  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • J johnr
    I wonder if anyone modified the original sensebender sketch to include a door sensor?
    Do you need a pullup? If you have a sketch somewhere I would be happy if you could send/post it, as I have problem finding time to code right now.
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @johnr
    Here's one for a button, but shouldn't matter:
    https://forum.mysensors.org/topic/2887/sensebender-micro-button/2
    • J johnr
      alexsh1A
      alexsh1A
      alexsh1
      @johnr This is easy.
      // PIN = 2 or 3 only
      void setup {
        pinMode(PIN,INPUT);
        digitalWrite(PIN,HIGH);
      This activates internal pull-up.
      The sensebender has got pinout of Pro Mini
      • T
        timropp
        Well that didn't go well... assembling my first micro. Soldered on some pins for the FTDI connection, added power (2xAA holder), and soldered on the radio with cap. Then I put in batteries and brought up my domoticz page to see if it showed up. Started to smell something, looked down, and there's smoke coming from the battery holder. Grabbed the whole thing and yanked the wire free then dropped it in the sink. Not sure where I screwed up, but I sure shorted something!
        VeraEdge UI7 with Mysensors ethernet gateway
        alexsh1A 1 Reply Last reply
          :scream: Did you find the problem?
          • T timropp
            alexsh1A
            alexsh1A
            alexsh1
            @timropp sounds like you shorted batteries somewhere
            • T
              timropp
              Nope, didn't find the problem. Must be some solder that shorted the batteries out but I don't see it. Oh well... main problem is that was my only 2AA holder on hand, and it melted right through the end of it, so now I have to wait on more before I can try again. Bummer :)
              • alexsh1A
                alexsh1A
                alexsh1
                You can feed it with just two wires connected to the USB FTDI TTL converter / programmer - have a look at this https://www.mysensors.org/hardware/micro
                Available Pins - GND, GND, VCC (on the right)
                  mvader
                  I am having an odd issue with one of my sensebender boards.
                  I have flashed 5 in a row, same sketch, same everything.
                  all look fine (and in english) in the serial monitor. but this one board displays different.
                  it does seem to work. but i can't figure out why it's showing up different in the monitor.
                  any ideas?
                  Óåîóåâåîäåò Íéãòï Æ× 1.5óåîä: 2-2-0-0 ó=255,ã=0,ô=17,ðô=0,ì=3,óç=0,óô=ïë:1.5
                  óåîä: 2-2-0-0 ó=255,ã=3,ô=6,ðô=1,ì=1,óç=0,óô=ïë:0
                  óåîóïò óôáòôåä, éä=2, ðáòåîô=0, äéóôáîãå=1
                   - Ïîìéîå!
                  óåîä: 2-2-0-0 ó=255,ã=3,ô=11,ðô=0,ì=17,óç=0,óô=ïë:Óåîóåâåîäåò Íéãòï
                  óåîä: 2-2-0-0 ó=255,ã=3,ô=12,ðô=0,ì=3,óç=0,óô=ïë:1.5
                  óåîä: 2-2-0-0 ó=1,ã=0,ô=6,ðô=0,ì=0,óç=0,óô=ïë:
                  óåîä: 2-2-0-0 ó=2,ã=0,ô=7,ðô=0,ì=0,óç=0,óô=ïë:
                  óåîä: 2-2-0-0 ó=3,ã=0,ô=1,ðô=0,ì=0,óç=0,óô=ïë:
                  óåîä: 2-2-0-0 ó=4,ã=0,ô=16,ðô=0,ì=0,óç=0,óô=ïë:
                  éóÍåôòéã: 0
                  ÔåíðÄéææ :174.85
                  ÈõíÄéææ  :154.00
                  Ô: 74.85
                  È: 54
                  óåîä: 2-2-0-0 ó=1,ã=1,ô=0,ðô=7,ì=5,óç=0,óô=ïë:74.8
                  óåîä: 2-2-0-0 ó=2,ã=1,ô=1,ðô=2,ì=2,óç=0,óô=ïë:54
                  óåîä: 2-2-0-0 ó=255,ã=3,ô=0,ðô=1,ì=1,óç=0,óô=ïë:97
                  ÏÔÁ Æ× õðäáôå åîáâìåä
                  óåîä: 2-2-0-0 ó=4,ã=1,ô=23,ðô=2,ì=2,óç=0,óô=ïë:99
                  Ìéçèô: 99
                  ÔåíðÄéææ :0.01
                  ˆõíÄéææ  :0.00
                  Ìéçèô: 99
                  tbowmoT 1 Reply Last reply
                  • M mvader
                    any ideas?
