  3. Time awareness and scheduling events
30 Posts 8 Posters 11.9k Views 1 Watching
    The trend in HA now moves towards pushing some of the "intelligence" to the nodes. This creates autonomous units that can actually work for a while without contacting and relying on the "mothership".
      @hek I also want to be able to switch on my lights when my gateway is down, but when we want to move intelligence to the nodes (eg make them programmable using rules as seen in another discussion) we have to think upfront what the implications are and how to implement this. I should not rush some kind of schedule rules now, without thinking over the whole concept first.
      hekH T 2 Replies Last reply
      • YveauxY Yveaux
        @Yveaux
        Fully agree. That why we're discussing the concepts :facepunch: :)
        • YveauxY Yveaux
          ToSa
          Code Contributor
          @Yveaux
          This is a request for ideas before I start coding any of this!!!
          time awareness was straight forward based on existing functionality (even if I would still argue that it should be an integral part of the sensor code and not require separate code in the custom sketch).The rules engine requires much more prep work and smart ideas.
          In an earlier project I ended up with the following (not saying that this is the best approach - just to start the discussion):
          • simple memory manager assigning memory addresses so that you can remotely request or set a variable in memory the same way you do today with sensors (think about a memory address having its own sensor-id on the node)
          • rules to set variables on the same node or on remote nodes (or on the gateway/controller)
          • rules triggered by schedule or triggered by events (button clicked / temperature changed / ...)
          • no need to trigger rules remotely - you can get that by setting a variable remotely and have a rule listening on changes to that variable (node A with the light switch telling node B with the relay to turn on the light)
          • gateway is always made aware of what's going on but usually not required for the execution
          The problem is that the "setup" of the network and the specific nodes gets way more complex - easy to do for software developers but hard to do for a "normal" user.
            @Yveaux
            @hek yeah yeah... The initial post sounded quite concrete and is limited to time and scheduling. Therefore I wanted to broaden things a bit. But I guess this will automatically happen in a few hours anyway, if you get what I mean ;-)
            • T
              ToSa
              Code Contributor
              @hek any plans to setup a "dev_1.5" branch or something similar? If we continue adding major functionality changes to 1.4 it will never get "ready" :)
              hekH 1 Reply Last reply
              • T ToSa
                @ToSa
                Yes, only ONE page left to document (API). Then I'll release 1.4 (push it to master) and we can have development for our selves again ;)
                • korttomaK korttoma
                  @hek I ordered a few of these -> http://www.ebay.com/itm/191276972230 hoping they can serve the same purpose.
                  korttomaK
                  korttomaK
                  korttoma
                  I have now been playing with one of these for a few hour and I really like it. Running an LCD and TinyRTC on the same I2C bus and it is working fine.
                  Need some more time on the sketch before I mount everything in a box. The goal is a scene controller
                  / clock / info display by the bed.
                  I was thinking of adding the knock sensor as a "clapper" device but I don't think I can pull of the code so that it would keep updating the clock as often as I would like.
                  • Tomas
                    @korttoma
                    Yes, received mine yesterday but haven't had time to play with it yet.
                    The DS3231 I got seems to have a build-in temp-sensor also.
                    • greglG
                      greglG
                      gregl
                      Probably not something you need guys, but something i did the other day - a sketch to request the time from Vera and set an RTC.
                      My requirement is to keep the RTC synced when daylight saving changes, so sync would be at 2:01 Sundays.
                      https://codebender.cc/sketch:48244
                      • greglG gregl
                        @gregl
                        Thanks @gregl, was just about to create something similar :)
                        • greglG
                          greglG
                          gregl
                          No prob... you can remove the bugs ive added ;-)
                          • korttomaK
                            korttomaK
                            korttoma
                            Thanks! @GREGL I find it useful also for my project.
                            • Tomas
                            • JohnJ
                              JohnJ
                              John
                              I would suggest to sync times a little bit more because if i remember correct the 1307 is quite sensitive for drifting because of temperature, if it would drift 3 seconds a day would be around 16 minutes a year, the DS3231 compansates this with the build in temp sensor.
                              But i could be incorrect, but, update your rtc more often anyway ;)
                              • korttomaK
                                korttomaK
                                korttoma
                                #23
                                Just tried the DS3232RTC library from the examples provided by @hek and it seems like the RTC I2C DS1307 AT24C32 (link to device in earlier post) I have is working happily with this library also. I guess all the features of the library does not work but since the features on my device are working I will stick with this lib since it is provided by MySensors.
                                Maybe you should try it out to @gregl
                                BTW!, the RTC I have seems to drift quite allot (~1s/h) so I would not recommend it to someone that needs accuracy.
                                • Tomas
                                • T
                                  ToSa
                                  Code Contributor
                                  All - help me understand the use-case for a RTC on a sensor please.
                                  From the discussion above I get that we might have two different needs:
                                  • really high accuracy
                                  • a second (or few seconds) deviation are acceptable
                                  We lose accuracy in RF transmission already, therefore fetching the time on the controller or gateway and sending it to the nodes is not appropriate for the high accuracy need. A RTC would not help in this case because you need to tell the RTC the current time to start with and if that's already inaccurate, you won't get the accuracy needed. The only way to get real accuracy would be to fetch it on the node directly e.g. with a DCF77 receiver.
                                  For the "less accuracy needed" scenario why would you add hardware to the node if receiving a time broadcast from the controller every x minutes is good enough to get the required (lower) accuracy "in software" without the need for hardware?
                                  • JohnJ
                                    JohnJ
                                    John
                                    wrote on last edited by John
                                    #25
                                    You would be better of with an http://www.maximintegrated.com/en/products/digital/real-time-clocks/DS3231.html which has a theoretically drift between 1 and 2 minutes a year (depending on operating temperatures).If i'm correct it uses the internal temp sensor for drift compensation (and could also be read?).
                                    • T ToSa
                                      If your mains powered watering node has a power failure (restarts) and loses connection to controller.
                                      • JohnJ
                                        JohnJ
                                        John
                                        #27
                                        http://forum.mysensors.org/topic/284/simple-temp-light-time-setup-with-lcd-1-4-no-beta-anymore
                                        Time currently is being pushed every minute by the device created on the controller to "the display" (It has no RTC now). When it fails to receive the new time it would then be standing still. So it is nice to have without power failure.
                                        • JohnJ John
                                          ToSa
                                          Code Contributor
                                          @hek @John
                                          using the "time.h" library on the node the time will continue to run. It will not be very accurate (as accurate as the "millis" in arduino) which should be sufficient to turn off the water after 15 minutes (no matter if that's a few seconds off) and good enough to let the clock tick further unless the next successful submission is received from the controller.
                                          JohnJ 1 Reply Last reply
