pjr
                  Gree is the most largest manufacturer of AC devices and Tadiran outdoor unit looks quite a lot like Gree.. at least I'd try that first.
                  e: Oh. Looks like Carrier also has some relation with Tadiran.
                  ToniA
                  Yes, on my AC IR decoder sketch I have decoder modules for different heatpumps. Like this:
                  https://github.com/ToniA/Raw-IR-decoder-for-Arduino/blob/master/MitsubishiElectric.cpp
                  So, write a new one, and add a call to it into https://github.com/ToniA/Raw-IR-decoder-for-Arduino/blob/master/rawirdecode.ino#L315. First you need to write a condition to recognize the protocol (like, from the first bytes + length etc). Then just start adding functionality, like decoding the temperature, then operating mode etc.
                  • T ToniA
                    dpressleD
                    dpressleD
                    dpressle
                    @ToniA i got you, but the problem is i still dont know the checksum value, working on it...
                    • Nca78N
                      @dpressle could you please also post a picture of the back of your remote control ? I would like to confirm it's the one I quoted above, would be very interesting as it seems this RC/protocol is shared with a loooot of brands and models.
                      It's a very interesting case for this reason but also because it's using a checksum based on 4 bits words and excluding some of the "data" bits (at least the fan speed), it's the first time I see this.
                      • Nca78N Nca78
                        dpressleD
                        dpressleD
                        dpressle
                        @Nca78 yes it is YB1FA
                          A Former User
                          In case you are still interested, here is the full description of this code:
                          0_1469565492669_Gree.pdf
                          Nca78N dpressleD 2 Replies Last reply
                          • ? A Former User
                            @joker_mkd That's a fraction of a VERY interesting document you have posted here
                            I suppose the other 180 pages are not freely available ? :D
                            ? 1 Reply Last reply
                            • ? A Former User
                              dpressleD
                              dpressleD
                              dpressle
                              Thanks, this is great looks like exactly what i need, all the relevant information is there.
                              I will now write some code to implement this.
                              • Nca78N Nca78
                                A Former User
                                @Nca78 Unfortunately not. This is a part of the document which we use to define IR codes for our product called PebbleAIR . These codes are implemented in the Android and iOS app. It took me a lot of time, money and effort to decode all the different brands and remotes. I often browse the forums and if I see that someone is stuck or in a need, I share remote data from time to time. If you desperately need data for a certain brand od model feel free to PM me, and I might help you.
                                • ? A Former User
                                  @joker_mkd I understand, it's very nice from you to share these pages already !
                                  You have a nice product, I love the flashing function I will have to try that just for the fun of it :)
                                  • ? A Former User
                                    dpressleD
                                    dpressleD
                                    dpressle
                                    wrote on last edited by dpressle
                                    #33
                                    @joker_mkd product looks great, did you ever thought of making these units smaller (so can be attached on an AC for example) and have some kind of API exposed so any Home Automation can use them? MySensors ZWave Wifi http etc...
                                      A Former User
                                      @dpressle We are in the process of making an API, because several companies have asked us for this. I was not involved in the process of hardware design, and I agree that the unit could have been made smaller, probably in the next revision.
                                      • ? A Former User
                                        dpressleD
                                        dpressleD
                                        dpressle
                                        @joker_mkd Sounds wonderful, good luck, i will be watching you :wink:
                                        • T
                                          ToniA
                                          This is what I have done as a hobby so far: https://www.openhardware.io/view/41/Heatpump-airconditioner-controller
                                          There's no Gree support in the HeatpumpIR library, though.
