  3. 💬 AC-DC double solid state relay module
hlk-pm01solid state relaylight switchlightacdc
226 Posts 67 Posters 170.5k Views 65 Watching
  • scalzS scalz
    @tonnerre33 yep. you're right, it's cms I'm sorry :disappointed: I think.. good luck to fit everything with arduino mini in wall.
    About the cutoff, I replaced this by a simple temperature sensor for monitoring. imho, i have two fuses onboards + varistor, enough for me comparing to some commercial products. If it burns you have a big problem somewhere!! But sure it's better to know what you do, thermal fuses is good ;)
    tonnerre33T
    tonnerre33T
    tonnerre33
    @scalz don't be sorry, i just need to learn to weld cms xd But for not disturb this project, i'll continue ta ask my questions in your topic project ;)
    • Nca78N
      @tonnerre33 said:
      But for command up/down, and in order to do an hardware protection, we can use an inversor relay.
      I don't know if we need an inversor relay. For sure it will be hard to find another relay as small as these SSRs
      Maybe I'm wrong but I from what I know roller shutter motors have a common ground and then you connect the phase for the direction you want to use. I think it can be done in software, with hardware it cannot be done on this PCB because of the way the SSRs are connected.
      @scalz on your board you use relays that are much bigger than those tiny SSRs, in the end it probably gives the same result for the space used on the board, and as you have the radio on the other side the depth difference is not very big, just 2mm from the plastic at the base of the connectors.
      • okosO
        okosO
        okos
        wrote on last edited by okos
        #54
        Hi I did everything according to the project and I have problem "error sending the switch command check device / hardware"
        One change for me is 10nF capacitor instead of 100nF (I dont have now
        Could this be the reasons this error?!
        Nca78N 1 Reply Last reply
        • okosO okos
          wrote on last edited by Nca78
          #55
          @okos if you have the device in Domoticz it means it could run, and send data to the gateway controller.
          Did you change anything in hardware of software between the moment you added the node/sensor to Domoticz and the moment you tried to activate it ?
          Are you sure your settings for the ACK are ok ? Maybe you are not sending one in the node but waiting from one in Domoticz ? Check the "Ack" column in Domoticz and if it's true try to change it to false.
          okosO 1 Reply Last reply
            Matt
            wrote on last edited by Matt
            #56
            Aproxx you roxx. It works! Not sure what to do with it yet, but likely it will end up in a wall sometime soon on light duties. Thanks for sharing such a great design :-)
            Hmm just pulled some switches, they are mostly SPDT jobbies on multiple switches, no idea how to hood this bad-boy up =(
            • Daniel OliveiraD
              Daniel OliveiraD
              Daniel Oliveira
              Hi everyone,
              First I would like to thank the OP for sharing this great project :)
              Then I would like to ask what would happen if the node cannot connect to the gateway on startup? It would still be possible to use the switch?
              Thank you,
              MySensors rules my home :)
              • Daniel OliveiraD Daniel Oliveira
                Hi everyone,
                Thank you,
                #58
                Hello, on startup if it cannot connect to gateway MySensors library will loop until it connects, so no. But once started as you have direct connection to the switch it will work even if the gateway fails.
                Daniel OliveiraD 1 Reply Last reply
                • Nca78N Nca78
                  Daniel OliveiraD
                  Daniel OliveiraD
                  Daniel Oliveira
                  @Nca78 Thank you for the reply,
                  There is a way to overcame that? Like add a max retry of sorts? My concern is that if by some reason the gateway fails and the node reboots I will not be able use the switch.
                  Or does MySensors have another fail safe mechanism that I'm not aware?
                  • Nca78N
                    No that I know.
                    But this situation is really unlikely, nodes are very stable usually (else you'll quickly see a problem). Basically you would need the gateway to fail, then a power outage to reboot your node.
                    • Nca78N Nca78
                      okosO
                      okosO
                      okos
                      Thanks for the answer :smiley: Nca78, but I do not know where to look for settings Ack.
                      Please help
                      • okosO okos
                        Please help
                        @okos go to Setup menu / Hardware, then click on the "Setup" button for your MySensors gateway.
                        In the top list select the node, and in the bottom you will see the sensors attached to this node, and a Ack column for each sensor. To edit the ack column just select item and you have the checkbox below the grid with update button.
                        • Nca78N Nca78
                          okosO
                          okosO
                          okos
                          #63
                          • Nca78N
                            First board soldered and tested, it runs very well, thank you for the great work @aproxx !
                            Thank you @Konstantin-Kolesnichenko also for adapting the script to version 2.0.
                            I just didn't dare to install the ds18b20, the tiny distance to the temp fuse pad gives me some nightmares :cold_sweat: so I prefer having no temperature sensor and put a piece of insulating tape on both sides.
                            This one will go in the ceiling, but for next board I will keep the vcc pin of the NRF24 and change a bit the code to use touch sensors behind a livolo glass plate. I need some top level WAF before I can go on with the MySensorization of all the appartment :D
                            0_1471537898596_SSR_Relay_Board.jpg (like the others I will not show the back side and it's ugly pieces of insulating tape :D)
                            @okos did you fix your problem ? I see your deleted message.
                            • Nca78N Nca78
                              okosO
                              okosO
                              okos
                              #65
                              Now everything is ok.
