  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.8k Views 1 Watching
  • karl261K karl261
    Hi, this is all about the 2.0.0 master stable release. All systems use this code.
    I have 1 gateway, 1 repeater and 1 sensor node. The sensor node is a bit far from the gateway, so I put a repeater node in the middle with an amplified nrf24 version and the real antenna.
    Now what I see from the serial monitor is that gateway and repeater are up and running and the sensor node too.
    My problem is, that I cannot get the sensor node to use the repeater.
    If I bring the sensor close to the gateway they talk directly to each other. If I bring it further away, it does not switch over to use the repeater, but communication just remains dead (for days).
    I did try the MY_PARENT_NODE_ ID but it does not do anything. Even if I bring all 3 devices close together, the repeater is not being used.
    Can anyone confirm this behaviour? I am using the example sketches for gateway and repeater, and a very simple sketch for the sensor.
    Thanks for any ideas!
    tekkaT
    tekkaT
    tekka
    @karl261 Please post the full debug log of all nodes.
    • karl261K
      karl261K
      karl261
      Yes, I can do that, but only in about 4 weeks, because I am away.
      For my understanding: MY_PARENT_NODE_ ID is the correct approach for forcing traffic through a certain repeater, isn't it?
      • karl261K
        karl261K
        karl261
        @tekka I am still struggling with my repeater node. Below the output of the gateway (via pimatic-mysensors).
        So, when I switch on the repeater, why do I get these two "fail" messages? I can see in the log of the repeater that they are received well.
        Also, I noticed that the repeater is sending from time to time something to the gateway:
        mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
        13:32:51debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
        13:32:51debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
        Seems to be some sort of check that the routing table is still ok? When is it supposed to send that? Because sometimes it is not sending this for half an hour, then it is sending this every 20 seconds or so...
        debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
        13:31:11debug [pimatic-mysensors]: <- I_SKETCH_VERSION  99;255;3;0;12;1.0
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        13:31:11debug [pimatic-mysensors]: <- I_SKETCH_NAME  99;255;3;0;11;Repeater Node
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Repeater Node
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=fail:M
        13:31:11debug [pimatic-mysensors]: -> Sending  99;255;3;0;6;M
        13:31:11debug [pimatic-mysensors]: <- I_CONFIG  99;255;3;0;6;0
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        13:31:11debug [pimatic-mysensors]: <- Presented Node  [ '99', '255', '0', '0', '18', '2.0.0' ]
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=0,t=18,pt=0,l=5,sg=0:2.0.0
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
        13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
        13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
        13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:GWL OK
        13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:CHKUPL:OK
        13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:FPAR REQ (sender=99)
        13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:BC
        13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        • karl261K
          karl261K
          karl261
          Also, I can't really figure out what is failing here. This was when I was switching a node on. Later I see that it is transmitting data from time to time. I also can't figure out why the repeater is transmitting the data five times.
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=fail:M
          14:23:24debug [pimatic-mysensors]: -> Sending  30;255;3;0;6;M
          14:23:24debug [pimatic-mysensors]: <- I_CONFIG  30;255;3;0;6;99
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:99
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          14:23:24debug [pimatic-mysensors]: <- Presented Node  [ '30', '1', '0', '0', '7', '' ]
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
          14:23:24debug [pimatic-mysensors]: <- Presented Node  [ '30', '0', '0', '0', '6', '' ]
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
          14:23:24debug [pimatic-mysensors]: <- I_SKETCH_VERSION  30;255;3;0;12;1.0 151106
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0:1.0 151106
          14:23:24debug [pimatic-mysensors]: <- I_SKETCH_NAME  30;255;3;0;11;EgTmpHumBat5min
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=11,pt=0,l=15,sg=0:EgTmpHumBat5min
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
          14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
          14:23:23debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
          14:23:23debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
          14:23:23debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
          14:33:46debug [pimatic-mysensors]: <- MySensorDHT  { sender: 30, sensor: 1, type: 1, value: '57' }
          14:33:46debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:57
          14:33:46debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
          14:33:46debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
          14:33:46debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
          • karl261K
            karl261K
            karl261
            Something is wrong. In case somebody cares about a bit more debug output.
            99 Repeater
            4 Some outside node BME280
            30 Outside node SI7021
            Somewhere towards the end I toggled the power of the repeater node.
            I go and get some log from the repeater.
