  3. Battery powering
Battery powering
27 Posts 6 Posters 9.0k Views 4 Watching
  • CrankyCoderC CrankyCoder
    Happy Friday guys! Fighting with another node and hoping someone may have some thoughts. I have followed the battery powered guide.
    My little sensor does not want to run on 3v. Anyone have any luck running 2.0 on a 3v battery?
    F
    F
    flopp
    wrote on last edited by flopp
    @Jason-Brunk
    I don't use 2.0, yet, but I have a lot 1.5.1 running on battery without problem.
    Try to run your node with power from e.g. FTDI or other source, then you can see if it works and also if it sleeps.
    What I notice for some of my nodes is that it needs a new battery to work, when my CR2032 battery comes down to ~2,5 volt it stop working maybe because of the mA is to low from battery to power up NRF or ATmega.
    CrankyCoderC 1 Reply Last reply
    • YveauxY Yveaux
      @Jason-Brunk what arduino ide are you using? 1.6.10 seems to have issues in combination with MySensors.
      CrankyCoderC
      CrankyCoderC
      CrankyCoder
      @Yveaux I am using 1.6.9
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      • F flopp
        @Jason-Brunk
        CrankyCoderC
        CrankyCoderC
        CrankyCoder
        @flopp Just put a fresh battery in. Checked it before hand, 3.07v
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=1)
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        What capacitor size are you using on the radio? any use to put a cap on the main power/gnd between the battery and the rest of the circuit?
        www.CrankyCoder.net
        MySensors: 2.3
        F 2 Replies Last reply
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          F
          F
          flopp
          @Jason-Brunk
          I am using 4,7 uF SMD mounted on the NRF.
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            F
            F
            flopp
            @Jason-Brunk
            You can try with a cap on main pwr/gnd.
            Maybe you can measure the voltage on main pwr/gnd and see what happens when it starts?
            • F flopp
              @Jason-Brunk
              CrankyCoderC
              CrankyCoderC
              CrankyCoder
              @flopp i changed batteries and made sure i don't go below 2.6v and still the furthest i get is
              TSP▒Starting sensor (RNNNA-, 2.0.0)
              TSM:INIT
              TSM:RADIO:OK
              TSM:INIT
              TSM:RADIO:OK
              Looks like it is locking up as soon as the radio is initialized.
              www.CrankyCoder.net
              MySensors: 2.3
              F 1 Reply Last reply
                TSM:INIT
                TSM:RADIO:OK
                TSM:INIT
                TSM:RADIO:OK
                F
                F
                flopp
                @Jason-Brunk
                Do you have an other NRF, if you have try with that
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  yeah, this one works if i give it a 3.3v power source. But i can try my other one.
                  www.CrankyCoder.net
                  MySensors: 2.3
                  YveauxY F 3 Replies Last reply
                    @Jason-Brunk Do you know/did you change the brown-out level of your atmega? See BODLEVEL at e.g. http://cryoarchive.net/tutorials/avr-tutorials/avr-fuses-explained/
                    What Arduino hardware are we talking about?
                      F
                      F
                      flopp
                      • CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        Im using a 3.3v pro mini.
                        From what I gathered BOD level only affected the power down. Would it affect the power up and radio initialization?
                        www.CrankyCoder.net
                        MySensors: 2.3
                          F
                          F
                          flopp
                          Do you mean NRF?
                          NRF should work down to 1,9 volt
                          • F flopp
                            Do you mean NRF?
                            CrankyCoderC
                            CrankyCoderC
                            CrankyCoder
                            @flopp That is correct, everything registers ok and debug shows the connections when i give it 3.3v from my usb power supply
                            www.CrankyCoder.net
                            MySensors: 2.3
                              F
                              F
                              flopp
                              Then it can be bad battery.
                              Measure battery, should be about 3.1.
                              Connect something to the battery, like an LED, battery shall now show maybe 2.9, not lower. If it shows lower I guess the battery is almost empty.
                                How are you pwering it? Through RAW or VCC? Did you remove/disable the regulator?
                                • YveauxY Yveaux
                                  CrankyCoderC
                                  CrankyCoderC
                                  CrankyCoder
                                  @Yveaux VCC. Yeah i pulled the regulator off
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                    @Jason-Brunk Does it run stable without the nRF? E.g. disconnect nRF and simply print something to serial.
                                    • CrankyCoderC
                                      CrankyCoderC
                                      CrankyCoder
                                      tried to do the BOD fuse update. bricked a pro mini. grabbed another one. it took the updated boot loader.
                                      if i disconnect the radio it just loops
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      !TSM:RADIO:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      as you would expect.
                                      If i hook the radio up i get this.
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSP:Á
                                      I do still need to remove the regulator and led on this one. Not sure if that's the issue. I have also tried a brand new cr2032 battery
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                      • CrankyCoderC
                                        CrankyCoderC
                                        CrankyCoder
                                        So here is my latest. I modified the arduino pro mini. Changed the BOD fuse value and reburned the bootloader. I wired it all back up. Got it to register. I got 6 button presses where it sent the data. Now I am right back where it was.
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSP:ASSIGNID:Starting sensor (RNNNA-, 2.0.0)
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSP:ASS▒Starting sensor (RNNNA-, 2.0.0)
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        I am just not having much luck getting this to work via battery. I have a 100u capacitor on the radio.
                                        If anyone has any thoughts I am all ears. I kind of at a loss now. I am using the 2.0.0 release.
                                        www.CrankyCoder.net
                                        MySensors: 2.3
                                        • CrankyCoderC
                                          CrankyCoderC
                                          CrankyCoder
                                          More testing update:
                                          I tried 2 AA batteries. Which would be the same voltage, just more mah. 0 Issues. Using the battery monitor with the AA batteries it shows the voltage at about 2.84v
                                          When I hook a brand new cr2032 up though, I press the button and it shows voltage is already down to 2.48v. I have the BOD disabled (I believe) per the instructions to modify the boards.txt and reburn the bootloader.
                                          The batteries I have are energizer cr2032. I would think they are ok, but they could all be junk. I have tried 4 so far.
                                          www.CrankyCoder.net
                                          MySensors: 2.3
                                          m26872M 1 Reply Last reply
                                          12.5k