                     - Ïîìéîå!
                    éóÍåôòéã: 0
                    ÔåíðÄéææ :174.85
                    ÈõíÄéææ  :154.00
                    Ô: 74.85
                    È: 54
                    Ìéçèô: 99
                    ÔåíðÄéææ :0.01
                    ˆõíÄéææ  :0.00
                    Ìéçèô: 99
                    tbowmoT
                    tbowmoT
                    tbowmo
                    @mvader
                    What baudrate are you using? It seems like it's to much off, for the ftdi to decode it correctly. Have you tried to lower it to, let's say 9600 baud? And does it still do this?
                    • tbowmoT tbowmo
                      @mvader
                      mvader
                      @tbowmo said:
                      @mvader
                      I have not tried 9600, but i've done 5 today all the same code.. no problems.
                      i have 4 others deployed from when i first bought these (when they came out) same code for them as well..
                      could be a bum board..idk. when i fired it up, i could see it in the controller software though. so it does seem to work. it just gives me that in the serial monitor.. strange for sure :) I'll let you know how 9600 works out.
                      AnticimexA 1 Reply Last reply
                      • M mvader
                        @tbowmo said:
                        @mvader
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @mvader what baffles me is that numbers seem to encode ok but alphabetical characters do not. You don't use some exotic ascii encoding in your terminal? (not likely if you can switch to a different SenseBender and get sane output I suppose)
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @mvader
                          115200 is on the edge of what is possible with the 8Mhz that the sensebender is using. And it's a uncalibrated RC oscillator that's in use. So this one might be a bit off to the lower side (run 7.5Mhz for example) which could throw off your serial port a bit.
                          (But as @Anticimex mentions, it does look weird that the numbers are readable..)
                          • tbowmoT tbowmo
                            @mvader
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @tbowmo @mvader it can still be a timing problem. Numbers in the ascii table have the most significant bits zero (they are in the range 0x3x and below) and since regular UART protocols transmit lsb first, the first bits may be within legal timing while the later bits are not, so the higher the ascii value, the higher the risk for corruption.
                            • FotoFieberF
                              FotoFieberF
                              FotoFieber
                              Playing with 2.0 I wanted to upgrade my sensebenders but I didn't find the sketch (neither in the main distribution nor in the examples folder).
                              Is there a version 2.0 compatible sketch?
                                Yep, it was moved to the Sensebender repo during the 2.0 release:
                                https://github.com/mysensors/SensebenderMicro/blob/master/Arduino/SensebenderMicro/SensebenderMicro.ino
                                • FotoFieberF FotoFieber
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @FotoFieber it is low located in the SenseBender repo in GitHub
                                  • AnticimexA Anticimex
                                    FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    @Anticimex
                                    Thx. This is an old version. I found a newer on my hard drive (old development branch). As I do only need temp/hum, I reduced the sketch and it is working fine.
                                      @Anticimex
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @FotoFieber @tbowmo isn't the one in the SenseBender repo supposed to be the latest&greatest?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @Anticimex @FotoFieber
                                        Yup, it was moved over from development branch on the release night. So should be the latest and greatest
                                        • J
                                          J
                                          jovo
                                          Hi!
                                          I am in process of upgrading my Sensebenders to V2.0 and like to enable the OTA function.
                                          Who can give me some pointers on the capabilities of OTA for this Sensebender Micro board?
                                          I know that has external flash for this purpose, but i am stuggling a bit finding how to use it.
                                          So I am keen to read information on dependencies of the Sensebender sketch as well as the controller options.
                                          My environment:
                                          6x Sensebender
                                          Wifi based Gateway
                                          Domoticz as controller
                                          Things I like to know:
                                          • Is my sensebender shipped with optiboot bootloader? (have them about 1 year now)?
                                          • do i require special Gateway software? (i noticed a sketch called something like GatewayESP8266OTA)
                                          • what can i expect from Domoticz? probably not much, so do i need to connect to another controller (e.g. MYSController) to perform an update?
                                          • What controller is advised for the standard bootloader (optiboot bootloader)?
                                          I am sure those things are discussed in the past, but I was unable to find it.
                                          Would be great if somebody can share a howto or wiki on this topic.
                                          thanks in advance