            0;255;3;0;9;TSM:INIT
            0;255;3;0;9;TSM:RADIO:OK
            0;255;3;0;9;TSM:GW MODE
            0;255;3;0;9;TSM:READY
            0;255;0;0;18;2.0.0
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.0
            2;1;1;0;0;20.0
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.9
            2;0;1;0;1;73.9
            0;255;3;0;9;TSP:MSG:READ 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.5
            3;1;1;0;0;20.5
            0;255;3;0;9;TSP:MSG:READ 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.6
            3;1;1;0;0;20.6
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.0
            2;1;1;0;0;21.0
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.4
            2;0;1;0;1;74.4
            0;255;3;0;9;TSP:SANCHK:OK
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.5
            2;1;1;0;0;19.5
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.6
            2;0;1;0;1;73.6
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.0
            2;1;1;0;0;19.0
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.2
            2;0;1;0;1;73.2
            0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:61
            30;1;1;0;1;61
            30;1;1;0;1;61
            30;1;1;0;1;61
            30;1;1;0;1;61
            3;1;1;0;0;20.5
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=0,c=1,t=1,pt=2,l=2,sg=0:41
            4;0;1;0;1;41
            4;0;1;0;1;41
            4;0;1;0;1;41
            4;0;1;0;1;41
            4;0;1;0;1;41
            3;1;1;0;0;20.6
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.4
            2;1;1;0;0;20.4
            2;0;1;0;1;73.9
            2;1;1;0;0;19.5
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.7
            2;0;1;0;1;73.7
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.7
            2;1;1;0;0;20.7
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.4
            2;0;1;0;1;73.4
            3;1;1;0;0;20.5
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.6
            2;1;1;0;0;20.6
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.1
            2;0;1;0;1;73.1
            3;1;1;0;0;20.6
            2;1;1;0;0;19.5
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.5
            2;0;1;0;1;73.5
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.0
            4;1;1;0;0;26.0
            4;1;1;0;0;26.0
            4;1;1;0;0;26.0
            3;1;1;0;0;20.5
            2;1;1;0;0;20.7
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.0
            2;0;1;0;1;74.0
            3;1;1;0;0;20.6
            0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.0
            3;0;1;0;1;61.0
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:18.9
            2;1;1;0;0;18.9
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:72.9
            2;0;1;0;1;72.9
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.6
            4;1;1;0;0;26.6
            4;1;1;0;0;26.6
            4;1;1;0;0;26.6
            4;1;1;0;0;26.6
            4;1;1;0;0;26.6
            4;1;1;0;0;26.6
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:18.8
            2;1;1;0;0;18.8
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:72.7
            2;0;1;0;1;72.7
            0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.1
            3;0;1;0;1;61.1
            2;1;1;0;0;19.5
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.3
            2;0;1;0;1;73.3
            3;1;1;0;0;20.5
            2;1;1;0;0;20.6
            2;0;1;0;1;73.9
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.6
            2;1;1;0;0;19.6
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.8
            2;0;1;0;1;73.8
            2;1;1;0;0;20.4
            2;0;1;0;1;74.4
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.2
            2;1;1;0;0;20.2
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.3
            2;0;1;0;1;74.3
            2;1;1;0;0;20.7
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.7
            2;0;1;0;1;74.7
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.5
            2;1;1;0;0;20.5
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.5
            2;0;1;0;1;74.5
            2;1;1;0;0;20.6
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.6
            2;0;1;0;1;74.6
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.8
            2;1;1;0;0;20.8
            2;0;1;0;1;74.7
            2;1;1;0;0;21.0
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.8
