  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • T timropp
    Well that didn't go well... assembling my first micro. Soldered on some pins for the FTDI connection, added power (2xAA holder), and soldered on the radio with cap. Then I put in batteries and brought up my domoticz page to see if it showed up. Started to smell something, looked down, and there's smoke coming from the battery holder. Grabbed the whole thing and yanked the wire free then dropped it in the sink. Not sure where I screwed up, but I sure shorted something!
    alexsh1A
    alexsh1A
    alexsh1
    @timropp sounds like you shorted batteries somewhere
    • T
      timropp
      Nope, didn't find the problem. Must be some solder that shorted the batteries out but I don't see it. Oh well... main problem is that was my only 2AA holder on hand, and it melted right through the end of it, so now I have to wait on more before I can try again. Bummer :)
      VeraEdge UI7 with Mysensors ethernet gateway
      • alexsh1A
        alexsh1A
        alexsh1
        You can feed it with just two wires connected to the USB FTDI TTL converter / programmer - have a look at this https://www.mysensors.org/hardware/micro
        Available Pins - GND, GND, VCC (on the right)
          mvader
          I am having an odd issue with one of my sensebender boards.
          I have flashed 5 in a row, same sketch, same everything.
          all look fine (and in english) in the serial monitor. but this one board displays different.
          it does seem to work. but i can't figure out why it's showing up different in the monitor.
          any ideas?
          Óåîóåâåîäåò Íéãòï Æ× 1.5óåîä: 2-2-0-0 ó=255,ã=0,ô=17,ðô=0,ì=3,óç=0,óô=ïë:1.5
          óåîä: 2-2-0-0 ó=255,ã=3,ô=6,ðô=1,ì=1,óç=0,óô=ïë:0
          óåîóïò óôáòôåä, éä=2, ðáòåîô=0, äéóôáîãå=1
           - Ïîìéîå!
          óåîä: 2-2-0-0 ó=255,ã=3,ô=11,ðô=0,ì=17,óç=0,óô=ïë:Óåîóåâåîäåò Íéãòï
          óåîä: 2-2-0-0 ó=255,ã=3,ô=12,ðô=0,ì=3,óç=0,óô=ïë:1.5
          óåîä: 2-2-0-0 ó=1,ã=0,ô=6,ðô=0,ì=0,óç=0,óô=ïë:
          óåîä: 2-2-0-0 ó=2,ã=0,ô=7,ðô=0,ì=0,óç=0,óô=ïë:
          óåîä: 2-2-0-0 ó=3,ã=0,ô=1,ðô=0,ì=0,óç=0,óô=ïë:
          óåîä: 2-2-0-0 ó=4,ã=0,ô=16,ðô=0,ì=0,óç=0,óô=ïë:
          éóÍåôòéã: 0
          ÔåíðÄéææ :174.85
          ÈõíÄéææ  :154.00
          Ô: 74.85
          È: 54
          óåîä: 2-2-0-0 ó=1,ã=1,ô=0,ðô=7,ì=5,óç=0,óô=ïë:74.8
          óåîä: 2-2-0-0 ó=2,ã=1,ô=1,ðô=2,ì=2,óç=0,óô=ïë:54
          óåîä: 2-2-0-0 ó=255,ã=3,ô=0,ðô=1,ì=1,óç=0,óô=ïë:97
          ÏÔÁ Æ× õðäáôå åîáâìåä
          óåîä: 2-2-0-0 ó=4,ã=1,ô=23,ðô=2,ì=2,óç=0,óô=ïë:99
          Ìéçèô: 99
          ÔåíðÄéææ :0.01
          ˆõíÄéææ  :0.00
          Ìéçèô: 99
          tbowmoT 1 Reply Last reply
          • M mvader
            any ideas?
             - Ïîìéîå!
            éóÍåôòéã: 0
            ÔåíðÄéææ :174.85
            ÈõíÄéææ  :154.00
            Ô: 74.85
            È: 54
            Ìéçèô: 99
            ÔåíðÄéææ :0.01
            ˆõíÄéææ  :0.00
            Ìéçèô: 99
            tbowmoT
            tbowmoT
            tbowmo
            @mvader
            What baudrate are you using? It seems like it's to much off, for the ftdi to decode it correctly. Have you tried to lower it to, let's say 9600 baud? And does it still do this?
            • tbowmoT tbowmo
              @mvader
              mvader
              @tbowmo said:
              @mvader
              I have not tried 9600, but i've done 5 today all the same code.. no problems.
              i have 4 others deployed from when i first bought these (when they came out) same code for them as well..
              could be a bum board..idk. when i fired it up, i could see it in the controller software though. so it does seem to work. it just gives me that in the serial monitor.. strange for sure :) I'll let you know how 9600 works out.
