  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.8k Views 1 Watching
  • karl261K
    karl261K
    karl261
    Hm, somehow I have the impression it depends a bit if I have #define MY_DEBUG in my repeater sketch or not. I had to put it back in, because I want to take some logs, and it is behaving a bit better now. At least single messages. And less fails.
    Daniel OliveiraD tekkaT 2 Replies Last reply
    • karl261K karl261
      Daniel OliveiraD
      Daniel OliveiraD
      Daniel Oliveira
      Hi @karl261,
      It's a long shot but can you double check your power sources? I had some weird issues like those in the past because of bad quality power sources.
      I recommend adding a 47uF electrolytic capacitor as close as possible to the NRF24 GND and VCC pins, as a 470uF between the GND and the Vin pins of the arduino.
      And keep the external power source on even when connecting the USB cable to read the debug messages.
      Hope you solve this issue soon
      MySensors rules my home :)
      karl261K 1 Reply Last reply
      • karl261K karl261
        tekkaT
        tekkaT
        tekka
        @karl261 Ok, I need to see the sketches first: can you post the sketch of all nodes, i.e. GW, node 99, node 3, node 4? Also, do you have MYSController installed for a few tests?
        • karl261K
          karl261K
          karl261
          wrote on last edited by karl261
          Oki doki, thanks for looking at this:
          Sketch GW:
           * LEDs (OPTIONAL):
           * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Flash leds on rx/tx/err
          // Set blinking period
          // Enable inclusion mode
          Sketch 99:
           * Version 1.0 - Henrik Ekblad
           * Example sketch showing how to create a node thay repeates messages
           * from nodes far from gateway back to gateway.
           * It is important that nodes that has enabled repeater mode calls
           * process() frequently. Repeaters should never sleep.
          #define MY_REPEATER_FEATURE
          #define MY_NODE_ID 99
            //Send the sensor node sketch version information to the gateway
            sendSketchInfo("Repeater Node", "1.0");
          Sketch 4:
          by m26872, 20151109
          //#define MY_PARENT_NODE_ID 31
          #define MY_NODE_ID 4
          #define MY_BAUD_RATE 9600
          #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
          #include <RunningAverage.h>
          #include <SparkFunBME280.h>
          //#define DEBUG   // local debug
          #ifdef DEBUG
          // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define CHILD_ID_PRES 2
           #define SLEEP_TIME 15000 // 15s for DEBUG
          //#define SLEEP_TIME 300000   // 5 min
          #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
          #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
          #define VMIN 1900
          #define VMAX 3300
          #define PRES_TRANSMIT_THRESHOLD 1.0
          #define AVERAGES 2
          int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
          int measureCount = 0;
          float lastTemperature = -100;
          float lastPressure = -100;
          int lastHumidity = -100;
          //SI7021 humiditySensor;
          BME280 mySensor;
          // MyMessage to controler
          MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
            sendSketchInfo("OUTSIDE P&T&H", "1.2");
            present(CHILD_ID_PRES, S_BARO);
            present(CHILD_ID_HUM, S_HUM);
            DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
            DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
            DEBUG_PRINT("Voltage: ");
            DEBUG_PRINT(readVcc());
            DEBUG_PRINTLN(" mV");
            delay(500);
            DEBUG_PRINTLN(" *C");
            mySensor.settings.commInterface = I2C_MODE;
            mySensor.settings.I2CAddress = 0x77;
            //runMode can be:
            //  0, Sleep mode
            //  1 or 2, Forced mode
            //  3, Normal mode
            mySensor.settings.runMode = 1;
            mySensor.settings.filter = 0;
            mySensor.settings.tempOverSample = 1;
            mySensor.settings.pressOverSample = 1;
            mySensor.settings.humidOverSample = 1;
            if (!mySensor.begin())
              Serial.println("BME init failed!");
              while (1);
            else Serial.println("BME init success!");
            raHum.clear();
            measureCount ++;
            batteryReportCounter ++;
            bool forceTransmit = false;
            if (measureCount > FORCE_TRANSMIT_CYCLE) {
              forceTransmit = true;
            mySensor.begin();
            // Read and print internal temp
            float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
            DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
            // Check battery
            if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
              long batteryVolt = readVcc();
              DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
              uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
              DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
              batteryReportCounter = 0;
          //  sleep(SLEEP_TIME);
          if(isTransportOK()){
              sleep(SLEEP_TIME);  // transport is OK, node can sleep
            else {
              wait(5000); // transport is not operational, allow the transport layer to fix this
          // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
          // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
          long readVcc() {
            result = 1134738L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
          // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
          double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
            unsigned int wADC;
            double t;
            // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
            ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
            ADCSRA |= _BV(ADEN);  // enable the ADC
            delay(20);            // wait for voltages to become stable.
            ADCSRA |= _BV(ADSC);  // Start the ADC
            while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
            wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
            t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
            return (t);   // The returned temperature in degrees Celcius.
