  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.8k Views 1 Watching
  • tekkaT tekka
    @karl261 Ok, and now send C_INTERNAL | I_DEBUG | E - first to node 99, then to the GW and finally, press Discover in MYSController. This should re-establish the routing table.
    karl261K
    karl261K
    karl261
    @tekka I received ok twice back. Now the nano (GW) is blinking like crazy. And so is the pro mini (repeater). I do a power cycle?
    tekkaT 1 Reply Last reply
    • karl261K karl261
      tekkaT
      tekkaT
      tekka
      @karl261 yup
      karl261K 1 Reply Last reply
      • tekkaT tekka
        @karl261 yup
        karl261K
        karl261K
        karl261
        @tekka Still weird:
        99 says 0203 so 02 is going via 03?? Why?
        0 says 0263 so 02 is going via 99?
        247	22.08.2016 22:15:24	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
        250	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
        252	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0203
        254	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
        255	22.08.2016 22:15:50	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
        257	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0263
        259	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
        • karl261K karl261
          @tekka Still weird:
          tekkaT
          tekkaT
          tekka
          @karl261 hmm...indeed, that's weird. Do you have the debug log of node 3?
          • tekkaT tekka
            karl261K
            karl261K
            karl261
            @tekka Which log exactly? Node 3 is Mysensors 1.5... It is sitting somewhere hidden...
            • karl261K karl261
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              #24
              @karl261 But you wrote:
              Btw, all is on 2.0.0.
              mixed setups are not advisable (and not supported). Please update if possible.
              • tekkaT tekka
                karl261K
                karl261K
                karl261
                @tekka Yes, with "all" I meant those being involved in the repeater stuff.
                • karl261K karl261
                  tekkaT
                  tekkaT
                  tekka
                  @karl261 Can you add this to node 4 (this is the relayed one?):
                  #define MY_PARENT_NODE_ID 99
                  karl261K 2 Replies Last reply
                  • tekkaT tekka
                    karl261K
                    karl261K
                    karl261
                    wrote on last edited by karl261
                    #27
                    @tekka I can add it to node 30 right now. It is also supposed to be relayed. In fact this is why I did start this thread in the first place, I had no luck with these two lines. Will try again.
                    Oooohhh, there is a mistake further up: I am talking about node 30, and wrote node 3. That is incorrect. Let's see if I can edit. That is why you were asking about the 1.5...
                    • tekkaT tekka
                      karl261K
                      karl261K
                      karl261
                      #28
                      @tekka Node 30 does still not care about the two lines. It is sending direct.
                      It also does not send back any routing table. Maybe because it is sleeping most of the time?
                      • karl261K karl261
                        tekkaT
                        tekkaT
                        tekka
                        @karl261 If it's not defined as repeater, it won't have a routing table. And yes, sleeping nodes do not listen for incoming traffic. But still, if GW and node 99 are up, it should prefer 99 - can you show me the log of node 30 during booting?
                        • tekkaT tekka
                          karl261K
                          karl261K
                          karl261
                          #30
                          @tekka Now it seems to work.
                          But I recompiled, because I had MY_DEBUG commented out. Somehow there is something wrong with debug...
                          TSM:INIT
                          TSM:RADIO:OK
                          TSP:ASSIGNID:OK (ID=30)
                          TSM:FPAR
                          TSP:MSG:SEND 30-30-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSP:MSG:READ 3-3-30 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                          TSP:MSG:FPAR RES (ID=3, dist=1)
                          TSP:MSG:PAR OK (ID=3, dist=2)
                          TSP:MSG:READ 99-99-30 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                          TSP:MSG:FPAR RES (ID=99, dist=1)
                          TSP:MSG:FPAR (PPAR FOUND)
                          TSP:MSG:PAR OK (ID=99, dist=2)
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=30)
                          TSM:UPL
                          TSP:PING:SEND (dest=0)
                          TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                          TSP:MSG:READ 0-0-30 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          TSP:MSG:READ 0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0:2
                          TSP:MSG:PONG RECV (hops=2)
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          Serial started
                          Voltage: 3289 mV
                          TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                          TSP:MSG:SEND 30-30-99-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                          TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:99
                          TSP:MSG:READ 0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=ok:EgTmpHumBat5min
                          TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0,ft=0,st=ok:1.0 151106
                          TSP:MSG:SEND 30-30-99-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                          TSP:MSG:SEND 30-30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                          Node and 2 children presented.
                          Request registration...
