  3. Curtain Control Node.
domoticzcurtain controlmysensors node
51 Posts 15 Posters 31.1k Views 22 Watching
  • Tore André RosanderT Tore André Rosander
    @AWI
    I have been searching for something like this for a while, thank you for the code!
    But i have some problems compiling it :\
    C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void saveStateL(int, long int)':
    stepper_mysensor:74: error: 'saveState' was not declared in this scope
             saveState(EEposition + y , convLongInt.LongByte[y]) ;
    C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'long int loadStateL(int)':
    stepper_mysensor:81: error: 'loadState' was not declared in this scope
             convLongInt.LongByte[y] = loadState(EEposition + y) ;
    C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void presentation()':
    stepper_mysensor:129: error: 'present' was not declared in this scope
       present(CHILD_ID, S_COVER, "Curtain");                        // Window Cover sub-type, commands: V_UP, V_DOWN, V_STOP
    stepper_mysensor:132: error: 'sendSketchInfo' was not declared in this scope
       sendSketchInfo(SN, SV);
    C:\Users\ToreR\Documents\Arduino\stepper_mysensor\stepper_mysensor.ino: In function 'void loop()':
    stepper_mysensor:195: error: 'send' was not declared in this scope
                 send( percentageMsg.set((100 * setPosition)/(closedPosition - openPosition))) ;
    exit status 1
    'saveState' was not declared in this scope```
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    @Tore-André-Rosander are you using the development branch? The errors seem to indicate that is the case.
    Tore André RosanderT 1 Reply Last reply
    • AWIA AWI
      Tore André Rosander
      @AWI Thank you, that helped :)
      I now have it up and running.
      But how do i connect and use this with a controller (like Domoticz)?
      I use an ESP gateway (from the dev branch) and the curtain node is connected and showing up in domoticz.
      But how do i make domoticz send commands to the curtain node?
      All i get when adding the curtain node both as on/off button and blinds in domoticz is "unreconized" in the curtain serial monoitor.
      AWIA 1 Reply Last reply
        AWIA
        AWIA
        AWI
        @Tore-André-Rosander I have defined it as "Blinds Percentage" in Domoticz. This send the V_STATUS and V_PERCENTAGE messages where the node should respond to...
        0_1458557025507_upload-d16cb932-d511-433f-9488-112b68d308f4
        • AWIA AWI
          Tore André Rosander
          @AWI THanks again for your fast replys!
          This is what i get in serial monitor when i use the "up" "down" buttons for blinds percentage in domoticz.
          This is my very first MySensor setup so it might be some error with my setup, i will have a deeper look at it later tonight.
          Starting sensor (RNNNA-, 2.0.0-beta)
          Radio init successful.
          State read: -1
          State read: -1
          send: 13-13-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
          send: 13-13-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
          send: 13-13-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
          read: 0-0-13 s=255,c=3,t=15,pt=0,l=2,sg=0:
          read: 0-0-13 s=255,c=3,t=6,pt=0,l=1,sg=0:M
          send: 13-13-0-0 s=1,c=0,t=5,pt=0,l=7,sg=0,st=ok:Curtain
          send: 13-13-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Curtain control 13
          send: 13-13-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
          Init complete, id=13, parent=0, distance=1
          read: 0-0-13 s=1,c=1,t=29,pt=0,l=0,sg=0:
          Message - valid: 1, Unrecognized read: 0-0-13 s=1,c=1,t=30,pt=0,l=0,sg=0:
          Message - valid: 1, Unrecognized read: 0-0-13 s=1,c=1,t=29,pt=0,l=0,sg=0:
          Message - valid: 1, Unrecognized```
            State read: -1
            State read: -1
            AWIA
            AWIA
            AWI
            @Tore-André-Rosander Nothing wrong with you interpretation. I have not written this sketch as a complete S_COVER implementation. Only the V_PERCENTAGE part (not V_UP/V_DOWN). If you define it in Domoticz as "Blinds percentage" (see my previous post) it will work. Sorry for the confusion.
            • AWIA AWI
              Tore André Rosander
              @AWI Seems like my problem is with Domoticz itselfe.
