716 Posts 111 Posters 703.1k Views 93 Watching
  • rchampR rchamp
    what is the size of the mounting holes? i don't have a caliper yet to measure this small of a size (ordering on amazon)
    sundberg84S
    sundberg84S
    I dont have eagles at this computer, so I have to answer you tonight (8 hours) or so...
    Thanks for the nice feedback!
    • rchampR rchamp
      sundberg84S
      sundberg84S
      @rchamp - sorry for later reply, the mounting holes are 2mm or 78.7mil.
      rchampR 1 Reply Last reply
      • sundberg84S sundberg84
        rchampR
        rchampR
        rchamp
        @sundberg84
        awesome thanks!
        • Nca78N
          Hello, I ordered a second batch from PCBWay, it's ok except some components have a frame on the silkscreen, not very beautiful.
          Just wanted to say that it was a pain to cut the 1.6mm PCB so this time I ordered in 0.8mm and it is sooooo easy to cut with regular cissors: no efforts and very clean cut ! So if you plan to cut the right part, order at 1mm or below, you will enjoy the cutting phase :D
          • Nca78N Nca78
            sundberg84S
            sundberg84S
            Sorry, I dont understand what you mean - can you give me a closeup photo? It should be functional AND beautiful :) If the silkscreen overlaps the copper parts this could interfer as well...
            I also learned it the hard way - and since there isnt any high power ciciut it should be ok to order very thin pcbs.
            I used a metallic saw for one :persevere: and for some i cut a trace with a knife and bended it until it cracked.
            Nca78N 1 Reply Last reply
            • Martin TellblomM
              Martin TellblomM
              Martin Tellblom
              Just ordered 10 white bords, they look so great :)
              MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
                wrote on last edited by Nca78
                #169
                I fact it's the case only for the "Rev B" and licence text at the top left. No big deal but it was looking better without the frame from DirtyPCB
                I used the knife too (don't have a metal saw) with the 1.6mm PCBs and it was long and messy. Now it's just like a strong cardboard.
                • Q
                  Q
                  Qu3Uk
                  I ordered some via DirtyPCB - Ordering via OpenHardware it seems to suggest you are buying Rev4. Says Rev4 under the order button at least.
                  • Q Qu3Uk
                    sundberg84S
                    sundberg84S
                    #171
                    @Qu3Uk - Yes, and its missleading. Its rev 9 you are ordering but the fourth update on openhardware.io Its no problem ordering from there, I always update those gerber files first.
                    • dbemowskD
                      dbemowskD
                      #172
                      I just wanted to make some suggestions for this board for the possible next revision. I recently ordered a 10 pack (which when I got it ended up being an 11 pack... BONUS BOARD).
                      When I put together my first board there were some things that I noticed. First, the boards that I got are labeled as rev 8 boards, but there is one small difference from the one shown on the openhardware.io website.
                      board differences
                      The placement of the 4.7uf capacitor and the raw power connection holes next to the nRF24L01+ socket are reversed. The spot that you have for the 4.7uf capacitor for the nRF24L01+ radio module is just a bit too close to the nRF24 connector. It appears that the capacitor that you chose in your design software was for a ceramic type cap that has a wider hole spacing and is narrower. Choose one for an electrolytic cap and move it away from the nRF24 connector a bit more. This should give the closer hole spacing designed for a small electrolytic cap and leave enough room for it.
                      Similarly the spot you have for the 10uf cap above the regulator appears to also be a design for a ceramic cap with the wider hole spacing. Selecting electrolytics for these should not only give you the correct hole spacing for the electrolytic, but it should also better mark where the negative lead of the cap needs to go on your silkscreen layer.
                      The other thing that I wish this had was pads for a SMT AMS1117 regulator. This could be placed in the space under the nRF24 radio or just under the pro mini. You could do this in conjunction with the TO92 style that you have currently placed. It would give the board a bit more flexibility for users. In my parts box, I only had the AMS1117 regulators and not the TO92 style. I have since ordered some of the TO92 style, but having the flexibility for either would have been nice.
                      Last but not least, it would be nice to have slightly larger corner mounting holes. I don't have many small screws that fit those holes, and I have none that would work with the standoffs that I use.
                      Other than those few things, it seems like a rock solid board. Thanks for the hard work.
                      • dbemowskD dbemowsk
                        board differences
                        sundberg84S
                        sundberg84S
                        #173
                        @dbemowsk - Hi!
                        Thank you for great input!
                        Why the difference, is because I released rev 8 but made some last minute changes and forgot to update to rev 8.1.
                        You pretty much found the difference. It was a couple of days so I didnt think anybody would notice.
                        Did you order from DirtyPCB? I see not it got the old rev 8 version. I will update openhardware.io!
                        Your suggestions about the 4,7uF cap is exactly what I did in the correct Rev 8 version.
                        I use electrolytic caps on both 4,7 0,1 and 10 uF without any problems. The G marks ground.
                        I also like the AMS1117 but since its another design than LE33 and MySensors site wuggest LE33 i went with this.
                        Its a balance between flexibility and easy to use. To many components (like dual voltage regulators) will confuse some new users.
                        I will try to fit in some bigger holes in rev 9 (currently working on it) and see what I can do about the AMS1117 .
