  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • HaakonH
    HaakonH
    Haakon
    Hi! I have just gotten four Sensebenders and was hoping to connect PIRs to them and powering them with AA batteries. I understand from the forums that people do this. But is there a working Arduino sketch example implementing a PIR for wake-up out there? (And perhaps there is a more detailed description for such a hardware setup for us newbies?)
    alexsh1A 1 Reply Last reply
    • T
      tomkxy
      I have bought another couple of sensebenders.
      I am not able to upload sketches to one of them.
      When I connect the programmer the status led goes to solid red. From another one, I realized that it is not solid red.
      What is the meaning of a solid red status LED?
        What does the log say when you upload?
        • HaakonH Haakon
          alexsh1A
          alexsh1A
          alexsh1
          @Haakon Have a look here - https://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
          Just change your board for sensebender.
          • T
            tomkxy
            @hek
            D -Uflash:w:/var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build8699526819198040594.tmp/SecurityPersonalizer.cpp.hex:i
                     User configuration file is "/Users/tom/.avrduderc"
                     Using Port                    : /dev/cu.usbserial-DA01IGTO
                     Overriding Baud Rate          : 57600
            avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
            avrdude: ser_recv(): read error: Device not configured
            Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload
            I have Sensebender selected as board.
            Btw, where is the hardware folder? It is not present anymore in the development branch?
              You can use the build in board manager nowadays.
              https://github.com/mysensors/ArduinoBoards
              Check board for solder bridges or anything suspicious.
              • J
                J
                johnr
                I wonder if anyone modified the original sensebender sketch to include a door sensor?
                Do you need a pullup? If you have a sketch somewhere I would be happy if you could send/post it, as I have problem finding time to code right now.
                martinhjelmareM alexsh1A 2 Replies Last reply
                • J johnr
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @johnr
                  Here's one for a button, but shouldn't matter:
                  https://forum.mysensors.org/topic/2887/sensebender-micro-button/2
                  • J johnr
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @johnr This is easy.
                    // PIN = 2 or 3 only
                    void setup {
                      pinMode(PIN,INPUT);
                      digitalWrite(PIN,HIGH);
                    This activates internal pull-up.
                    The sensebender has got pinout of Pro Mini
                    • T
                      timropp
                      Well that didn't go well... assembling my first micro. Soldered on some pins for the FTDI connection, added power (2xAA holder), and soldered on the radio with cap. Then I put in batteries and brought up my domoticz page to see if it showed up. Started to smell something, looked down, and there's smoke coming from the battery holder. Grabbed the whole thing and yanked the wire free then dropped it in the sink. Not sure where I screwed up, but I sure shorted something!
                      VeraEdge UI7 with Mysensors ethernet gateway
                        :scream: Did you find the problem?
                        • T timropp
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @timropp sounds like you shorted batteries somewhere
                          • T
                            timropp
                            Nope, didn't find the problem. Must be some solder that shorted the batteries out but I don't see it. Oh well... main problem is that was my only 2AA holder on hand, and it melted right through the end of it, so now I have to wait on more before I can try again. Bummer :)
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              You can feed it with just two wires connected to the USB FTDI TTL converter / programmer - have a look at this https://www.mysensors.org/hardware/micro
                              Available Pins - GND, GND, VCC (on the right)
                                mvader
                                I am having an odd issue with one of my sensebender boards.
                                I have flashed 5 in a row, same sketch, same everything.
                                all look fine (and in english) in the serial monitor. but this one board displays different.
                                it does seem to work. but i can't figure out why it's showing up different in the monitor.
                                any ideas?
                                Óåîóåâåîäåò Íéãòï Æ× 1.5óåîä: 2-2-0-0 ó=255,ã=0,ô=17,ðô=0,ì=3,óç=0,óô=ïë:1.5
                                óåîä: 2-2-0-0 ó=255,ã=3,ô=6,ðô=1,ì=1,óç=0,óô=ïë:0
                                óåîóïò óôáòôåä, éä=2, ðáòåîô=0, äéóôáîãå=1
                                 - Ïîìéîå!
