  3. Battery powering
Battery powering
27 Posts 6 Posters 9.0k Views 4 Watching
  • CrankyCoderC CrankyCoder
    @flopp Just put a fresh battery in. Checked it before hand, 3.07v
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=1)
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    What capacitor size are you using on the radio? any use to put a cap on the main power/gnd between the battery and the rest of the circuit?
    F
    F
    flopp
    @Jason-Brunk
    I am using 4,7 uF SMD mounted on the NRF.
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      F
      F
      flopp
      @Jason-Brunk
      You can try with a cap on main pwr/gnd.
      Maybe you can measure the voltage on main pwr/gnd and see what happens when it starts?
      CrankyCoderC 1 Reply Last reply
      • F flopp
        @Jason-Brunk
        CrankyCoderC
        CrankyCoderC
        CrankyCoder
        @flopp i changed batteries and made sure i don't go below 2.6v and still the furthest i get is
        TSP▒Starting sensor (RNNNA-, 2.0.0)
        TSM:INIT
        TSM:RADIO:OK
        TSM:INIT
        TSM:RADIO:OK
        Looks like it is locking up as soon as the radio is initialized.
        Home Automation Tinkerer
        www.CrankyCoder.net
        Gateway: MQTTClientGateway
        MySensors: 2.3
        F 1 Reply Last reply
          TSM:INIT
          TSM:RADIO:OK
          TSM:INIT
          TSM:RADIO:OK
          F
          F
          flopp
          @Jason-Brunk
          Do you have an other NRF, if you have try with that
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            yeah, this one works if i give it a 3.3v power source. But i can try my other one.
            www.CrankyCoder.net
            MySensors: 2.3
            YveauxY F 3 Replies Last reply
              @Jason-Brunk Do you know/did you change the brown-out level of your atmega? See BODLEVEL at e.g. http://cryoarchive.net/tutorials/avr-tutorials/avr-fuses-explained/
              What Arduino hardware are we talking about?
                F
                F
                flopp
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  Im using a 3.3v pro mini.
                  From what I gathered BOD level only affected the power down. Would it affect the power up and radio initialization?
                  www.CrankyCoder.net
                  MySensors: 2.3
                    F
                    F
                    flopp
                    Do you mean NRF?
                    NRF should work down to 1,9 volt
                    • F flopp
                      Do you mean NRF?
                      CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      @flopp That is correct, everything registers ok and debug shows the connections when i give it 3.3v from my usb power supply
                      www.CrankyCoder.net
                      MySensors: 2.3
                        F
                        F
                        flopp
                        Then it can be bad battery.
                        Measure battery, should be about 3.1.
                        Connect something to the battery, like an LED, battery shall now show maybe 2.9, not lower. If it shows lower I guess the battery is almost empty.
                          How are you pwering it? Through RAW or VCC? Did you remove/disable the regulator?
                          • YveauxY Yveaux
                            CrankyCoderC
                            CrankyCoderC
                            CrankyCoder
                            @Yveaux VCC. Yeah i pulled the regulator off
                            www.CrankyCoder.net
                            MySensors: 2.3
                              @Jason-Brunk Does it run stable without the nRF? E.g. disconnect nRF and simply print something to serial.
                              • CrankyCoderC
                                CrankyCoderC
                                CrankyCoder
                                tried to do the BOD fuse update. bricked a pro mini. grabbed another one. it took the updated boot loader.
                                if i disconnect the radio it just loops
                                TSM:PDT
                                TSM:INIT
                                !TSM:RADIO:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                TSM:INIT
                                !TSM:RADIO:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                TSM:INIT
                                !TSM:RADIO:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                as you would expect.
                                If i hook the radio up i get this.
                                TSM:INIT
                                TSM:RADIO:OK
                                TSP:Á
                                I do still need to remove the regulator and led on this one. Not sure if that's the issue. I have also tried a brand new cr2032 battery
                                www.CrankyCoder.net
                                MySensors: 2.3
                                • CrankyCoderC
                                  CrankyCoderC
                                  CrankyCoder
                                  So here is my latest. I modified the arduino pro mini. Changed the BOD fuse value and reburned the bootloader. I wired it all back up. Got it to register. I got 6 button presses where it sent the data. Now I am right back where it was.
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSP:ASSIGNID:Starting sensor (RNNNA-, 2.0.0)
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSP:ASS▒Starting sensor (RNNNA-, 2.0.0)
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  I am just not having much luck getting this to work via battery. I have a 100u capacitor on the radio.
                                  If anyone has any thoughts I am all ears. I kind of at a loss now. I am using the 2.0.0 release.
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                  • CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    More testing update:
                                    I tried 2 AA batteries. Which would be the same voltage, just more mah. 0 Issues. Using the battery monitor with the AA batteries it shows the voltage at about 2.84v
                                    When I hook a brand new cr2032 up though, I press the button and it shows voltage is already down to 2.48v. I have the BOD disabled (I believe) per the instructions to modify the boards.txt and reburn the bootloader.
                                    The batteries I have are energizer cr2032. I would think they are ok, but they could all be junk. I have tried 4 so far.
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                    m26872M 1 Reply Last reply
                                      m26872M
                                      m26872M
                                      m26872
                                      @Jason-Brunk I would try to put in a delay of the radio startup in the sketch. Maybe there's to much or fast simultaneous power consuption initially with respect to the coincell.
                                      • CrankyCoderC
                                        CrankyCoderC
                                        CrankyCoder
                                        Another quick update, seems to be making progress.
                                        I decided to try to flash a 1mhz boot loader onto my pro mini. Then reuploaded my switch sketch. So far it's looking good. Button presses are registering as expected. 2 things I have seen.
                                        1. i think i need to read up some more on changing clock speed. My sleep command should wake up and report battery level once an hour. This did not happen at all through the night.
                                        2. now that I am running at 1mhz when i tried to connect via serial for debugging using the default baudrate it was junk. I forced the baud rate to nice and slow, and it looked like that was going to do it. but no go.
                                        www.CrankyCoder.net
                                        MySensors: 2.3
                                        • Nca78N
                                          Hello I gave you some tips for button cell on your other thread.
                                          In addition: if you are using interrupts only then your power consumption should be extremely low, I don't think it's necessary to wake up regularly to send battery level.
                                          If you don't do it then then you have even lower consumption because the watchdog timer is turned off, my CR2032 door/windows nodes using the sleep method from MySensors draws less than 2uA, there can be no visible change in battery level except if you leave your node in a closet for one year ;)
                                          12.5k