                        Thank you for great input - ill keep it in mind!
                        Br
                        Andreas
                        • daand83D
                          daand83D
                          daand83
                          First of all, thank you @sundberg84 for this great PCB. Super easy to work with. Still; there is one question that I haven't been able to figure out yet.
                          I'm running my pcb as a battery node and want to monitor the battery status. However A0 always returns a value somewhere around 30 +/- 15 - even with brand new batteries. Calculated into voltage, this would mean around 1,04V.
                          I've checked and double checked that I'm using 470k and 1M resistors.
                          I've also measured using a multi meter, with incoming value of 3,2 V and outgoing from booster 3,36V.
                          Any ideas that might point me in the right direction for solving this noob issue?
                          • daand83D daand83
                            sundberg84S
                            sundberg84S
                            #175
                            @daand83 - do you mean analogread() always returns 30 but you still got 1,04V in? If so, either you have a bad connection to A0 or the chip is broken. I have had atmegas (pro mini) which was broken.
                            You could try soldering a second wire from A0 to the voltage divider to exclude connections errors. You could also measure the voltage input on the atmega chip. If its 1.04 there as well a bad connection can be excluded and you hav a bad pro mini / atmenga chip.
                            It coule be a code error as well, if you have changed to code...
                            daand83D 1 Reply Last reply
                              daand83D
                              daand83D
                              daand83
                              @sundberg84
                              What I've done is this;
                              Measured voltage on PWR/GND which returns 3,2 V. I've measured voltage on GND/Vout on the battery booster which returns 3,36V. However, analogread always returns something like 300 +/-10, which (using the formula provided) indicates a voltage of 1,04 V and a battery percentage of ~30%. This has been the case with brand new batteries as well as old ones...
                              • daand83D daand83
                                @sundberg84
                                sundberg84S
                                sundberg84S
                                #177
                                @daand83 - this is quite dependent on which code you use I think but it sounds right. A return of 1000 would be 3,3V in my code.
                                This is my code:
                                Defines:
                                #define VMIN 1.9                         //  Vmin (radio Min Volt)=1.9V (564)
                                #define VMAX 3.0                        //  Vmax = (2xAA bat)=3.0V (892)
                                int batteryPcnt = 0;                       // Calc value for battery %
                                int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
                                Setup()
                                Loop()
                                delay(500);
                                   // Battery monitoring reading
                                   delay(500);
                                   // Calculate the battery in %
                                Serial.print(batteryPcnt);
                                Serial.println(" %");
                                if (batteryPcnt > 100) {
                                     batteryPcnt=100;
                                I think you should measure the voltage on A0 to Gnd and see what you get.
                                  This is my code:
                                  Defines:
                                  Setup()
                                  Loop()
                                  delay(500);
                                     delay(500);
                                       batteryPcnt=100;
                                  daand83D
                                  daand83D
                                  daand83
                                  @sundberg84 - the only weird part is that analogread() returns a value of 300, which in turn is below VMIN; and hence a negative value (1,04-1,9)/(3,0-1,9) = -78%.
                                  But if I understand you correctly the next two steps in the troubleshooting process would be;
                                  • measure GND/VCC on the atmega-chip as well to make sure that it is indeed not a faulty chip?
                                  • solder a second connection from A0 to the voltage divider to remove any bad connections
                                  Thanks again :) :+1:
                                  • daand83D daand83
                                    daand83D
                                    daand83D
                                    daand83
                                    wrote on last edited by daand83
                                    #179
                                    I have to verify when I get home, but I've probably found the problem... Seems as a stupid copy/paste problem. No call to analogreference(INTERNAL). Don't know how I've been able to overlook this for a week now, but... Will check back with result later on...
                                    • daand83D daand83
                                      sundberg84S
                                      sundberg84S
                                      #180
                                      @daand83 - haha, easy to forget - I also forgot to post in in my example above (changed now) :)
                                      Only one line of code in a different place... well, hope you found it!
                                        daand83D
                                        daand83D
                                        daand83
                                        @sundberg84 - Indeed missing analogreference. All good now, even got a battery value of 102 % ;)
                                        • NiklasON
                                          NiklasON
                                          NiklasO
                                          @sundberg84 said:
                                          AMS1117
                                          mmmm I would like to see a board with room for AMS1117 and caps... :)
                                          While waiting for my Newbie PCBs to arrive I have built my own test sensor on a bit of breadboard. Got the new 0,8-3.3v to 3.3v today. My boosters. So, I just cut the trace going from the battery to the rest of the components and arduino and there I connected my booster. VIN directly from bat + and gnd from bat -, Also, everything else that need GND is connected to the same place. I then reconnected the plus power rail to the power coming from the booster. I also moved the radio connection so that if feed directly from the battery. Measurements show me 3.3 v to arduino and other sensors and about 2.9 to the radio directly from batt. Something does not want to work. It is something with the power to the radio. Running sensor on battery only, no booster, works just fine. Running node with everything on vout from the booster, it just won't work. The radio struggles to do something useful but it fails. Running radio on batt and the rest on booster does not work. 'But, if I power the node with power from the serial adapter. the node woks again but only if the battery provide power to the radio at the same time.
                                          Any suggestions? Quite tired, can be messy ;)