                          TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                          TSP:MSG:READ 0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          Node registration=1
                          Init complete, id=30, parent=99, distance=2, registration=1
                          T: 21.59
                          TempDiff :121.59
                          TSP:MSG:SEND 30-30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.6
                          T sent!
                          H: 81
                          HumDiff  :181.00
                          TSP:MSG:SEND 30-30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=ok:81
                          H sent!
                          Battery voltage: 3279 mV
                          Battery percent: 98 %
                          TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:98
                          T: 21.61
                          TempDiff :0.02
                          H: 81
                          HumDiff  :0.00
                          • karl261K karl261
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            Serial started
                            Voltage: 3289 mV
                            Node registration=1
                            T: 21.59
                            TempDiff :121.59
                            T sent!
                            H: 81
                            HumDiff  :181.00
                            H sent!
                            T: 21.61
                            TempDiff :0.02
                            H: 81
                            HumDiff  :0.00
                            tekkaT
                            tekkaT
                            tekka
                            You mean, if MY_DEBUG is commented out, the node does not communicate over the repeater (99)?
                            • tekkaT tekka
                              karl261K
                              karl261K
                              karl261
                              @tekka Well, yes, I added the two lines you suggested, re-compiled, and then it was not using the 99. And also some posts above, I had these weird messages transmitted 6-7 times, see logs. This happend while MY_DEBUG was commented out.
                              Hm, I can re-upload the sketch and see if this is reproducible.
                              • karl261K karl261
                                tekkaT
                                tekkaT
                                tekka
                                @karl261 Yes, that would be good - node 30 is running@1Mhz?
                                karl261K 3 Replies Last reply
                                • tekkaT tekka
                                  karl261K
                                  karl261K
                                  karl261
                                  @tekka Yes, @1 MHz.
                                  • tekkaT tekka
                                    karl261K
                                    karl261K
                                    karl261
                                    @tekka No, it seems to work as expected. Any idea why I am getting this "fail" line?
                                    23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:READ 30-30-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                    23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:BC
                                    23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=30)
                                    23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:CHKUPL:OK
                                    23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:GWL OK
                                    23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-30-30 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                    23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                    23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
                                    23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                    23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
                                    23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
                                    23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:99
                                    23.08.2016 00:30:35	RX	30;255;3;0;6;99
                                    23.08.2016 00:30:35	TX	30;255;3;0;6;M
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=ok:M
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0:1.0 151106
                                    23.08.2016 00:30:35	RX	30;255;3;0;12;1.0 151106
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
                                    23.08.2016 00:30:35	RX	30;1;0;0;7;
                                    23.08.2016 00:30:35	DEBUG	Update child id=1, type=S_HUM
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.3
                                    23.08.2016 00:30:35	RX	30;0;1;0;0;24.3
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:73
                                    23.08.2016 00:30:35	RX	30;1;1;0;1;73
                                    23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0:91
                                    23.08.2016 00:30:35	RX	30;255;3;0;0;91
                                    • karl261K karl261
                                      tekkaT
                                      tekkaT
                                      tekka
                                      #36
                                      @karl261 Does it fail regularly?
                                      • tekkaT tekka
                                        karl261K
                                        karl261K
                                        karl261
                                        #37
                                        @tekka yes, these fails come and go, I see them all the time, but not at the same place necessarily. The logs posted above show plenty of them.
                                        I don't understand this radio trouble.,the distances between the nodes are not long. The radios are all connected using all tricks, the relay is a nrf24+pa+lna which is located in a good location... Maybe all radios are crap? There is only one wifi network and it is not very busy... It's my own. Maybe I should change the channel? 110 or so sounds good. I am using default now. Power is set to max for all nodes, the nrf24+pa+lna is shielded from itself, I put small antenna extensions on the normal ones after @petewill, they all have nice caps, gw and repeater have excellent power sources, ...
                                        I found a script how to test nrf radios... Maybe I should try that?
                                        If I was going to buy new radios, just to try, which ones are the best???
                                        Edit: Hm, I think if I use antennas, it really helps if they all point into the same direction. Like all horizontal or all vertical. Which would make sens, wouldn't it?
                                        • tekkaT tekka
                                          karl261K
                                          karl261K
                                          karl261
                                          @tekka But now I found something: the repeater sketch does not work, if MY_DEBUG is commented out. I tried several times forth and back. On the gw I get the output below.
                                          0;255;3;0;9;TSP:MSG:READ 99-99-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=99)
                                          0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                                          tekkaT karl261K 2 Replies Last reply
