  3. Dimmable LED kitchen light (Arduino, APDS-9960, RGBWW led)
arduinoapds-9960
37 Posts 13 Posters 17.3k Views 12 Watching
    Wow! That's nice!
    • TheoLT
      TheoLT
      TheoL
      Love it. Have you tried the APDS-9930? I have them laying around, but haven't got time to try them
      • TheoLT TheoL
        @TheoL I didn't know they existed. What's the difference?
        BartEB TheoLT 2 Replies Last reply
          BartEB
          BartEB
          BartE
          @mfalkvidd a video with cool 8 bit music :-) nice
          • Boots33B
            Boots33B
            Boots33
            Great looking light setup...... now if you could just get the the sensor to control the kids as well I might be able to get them to do the washing up too. ;)
              TheoLT
              TheoLT
              TheoL
              @mfalkvidd Haven't checked all details. But for most less accurate but much cheaper. I believe I paid about 8 times less for the 9930 an aliexpress.
              Nca78N 1 Reply Last reply
              • greglG
                greglG
                gregl
                @mfalkvidd - Nice work.
                Q: How close to the sensor does your hand need to be? and can this distance be controlled?
                • TheoLT TheoL
                  wrote on last edited by Nca78
                  Great project, I have ordered a 9960 and I can't wait to receive it and play with it, this could be a good start.
                  I didn't know about this one, thank you about the information ! From what I see quickly the 9930 is only a proximity detection sensor, it cannot sense movement like the 9960. It can sense distance so it could be used for this application but it has shorter range, 10cm instead of 10 to 20 for the 9960.
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    Could this also have been done using a ultrasonic distance sensor?
                    • greglG gregl
                      The sensor starts registering at about 25cm/10in distance and reports maximum proximity at about 5cm/2in (anything closer than that results in a reading of 255).
                      setProximityGain might affect this, but I haven't tried.
                        My experience with the HC-SR04 is that consecutive readings vary too much. A smoothening algorithm (take the median of 5 readings for example) might work, but one reading of the HC-SR04 takes 60 ms which already is 3 times longer than the sample rate I use for the ADPS-9960 so the dimming would probably "stutter" a lot. The speed of sound is simply too slow :)
                        • sundberg84S
                          sundberg84S
                          @mfalkvidd - Great work! This is exactly what I had in mind - now i can follow this great example and spare me some hours! Thanks!
                          • mfalkviddM
                            I would like to remove the need for holding still to "lock" the light level, but it is a bit hard since the sensor will get several readings while I remove my hand which will set the light level at all sorts of values.
                            Setting a timeout that "resets" the level to an earlier value when the sensor stops detecting should be possible, but will require some experimenting to get right.
                            Implementing a PID regulator might be useful as well, but would require revisiting some long forgotten math skills.
                              @mfalkvidd Nice project man!
                              Did you consider protecting the sensor somehow from direct air contact? Kitchen stuff stends to get real greasy over time...
                              • YveauxY Yveaux
                                I did not consider that. I think the sensor will sense transparent plastic and glass but I haven't tested, so maybe it is possible to put some protection in front of it.
                                TheoLT 1 Reply Last reply
                                  TheoLT
                                  TheoLT
                                  TheoL
                                  @mfalkvidd I have so far not been able to cover the sensor. It's very sensitive. So if somebody knows a material that can cover the sensor while keeping it operating, I'll be be much obliged.
                                    #21
                                    @mfalkvidd
                                    I have played a lot with 9960 few weeks ago, as I have a project with it, I will show you maybe.. ;)
                                    • theoretically 9960 is better than 9930. If you look at datasheet of 9930 it's mentioned as proximity (no gesture engine in it). whereas 9960 is.
                                    • sometimes I had to tweak few offsets in lib for sensitivity or thresholds (on my side, because there is a very nasty while loop in the gesture process..)
                                    • for covering it, you need a material with 80% min of IR transmittance or it won't work well or not at all..
                                      So with this kind of sensor, without a special material, you need a hole (enough large, see datasheet).
                                    • scalzS scalz
                                      @mfalkvidd
                                      And the datasheet says 1mm thickness maximum for the glass/plastic and also 1mm maximum air gap between sensor and glass. They also suggest if you put a glass to put a rubber layer with just two holes for the led (1.5mm) and the photodetector (2mm) to avoid crosstalk (reflection of the IR light from the led will generate fake proximity or movement detections).
                                      In short it sounds much easier to not use a cover, or else to make a "big" hole for the full sensor size.
                                        @Nca78 i think behind a glass plate it's less reliable, even if using rubber layer because this sensor can be sensitive to light fluctuations etc, imho not the best sensor behing a glass plate but i have not run so much attempts on covering it, so..
                                        but it's a fun sensor :)
                                        • mfalkviddM
                                          With the cost of the sensor down to $7.40 (from $15 when I first bought one) and even lower when buying multiple sensors I think it is better to just replace the sensor when it becomes too dirty.
                                          12.5k
