  3. Orientation sensor (and actuator)
19 Posts 5 Posters 10.3k Views 8 Watching
    Nice to someone play around with a 10DOF device. And I like the video! :)
    • Fat FlyF
      Fat FlyF
      Fat Fly
      Can to drive with mpu9250 solar panels ? Solar tracker by sun position coordinates ?
      AWIA 1 Reply Last reply
      • tbowmoT
        tbowmoT
        tbowmo
        That looks awesome. Think I have to try something like that as well :)
        • Fat FlyF
          Fat FlyF
          Fat Fly
          MPU 6250 works too. But how to drive linear actuators and how to set and from where get coordinates? Oh. Too many questions.
          • Fat FlyF Fat Fly
            AWIA
            AWIA
            AWI
            @Fat-Fly a sun panel tracker based on this circuit is in place on my roof. My major issue is mechanical. How to seal the (stepper) motors from the environment.
            K 1 Reply Last reply
            • AWIA AWI
              K
              K
              koen01
              wrote on last edited by koen01
              I once saw someone on YouTube that mounted them in pvc pipe with a cap.
              He used electric drill motors for the actuators though.
              https://youtu.be/HnwTqx-INes
              • Fat FlyF
                Fat FlyF
                Fat Fly
                How to this sensor knows where is the sun?
                • Fat FlyF Fat Fly
                  K
                  K
                  koen01
                  I guess 4 ldrs with a cross between ?
                  • Fat FlyF
                    Fat FlyF
                    Fat Fly
                    Okay. But why for this mpu9250? These ldr's not working correctly if cloudy. Turn with sun coordinates is possible but i do not find cheap system. Raspberry PI and with arduino + mpu9250 or 6250 + linear actuators.
                    • Fat FlyF Fat Fly
                      AWIA
                      AWIA
                      AWI
                      wrote on last edited by AWI
                      @Fat-Fly the position of the sun is very predictable :wink:. I use a simplified algorithm to calculate where it will come from. So no DOF sensor needed here only the actuator.
                      • Fat FlyF
                        Fat FlyF
                        Fat Fly
                        wrote on last edited by Fat Fly
                        https://www.youtube.com/watch?v=BEmGntpX-Dk
                        • Fat FlyF
                          Fat FlyF
                          Fat Fly
                          How to drive this ?
                          • K
                            K
                            koen01
                            @AWI
                            Is it possible to sleep the node and wake it up by external interrupt ?
                            I have a use case for this but it has to be battery powered.
                            • K koen01
                              @AWI
                              AWIA
                              AWIA
                              AWI
                              @koen01 I assume you are refering to the orientation sensor.. You can sleep the node and have it wake up by external or internal (timer) interrupt. Power consumption when powered down is minimal. Look at API for "Sleeping". I am using a setup with solar power for a wind/weather station (on-going development ..)
                              • AWIA AWI
                                K
                                K
                                koen01
                                @AWI
                                Thank you for answer.
                                See this link for an project based in this.
                                Its basically a scène controller in the shape of a cube.
                                I got the idea from the original poster in the thread over at home-assistant.
                                https://community.home-assistant.io/t/rubiks-mood-cube-magic-cube/9965/8
                                I will post a BOM, sketch and pics if someone wants me to.
                                • K koen01
                                  @AWI
                                  K
                                  K
                                  koen01
                                  @AWI
                                  This is how it looks like at the moment.
                                  Still taped together as everything is beta stage. ;)
                                  https://youtu.be/_hbFNwnpov0
                                  • K koen01
                                    @AWI
                                    K
                                    K
                                    koen01
                                    Some more info on the cube can be found at the homeassistant forums
                                    https://community.home-assistant.io/t/rubiks-mood-cube-magic-cube/9965/11?u=koen01
                                      @koen01, really like this cool cube project.
                                      Couldn't you add it as a new project on openhardware.io? This enables me to show it on the mysensors.org build pages as well.