            2;0;1;0;1;74.8
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.9
            2;1;1;0;0;20.9
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.9
            2;0;1;0;1;74.9
            2;1;1;0;0;21.0
            0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.2
            3;0;1;0;1;61.2
            2;1;1;0;0;20.6
            2;0;1;0;1;74.6
            3;0;1;0;1;61.1
            2;1;1;0;0;20.5
            2;0;1;0;1;74.7
            4;1;1;0;0;26.0
            4;1;1;0;0;26.0
            4;1;1;0;0;26.0
            4;1;1;0;0;26.0
            4;1;1;0;0;26.0
            4;1;1;0;0;26.0
            4;1;1;0;0;26.0
            2;1;1;0;0;20.8
            3;1;1;0;0;20.6
            2;1;1;0;0;20.9
            2;0;1;0;1;74.9
            3;1;1;0;0;20.5
            3;0;1;0;1;61.2
            2;1;1;0;0;20.6
            2;0;1;0;1;74.7
            2;1;1;0;0;20.8
            2;0;1;0;1;74.8
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=0,c=1,t=1,pt=2,l=2,sg=0:45
            4;0;1;0;1;45
            4;0;1;0;1;45
            4;0;1;0;1;45
            4;0;1;0;1;45
            4;0;1;0;1;45
            2;1;1;0;0;20.4
            2;0;1;0;1;74.6
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.5
            4;1;1;0;0;26.5
            4;1;1;0;0;26.5
            4;1;1;0;0;26.5
            4;1;1;0;0;26.5
            4;1;1;0;0;26.5
            4;1;1;0;0;26.5
            2;1;1;0;0;20.7
            2;0;1;0;1;74.9
            3;1;1;0;0;20.6
            3;1;1;0;0;20.5
            3;0;1;0;1;61.1
            2;1;1;0;0;21.0
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:75.0
            2;0;1;0;1;75.0
            2;1;1;0;0;20.6
            2;0;1;0;1;74.7
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.1
            2;1;1;0;0;21.1
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:75.1
            2;0;1;0;1;75.1
            2;1;1;0;0;20.8
            2;0;1;0;1;75.0
            3;0;1;0;1;61.2
            2;1;1;0;0;21.1
            2;0;1;0;1;75.1
            4;0;1;0;1;41
            4;0;1;0;1;41
            4;0;1;0;1;41
            4;0;1;0;1;41
            4;0;1;0;1;41
            4;0;1;0;1;41
            3;0;1;0;1;61.1
            2;1;1;0;0;20.5
            2;0;1;0;1;74.8
            3;0;1;0;1;61.2
            2;1;1;0;0;20.4
            2;0;1;0;1;74.7
            3;0;1;0;1;61.1
            2;1;1;0;0;20.8
            2;0;1;0;1;73.6
            2;1;1;0;0;20.9
            2;0;1;0;1;75.1
            2;1;1;0;0;20.7
            2;0;1;0;1;74.9
            0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:60
            30;1;1;0;1;60
            30;1;1;0;1;60
            30;1;1;0;1;60
            2;1;1;0;0;20.8
            2;1;1;0;0;20.6
            2;0;1;0;1;74.8
            3;0;1;0;1;61.2
            3;0;1;0;1;61.1
            2;1;1;0;0;20.4
            2;0;1;0;1;74.7
            3;0;1;0;1;61.2
            2;1;1;0;0;21.0
            2;0;1;0;1;75.1
            3;0;1;0;1;61.1
            2;1;1;0;0;21.1
            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:75.2
            2;0;1;0;1;75.2
            3;0;1;0;1;61.2
            2;1;1;0;0;20.6
            2;0;1;0;1;74.8
            3;0;1;0;1;61.1
            2;1;1;0;0;20.4
            2;0;1;0;1;74.7
            3;1;1;0;0;20.6
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=0,c=1,t=1,pt=2,l=2,sg=0:40
            4;0;1;0;1;40
            4;0;1;0;1;40
            4;0;1;0;1;40
            4;0;1;0;1;40
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=2,c=1,t=4,pt=7,l=5,sg=0:1020.2
            4;2;1;0;4;1020.2
            4;2;1;0;4;1020.2
            4;2;1;0;4;1020.2
            4;2;1;0;4;1020.2
            4;2;1;0;4;1020.2
            4;2;1;0;4;1020.2
            4;2;1;0;4;1020.2
            2;1;1;0;0;20.7
            2;0;1;0;1;74.9
            3;1;1;0;0;20.5
            2;1;1;0;0;20.9
            2;0;1;0;1;75.1
            2;1;1;0;0;20.7
            2;0;1;0;1;74.9
            2;1;1;0;0;20.9
            2;0;1;0;1;75.1
            2;1;1;0;0;20.6
            2;0;1;0;1;74.8
            2;1;1;0;0;20.8
            2;0;1;0;1;75.0
            2;1;1;0;0;20.5
            2;0;1;0;1;74.8
            2;1;1;0;0;20.7
            2;0;1;0;1;75.0
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=0,c=1,t=1,pt=2,l=2,sg=0:44
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.1
            4;1;1;0;0;26.1
            4;1;1;0;0;26.1
            4;1;1;0;0;26.1
            4;1;1;0;0;26.1
