  3. [Solved] MySensors 2.0 Ethernet gateway (ENC28J60) restart / IP issue
49 Posts 9 Posters 28.6k Views 8 Watching
  • intelliumI intellium
    Hi all,
    I'm new to the MySensors scene (and Arduino for that matter). I seem to be having an issue with the ethernet gateway setup.
    My setup:
    Arduino Nano v3 clone
    ENC28J60 15/21 ethernet shield
    The RF24 radio module.
    It took me a while to get at least some output on this setup, which is probably due to my lack of experience. I have the system running, but the output is as follows:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 183.4.241.184
    This keeps repeating itself over and over again. The leds on the LAN port are blinking and loading up a simple test sketch works fine with this setup. In the gateway sketch however, not so much. It doesn't even seem to use the UP I have configured in the sketch :
    // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_GATEWAY_ENC28J60
    // Gateway IP address
    #define MY_IP_ADDRESS 10, 20, 1, 124
    #define MY_PORT 5003
    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEF
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #include <UIPEthernet.h>
    I think this has something to do with the UIPEthernet library, but I'm not sure. I know currently a W5100 is recommended, but I only have a bunch of ENC28J60's, which as far as I can tell, should work too.
    Anybody able to shed some light onto this ?
    TheoLT
    TheoLT
    TheoL
    @intellium As far as I can tell. It looks like your Arduino is continuously resetting itself. It should not repeat the first log you've posted.
    This can be caused by some reasons:
    1. A write operation to a memory location where it shouldn't be writing. I've experienced this last weekend why I used an strcpy wrongly. But since you're using tested software this is not likely.
    2. The circuit isn't getting enough power. And the Arduino resets itself.
    how does your circuit looks like?
    intelliumI 1 Reply Last reply
    • TheoLT TheoL
      intelliumI
      intelliumI
      intellium
      @TheoL The circuit not getting enough power was something I ran into way before my current issues :)
      Currently, the nano is feeding the RF24 module on the 3.3v line and the ENC28J60 module is fed from a separate 5v line.
      It's connected as depicted in the ethernet gateway setup Ethernet gateway - Wiring things up. This same setup works fine with a simple test sketch for the ENC module.
      I'm using the Arduino IDE 1.6.11 and the UIPEthernet library (v1.09) from here : Github - UIPEthernet
      Does this info help ?
      TheoLT 1 Reply Last reply
        TheoLT
        TheoLT
        TheoL
        @intellium I'm no expert. But does the simple example work when everything is connected (radio and LED's)?
        • TheoLT TheoL
          intelliumI
          intelliumI
          intellium
          @TheoL Yeah, it's exactly the same setup (hardware wise). Has to be something in the software part (MySensors / UIPEthernet) thats not working correctly.
          Does anybody have a working setup using MySensors 2.0 Gateway with an ENC28J60 module ?
          TheoLT YveauxY tekkaT 3 Replies Last reply
            TheoLT
            TheoLT
            TheoL
            @intellium Maybe @mfalkvidd ?
              @intellium with w5100 we currently face an issue, causing the arduino to reset, caused by a bug in the avr gcc tool chain.
              Until fixed in the tool chain and adopted by arduino there is not much more than trial and error to see if it runs stable. Reverting arduino ide won't help either, because this bug has been in for a long time.
              I'm not saying this is what is happening to you, but it just might.
              • YveauxY Yveaux
                intelliumI
                intelliumI
                intellium
                @Yveaux Hmm, thats annoying. So, if I'm experiencing this issue, I'm basically S.O.L. ? :(
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  @intellium The avr toolchain bug is related to variadic arguments used for debug prints. If you comment MY_DEBUG, do you still have the issue?
                  • tekkaT tekka
                    intelliumI
                    intelliumI
                    intellium
                    @tekka You sir, are my new best friend :)
                    Sure enough, disabling the debug and uploading the code seems to make everything work. The gateway outputs the correct IP and is now pingable !
                    tekkaT TheoLT 2 Replies Last reply
                      tekkaT
                      tekkaT
                      tekka
                      @intellium excellent :) Have fun
                        TheoLT
                        TheoLT
                        TheoL
                        @intellium @Tekka is actually the best friend for most of us ;-)
                        tekkaT 1 Reply Last reply
                        • TheoLT TheoL
                          tekkaT
                          tekkaT
                          tekka
                          @TheoL haha, that's the MySensors spirit :sparkles:
                          • intelliumI
                            intelliumI
                            intellium
                            May have spoken to soon....
