  3. [solved] MySensorWrapper - Wrapping sensor libraries for MySensors 2.0.x - need help
programmingideavisualmicrodevelopment
14 Posts 5 Posters 5.6k Views 4 Watching
  • TheoLT TheoL
    @Daniel-Oliveira Make sure that you have all the defines in your main sketch before including <MySensors.h>. And also include your own libraries as the last ones. So #include <MySensorWrapperBH1750.h> should be your last include in your main sketch.
    I think that will work.
    Daniel OliveiraD
    Daniel OliveiraD
    Daniel Oliveira
    Thank you once more for the help, but that is exactly what I have, and still no luck :(
    MySensors rules my home :)
    • Nca78N
      I think your problem is you are including MySensors library before the configuration is visible to the controller. The error you have means it has started to compile the MySensors.h before it checked the MySensorConfig.h and saw the #define MY_RADIO_NRF24
      You should try to remove the #ifndef _MYSENSORCONFIG_h from the MySensorConfig.h file and put it in each file where you need to include MySensors.h, and inside this condition include both MySensorConfig.h and MySensors.h :
       #include "MySensorConfig.h"
      and your "MySensorConfig.h becomes :
      // MySensorConfig.h
      #define _MYSENSORCONFIG_h
      #define MY_BAUD_RATE 9600
      #define SLEEP_TIME 5000
      Daniel OliveiraD 1 Reply Last reply
      • Nca78N Nca78
        // MySensorConfig.h
        Daniel OliveiraD
        Daniel OliveiraD
        Daniel Oliveira
        // MySensorConfig.h
        Hi and thank you for the help.
        Things apparently improved but still not there.
        Should I put the include of the MySensorConfig.h and MySensors.h as you mentioned also in the .ino file?
        And when a I have a class adding it to the header file is enough or should I also add it to the .cpp?
        Anyway I have problems in the linking stage apparently, do you have a clue?
        Compiling 'MySensorGeneric' for 'Arduino Nano w/ ATmega328'
        Build folder: file:///C:/Users/Daniel/AppData/Local/Temp/VMicroBuilds/MySensorGeneric/nano_atmega328
        Summary: Header=1 Prototypes=4 Imports=1
        Additional Defines: MY_DEBUG;
        Architecture Tools: C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/
        Sketchbook: file:\\\C:\Users\Daniel\Documents\Arduino
        Sketch Include Paths
        Include Path 'C:\Users\Daniel\Documents\Arduino\projects\MySensorGeneric'
        Core Include Paths
        Include Path 'C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino'
        Include Path 'C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs'
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\MySensorGeneric.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" -I"C:\Users\Daniel\Documents\Arduino\libraries\MySensors" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\MySensorGeneric.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" -I"C:\Users\Daniel\Documents\Arduino\libraries\MySensors" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src\SPI.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" -I"C:\Users\Daniel\Documents\Arduino\libraries\MySensors" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\MySensorGeneric.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" -I"C:\Users\Daniel\Documents\Arduino\libraries\MySensors" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750\utility" "C:\Users\Daniel\Documents\Arduino\libraries\BH1750\BH1750.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" -I"C:\Users\Daniel\Documents\Arduino\libraries\MySensors" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750\utility" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire\src" "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire\src\Wire.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" -I"C:\Users\Daniel\Documents\Arduino\libraries\MySensors" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750\utility" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire\src" "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire\src\utility\twi.c" -o "nul"
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" -I"C:\Users\Daniel\Documents\Arduino\libraries\MySensors" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750\utility" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire\src" "C:\Users\Daniel\Documents\Arduino\libraries\BH1750\BH1750.cpp" -o "nul"
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\bin\avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=106010 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\variants\eightanaloginputs" -I"C:\Users\Daniel\Documents\Arduino\libraries\MySensors" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" -I"C:\Users\Daniel\Documents\Arduino\libraries\BH1750" -I"C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire\src" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\MySensorGeneric.cpp" -o "nul"
        Building core ...
        Building libraries ...
        Using library BH1750 version 0.0.0 in folder C:\Users\Daniel\Documents\Arduino\libraries\BH1750
        Using previously compiled file: C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\BH1750\BH1750.cpp.o
        Using library MySensors version 2.0.1-beta in folder C:\Users\Daniel\Documents\Arduino\libraries\MySensors
        Using library SPI version 1.0 in folder C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI
        Using library Wire version 1.0 in folder C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire
        Building project code ...
        Using previously compiled file: C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\MySensorGeneric.cpp.o
        Using previously compiled file: C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\MySensorWrapperBH1750.cpp.o
        Linking it all together ...