           * Parameters
            bool tx = force;
            float temperature = mySensor.readTempC();
            if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
              send(msgTemp.set(temperature,1));
              measureCount = 0;
              DEBUG_PRINTLN("T sent!");
            int humidity = mySensor.readFloatHumidity();
            raHum.addValue(humidity);
            if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
              send(msgHum.set(humidity));
              lastHumidity = humidity;
              measureCount = 0;
              DEBUG_PRINTLN("H sent!");
            float pressure = mySensor.readFloatPressure()/100.0;
            DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
            float diffPress = abs(lastPressure - pressure);
            DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
            if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
              send(msgPres.set(pressure,1));
              lastPressure = pressure;
              measureCount = 0;
              DEBUG_PRINTLN("P sent!");
          Sketch Node 30:
          by m26872, 20151109
          //#define MY_NODE_ID 30
          #include <SI7021.h>
          #define DEBUG
          #ifdef DEBUG
          #define CHILD_ID_TEMP 0
          #define CHILD_ID_HUM 1
          // #define SLEEP_TIME 15000 // 15s for DEBUG
          #define VMIN 1900
          #define VMAX 3300
          #define AVERAGES 2
          sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
            present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
            DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
            delay(500);
            raHum.clear();
            measureCount ++;
            // Check battery
            sleep(SLEEP_TIME);
          long readVcc() {
            unsigned int wADC;
            double t;
           * Parameters
            bool tx = force;
            float temperature = data.celsiusHundredths / 100.0;
              measureCount = 0;
              measureCount = 0;
          • Daniel OliveiraD Daniel Oliveira
            Hi @karl261,
            karl261K
            karl261K
            karl261
            @Daniel-Oliveira Yeah, I know about these power things. I am pretty sure the power is ok. I use the caps on all my nodes. For the repeater (99) I picked a very stable 5V source and the NRF24+PA+LNA sits behind its own 3.3V regulator that has a high current output. The NRF24+PA+LNA is shielded after @Oitzu's method, so it should not interfere with itself. Actually I tried to implement all the tricks.
            Btw, all is on 2.0.0.
            GW: Nano
            99: Pro mini
            30 + 4: 1Mhz battery nodes after @m26872's "My Slim 2AA Battery Node".
            It all sounds too nice to be true... ;-)
            • tekkaT tekka
              karl261K
              karl261K
              karl261
              @tekka MYSController? No, but if you point me to a link or so I could install of course.
              Edit: Ok, I downloaded your software. It seems it is running well on my PC. I am ready to test.
              Edit2: The 1.0.0beta.
              tekkaT 1 Reply Last reply
              • karl261K karl261
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                @karl261 What version is it saying?
                • tekkaT tekka
                  karl261K
                  karl261K
                  karl261
                  @tekka 1.0.0beta built 3314
                  • karl261K karl261
                    tekkaT
                    tekkaT
                    tekka
                    @karl261 Ok, then send a C_INTERNAL | I_DEBUG | R message to the GW and node 99 and upload the output.
                    • tekkaT tekka
                      karl261K
                      karl261K
                      karl261
                      @tekka So you mean I connect to my serial gateway and then issue the commands? Yes, let's see.
                      • karl261K
                        karl261K
                        karl261
                        Here we go:
                        10	22.08.2016 21:49:41	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
                        12	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0202
                        14	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0303
                        16	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0463
                        18	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	1E1E
                        20	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	1F1F
                        22	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
                        24	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	8B03
                        25	22.08.2016 21:50:06	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
                        28	22.08.2016 21:50:06	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
                        30	22.08.2016 21:50:06	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0303
                        32	22.08.2016 21:50:07	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
                        34	22.08.2016 21:50:07	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	1E1E
                        37	22.08.2016 21:50:23	RX	2	1	C_SET	NO	V_TEMP	20.8
                        39	22.08.2016 21:50:23	RX	2	0	C_SET	NO	V_HUM	76.1
                        • karl261K karl261
                          Here we go:
                          tekkaT
                          tekkaT
                          tekka
                          @karl261 Ok, and now send C_INTERNAL | I_DEBUG | E - first to node 99, then to the GW and finally, press Discover in MYSController. This should re-establish the routing table.
                          • tekkaT tekka
                            karl261K
                            karl261K
                            karl261
                            @tekka I received ok twice back. Now the nano (GW) is blinking like crazy. And so is the pro mini (repeater). I do a power cycle?
                            • karl261K karl261
                              tekkaT
                              tekkaT
                              tekka
                              @karl261 yup
                              • tekkaT tekka
                                @karl261 yup
                                karl261K
                                karl261K
                                karl261
                                @tekka Still weird:
                                99 says 0203 so 02 is going via 03?? Why?
                                0 says 0263 so 02 is going via 99?
                                247	22.08.2016 22:15:24	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
                                250	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
                                252	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0203
                                254	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
                                255	22.08.2016 22:15:50	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
                                257	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0263
                                259	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
                                • karl261K karl261
                                  @tekka Still weird:
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @karl261 hmm...indeed, that's weird. Do you have the debug log of node 3?
                                  • tekkaT tekka
                                    karl261K
                                    karl261K
                                    karl261
                                    @tekka Which log exactly? Node 3 is Mysensors 1.5... It is sitting somewhere hidden...
                                    • karl261K karl261
                                      tekkaT
                                      tekkaT
                                      tekka
                                      #24
                                      mixed setups are not advisable (and not supported). Please update if possible.
                                      • tekkaT tekka
                                        karl261K
                                        karl261K
                                        karl261
                                        @tekka Yes, with "all" I meant those being involved in the repeater stuff.
                                        • karl261K karl261
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @karl261 Can you add this to node 4 (this is the relayed one?):
                                          #define MY_PARENT_NODE_ID 99
                                          karl261K 2 Replies Last reply