              I have the same problem as described in this post https://www.domoticz.com/forum/viewtopic.php?f=6&t=7748
                AWIA
                AWIA
                AWI
                @Tore-André-Rosander You can probably solve it by deleting the sensor in Domoticz and let the sketch present itself as S_DIMMER (and use another sensor id)
                  Tore André Rosander
                  Maybe its because i have not calibrated it? I dont have any pushbuttons laying around, so im gonna make one with some wires. But i see that there is two pins defined as buttons. Should i use the buttonPin1 as VCC?
                  So it would look something like buttonPin1 -> buttonPin2 -> button -> gnd?
                    AWIA
                    AWIA
                    AWI
                    @Tore-André-Rosander You can ignore buttonpin2. Just connect your "button" to buttonpin1 and ground.
                    • AWIA AWI
                      Looks good. I am curious to see the details... jealous for the speed :runner: your curtain is moving.
                      I have been working on a similar project last week. The mechanics and ´looks´ are the most difficult part for me.
                      For now I have used a ´tuned´ cheap & small stepper which makes it slooow but effective ;-) The rail and mounting is standard IKEA. The pro-mini has the jModule attached. Works like a charm (/snail)!
                      0_1457980545567_upload-c50fc1e9-f23e-458d-a812-62ad4bf478e0
                      0_1457981153586_upload-c7064209-3900-4e4b-b335-8c88721367c0
                      TheoLT
                      TheoLT
                      TheoL
                      @AWI I'm curious where you got the rails for the curtain. I wasn't been able to find them, but stumbled on this topic.
                      • TheoLT TheoL
                        AWIA
                        AWIA
                        AWI
                        @TheoL Ikea :smile:
                        TheoLT 1 Reply Last reply
                        • AWIA AWI
                          @TheoL Ikea :smile:
                          TheoLT
                          TheoLT
                          TheoL
                          @AWI Really interested in the mechanics ;-)
                          • franzelareF
                            franzelareF
                            franzelare
                            I'm currently working on a similar project, only I got started with 24V DC motors that I got from my work (left overs from a test project) These motors are very strong (way way over rated) and have a big gearbox what unfortunately makes the movement a bit slow.
                            I started off with 1 motor to move 2 curtains at the same time, but will change this to 2 motors for either side since the better half of me likes to control the curtains separately in case she only wants to close 1.
                            Next to the automation there will also be a manual control switch be hidden behind the curtains in case the node is down and I'm not at home to fix the issue...
                            all running on an ESP8266 (ESP-12e) unit to have it over WiFi and have enough io
                            Currently the test setup is working fine and I'm ordering parts to start implementing this a bit bigger in the first room. the test setup I made with some old wood 1 meter of rail and a few old rugs as curtains...
                            I use a GT2 timing belt that is commently used for 3D printers and pully's are widely available as well as the belts in different lengths (I order them on rolls of 10 meters) and attached the timing belt to a carriage that is normally to pull the curtains with a rod.
                            the motor is mounted on a bracket with currently 2 end stop switches for open and close (but will be 1 switch for open and 1 for close in the final solution)
                            resulting in driving the curtain from 1 side
                            electronics are working fine now and need to be ported to a test print and later to a real PCB design
                            • R
                              R
                              romeok01
                              wrote on last edited by romeok01
                              #31
                              Hello.
                              To my project i use stepper motor JK42HS34-0404 and driver L298N.
                              This is a wiring diagram.
                              This is a program code that I use
                              #include <AccelStepper.h>
                              #define HALFSTEP 4  // Stepper uses "Halfstep" mode
                              #define CURTAIN_CLOSED 1000 // value when closed
                              #define CURTAIN_OPEN 0 // value when open
                              // MySensors definitions
                              // Initialize message
                              // Motor pin definitions
                              #define motorPin1  3     // IN1 on the ULN2003 driver 1
                              #define motorPin2  4     // IN2 on the ULN2003 driver 1
                              #define motorPin3  5     // IN3 on the ULN2003 driver 1
                              #define motorPin4  6     // IN4 on the ULN2003 driver 1
                              // Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
                              AccelStepper stepper1(HALFSTEP, motorPin1, motorPin2, motorPin3, motorPin4);
                              unsigned long current_position ; // remembers current position, need to be saved in EEPROM?
