  3. Battery powering
Battery powering
27 Posts 6 Posters 9.0k Views 4 Watching
  • F flopp
    @Jason-Brunk
    I don't use 2.0, yet, but I have a lot 1.5.1 running on battery without problem.
    Try to run your node with power from e.g. FTDI or other source, then you can see if it works and also if it sleeps.
    What I notice for some of my nodes is that it needs a new battery to work, when my CR2032 battery comes down to ~2,5 volt it stop working maybe because of the mA is to low from battery to power up NRF or ATmega.
    CrankyCoderC
    CrankyCoderC
    CrankyCoder
    @flopp Just put a fresh battery in. Checked it before hand, 3.07v
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    What capacitor size are you using on the radio? any use to put a cap on the main power/gnd between the battery and the rest of the circuit?
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    F 2 Replies Last reply
    • CrankyCoderC CrankyCoder
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      F
      F
      flopp
      @Jason-Brunk
      I am using 4,7 uF SMD mounted on the NRF.
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        F
        F
        flopp
        @Jason-Brunk
        You can try with a cap on main pwr/gnd.
        Maybe you can measure the voltage on main pwr/gnd and see what happens when it starts?
        CrankyCoderC 1 Reply Last reply
        • F flopp
          @Jason-Brunk
          CrankyCoderC
          CrankyCoderC
          CrankyCoder
          @flopp i changed batteries and made sure i don't go below 2.6v and still the furthest i get is
          TSP▒Starting sensor (RNNNA-, 2.0.0)
          TSM:INIT
          TSM:RADIO:OK
          TSM:INIT
          TSM:RADIO:OK
          Looks like it is locking up as soon as the radio is initialized.
          www.CrankyCoder.net
          MySensors: 2.3
          F 1 Reply Last reply
            TSM:INIT
            TSM:RADIO:OK
            TSM:INIT
            TSM:RADIO:OK
            F
            F
            flopp
            @Jason-Brunk
            Do you have an other NRF, if you have try with that
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              yeah, this one works if i give it a 3.3v power source. But i can try my other one.
              www.CrankyCoder.net
              MySensors: 2.3
              YveauxY F 3 Replies Last reply
                @Jason-Brunk Do you know/did you change the brown-out level of your atmega? See BODLEVEL at e.g. http://cryoarchive.net/tutorials/avr-tutorials/avr-fuses-explained/
                What Arduino hardware are we talking about?
                  F
                  F
                  flopp
                  • CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    Im using a 3.3v pro mini.
                    From what I gathered BOD level only affected the power down. Would it affect the power up and radio initialization?
                    www.CrankyCoder.net
                    MySensors: 2.3
                      F
                      F
                      flopp
                      Do you mean NRF?
                      NRF should work down to 1,9 volt
                      • F flopp
                        Do you mean NRF?
                        CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        @flopp That is correct, everything registers ok and debug shows the connections when i give it 3.3v from my usb power supply
                        www.CrankyCoder.net
                        MySensors: 2.3
                          F
                          F
                          flopp
                          Then it can be bad battery.
                          Measure battery, should be about 3.1.
                          Connect something to the battery, like an LED, battery shall now show maybe 2.9, not lower. If it shows lower I guess the battery is almost empty.
                            How are you pwering it? Through RAW or VCC? Did you remove/disable the regulator?
                            • YveauxY Yveaux
                              CrankyCoderC
                              CrankyCoderC
                              CrankyCoder
                              @Yveaux VCC. Yeah i pulled the regulator off
                              www.CrankyCoder.net
                              MySensors: 2.3
                                @Jason-Brunk Does it run stable without the nRF? E.g. disconnect nRF and simply print something to serial.
                                • CrankyCoderC
                                  CrankyCoderC
                                  CrankyCoder
                                  tried to do the BOD fuse update. bricked a pro mini. grabbed another one. it took the updated boot loader.
                                  if i disconnect the radio it just loops
                                  TSM:PDT
                                  TSM:INIT
                                  !TSM:RADIO:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  TSM:INIT
                                  !TSM:RADIO:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  TSM:INIT
                                  !TSM:RADIO:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  as you would expect.
                                  If i hook the radio up i get this.
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSP:Á
                                  I do still need to remove the regulator and led on this one. Not sure if that's the issue. I have also tried a brand new cr2032 battery
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                  • CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    So here is my latest. I modified the arduino pro mini. Changed the BOD fuse value and reburned the bootloader. I wired it all back up. Got it to register. I got 6 button presses where it sent the data. Now I am right back where it was.
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSP:ASSIGNID:Starting sensor (RNNNA-, 2.0.0)
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSP:ASS▒Starting sensor (RNNNA-, 2.0.0)
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    I am just not having much luck getting this to work via battery. I have a 100u capacitor on the radio.
                                    If anyone has any thoughts I am all ears. I kind of at a loss now. I am using the 2.0.0 release.
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                    • CrankyCoderC
                                      CrankyCoderC
                                      CrankyCoder
                                      More testing update:
                                      I tried 2 AA batteries. Which would be the same voltage, just more mah. 0 Issues. Using the battery monitor with the AA batteries it shows the voltage at about 2.84v
                                      When I hook a brand new cr2032 up though, I press the button and it shows voltage is already down to 2.48v. I have the BOD disabled (I believe) per the instructions to modify the boards.txt and reburn the bootloader.
                                      The batteries I have are energizer cr2032. I would think they are ok, but they could all be junk. I have tried 4 so far.
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                      m26872M 1 Reply Last reply
                                        m26872M
                                        m26872M
                                        m26872
                                        @Jason-Brunk I would try to put in a delay of the radio startup in the sketch. Maybe there's to much or fast simultaneous power consuption initially with respect to the coincell.
                                        • CrankyCoderC
                                          CrankyCoderC
                                          CrankyCoder
                                          Another quick update, seems to be making progress.
                                          I decided to try to flash a 1mhz boot loader onto my pro mini. Then reuploaded my switch sketch. So far it's looking good. Button presses are registering as expected. 2 things I have seen.
                                          1. i think i need to read up some more on changing clock speed. My sleep command should wake up and report battery level once an hour. This did not happen at all through the night.
                                          2. now that I am running at 1mhz when i tried to connect via serial for debugging using the default baudrate it was junk. I forced the baud rate to nice and slow, and it looked like that was going to do it. but no go.
                                          www.CrankyCoder.net
                                          MySensors: 2.3
                                          12.5k
