  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.7k Views 1 Watching
  • karl261K
    karl261K
    karl261
    wrote on last edited by karl261
    Oki doki, thanks for looking at this:
    Sketch GW:
     * LEDs (OPTIONAL):
     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    Sketch 99:
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to create a node thay repeates messages
     * from nodes far from gateway back to gateway.
     * It is important that nodes that has enabled repeater mode calls
     * process() frequently. Repeaters should never sleep.
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 99
      //Send the sensor node sketch version information to the gateway
      sendSketchInfo("Repeater Node", "1.0");
    Sketch 4:
    by m26872, 20151109
    //#define MY_PARENT_NODE_ID 31
    #define MY_NODE_ID 4
    #define MY_BAUD_RATE 9600
    #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
    #include <RunningAverage.h>
    #include <SparkFunBME280.h>
    //#define DEBUG   // local debug
    #ifdef DEBUG
    // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_PRES 2
     #define SLEEP_TIME 15000 // 15s for DEBUG
    //#define SLEEP_TIME 300000   // 5 min
    #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
    #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
    #define VMIN 1900
    #define VMAX 3300
    #define PRES_TRANSMIT_THRESHOLD 1.0
    #define AVERAGES 2
    int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
    int measureCount = 0;
    float lastTemperature = -100;
    float lastPressure = -100;
    int lastHumidity = -100;
    //SI7021 humiditySensor;
    BME280 mySensor;
    // MyMessage to controler
    MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
      sendSketchInfo("OUTSIDE P&T&H", "1.2");
      present(CHILD_ID_PRES, S_BARO);
      present(CHILD_ID_HUM, S_HUM);
      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
      DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
      DEBUG_PRINT("Voltage: ");
      DEBUG_PRINT(readVcc());
      DEBUG_PRINTLN(" mV");
      delay(500);
      DEBUG_PRINTLN(" *C");
      mySensor.settings.commInterface = I2C_MODE;
      mySensor.settings.I2CAddress = 0x77;
      //runMode can be:
      //  0, Sleep mode
      //  1 or 2, Forced mode
      //  3, Normal mode
      mySensor.settings.runMode = 1;
      mySensor.settings.filter = 0;
      mySensor.settings.tempOverSample = 1;
      mySensor.settings.pressOverSample = 1;
      mySensor.settings.humidOverSample = 1;
      if (!mySensor.begin())
        Serial.println("BME init failed!");
        while (1);
      else Serial.println("BME init success!");
      raHum.clear();
      measureCount ++;
      batteryReportCounter ++;
      bool forceTransmit = false;
      if (measureCount > FORCE_TRANSMIT_CYCLE) {
        forceTransmit = true;
      mySensor.begin();
      // Read and print internal temp
      float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
      DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
      // Check battery
      if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
        long batteryVolt = readVcc();
        DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
        DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
        batteryReportCounter = 0;
    //  sleep(SLEEP_TIME);
    if(isTransportOK()){
        sleep(SLEEP_TIME);  // transport is OK, node can sleep
      else {
        wait(5000); // transport is not operational, allow the transport layer to fix this
    // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
    long readVcc() {
      result = 1134738L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
    // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
    double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
      unsigned int wADC;
      double t;
      // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
      ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
      ADCSRA |= _BV(ADEN);  // enable the ADC
      delay(20);            // wait for voltages to become stable.
      ADCSRA |= _BV(ADSC);  // Start the ADC
      while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
      wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
      t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
      return (t);   // The returned temperature in degrees Celcius.
     * Parameters
      bool tx = force;
      float temperature = mySensor.readTempC();
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
        send(msgTemp.set(temperature,1));
        measureCount = 0;
        DEBUG_PRINTLN("T sent!");
      int humidity = mySensor.readFloatHumidity();
      raHum.addValue(humidity);
      if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
        send(msgHum.set(humidity));
        lastHumidity = humidity;
        measureCount = 0;
        DEBUG_PRINTLN("H sent!");
      float pressure = mySensor.readFloatPressure()/100.0;
      DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
      float diffPress = abs(lastPressure - pressure);
      DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
      if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
        send(msgPres.set(pressure,1));
        lastPressure = pressure;
        measureCount = 0;
        DEBUG_PRINTLN("P sent!");
    Sketch Node 30:
    by m26872, 20151109
    //#define MY_NODE_ID 30
    #include <SI7021.h>
    #define DEBUG
    #ifdef DEBUG
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    // #define SLEEP_TIME 15000 // 15s for DEBUG
    #define VMIN 1900
    #define VMAX 3300
    #define AVERAGES 2
    sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
      present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
      delay(500);
      raHum.clear();
      measureCount ++;
      // Check battery
      sleep(SLEEP_TIME);
    long readVcc() {
      unsigned int wADC;
      double t;
     * Parameters
      bool tx = force;
      float temperature = data.celsiusHundredths / 100.0;
        measureCount = 0;
        measureCount = 0;
    • Daniel OliveiraD Daniel Oliveira
      Hi @karl261,
      It's a long shot but can you double check your power sources? I had some weird issues like those in the past because of bad quality power sources.
      I recommend adding a 47uF electrolytic capacitor as close as possible to the NRF24 GND and VCC pins, as a 470uF between the GND and the Vin pins of the arduino.
      And keep the external power source on even when connecting the USB cable to read the debug messages.