        "C:\Users\Daniel\AppData\Local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-gcc" -w -Os -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328/MySensorGeneric.ino.elf" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\MySensorGeneric.cpp.o" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\Wire\Wire.cpp.o" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\Wire\utility\twi.c.o" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\SPI\SPI.cpp.o" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\BH1750\BH1750.cpp.o" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328\MySensorWrapperBH1750.cpp.o" "C:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328/core.a" "-LC:\Users\Daniel\AppData\Local\Temp\VMicroBuilds\MySensorGeneric\nano_atmega328" -lm
        MySensorWrapperBH1750.cpp.o (symbol from plugin)*: In function wakeUp1()
        (.text+0x0)*: multiple definition of wakeUp1()
        MySensorGeneric.cpp.o (symbol from plugin)*: (.text+0x0): first defined here
        (.text+0x0)*: multiple definition of _wakeUp1Interrupt
        // and similiar erros another 100 times
        collect2.exe*: error: ld returned 1 exit status
        Error compiling for board Arduino Nano w/ ATmega328
        Thank you all for the help
        • Daniel OliveiraD
          Daniel OliveiraD
          Daniel Oliveira
          Hi @tekka , @ericvdb and @Stuart-Middleton ,
          As VisualMicro users can you kindly take a look as this thread?
          Thank you in advance
          • Daniel OliveiraD Daniel Oliveira
            Daniel OliveiraD
            Daniel OliveiraD
            Daniel Oliveira
            Bump :)
            • E
              E
              ericvdb
              @Daniel-Oliveira That seems to me an issue with the build process.
              I think you better point this out on the VisualMicro Forum
              • E ericvdb
                Daniel OliveiraD
                Daniel OliveiraD
                Daniel Oliveira
                Thank you for the tip, and I bring news.
                Indeed I open a thread and after trying the suggested (that in fact was already suggested here) I found that I?m able to do what I want with another library, for example Bounce2.
                If I add #include "Bounce.h" to both my .ino file and to my MySensorWrapperBH1750.h it works flawlessly.
                In the other hand if I include have the MySensorWrapperBH1750.h like this:
                // and then my class
                And I include ONLY the MySensorWrapperBH1750.h in my .ino file I get the same error.
                What I understand from here is that even including MySensors library only once some how it is included twice when compiling.
                Does MySonsors lack somehow a "multiple inclusion protection"?
                Regards,
                  wrote on last edited by hek
                  You can only include MySensors.h once from your sketch. It drags in .cpp files.
                  So if you need MySensors things in your class, just include the stuff you need. I.e. MyMessage.h.
                    Daniel OliveiraD
                    Daniel OliveiraD
                    Daniel Oliveira
                    Hi @hek
                    As usual you are a live saviour, in this case MySensor projects saviour :)
                    Because I want to access present() and send() functions I had to include the MySensorsCore.h and then add to the project (source files) the Version.h and the MyEepromAdresses.h to be able to compile.
                    I'll do some tests and report back.
                    • Daniel OliveiraD
                      Daniel OliveiraD
                      Daniel Oliveira
                      wrote on last edited by Daniel Oliveira
                      Hi!
                      I accomplish to do what I wanted thanks to the help of you all, so I'm sharing the results :)
                      I ended up with this very simple MySensorGeneric.ino that is able to manage a DHT and a BH1750
                      * Name:		MySensorGeneric.ino
                      * Created:	20-Aug-16 22:47:51
                      * Author:	Daniel
                      * Version 0.1 - Development
                      #include "MySensorWrapperDHT.h"
                      #include "MySensorWrapperBH1750.h"
                      #define CHILD_ID_LIGHT 2
                      #define CHILD_ID_TEMP  1
                      #define CHILD_ID_HUM   0
                      MySensorWrapperBH1750 SensorBH1750(CHILD_ID_LIGHT);
                      MySensorWrapperDHT    SensorDHT(CHILD_ID_TEMP, CHILD_ID_HUM, HUMIDITY_SENSOR_DIGITAL_PIN);
                        SensorBH1750.Setup();
                        SensorDHT.Setup();
                        sendSketchInfo("My Generic Sensor", "0.11");
                        SensorBH1750.Present();
                        SensorDHT.Present();
                        SensorBH1750.UpdateSensorValue();
                        SensorDHT.UpdateSensorValue();
                        wait(SLEEP_TIME);
                      I've created a class to manage the BH1750:
                      // MySensorWrapperBH1750.h
                      #ifndef _MYSENSORWRAPPERBH1750_h
                      #define _MYSENSORWRAPPERBH1750_h
                      //Need to add to project Version.h and MyEepromAdresses.h
                      #include "MySensorsCore.h"
                      #include <BH1750.h>
                      class MySensorWrapperBH1750
                      public:
                        MySensorWrapperBH1750(uint8_t sensor_id);
                        ~MySensorWrapperBH1750();
                        void Setup();
                        void Present();
                        void UpdateSensorValue();
                      private:
                        uint8_t _sensor_id;
                        uint16_t _lastValue;
                        BH1750 _sensor;
                        MyMessage _msg;
                      * Name:		MySensorWrapperBH1750
                      * Author:	Daniel
                      * Version 0.1 - Draft
                      * MySensors Wrapper for BH1750 sensor.
                      * Wiring (I2C):
                      * Sensor -> Arduino
                      *  GND   -> GND
                      *  ADD   -> NC
                      *  SDA   -> A4
                      *  SCL   -> A5
                      *  VCC   -> +5V
                      MySensorWrapperBH1750::MySensorWrapperBH1750(uint8_t sensor_id)
                        _sensor_id = sensor_id;
                        MyMessage _msg(_sensor_id, V_LEVEL);
                      MySensorWrapperBH1750::~MySensorWrapperBH1750()
                      void MySensorWrapperBH1750::Setup()
                        // TODO: Set initialization mode
                        // Default mode:
                        // Start measurement at 1lx resolution. Measurement time is approx 120ms.