            4;1;1;0;0;26.1
            4;1;1;0;0;26.1
            2;1;1;0;0;20.5
            2;0;1;0;1;74.8
            2;1;1;0;0;20.6
            2;1;1;0;0;20.7
            2;0;1;0;1;74.9
            2;1;1;0;0;20.5
            2;0;1;0;1;74.7
            2;1;1;0;0;20.2
            2;0;1;0;1;74.5
            2;1;1;0;0;20.9
            2;0;1;0;1;73.8
            2;1;1;0;0;20.5
            2;0;1;0;1;74.8
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            4;1;1;0;0;26.7
            2;1;1;0;0;20.6
            3;0;1;0;1;61.2
            2;1;1;0;0;20.8
            2;0;1;0;1;74.9
            3;0;1;0;1;61.1
            2;1;1;0;0;20.2
            2;0;1;0;1;74.6
            4;0;1;0;1;40
            4;0;1;0;1;40
            4;0;1;0;1;40
            4;0;1;0;1;40
            4;0;1;0;1;40
            4;0;1;0;1;40
            2;1;1;0;0;20.6
            2;0;1;0;1;74.8
            2;1;1;0;0;20.4
            2;1;1;0;0;20.9
            2;0;1;0;1;75.1
            2;1;1;0;0;20.8
            2;0;1;0;1;75.0
            2;1;1;0;0;20.5
            2;0;1;0;1;74.9
            99;255;0;0;18;2.0.0
            99;255;3;0;6;0
            99;255;3;0;12;1.0
            3;1;1;0;0;20.6
            0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.3
            3;0;1;0;1;61.3
            2;1;1;0;0;20.4
            2;0;1;0;1;74.8
            3;0;1;0;1;61.2
            2;1;1;0;0;20.6
            2;0;1;0;1;75.0
            3;1;1;0;0;20.5
            0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.4
            3;0;1;0;1;61.4
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            4;0;1;0;1;44
            3;1;1;0;0;20.6
            3;0;1;0;1;61.2
            0;255;3;0;9;TSP:MSG:READ 4-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
            0;255;3;0;9;TSP:MSG:PINGED (ID=4, hops=2)
            0;255;3;0;9;!TSP:MSG:SEND 0-0-99-4 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
            2;1;1;0;0;20.5
            2;0;1;0;1;74.8
            2;1;1;0;0;20.6
            2;0;1;0;1;74.9
            3;1;1;0;0;20.5
            2;0;1;0;1;74.8
            3;0;1;0;1;61.3
            • karl261K
              karl261K
              karl261
              Hm, somehow I have the impression it depends a bit if I have #define MY_DEBUG in my repeater sketch or not. I had to put it back in, because I want to take some logs, and it is behaving a bit better now. At least single messages. And less fails.
              Daniel OliveiraD tekkaT 2 Replies Last reply
              • karl261K karl261
                Daniel OliveiraD
                Daniel OliveiraD
                Daniel Oliveira
                Hi @karl261,
                It's a long shot but can you double check your power sources? I had some weird issues like those in the past because of bad quality power sources.
                I recommend adding a 47uF electrolytic capacitor as close as possible to the NRF24 GND and VCC pins, as a 470uF between the GND and the Vin pins of the arduino.
                And keep the external power source on even when connecting the USB cable to read the debug messages.
                Hope you solve this issue soon
                MySensors rules my home :)
                karl261K 1 Reply Last reply
                • karl261K karl261
                  tekkaT
                  tekkaT
                  tekka
                  @karl261 Ok, I need to see the sketches first: can you post the sketch of all nodes, i.e. GW, node 99, node 3, node 4? Also, do you have MYSController installed for a few tests?
                  • karl261K
                    karl261K
                    karl261
                    wrote on last edited by karl261
                    Oki doki, thanks for looking at this:
                    Sketch GW:
                     * LEDs (OPTIONAL):
                     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
                    // Enable serial gateway
                    #define MY_GATEWAY_SERIAL
                    #if F_CPU == 8000000L
                    #define MY_BAUD_RATE 38400
                    // Flash leds on rx/tx/err
                    // Set blinking period
                    // Enable inclusion mode
                    Sketch 99:
                     * Version 1.0 - Henrik Ekblad
                     * Example sketch showing how to create a node thay repeates messages
                     * from nodes far from gateway back to gateway.
