  3. Battery powering
Battery powering
27 Posts 6 Posters 9.0k Views 4 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    I am wondering if maybe the capacitor on my radio is too big while running off the coin cell.
    Here is what i am getting currently
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC CrankyCoder
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      @Jason-Brunk what arduino ide are you using? 1.6.10 seems to have issues in combination with MySensors.
      CrankyCoderC 1 Reply Last reply
        Happy Friday guys! Fighting with another node and hoping someone may have some thoughts. I have followed the battery powered guide.
        My little sensor does not want to run on 3v. Anyone have any luck running 2.0 on a 3v battery?
        F
        F
        flopp
        wrote on last edited by flopp
        @Jason-Brunk
        I don't use 2.0, yet, but I have a lot 1.5.1 running on battery without problem.
        Try to run your node with power from e.g. FTDI or other source, then you can see if it works and also if it sleeps.
        What I notice for some of my nodes is that it needs a new battery to work, when my CR2032 battery comes down to ~2,5 volt it stop working maybe because of the mA is to low from battery to power up NRF or ATmega.
        • YveauxY Yveaux
          CrankyCoderC
          CrankyCoderC
          CrankyCoder
          @Yveaux I am using 1.6.9
          www.CrankyCoder.net
          MySensors: 2.3
          • F flopp
            @Jason-Brunk
            CrankyCoderC
            CrankyCoderC
            CrankyCoder
            @flopp Just put a fresh battery in. Checked it before hand, 3.07v
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            What capacitor size are you using on the radio? any use to put a cap on the main power/gnd between the battery and the rest of the circuit?
            www.CrankyCoder.net
            MySensors: 2.3
            F 2 Replies Last reply
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              F
              F
              flopp
              @Jason-Brunk
              I am using 4,7 uF SMD mounted on the NRF.
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                F
                F
                flopp
                @Jason-Brunk
                You can try with a cap on main pwr/gnd.
                Maybe you can measure the voltage on main pwr/gnd and see what happens when it starts?
                • F flopp
                  @Jason-Brunk
                  CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  @flopp i changed batteries and made sure i don't go below 2.6v and still the furthest i get is
                  TSP▒Starting sensor (RNNNA-, 2.0.0)
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:INIT
                  TSM:RADIO:OK
                  Looks like it is locking up as soon as the radio is initialized.
                  www.CrankyCoder.net
                  MySensors: 2.3
                  F 1 Reply Last reply
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:INIT
                    TSM:RADIO:OK
                    F
                    F
                    flopp
                    @Jason-Brunk
                    Do you have an other NRF, if you have try with that
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      yeah, this one works if i give it a 3.3v power source. But i can try my other one.
                      www.CrankyCoder.net
                      MySensors: 2.3
                      YveauxY F 3 Replies Last reply
                        @Jason-Brunk Do you know/did you change the brown-out level of your atmega? See BODLEVEL at e.g. http://cryoarchive.net/tutorials/avr-tutorials/avr-fuses-explained/
                        What Arduino hardware are we talking about?
                          F
                          F
                          flopp
                          • CrankyCoderC
                            CrankyCoderC
                            CrankyCoder
                            Im using a 3.3v pro mini.
                            From what I gathered BOD level only affected the power down. Would it affect the power up and radio initialization?
                            www.CrankyCoder.net
                            MySensors: 2.3
                              F
                              F
                              flopp
                              Do you mean NRF?
                              NRF should work down to 1,9 volt
                              • F flopp
                                Do you mean NRF?
                                CrankyCoderC
                                CrankyCoderC
                                CrankyCoder
                                @flopp That is correct, everything registers ok and debug shows the connections when i give it 3.3v from my usb power supply
                                www.CrankyCoder.net
                                MySensors: 2.3
                                  F
                                  F
                                  flopp
                                  Then it can be bad battery.
                                  Measure battery, should be about 3.1.
                                  Connect something to the battery, like an LED, battery shall now show maybe 2.9, not lower. If it shows lower I guess the battery is almost empty.
                                    How are you pwering it? Through RAW or VCC? Did you remove/disable the regulator?
                                    • YveauxY Yveaux
                                      CrankyCoderC
                                      CrankyCoderC
                                      CrankyCoder
                                      @Yveaux VCC. Yeah i pulled the regulator off
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                        @Jason-Brunk Does it run stable without the nRF? E.g. disconnect nRF and simply print something to serial.
                                        • CrankyCoderC
                                          CrankyCoderC
                                          CrankyCoder
                                          tried to do the BOD fuse update. bricked a pro mini. grabbed another one. it took the updated boot loader.
                                          if i disconnect the radio it just loops
                                          TSM:PDT
                                          TSM:INIT
                                          !TSM:RADIO:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          !TSM:RADIO:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          !TSM:RADIO:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          as you would expect.
                                          If i hook the radio up i get this.
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSP:Á
                                          I do still need to remove the regulator and led on this one. Not sure if that's the issue. I have also tried a brand new cr2032 battery
                                          www.CrankyCoder.net
                                          MySensors: 2.3
                                          12.5k
