  3. Orientation sensor (and actuator)
19 Posts 5 Posters 10.4k Views 8 Watching
  • Fat FlyF Fat Fly
    Can to drive with mpu9250 solar panels ? Solar tracker by sun position coordinates ?
    AWIA
    AWIA
    AWI
    @Fat-Fly a sun panel tracker based on this circuit is in place on my roof. My major issue is mechanical. How to seal the (stepper) motors from the environment.
    K 1 Reply Last reply
    • AWIA AWI
      K
      K
      koen01
      wrote on last edited by koen01
      I once saw someone on YouTube that mounted them in pvc pipe with a cap.
      He used electric drill motors for the actuators though.
      https://youtu.be/HnwTqx-INes
      • Fat FlyF
        Fat FlyF
        Fat Fly
        How to this sensor knows where is the sun?
        • Fat FlyF Fat Fly
          K
          K
          koen01
          I guess 4 ldrs with a cross between ?
          • Fat FlyF
            Fat FlyF
            Fat Fly
            Okay. But why for this mpu9250? These ldr's not working correctly if cloudy. Turn with sun coordinates is possible but i do not find cheap system. Raspberry PI and with arduino + mpu9250 or 6250 + linear actuators.
            AWIA 1 Reply Last reply
            • Fat FlyF Fat Fly
              AWIA
              AWIA
              AWI
              wrote on last edited by AWI
              @Fat-Fly the position of the sun is very predictable :wink:. I use a simplified algorithm to calculate where it will come from. So no DOF sensor needed here only the actuator.
              • Fat FlyF
                Fat FlyF
                Fat Fly
                wrote on last edited by Fat Fly
                https://www.youtube.com/watch?v=BEmGntpX-Dk
                • Fat FlyF
                  Fat FlyF
                  Fat Fly
                  How to drive this ?
                  • K
                    K
                    koen01
                    @AWI
                    Is it possible to sleep the node and wake it up by external interrupt ?
                    I have a use case for this but it has to be battery powered.
                    • K koen01
                      @AWI
                      AWIA
                      AWIA
                      AWI
                      @koen01 I assume you are refering to the orientation sensor.. You can sleep the node and have it wake up by external or internal (timer) interrupt. Power consumption when powered down is minimal. Look at API for "Sleeping". I am using a setup with solar power for a wind/weather station (on-going development ..)
                      • AWIA AWI
                        K
                        K
                        koen01
                        @AWI
                        Thank you for answer.
                        See this link for an project based in this.
                        Its basically a scène controller in the shape of a cube.
                        I got the idea from the original poster in the thread over at home-assistant.
                        https://community.home-assistant.io/t/rubiks-mood-cube-magic-cube/9965/8
                        I will post a BOM, sketch and pics if someone wants me to.
                        • K koen01
                          @AWI
                          K
                          K
                          koen01
                          @AWI
                          This is how it looks like at the moment.
                          Still taped together as everything is beta stage. ;)
                          https://youtu.be/_hbFNwnpov0
                          • K koen01
                            @AWI
                            K
                            K
                            koen01
                            Some more info on the cube can be found at the homeassistant forums
                            https://community.home-assistant.io/t/rubiks-mood-cube-magic-cube/9965/11?u=koen01
                              @koen01, really like this cool cube project.
                              Couldn't you add it as a new project on openhardware.io? This enables me to show it on the mysensors.org build pages as well.