                     * It is important that nodes that has enabled repeater mode calls
                     * process() frequently. Repeaters should never sleep.
                    #define MY_REPEATER_FEATURE
                    #define MY_NODE_ID 99
                      //Send the sensor node sketch version information to the gateway
                      sendSketchInfo("Repeater Node", "1.0");
                    Sketch 4:
                    by m26872, 20151109
                    //#define MY_PARENT_NODE_ID 31
                    #define MY_NODE_ID 4
                    #define MY_BAUD_RATE 9600
                    #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
                    #include <RunningAverage.h>
                    #include <SparkFunBME280.h>
                    //#define DEBUG   // local debug
                    #ifdef DEBUG
                    // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                    #define CHILD_ID_HUM 0
                    #define CHILD_ID_TEMP 1
                    #define CHILD_ID_PRES 2
                     #define SLEEP_TIME 15000 // 15s for DEBUG
                    //#define SLEEP_TIME 300000   // 5 min
                    #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                    #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                    #define VMIN 1900
                    #define VMAX 3300
                    #define PRES_TRANSMIT_THRESHOLD 1.0
                    #define AVERAGES 2
                    int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                    int measureCount = 0;
                    float lastTemperature = -100;
                    float lastPressure = -100;
                    int lastHumidity = -100;
                    //SI7021 humiditySensor;
                    BME280 mySensor;
                    // MyMessage to controler
                    MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
                      sendSketchInfo("OUTSIDE P&T&H", "1.2");
                      present(CHILD_ID_PRES, S_BARO);
                      present(CHILD_ID_HUM, S_HUM);
                      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
                      DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                      DEBUG_PRINT("Voltage: ");
                      DEBUG_PRINT(readVcc());
                      DEBUG_PRINTLN(" mV");
                      delay(500);
                      DEBUG_PRINTLN(" *C");
                      mySensor.settings.commInterface = I2C_MODE;
                      mySensor.settings.I2CAddress = 0x77;
                      //runMode can be:
                      //  0, Sleep mode
                      //  1 or 2, Forced mode
                      //  3, Normal mode
                      mySensor.settings.runMode = 1;
                      mySensor.settings.filter = 0;
                      mySensor.settings.tempOverSample = 1;
                      mySensor.settings.pressOverSample = 1;
                      mySensor.settings.humidOverSample = 1;
                      if (!mySensor.begin())
                        Serial.println("BME init failed!");
                        while (1);
                      else Serial.println("BME init success!");
                      raHum.clear();
                      measureCount ++;
                      batteryReportCounter ++;
                      bool forceTransmit = false;
                      if (measureCount > FORCE_TRANSMIT_CYCLE) {
                        forceTransmit = true;
                      mySensor.begin();
                      // Read and print internal temp
                      float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                      DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                      // Check battery
                      if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                        long batteryVolt = readVcc();
                        DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                        DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                        batteryReportCounter = 0;
                    //  sleep(SLEEP_TIME);
                    if(isTransportOK()){
                        sleep(SLEEP_TIME);  // transport is OK, node can sleep
                      else {
                        wait(5000); // transport is not operational, allow the transport layer to fix this
                    // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                    // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                    long readVcc() {
                      result = 1134738L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                    // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                    double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                      unsigned int wADC;
                      double t;
                      // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                      ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                      ADCSRA |= _BV(ADEN);  // enable the ADC
                      delay(20);            // wait for voltages to become stable.
                      ADCSRA |= _BV(ADSC);  // Start the ADC
                      while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                      wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                      t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                      return (t);   // The returned temperature in degrees Celcius.