                            Although the gateway now runs, after a few mins it seems to die. LAN leds keep blinking everything seems in order, but it's not pingable anymore and Domoticz starts logging messages that the gateway is unreachable. Is this somehow related? Or is this a whole different issue?
                            @tekka probably knows what to do, right? :D
                              tekkaT
                              tekkaT
                              tekka
                              @intellium can you add a serial print in loop() to see if the GW or the lan module freezes?
                              • tekkaT tekka
                                intelliumI
                                intelliumI
                                intellium
                                @tekka Sorry it took a while.
                                I gave it a try, but ever since adding print statements to the gateway loop(), the sensor nodes stopped communicating with it given FPAR failures. Even when I remove the print statements and return to the previous state, it keeps on giving FPAR failures on all sensor nodes... What would cause this ?
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @intellium hmm, hard to diagnose without additional information - could be power-related. Can you add a better/stronger power-supply?
                                  • tekkaT tekka
                                    intelliumI
                                    intelliumI
                                    intellium
                                    @tekka Before I go the route of messing with the power supply, I did some fiddling...
                                    I added the following statements to both the gateway and the sensor sketches:
                                    //LOW POWER MODE RADIO
                                    //DEBUG FOR RADIO
                                    #define MY_DEBUG_VERBOSE_RF24
                                    //RADIO THROUGHPUT
                                    #define MY_RF24_DATARATE RF24_1MBPS
                                    Next I put them a little bit closer together (around 80cm apart). The FPAR:FAIL message are gone now. I see in the output on the Sensor node that it communicates with the gateway. Currently, the gateway is running with this setup and the controller (Domoticz) gets values. So this seems to be working OK.
                                    However, on the sensor node, the log sometimes indicates an error. Something like this :
                                    RF24:write register, reg=0, value=14
                                    RF24:open writing pipe, recipient=0
                                    RF24:write register, reg=10, value=0
                                    RF24:write register, reg=16, value=0
                                    RF24:send message to 0, len=12
                                    RF24:flushTX
                                    RF24:write register, reg=7, value=48
                                    RF24:MAX_RT
                                    RF24:flushTX
                                    RF24:start listening
                                    RF24:write register, reg=0, value=15
                                    RF24:write register, reg=10, value=1
                                    !TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=fail:29.0
                                    T: 29.00
                                    RF24:write register, reg=0, value=12
                                    RF24:power down
                                    RF24:power down
                                    RF24:stop listening
                                    RF24:flushTX
                                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=ok:36.0
                                    H: 36.00
                                    RF24:power down
                                    From what I've read, the st:fail means there was an error transmitting the value. Could this still be power related ? It seems so intermittent to me that my gut tells me power isn't the issue.
                                    • intelliumI
                                      intelliumI
                                      intellium
                                      @tekka Next I tried is adding a capacitor to both the gateway and node RF module. I added a 10uF capacitor to both of them. This seems to have stabilized RF communication. I'm not seeing any failures anymore and data is flowing...
                                      Back to the original issue... The gateway that seems to die...
                                      I've added some debug statements to the loop() to see if this would keep on running when the gateway seemingly dies.
                                      After 2 hours of operation, the gateway stopped responding to pings, and the controller also noticed the gateway was not alive anymore. When this happens, the output of the serial console is :
                                      New loop iteration: 21734
                                      New loop iteration: 21735
                                      New loop iteration: 21736
                                      New loop iteration: 21737
                                      New loop iteration: 21738
                                      New loop iteration: 21739
                                      New loop iteration: 21740
                                      New loop iteration: 21741
                                      New loop iteration: 21742
                                      New loop iteration: 21743
                                      New loop iteration: 21744
                                      As you can see, my loop code keeps on running at this point, suggesting it's just the ENC interface thats no longer reachable or has an issue. When I close and re-open the serial port monitor from the Arduino IDE, the gateway springs back to life and everything starts working again.
                                      • intelliumI
                                        intelliumI
                                        intellium
                                        The next run it only took 20 mins. before the gateway stopped responding....
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @intellium Issues with ENC: https://forum.arduino.cc/index.php?topic=398258.0
                                          sounds pretty much the same...