                                // MySensors
                                gw.begin(); // fixed node 13
                                gw.sendSketchInfo("Curtain control 13", "1.0"); // Send the sketch version information to the gateway and Controller
                                //pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
                                gw.present(CHILD_ID, S_COVER); // Window Cover sub-type, commands: V_UP, V_DOWN, V_STOP
                                stepper1.setMaxSpeed(500.0);
                                stepper1.setAcceleration(700.0);
                                stepper1.moveTo(CURTAIN_OPEN);
                                current_position = CURTAIN_OPEN ;
                              }//--(end setup )---
                                // if message = V_UP start moving until closed
                                // if message = V_DOWN start moving back until open
                                // if message = V_STOP stop moving
                                // Test: Change direction when the stepper reaches the target position
                                gw.process(); // check if message from controller
                                if (stepper1.distanceToGo() == 0){
                                  if (stepper1.currentPosition() == CURTAIN_OPEN){
                                    stepper1.moveTo(CURTAIN_CLOSED);
                                    Serial.println("Curtain Open, now closing");
                                    gw.request(CHILD_ID, V_UP, 0); // request new values from controller
                                  else{
                                    Serial.println("Curtain Closed, now opening");
                                    gw.request(CHILD_ID, V_DOWN, 0); // request new values from controller
                                stepper1.run();
                              // This is called when a message is received
                                // We only expect few types of messages from controller, check which
                                stepper1.moveTo(message.getInt() * CURTAIN_CLOSED/100);
                                Serial.print("Message - valid: ");
                                Serial.print(" , value: % ");
                                switch (message.getInt()) {
                                case 100:
                                  // Curtain should be opened
                                   Serial.print(", Message UP ");
                                case 0:
                                  // Curtain should be closed
                                   Serial.print(", Message DOWN ");
                                case 50:
                                  // Curtain action should be stopped
                                   Serial.print(", Message STOP ");
                                default:
                                  // not recognizable message
                                   Serial.print(", Unrecognized ");
                              When the program I have uploaded to my mysensors, the engine still turns, one left and one to the right and did not work the button blinds in Domoticz.
                              I cant turn off my stepper motor in Domoticz.
                              https://www.youtube.com/embed/1Wc1p_9YDQQ
                              Please help me.
                              • R
                                R
                                romeok01
                                I write a program on library Stepper not AccelStepper.
                                Now is working.
                                Program code:
                                #define MY_REPEATER_FEATURE
                                #include <Stepper.h>
                                #define CURTAIN_CLOSED 1000  // wartosc gdy kurtyna zamknieta
                                #define CURTAIN_OPEN -1000         // wartosc gdy kurtyna otwarta
                                #define CHILD_ID 1
                                // definicje MySensors
                                MyMessage message(CHILD_ID, S_COVER);
                                int in1Pin = 3;
                                int in2Pin = 4;
                                int in3Pin = 5;
                                int in4Pin = 6;
                                int lastState;
                                // liczba kroków na jeden obrót
                                #define stepsPerRevolution 200
                                //ustawienie szybkości silnika
                                int motorSpeed = 40;
                                Stepper myStepper(stepsPerRevolution, in1Pin, in2Pin, in3Pin, in4Pin);
                                // ustawienie pinów jako wyjście
                                  pinMode(in1Pin, OUTPUT);
                                  pinMode(in2Pin, OUTPUT);
                                  pinMode(in3Pin, OUTPUT);
                                  pinMode(in4Pin, OUTPUT);
                                // ustawienie szybkosci silnika
                                  myStepper.setSpeed(motorSpeed);
                                  // Wyslanie informacji o wersji programu
                                  sendSketchInfo("Program kurtyna", "1.0");
                                  if (message.type==V_UP) {
                                     myStepper.step(CURTAIN_OPEN);
                                     // Store state in eeprom
                                 if (message.type==V_DOWN) {
                                     myStepper.step(CURTAIN_CLOSED);
                                I use MySensors Library 2.0
                                Youtube film
                                https://www.youtube.com/embed/gm0r2kDXrt4
                                • franzelareF
                                  franzelareF
                                  franzelare
                                  your wiring diagram is not accessable:
                                  Error (403)
                                  It seems you don't belong here! You should probably sign in. Check out our Help Center and forums for help, or head back to home.
