  3. AC IR code decrypting
42 Posts 8 Posters 24.6k Views 8 Watching
  • ? A Former User
    In case you are still interested, here is the full description of this code:
    0_1469565492669_Gree.pdf
    @joker_mkd That's a fraction of a VERY interesting document you have posted here
    I suppose the other 180 pages are not freely available ? :D
    ? 1 Reply Last reply
    • ? A Former User
      dpressleD
      dpressleD
      dpressle
      Thanks, this is great looks like exactly what i need, all the relevant information is there.
      I will now write some code to implement this.
      • Nca78N Nca78
        A Former User
        @Nca78 Unfortunately not. This is a part of the document which we use to define IR codes for our product called PebbleAIR . These codes are implemented in the Android and iOS app. It took me a lot of time, money and effort to decode all the different brands and remotes. I often browse the forums and if I see that someone is stuck or in a need, I share remote data from time to time. If you desperately need data for a certain brand od model feel free to PM me, and I might help you.
        Nca78N dpressleD 2 Replies Last reply
        • ? A Former User
          @joker_mkd I understand, it's very nice from you to share these pages already !
          You have a nice product, I love the flashing function I will have to try that just for the fun of it :)
          • ? A Former User
            dpressleD
            dpressleD
            dpressle
            wrote on last edited by dpressle
            #33
            @joker_mkd product looks great, did you ever thought of making these units smaller (so can be attached on an AC for example) and have some kind of API exposed so any Home Automation can use them? MySensors ZWave Wifi http etc...
            • dpressleD dpressle
              A Former User
              @dpressle We are in the process of making an API, because several companies have asked us for this. I was not involved in the process of hardware design, and I agree that the unit could have been made smaller, probably in the next revision.
              dpressleD 1 Reply Last reply
              • ? A Former User
                dpressleD
                dpressleD
                dpressle
                @joker_mkd Sounds wonderful, good luck, i will be watching you :wink:
                • T
                  ToniA
                  This is what I have done as a hobby so far: https://www.openhardware.io/view/41/Heatpump-airconditioner-controller
                  There's no Gree support in the HeatpumpIR library, though.
                  • T ToniA
                    dpressleD
                    dpressleD
                    dpressle
                    @ToniA i know, i will try to add it to your library (if no one will beat me to it)
                    Nca78N 1 Reply Last reply
                      Not me :p
                      I'll implement it in my own library if I manage to make something valuable.
                      • Nca78N Nca78
                        Not me :p
                        dpressleD
                        dpressleD
                        dpressle
                        @Nca78 said:
                        Not me :p
                        Let me know if you get it done please!
                        • frishrashF
                          frishrashF
                          frishrash
                          Hi all,
                          This post is great. I started writing a similar library myself for Electra AC, I might just add it on top of @ToniA's library.
                          Quick question: can anyone recommend MySensors compatible controller that supports temperature/fan commands ?
                          The only thing I came across so far is this modification for Vera UI7 thermostat: https://forum.mysensors.org/topic/3606/redesigned-vera-ui7-thermostat-with-heat-cool-setpoint-hvac-state-fan-status-energy-mode
                          • dpressleD
                            dpressleD
                            dpressle
                            So i ended up implementing it in my own library, still under tests, i will publish it here once i push it to github.
                            • dpressleD
                              dpressleD
                              dpressle
                              Hi All,
                              Library can be found here:
                              GitHub
                              It contains a test ino to test the library and a ino to work with mysensors.
                              If you have any comments and or questions please dont hesitate to ask/comment.
                              Thanks to all of you who helped in this topic and especially to @joker_mkd who donated his gree code document.