      Hope you solve this issue soon
      karl261K
      karl261K
      karl261
      @Daniel-Oliveira Yeah, I know about these power things. I am pretty sure the power is ok. I use the caps on all my nodes. For the repeater (99) I picked a very stable 5V source and the NRF24+PA+LNA sits behind its own 3.3V regulator that has a high current output. The NRF24+PA+LNA is shielded after @Oitzu's method, so it should not interfere with itself. Actually I tried to implement all the tricks.
      Btw, all is on 2.0.0.
      GW: Nano
      99: Pro mini
      30 + 4: 1Mhz battery nodes after @m26872's "My Slim 2AA Battery Node".
      It all sounds too nice to be true... ;-)
      • tekkaT tekka
        @karl261 Ok, I need to see the sketches first: can you post the sketch of all nodes, i.e. GW, node 99, node 3, node 4? Also, do you have MYSController installed for a few tests?
        karl261K
        karl261K
        karl261
        @tekka MYSController? No, but if you point me to a link or so I could install of course.
        Edit: Ok, I downloaded your software. It seems it is running well on my PC. I am ready to test.
        Edit2: The 1.0.0beta.
        tekkaT 1 Reply Last reply
        • karl261K karl261
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          @karl261 What version is it saying?
          karl261K 1 Reply Last reply
          • tekkaT tekka
            karl261K
            karl261K
            karl261
            @tekka 1.0.0beta built 3314
            • karl261K karl261
              tekkaT
              tekkaT
              tekka
              @karl261 Ok, then send a C_INTERNAL | I_DEBUG | R message to the GW and node 99 and upload the output.
              • tekkaT tekka
                karl261K
                karl261K
                karl261
                @tekka So you mean I connect to my serial gateway and then issue the commands? Yes, let's see.
                • karl261K
                  karl261K
                  karl261
                  Here we go:
                  10	22.08.2016 21:49:41	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
                  12	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0202
                  14	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0303
                  16	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0463
                  18	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	1E1E
                  20	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	1F1F
                  22	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
                  24	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	8B03
                  25	22.08.2016 21:50:06	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
                  28	22.08.2016 21:50:06	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
                  30	22.08.2016 21:50:06	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0303
                  32	22.08.2016 21:50:07	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
                  34	22.08.2016 21:50:07	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	1E1E
                  37	22.08.2016 21:50:23	RX	2	1	C_SET	NO	V_TEMP	20.8
                  39	22.08.2016 21:50:23	RX	2	0	C_SET	NO	V_HUM	76.1
                  • karl261K karl261
                    Here we go:
                    tekkaT
                    tekkaT
                    tekka
                    @karl261 Ok, and now send C_INTERNAL | I_DEBUG | E - first to node 99, then to the GW and finally, press Discover in MYSController. This should re-establish the routing table.
                    • tekkaT tekka
                      karl261K
                      karl261K
                      karl261
                      @tekka I received ok twice back. Now the nano (GW) is blinking like crazy. And so is the pro mini (repeater). I do a power cycle?
                      • karl261K karl261
                        tekkaT
                        tekkaT
                        tekka
                        @karl261 yup
                        • tekkaT tekka
                          @karl261 yup
                          karl261K
                          karl261K
                          karl261
                          @tekka Still weird:
                          99 says 0203 so 02 is going via 03?? Why?
                          0 says 0263 so 02 is going via 99?
                          247	22.08.2016 22:15:24	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
                          250	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
                          252	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0203
                          254	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
                          255	22.08.2016 22:15:50	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
                          257	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0263
                          259	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
                          • karl261K karl261
                            @tekka Still weird:
                            tekkaT
                            tekkaT
                            tekka
                            @karl261 hmm...indeed, that's weird. Do you have the debug log of node 3?
                            • tekkaT tekka
                              karl261K
                              karl261K
                              karl261
                              @tekka Which log exactly? Node 3 is Mysensors 1.5... It is sitting somewhere hidden...
                              • karl261K karl261
                                tekkaT
                                tekkaT
                                tekka
                                #24
                                mixed setups are not advisable (and not supported). Please update if possible.
                                • tekkaT tekka
                                  karl261K
                                  karl261K
                                  karl261
                                  @tekka Yes, with "all" I meant those being involved in the repeater stuff.
                                  • karl261K karl261
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @karl261 Can you add this to node 4 (this is the relayed one?):
                                    #define MY_PARENT_NODE_ID 99
                                    karl261K 2 Replies Last reply
                                    • tekkaT tekka
                                      karl261K
                                      karl261K
                                      karl261
                                      #27
                                      @tekka I can add it to node 30 right now. It is also supposed to be relayed. In fact this is why I did start this thread in the first place, I had no luck with these two lines. Will try again.
                                      Oooohhh, there is a mistake further up: I am talking about node 30, and wrote node 3. That is incorrect. Let's see if I can edit. That is why you were asking about the 1.5...
                                      • tekkaT tekka
                                        karl261K
                                        karl261K
                                        karl261
                                        #28
                                        @tekka Node 30 does still not care about the two lines. It is sending direct.
                                        It also does not send back any routing table. Maybe because it is sleeping most of the time?
                                        • karl261K karl261
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @karl261 If it's not defined as repeater, it won't have a routing table. And yes, sleeping nodes do not listen for incoming traffic. But still, if GW and node 99 are up, it should prefer 99 - can you show me the log of node 30 during booting?