                                óåîä: 2-2-0-0 ó=255,ã=3,ô=11,ðô=0,ì=17,óç=0,óô=ïë:Óåîóåâåîäåò Íéãòï
                                óåîä: 2-2-0-0 ó=255,ã=3,ô=12,ðô=0,ì=3,óç=0,óô=ïë:1.5
                                óåîä: 2-2-0-0 ó=1,ã=0,ô=6,ðô=0,ì=0,óç=0,óô=ïë:
                                óåîä: 2-2-0-0 ó=2,ã=0,ô=7,ðô=0,ì=0,óç=0,óô=ïë:
                                óåîä: 2-2-0-0 ó=3,ã=0,ô=1,ðô=0,ì=0,óç=0,óô=ïë:
                                óåîä: 2-2-0-0 ó=4,ã=0,ô=16,ðô=0,ì=0,óç=0,óô=ïë:
                                éóÍåôòéã: 0
                                ÔåíðÄéææ :174.85
                                ÈõíÄéææ  :154.00
                                Ô: 74.85
                                È: 54
                                óåîä: 2-2-0-0 ó=1,ã=1,ô=0,ðô=7,ì=5,óç=0,óô=ïë:74.8
                                óåîä: 2-2-0-0 ó=2,ã=1,ô=1,ðô=2,ì=2,óç=0,óô=ïë:54
                                óåîä: 2-2-0-0 ó=255,ã=3,ô=0,ðô=1,ì=1,óç=0,óô=ïë:97
                                ÏÔÁ Æ× õðäáôå åîáâìåä
                                óåîä: 2-2-0-0 ó=4,ã=1,ô=23,ðô=2,ì=2,óç=0,óô=ïë:99
                                Ìéçèô: 99
                                ÔåíðÄéææ :0.01
                                ˆõíÄéææ  :0.00
                                Ìéçèô: 99
                                tbowmoT 1 Reply Last reply
                                • M mvader
                                  any ideas?
                                   - Ïîìéîå!
                                  éóÍåôòéã: 0
                                  ÔåíðÄéææ :174.85
                                  ÈõíÄéææ  :154.00
                                  Ô: 74.85
                                  È: 54
                                  Ìéçèô: 99
                                  ÔåíðÄéææ :0.01
                                  ˆõíÄéææ  :0.00
                                  Ìéçèô: 99
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @mvader
                                  What baudrate are you using? It seems like it's to much off, for the ftdi to decode it correctly. Have you tried to lower it to, let's say 9600 baud? And does it still do this?
                                  • tbowmoT tbowmo
                                    @mvader
                                    mvader
                                    @tbowmo said:
                                    @mvader
                                    I have not tried 9600, but i've done 5 today all the same code.. no problems.
                                    i have 4 others deployed from when i first bought these (when they came out) same code for them as well..
                                    could be a bum board..idk. when i fired it up, i could see it in the controller software though. so it does seem to work. it just gives me that in the serial monitor.. strange for sure :) I'll let you know how 9600 works out.
                                    AnticimexA 1 Reply Last reply
                                    • M mvader
                                      @tbowmo said:
                                      @mvader
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @mvader what baffles me is that numbers seem to encode ok but alphabetical characters do not. You don't use some exotic ascii encoding in your terminal? (not likely if you can switch to a different SenseBender and get sane output I suppose)
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @mvader
                                        115200 is on the edge of what is possible with the 8Mhz that the sensebender is using. And it's a uncalibrated RC oscillator that's in use. So this one might be a bit off to the lower side (run 7.5Mhz for example) which could throw off your serial port a bit.
                                        (But as @Anticimex mentions, it does look weird that the numbers are readable..)
                                        • tbowmoT tbowmo
                                          @mvader
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @tbowmo @mvader it can still be a timing problem. Numbers in the ascii table have the most significant bits zero (they are in the range 0x3x and below) and since regular UART protocols transmit lsb first, the first bits may be within legal timing while the later bits are not, so the higher the ascii value, the higher the risk for corruption.