              AnticimexA 1 Reply Last reply
              • M mvader
                @tbowmo said:
                @mvader
                AnticimexA
                AnticimexA
                Anticimex
                @mvader what baffles me is that numbers seem to encode ok but alphabetical characters do not. You don't use some exotic ascii encoding in your terminal? (not likely if you can switch to a different SenseBender and get sane output I suppose)
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @mvader
                  115200 is on the edge of what is possible with the 8Mhz that the sensebender is using. And it's a uncalibrated RC oscillator that's in use. So this one might be a bit off to the lower side (run 7.5Mhz for example) which could throw off your serial port a bit.
                  (But as @Anticimex mentions, it does look weird that the numbers are readable..)
                  • tbowmoT tbowmo
                    @mvader
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @tbowmo @mvader it can still be a timing problem. Numbers in the ascii table have the most significant bits zero (they are in the range 0x3x and below) and since regular UART protocols transmit lsb first, the first bits may be within legal timing while the later bits are not, so the higher the ascii value, the higher the risk for corruption.
                    • FotoFieberF
                      FotoFieberF
                      FotoFieber
                      Playing with 2.0 I wanted to upgrade my sensebenders but I didn't find the sketch (neither in the main distribution nor in the examples folder).
                      Is there a version 2.0 compatible sketch?
                        Yep, it was moved to the Sensebender repo during the 2.0 release:
                        https://github.com/mysensors/SensebenderMicro/blob/master/Arduino/SensebenderMicro/SensebenderMicro.ino
                        • FotoFieberF FotoFieber
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @FotoFieber it is low located in the SenseBender repo in GitHub
                          • AnticimexA Anticimex
                            FotoFieberF
                            FotoFieberF
                            FotoFieber
                            @Anticimex
                            Thx. This is an old version. I found a newer on my hard drive (old development branch). As I do only need temp/hum, I reduced the sketch and it is working fine.
                              @Anticimex
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @FotoFieber @tbowmo isn't the one in the SenseBender repo supposed to be the latest&greatest?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Anticimex @FotoFieber
                                Yup, it was moved over from development branch on the release night. So should be the latest and greatest
                                • J
                                  J
                                  jovo
                                  Hi!
                                  I am in process of upgrading my Sensebenders to V2.0 and like to enable the OTA function.
                                  Who can give me some pointers on the capabilities of OTA for this Sensebender Micro board?
                                  I know that has external flash for this purpose, but i am stuggling a bit finding how to use it.
                                  So I am keen to read information on dependencies of the Sensebender sketch as well as the controller options.
                                  My environment:
                                  6x Sensebender
                                  Wifi based Gateway
                                  Domoticz as controller
                                  Things I like to know:
                                  • Is my sensebender shipped with optiboot bootloader? (have them about 1 year now)?
                                  • do i require special Gateway software? (i noticed a sketch called something like GatewayESP8266OTA)
                                  • what can i expect from Domoticz? probably not much, so do i need to connect to another controller (e.g. MYSController) to perform an update?
                                  • What controller is advised for the standard bootloader (optiboot bootloader)?
                                  I am sure those things are discussed in the past, but I was unable to find it.
                                  Would be great if somebody can share a howto or wiki on this topic.
                                  thanks in advance
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @jovo
                                    Sensebender is delivered with "DualOptiboot" which uses the external flash.
                                    To enable OTA with 2.0.0, you have to compile your sketches with
                                    #define MY_OTA_FIRMWARE_FEATURE
                                    enabled. For controller / Gateway, you need something else than domoticz. I haven't tried OTA firmware upgrades myself yet, so I do not have any experience with what works, and what doesn't work, other than the fact that domoticz doesn't support OTA..
                                    TheoLT 1 Reply Last reply
                                    • tbowmoT tbowmo
                                      @jovo
                                      TheoLT
                                      TheoLT
                                      TheoL
                                      Today I soldered the headers to a new sensebender and try to start it. I've uploaded the 2.0 example but it can't find the gateway:
                                      Started
                                      Starting sensor (RNONA-, 2.0.0)
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      My other sense benders worked flawelessly. But this one can't communicate. Does anyone have any idea, what might be wrong?
                                      alexsh1A Q 2 Replies Last reply
                                      • TheoLT TheoL
                                        Started
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @TheoL I have exactly the same issue with one of the nodes though not the sensebender.
                                        All other nodes work just fine.
                                        Take a look:
                                        https://forum.mysensors.org/topic/4723/tsp-chkupl-fail
                                        • TheoLT TheoL
                                          Started
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          Q
                                          Q
                                          Qu3Uk
                                          @TheoL I had this problem last night, its unable to find the parent/gateway. I ended up swapping out the radio with one I'd extended the antenna on and it worked. I then attached a piece of wire to the original radio and that was worked too. I put it down to knock off components.
                                          I think there is a video detailing the correct length etc.