                        // #define BH1750_CONTINUOUS_HIGH_RES_MODE  0x10
                        // Device is automatically set to Power Down after measurement.
                        // #define BH1750_ONE_TIME_HIGH_RES_MODE  0x20
                        _sensor.begin();
                      void MySensorWrapperBH1750::Present()
                        present(_sensor_id, S_LIGHT_LEVEL);
                      void MySensorWrapperBH1750::UpdateSensorValue()
                        // Fetch light in Lux from BH1750 sensor
                        uint16_t newValue = _sensor.readLightLevel();// Get Lux value
                        if (isnan(newValue)) {
                          #ifdef MY_DEBUG
                              Serial.println("Failed reading Light from BH1750");
                        else if (newValue != _lastValue) {
                          #ifdef MY_DEBUG
                            Serial.print("Lux: ");
                            Serial.println(newValue);
                          send(_msg.set(newValue));
                          _lastValue = newValue;
                      And for the DHT I've created the following class:
                      // MySensorWrapperDHT.h
                      #ifndef _MYSENSORWRAPPERDHT_h
                      #define _MYSENSORWRAPPERDHT_h
                      #include "DHT.h"
                      class MySensorWrapperDHT
                      public:
                        MySensorWrapperDHT(uint8_t sensor_temp_id, uint8_t sensor_humd_id, uint8_t sensor_pin = 3);
                        ~MySensorWrapperDHT();
                        void Setup();
                        void Present();
                      private:
                        uint8_t _sensorTempId;
                        uint8_t _sensorHumdId;
                        uint8_t _sensorPin;
                        DHT _sensor;
                        MyMessage _msgTemp;
                        MyMessage _msgHumd;
                        float _lastTempValue;
                        float _lastHumdValue;
                      MySensorWrapperDHT.cpp
                      * Name:		MySensorWrapperDHT
                      * Author:	Daniel
                      * MySensors Wrapper for DHT sensor.
                      * Wiring ():
                      * Sensor -> Arduino
                      *  GND   -> GND
                      *  OUT   -> D3
                      *  VCC   -> +5V
                      * NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
                      * to 3.3V instead of 5V!
                      * Connect pin 2 of the sensor to whatever your DHTPIN is
                      * Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
                      * https://github.com/adafruit/DHT-sensor-library/blob/master/examples/DHTtester/DHTtester.ino
                      MySensorWrapperDHT::MySensorWrapperDHT(uint8_t sensor_temp_id, uint8_t sensor_humd_id, uint8_t sensor_pin)
                        _sensorTempId = sensor_temp_id;
                        _sensorHumdId = sensor_humd_id;
                        _sensorPin = sensor_pin;
                        MyMessage _msgTemp(_sensorTempId, V_TEMP);
                        MyMessage _msgHumd(_sensorHumdId, V_HUM);
                      MySensorWrapperDHT::~MySensorWrapperDHT()
                      void MySensorWrapperDHT::Setup()
                        _sensor.setup(_sensorPin, DHT::DHT22);
                      void MySensorWrapperDHT::Present()
                        present(_sensorTempId, S_TEMP);
                        present(_sensorHumdId, S_HUM);
                      void MySensorWrapperDHT::UpdateSensorValue()
                        // TODO: really needed?
                        wait(_sensor.getMinimumSamplingPeriod());
                        // Reading temperature or humidity takes about 250 milliseconds!
                        // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
                        float currentTempValue = _sensor.getTemperature();
                        float currentHumdValue = _sensor.getHumidity();
                        // Check if any reads failed and exit early (to try again).
                        if (isnan(currentTempValue) || isnan(currentHumdValue) ){
                          Serial.println("Failed to read from DHT sensor!");
                        else {
                          // Update temperature from DHT sensor
                          if (currentTempValue != _lastTempValue) {
                            _lastTempValue = currentTempValue;
                            send(_msgTemp.set(currentTempValue, true));
                            #ifdef MY_DEBUG
                              Serial.print("Temp: ");
                              Serial.println(currentTempValue);
                          // Update humidity from DHT sensor
                          if (currentHumdValue != _lastHumdValue) {
                            _lastHumdValue = currentHumdValue;
                            send(_msgHumd.set(currentHumdValue, 1));
                            #ifdef MY_DEBUG
                              Serial.print("Hum: ");
                              Serial.println(currentHumdValue);
                      And to my surprise the footprint after compiling is even smaller, 18,374 bytes (59%) of program storage space and 913 bytes (44%) of dynamic memory with a single .ino versus 17,748 bytes (58%) of program storage space and 857 bytes (42%) of dynamic memory the above project in VisualMicro. Both results with MY_DEBUG defined.
                      Next step is to create classes to manage switches, relays and LEDs.
                      Once again thank you all for the help and fell free to share your opinions about the way I'm trying to do things.
                      Best regards
                      12.5k