                     * Parameters
                      bool tx = force;
                      float temperature = mySensor.readTempC();
                      if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                        send(msgTemp.set(temperature,1));
                        measureCount = 0;
                        DEBUG_PRINTLN("T sent!");
                      int humidity = mySensor.readFloatHumidity();
                      raHum.addValue(humidity);
                      if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                        send(msgHum.set(humidity));
                        lastHumidity = humidity;
                        measureCount = 0;
                        DEBUG_PRINTLN("H sent!");
                      float pressure = mySensor.readFloatPressure()/100.0;
                      DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
                      float diffPress = abs(lastPressure - pressure);
                      DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
                      if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
                        send(msgPres.set(pressure,1));
                        lastPressure = pressure;
                        measureCount = 0;
                        DEBUG_PRINTLN("P sent!");
                    Sketch Node 30:
                    by m26872, 20151109
                    //#define MY_NODE_ID 30
                    #include <SI7021.h>
                    #define DEBUG
                    #ifdef DEBUG
                    #define CHILD_ID_TEMP 0
                    #define CHILD_ID_HUM 1
                    // #define SLEEP_TIME 15000 // 15s for DEBUG
                    #define VMIN 1900
                    #define VMAX 3300
                    #define AVERAGES 2
                    sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
                      present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
                      delay(500);
                      raHum.clear();
                      measureCount ++;
                      // Check battery
                      sleep(SLEEP_TIME);
                    long readVcc() {
                      unsigned int wADC;
                      double t;
                     * Parameters
                      bool tx = force;
                      float temperature = data.celsiusHundredths / 100.0;
                        measureCount = 0;
                        measureCount = 0;
                    • Daniel OliveiraD Daniel Oliveira
                      Hi @karl261,
                      karl261K
                      karl261K
                      karl261
                      @Daniel-Oliveira Yeah, I know about these power things. I am pretty sure the power is ok. I use the caps on all my nodes. For the repeater (99) I picked a very stable 5V source and the NRF24+PA+LNA sits behind its own 3.3V regulator that has a high current output. The NRF24+PA+LNA is shielded after @Oitzu's method, so it should not interfere with itself. Actually I tried to implement all the tricks.
                      Btw, all is on 2.0.0.
                      GW: Nano
                      99: Pro mini
                      30 + 4: 1Mhz battery nodes after @m26872's "My Slim 2AA Battery Node".
                      It all sounds too nice to be true... ;-)
                      • tekkaT tekka
                        karl261K
                        karl261K
                        karl261
                        @tekka MYSController? No, but if you point me to a link or so I could install of course.
                        Edit: Ok, I downloaded your software. It seems it is running well on my PC. I am ready to test.
                        Edit2: The 1.0.0beta.
                        tekkaT 1 Reply Last reply
                        • karl261K karl261
                          tekkaT
                          tekkaT
                          tekka
                          wrote on last edited by tekka
                          @karl261 What version is it saying?
                          • tekkaT tekka
                            karl261K
                            karl261K
                            karl261
                            @tekka 1.0.0beta built 3314
                            • karl261K karl261
                              tekkaT
                              tekkaT
                              tekka
                              @karl261 Ok, then send a C_INTERNAL | I_DEBUG | R message to the GW and node 99 and upload the output.
                              • tekkaT tekka
                                karl261K
                                karl261K
                                karl261
                                @tekka So you mean I connect to my serial gateway and then issue the commands? Yes, let's see.
                                • karl261K
                                  karl261K
                                  karl261
                                  Here we go:
                                  10	22.08.2016 21:49:41	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
                                  12	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0202
                                  14	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0303
                                  16	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0463
                                  18	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	1E1E
                                  20	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	1F1F
                                  22	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
                                  24	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	8B03
                                  25	22.08.2016 21:50:06	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
                                  28	22.08.2016 21:50:06	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
                                  30	22.08.2016 21:50:06	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0303
                                  32	22.08.2016 21:50:07	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
                                  34	22.08.2016 21:50:07	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	1E1E
                                  37	22.08.2016 21:50:23	RX	2	1	C_SET	NO	V_TEMP	20.8
                                  39	22.08.2016 21:50:23	RX	2	0	C_SET	NO	V_HUM	76.1
                                  • karl261K karl261
                                    Here we go:
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @karl261 Ok, and now send C_INTERNAL | I_DEBUG | E - first to node 99, then to the GW and finally, press Discover in MYSController. This should re-establish the routing table.
                                    • tekkaT tekka
                                      karl261K
                                      karl261K
                                      karl261
                                      @tekka I received ok twice back. Now the nano (GW) is blinking like crazy. And so is the pro mini (repeater). I do a power cycle?
                                      • karl261K karl261
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @karl261 yup
                                        • tekkaT tekka
                                          @karl261 yup
                                          karl261K
                                          karl261K
                                          karl261
                                          @tekka Still weird:
                                          99 says 0203 so 02 is going via 03?? Why?
                                          0 says 0263 so 02 is going via 99?
                                          247	22.08.2016 22:15:24	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
                                          250	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
                                          252	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0203
                                          254	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
                                          255	22.08.2016 22:15:50	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
                                          257	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0263
                                          259	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