                                  i use a DC motor so can't help with stepper motors, but can you share an image of how you setup your rails?
                                  • R
                                    R
                                    romeok01
                                    Now the wiring diagram should be visible.
                                    • R
                                      R
                                      romeok01
                                      I write program with AccelStepper library
                                      / Enable debug prints to serial monitor
                                      #include <AccelStepper.h>      //import biblioteki AccelStepper
                                      #define HALFSTEP 8
                                      #define CURTAIN_CLOSED 2000  // wartosc gdy kurtyna zamknieta
                                      #define CURTAIN_OPEN 0       // wartosc gdy kurtyna otwarta
                                      #define CHILD_ID 1
                                      // Definicja pinow silnika
                                      #define IN1  3     // IN1 - zielony
                                      #define IN2  4     // IN2 - czarny
                                      #define IN3  5     // IN3 - niebieski
                                      #define IN4  6     // IN4 - czerwony
                                      AccelStepper stepper1(HALFSTEP, IN1, IN2, IN3, IN4);
                                        stepper1.setMaxSpeed(200.0);
                                        stepper1.setAcceleration(1000.0);
                                        stepper1.setSpeed(200);
                                        stepper1.run();  //Start
                                          if (message.type==V_STOP) {
                                              stepper1.setCurrentPosition(0);
                                              request(CHILD_ID, V_STOP, 0); // request new values from controller
                                      I use MySensors library 2.0
                                      Now i working.
                                      • J
                                        J
                                        jacikaas
                                        I trying to adopt the code for 28BYJ-48 stepper motor with ULN2003 driver board for roller blinds control. Code is working, but when the stepper motor is always on - it gets hot. Because of it also its consumes more energy. So thats why I want to turn on ULN2003 board only when new action is started, and after that it should be shuted down again. I could do it, because ULN2003 has On/Off jumper:
                                        Question #1: I trying to use relay for that On/Off. Could I do it without relay and control On/Off jumper directly from arduino? Does relay is the best solution?
                                        Question #2: I suck at programming, but I trying to add theese lines to my code to control the relay SIL05-1A72-71D, which controls the ULN2003 driver board:
                                        int powerPin = 7; //before SETUP
                                        pinMode(powerPin, OUTPUT); // In SETUP
                                        digitalWrite(powerPin, LOW); // In SETUP
                                        digitalWrite(powerPin, HIGH); // In void receive function
                                        delay(CURTAIN_CLOSED); // In void receive function
                                        digitalWrite(powerPin, LOW); // In void receive function
                                        digitalWrite(powerPin, HIGH); - I think is in right position, but I don't know how to turn off relay when action is done. Please advise for coding, because I not good in it. Thank You! Below is the code:
                                        #define MY_NODE_ID 10
                                        //#define MY_REPEATER_FEATURE
                                        #define HALFSTEP 8
                                        #define CURTAIN_CLOSED 10000  // wartosc gdy kurtyna zamknieta
                                        #define CHILD_ID 1
                                        int powerPin = 7;
                                        AccelStepper stepper1(HALFSTEP, IN1, IN3, IN2, IN4);
                                          stepper1.setMaxSpeed(1000.0);
                                          stepper1.setAcceleration(100.0);
                                          sendSketchInfo("Roller blinds", "1.0");
                                         //   delay(CURTAIN_CLOSED);
                                         //   digitalWrite(powerPin, LOW);
                                        Suresh MaliS 1 Reply Last reply
                                        • J jacikaas
                                          #define HALFSTEP 8
                                          #define CHILD_ID 1
                                          int powerPin = 7;
                                          Suresh MaliS
                                          Suresh MaliS
                                          Suresh Mali
                                          @jacikaas said in Curtain Control Node.:
                                          You can enable and disable outputs and try. In the following function:
                                          //add the following at the begining of the function
                                          stepper1.enableOutputs ()
                                          //and add the following at the end in the same function.
                                          stepper1.disableOutputs ()
                                          I hope this helps haven't tried it myself.
                                          J 1 Reply Last reply