                              Nrf changed, and changed the position of the gate (it is now above - on the fridge :))
                              But I have another problem
                              I used the code from Konstantin Kolesnichenko (thanks), and even after the power is changing relay.
                              Example:
                              on relay 1
                              off Relay 2
                              turn off the power, and after power returning I
                              on relay 2
                              off Relay 1
                              Why exchange ?
                              • okosO okos
                                Example:
                                on relay 1
                                off Relay 2
                                on relay 2
                                off Relay 1
                                Why exchange ?
                                @okos I will try to do more tests tomorrow to see if I have the same problem. I see no obvious mistake in the script that would generate this though. The only thing I see would be if you have linked your module with physical switches and they are in different position. As the script assumes that at startup the buttons are in "off" position (circuit opened).
                                I think we should have this code at the end of the setup() method to initialize the oldValue and oldValue2 variables.
                                  debouncer.update();
                                  debouncer2.update();
                                  oldValue = debouncer.read();
                                • Nca78N
                                  @okos I confirm to you that without the change in my previous message, I had a similar problem (relay 1 always on and relay 2 always off at startup). After applying the change I don't have any problem on restart, it was just an initialization problem.
                                  I'm making some small improvements to the sketch, I will test tomorrow and post it.
                                  • okosO
                                    okosO
                                    okos
                                    Thanks Nca78, I'm waiting for a revised code
                                    • Nca78N
                                      this is the updated code, the list of changes at the top of the script.
                                      In short :
                                      • fixed initialization of hardware buttons
                                      • improved debug information
                                      • made temperature sensor optional (via a #define) as I think it's location on the board is not safe
                                      I think the behavior of the node is fine now, it has debug for physical buttons and the script uses less program space (<12k, <8k if temp sensor is disabled: you can enable debug even with an old atmega168 pro mini :)) and less ram (514 bytes for global variables).
                                      I added the temp sensor on my first board to make some tests, it's in the ceiling now in a big (10x10cm) but air-tight electric box. Both relays are switched off at the moment and I'm waiting for the temperature to stabilize, then I will try to switch the loads on and off, leave on for a long time etc etc. 28W light tube on first relay, 2x28W on the other, it should not create problem.
                                       *  HISTORY :
                                      // MySensor Debug
                                      //#define MY_REPEATER_FEATURE
                                      #define RELAY_PIN_2  5
                                      #define BUTTON_PIN_2 7
                                      #define CHILD_ID 11 // Id of the sensor child for 1st relay
                                      #define CHILD_ID_2 12 // Id of the sensor child for 2nd relay
                                      // Relay status
                                      #define RELAY_ON 1
                                      #define RELAY_OFF 0
                                      #ifdef USE_TEMP_SENSOR
                                      #include <OneWire.h>
                                      #define ONE_WIRE_BUS 8
                                      #define TEMPERATURE_ROUNDING 10.f   // Change value to change rounding of temperature value: 10.f for 0.1°C change, 5.f for 0.2°C change, 2.f for 0.5°C change
                                      Bounce debouncer = Bounce();
                                      int oldValue;
                                      bool state;
                                      Bounce debouncer2 = Bounce();
                                      int oldValue2;
                                      bool state2;
                                        present(CHILD_ID, S_LIGHT);
                                        present(CHILD_ID_2, S_LIGHT);
                                        sensors.begin();
                                        // Setup the button
                                        pinMode(BUTTON_PIN, INPUT);
                                        // Activate internal pull-up
                                        // Setup the button
                                        pinMode(BUTTON_PIN_2, INPUT);
                                        debouncer.attach(BUTTON_PIN);
                                        debouncer.interval(5);
                                        debouncer2.interval(5);
                                        debouncer.update();
                                        pinMode(RELAY_PIN, OUTPUT);
                                        pinMode(RELAY_PIN_2, OUTPUT);
                                        state = loadState(CHILD_ID);
                                        static float prevTemp = 0;
                                        debouncer.update();
                                        // Get the update value
                                        int value = debouncer.read();
                                        if (value != oldValue) {
                                        oldValue = value;
                                        if (value2 != oldValue2) {
                                        oldValue2 = value2;
                                      #ifdef MY_DEBUG
                                          prevTemp = temperature;
                                        if (message.isAck()) {
                                      #ifdef MY_DEBUG
                                          // Change relay state
                                          state = message.getBool();
                                          // Store state in eeprom
                                          saveState(CHILD_ID, state);
                                          state2 = message.getBool();
                                      // Set status of a relay pin
                                      #ifdef MY_DEBUG
                                        Serial.print(F(", Sensor="));
                                        Serial.print(sensorID);
                                        Serial.println(value);
                                      Z 1 Reply Last reply
                                      • Nca78N
                                        Temperature stabilized, but module became irresponsive. Switched on then off, it lit up but didn't appear in Domoticz log. Then after some time the power light of the arduino went off. Slow blow fuse is dead :(
                                        When I power the arduino through the programmer everything is fine, so I suppose the HLK died
                                        • Nca78N Nca78
                                          okosO
                                          okosO
                                          okos
                                          #71
                                          @Nca78
                                          You check out what's happened? My plate at the moment is working without a problem and the temperature in the box 35°C (bulb 40W)
                                          But on the new board my domoticz does detect ds18b20 and I think the problem may be inaccurate soldering DS18B20 because it is a very small gap between the legs.
                                          What do you think?
