  3. AC IR code decrypting
42 Posts 8 Posters 25.1k Views 8 Watching
    A Former User
    In case you are still interested, here is the full description of this code:
    0_1469565492669_Gree.pdf
    Nca78N dpressleD 2 Replies Last reply
    • ? A Former User
      @joker_mkd That's a fraction of a VERY interesting document you have posted here
      I suppose the other 180 pages are not freely available ? :D
      ? 1 Reply Last reply
      • ? A Former User
        dpressleD
        dpressleD
        dpressle
        Thanks, this is great looks like exactly what i need, all the relevant information is there.
        I will now write some code to implement this.
        • Nca78N Nca78
          A Former User
          @Nca78 Unfortunately not. This is a part of the document which we use to define IR codes for our product called PebbleAIR . These codes are implemented in the Android and iOS app. It took me a lot of time, money and effort to decode all the different brands and remotes. I often browse the forums and if I see that someone is stuck or in a need, I share remote data from time to time. If you desperately need data for a certain brand od model feel free to PM me, and I might help you.
          • ? A Former User
            @joker_mkd I understand, it's very nice from you to share these pages already !
            You have a nice product, I love the flashing function I will have to try that just for the fun of it :)
            • ? A Former User
              dpressleD
              dpressleD
              dpressle
              wrote on last edited by dpressle
              #33
              @joker_mkd product looks great, did you ever thought of making these units smaller (so can be attached on an AC for example) and have some kind of API exposed so any Home Automation can use them? MySensors ZWave Wifi http etc...
              • dpressleD dpressle
                A Former User
                @dpressle We are in the process of making an API, because several companies have asked us for this. I was not involved in the process of hardware design, and I agree that the unit could have been made smaller, probably in the next revision.
                dpressleD 1 Reply Last reply
                • ? A Former User
                  dpressleD
                  dpressleD
                  dpressle
                  @joker_mkd Sounds wonderful, good luck, i will be watching you :wink:
                  • T
                    ToniA
                    This is what I have done as a hobby so far: https://www.openhardware.io/view/41/Heatpump-airconditioner-controller
                    There's no Gree support in the HeatpumpIR library, though.
                    • T ToniA
                      dpressleD
                      dpressleD
                      dpressle
                      @ToniA i know, i will try to add it to your library (if no one will beat me to it)
                      Nca78N 1 Reply Last reply
                        Not me :p
                        I'll implement it in my own library if I manage to make something valuable.
                        • Nca78N Nca78
                          Not me :p
                          dpressleD
                          dpressleD
                          dpressle
                          @Nca78 said:
                          Not me :p
                          Let me know if you get it done please!
                          • frishrashF
                            frishrashF
                            frishrash
                            Hi all,
                            This post is great. I started writing a similar library myself for Electra AC, I might just add it on top of @ToniA's library.
                            Quick question: can anyone recommend MySensors compatible controller that supports temperature/fan commands ?
                            The only thing I came across so far is this modification for Vera UI7 thermostat: https://forum.mysensors.org/topic/3606/redesigned-vera-ui7-thermostat-with-heat-cool-setpoint-hvac-state-fan-status-energy-mode
                            • dpressleD
                              dpressleD
                              dpressle
                              So i ended up implementing it in my own library, still under tests, i will publish it here once i push it to github.
                              • dpressleD
                                dpressleD
                                dpressle
                                Hi All,
                                Library can be found here:
                                GitHub
                                It contains a test ino to test the library and a ino to work with mysensors.
                                If you have any comments and or questions please dont hesitate to ask/comment.
                                Thanks to all of you who helped in this topic and especially to @joker_mkd who donated his gree code document.
