  3. Dallas Temp failure to compile
23 Posts 11 Posters 10.0k Views 10 Watching
  • chrilleC
    chrilleC
    chrille
    I created an issue on this - https://github.com/mysensors/Arduino/issues/297
    • T
      tuspam
      Any news?
      • NickBuilderN
        NickBuilderN
        NickBuilder
        I'm also having this problem. Doesn't matter if I downgrade to a previous version of DallasTemperature.
        Any progress on this or advice on how to solve this?
        The issue seems to be closed, strange...
        • J
          J
          Justin Rich
          I was having way too many problems with the radios and code so I gave up and started to use beagle bone and just use domoticz api
          • tlpeterT
            tlpeterT
            tlpeter
            wrote on last edited by tlpeter
            Is there any resolution for this?
            I am facing the same problem and i do not know how to fix this.
            Edit, i found something.
            You need to comment out these lines:
            Only this way it compiles and sensors do work.
            I don't know what happens so maybe somebody with knowledge can explain this?
            //int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
              //sleep(conversionTime);```
            Nca78N HonkH Boots33B 3 Replies Last reply
            • tlpeterT tlpeter
              If you do that you don't leave enough time for your sensor to compute the temperature, your readings will be wrong.
              There is no problem with MySensors 2, and examples + libraries downloaded from MySensors' GitHub, I just tried and it builds.
              Go there: https://github.com/mysensors/
              Then select "MySensorsArduinoExamples" and download. Then you can copy the libraries directory in your arduino directory (you can override existing files), and the examples directory in [Arduino directory]\libraries\MySensors\ it will override old examples if they are already here.
              • tlpeterT tlpeter
                HonkH
                HonkH
                Honk
                @tlpeter
                This is my function to read all Sensors. You have to give the Sensor time to do the measuring and make the result available.
                I've commented everything out to get the min wait time. It is defined in the Datasheet of the Sensor
                If you wait or sleep for 750ms you are save. Depending on the resultion of the sensor you can wait a bit less.
                void readDallasSensors()
                  TempSensors.requestTemperatures();
                  //int16_t conversionTime = TempSensors.millisToWaitForConversion(TempSensors.getResolution());
                  sleep(750);
                  for (int i = 0; i < numTempSensors && i < MAX_ATTACHED_DS18B20; i++)
                    float temperature = TempSensors.getTempCByIndex(i);
                #ifdef DEBUG
                    SPrint(Temperature: );
                    Serial.println(temperature, 1);
                    if (abs(lastTemperature[i] - temperature) >= 0.1 && temperature != -127.00 && temperature != 85.00)
                      send(msg.setSensor(i).set(temperature, 1));
                      lastTemperature[i] = temperature;
                tlpeterT 1 Reply Last reply
                • tlpeterT
                  tlpeterT
                  tlpeter
                  It does not compile an di am not the only one saying that.
                  See this error:
                  Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
                  In file included from C:\Users\Peter\AppData\Local\Temp\arduino_modified_sketch_224748\DallasTemperatureSensor.ino:37:0:
                  C:\Users\Peter\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h: In function 'void loop()':
                  C:\Users\Peter\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:252:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
                       int16_t millisToWaitForConversion(uint8_t);
                  DallasTemperatureSensor:81: error: within this context
                  exit status 1
                  within this context
                  • HonkH Honk
                    @tlpeter
                      sleep(750);
                    #ifdef DEBUG
                    tlpeterT
                    tlpeterT
                    tlpeter
                    @Hermann-Kaiser said:
                    @tlpeter
                      sleep(750);
                    #ifdef DEBUG
                    That indeed works but still the example has some kind of an error or is not good enough for beginners like me :-)
                    Thanks, this works fine.
                    • tlpeterT tlpeter
                      Boots33B
                      Boots33B
                      Boots33
                      wrote on last edited by Boots33
                      @tlpeter yes there seems to be a problem once you update the library. Even if you roll back the problem persists. If you want to use the MySensors Dallas temp sketch as it is then you need to manually replace the library with the older 3.7.2 and then it will work.
                      I have uploaded the library in zip format. @hek I hope that it is OK to upload zip files
                      0_1470911411126_DallasTemperature.zip
                      • Nca78N
                        You are using an old version of the library, if you get the library from MySensors GitHub then the method is not private (like in the current version of the library you use) and it will compile.
                        • tlpeterT
                          tlpeterT
                          tlpeter
                          Thanks, that works fine.
                          How come that i have an old library? i use the 2.0.0 version
                          Is this perhaps a known issue which will be fixed soon?
                          Nca78N 1 Reply Last reply
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            It's not related to mysensors core library.
                            Also, as mentioned before in this thread, the Dallas library that is in the arduino examples repository, is working.
                            Are you sure that you are using the right libraries?
                            • tlpeterT
                              tlpeterT
                              tlpeter
                              I tihnk so, i used libraries that i was pointed too as they are moved.
                              All other sensors i have been playing with are working fine.
                              • tlpeterT tlpeter
                                @tlpeter it is because now the libraries which are not managed by MySensors project were moved to another repository. It means if you only updated MySensors, you kept the old libraries.
                                • tlpeterT
                                  tlpeterT
                                  tlpeter
                                  I removed everything and started from scratch and after that i copied the mysensors-master library.
                                  • tlpeterT tlpeter
                                    "removed everything" in MySensors directory ? That's not enough, as the third party libraries are in the libraries directory of Arduino
                                    • tlpeterT
                                      tlpeterT
                                      tlpeter
                                      I uninstalled that too.
                                      I really removed everything.
                                      Uninstalled arduino and removed the folders in the program files folder and the my documents folder too.
                                      • HonkH
                                        HonkH
                                        Honk
                                        why not put the function millisToWaitForConversion into the example.
                                        I like to have the latest libary available for sensors. It can be loaded with the arduino studio.
                                        Read the min wait time is pretty easy. it is just a switch case based on the datasheet.
                                        // returns number of milliseconds to wait till conversion is complete (based on IC datasheet)
                                        int16_t DallasTemperature::millisToWaitForConversion(uint8_t bitResolution)
                                            switch (bitResolution)
                                            case 9:
                                                return 94;
                                            case 10:
                                                return 188;
                                            case 11:
                                                return 375;
                                            default:
                                                return 750;
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @tlpeter
                                          Ok, so you are using a newer version of the DallasTemperature library, than the one that we have supplied in our MySensorsArduinoExamples. And yes, it seems that they have made millisToWaitForConversion() a private function there. Or someone has changed the library we included in our repository at some point in time, so it is made public.
                                          There are 2 options, as I see it :)
                                          1. Use the library that we have supplied in MySensorsArduinoExamples
                                          2. Make a PR against the original library, found here, and make the millisToWaitForConversion() public, and get them to release a new version of the library.
