  3. Curtain Control Node.
domoticzcurtain controlmysensors node
51 Posts 15 Posters 31.1k Views 22 Watching
  • Tore André RosanderT Tore André Rosander
    @AWI Seems like my problem is with Domoticz itselfe.
    I have the same problem as described in this post https://www.domoticz.com/forum/viewtopic.php?f=6&t=7748
    AWIA
    AWIA
    AWI
    @Tore-André-Rosander You can probably solve it by deleting the sensor in Domoticz and let the sketch present itself as S_DIMMER (and use another sensor id)
      Tore André Rosander
      Maybe its because i have not calibrated it? I dont have any pushbuttons laying around, so im gonna make one with some wires. But i see that there is two pins defined as buttons. Should i use the buttonPin1 as VCC?
      So it would look something like buttonPin1 -> buttonPin2 -> button -> gnd?
      AWIA 1 Reply Last reply
        AWIA
        AWIA
        AWI
        @Tore-André-Rosander You can ignore buttonpin2. Just connect your "button" to buttonpin1 and ground.
        • AWIA AWI
          Looks good. I am curious to see the details... jealous for the speed :runner: your curtain is moving.
          I have been working on a similar project last week. The mechanics and ´looks´ are the most difficult part for me.
          For now I have used a ´tuned´ cheap & small stepper which makes it slooow but effective ;-) The rail and mounting is standard IKEA. The pro-mini has the jModule attached. Works like a charm (/snail)!
          0_1457980545567_upload-c50fc1e9-f23e-458d-a812-62ad4bf478e0
          0_1457981153586_upload-c7064209-3900-4e4b-b335-8c88721367c0
          TheoLT
          TheoLT
          TheoL
          @AWI I'm curious where you got the rails for the curtain. I wasn't been able to find them, but stumbled on this topic.
          • TheoLT TheoL
            AWIA
            AWIA
            AWI
            @TheoL Ikea :smile:
            TheoLT 1 Reply Last reply
            • AWIA AWI
              @TheoL Ikea :smile:
              TheoLT
              TheoLT
              TheoL
              @AWI Really interested in the mechanics ;-)
              • franzelareF
                franzelareF
                franzelare
                I'm currently working on a similar project, only I got started with 24V DC motors that I got from my work (left overs from a test project) These motors are very strong (way way over rated) and have a big gearbox what unfortunately makes the movement a bit slow.
                I started off with 1 motor to move 2 curtains at the same time, but will change this to 2 motors for either side since the better half of me likes to control the curtains separately in case she only wants to close 1.
                Next to the automation there will also be a manual control switch be hidden behind the curtains in case the node is down and I'm not at home to fix the issue...
                all running on an ESP8266 (ESP-12e) unit to have it over WiFi and have enough io
                Currently the test setup is working fine and I'm ordering parts to start implementing this a bit bigger in the first room. the test setup I made with some old wood 1 meter of rail and a few old rugs as curtains...
                I use a GT2 timing belt that is commently used for 3D printers and pully's are widely available as well as the belts in different lengths (I order them on rolls of 10 meters) and attached the timing belt to a carriage that is normally to pull the curtains with a rod.
                the motor is mounted on a bracket with currently 2 end stop switches for open and close (but will be 1 switch for open and 1 for close in the final solution)
                resulting in driving the curtain from 1 side
                electronics are working fine now and need to be ported to a test print and later to a real PCB design
                • R
                  R
                  romeok01
                  wrote on last edited by romeok01
                  #31
                  Hello.
                  To my project i use stepper motor JK42HS34-0404 and driver L298N.
                  This is a wiring diagram.
                  This is a program code that I use
                  #include <AccelStepper.h>
                  #define HALFSTEP 4  // Stepper uses "Halfstep" mode
                  #define CURTAIN_CLOSED 1000 // value when closed
                  #define CURTAIN_OPEN 0 // value when open
                  // MySensors definitions
                  // Initialize message
                  // Motor pin definitions
                  #define motorPin1  3     // IN1 on the ULN2003 driver 1
                  #define motorPin2  4     // IN2 on the ULN2003 driver 1
                  #define motorPin3  5     // IN3 on the ULN2003 driver 1
                  #define motorPin4  6     // IN4 on the ULN2003 driver 1
                  // Initialize with pin sequence IN1-IN3-IN2-IN4 for using the AccelStepper with 28BYJ-48
                  AccelStepper stepper1(HALFSTEP, motorPin1, motorPin2, motorPin3, motorPin4);
                  unsigned long current_position ; // remembers current position, need to be saved in EEPROM?
                    // MySensors
                    gw.begin(); // fixed node 13
                    gw.sendSketchInfo("Curtain control 13", "1.0"); // Send the sketch version information to the gateway and Controller
                    //pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as input
                    gw.present(CHILD_ID, S_COVER); // Window Cover sub-type, commands: V_UP, V_DOWN, V_STOP
                    stepper1.setMaxSpeed(500.0);
                    stepper1.setAcceleration(700.0);
                    stepper1.moveTo(CURTAIN_OPEN);
                    current_position = CURTAIN_OPEN ;
                  }//--(end setup )---
                    // if message = V_UP start moving until closed
                    // if message = V_DOWN start moving back until open
                    // if message = V_STOP stop moving
                    // Test: Change direction when the stepper reaches the target position
                    gw.process(); // check if message from controller
                    if (stepper1.distanceToGo() == 0){
                      if (stepper1.currentPosition() == CURTAIN_OPEN){
                        stepper1.moveTo(CURTAIN_CLOSED);
                        Serial.println("Curtain Open, now closing");
                        gw.request(CHILD_ID, V_UP, 0); // request new values from controller
                      else{
                        Serial.println("Curtain Closed, now opening");
                        gw.request(CHILD_ID, V_DOWN, 0); // request new values from controller
                    stepper1.run();
                  // This is called when a message is received
                    // We only expect few types of messages from controller, check which
                    stepper1.moveTo(message.getInt() * CURTAIN_CLOSED/100);
                    Serial.print("Message - valid: ");
                    Serial.print(" , value: % ");
                    switch (message.getInt()) {
                    case 100:
                      // Curtain should be opened
                       Serial.print(", Message UP ");
                    case 0:
                      // Curtain should be closed
                       Serial.print(", Message DOWN ");
                    case 50:
                      // Curtain action should be stopped
                       Serial.print(", Message STOP ");
                    default:
                      // not recognizable message
                       Serial.print(", Unrecognized ");
                  When the program I have uploaded to my mysensors, the engine still turns, one left and one to the right and did not work the button blinds in Domoticz.
                  I cant turn off my stepper motor in Domoticz.
                  https://www.youtube.com/embed/1Wc1p_9YDQQ
                  Please help me.
                  • R
                    R
                    romeok01
                    I write a program on library Stepper not AccelStepper.
                    Now is working.
                    Program code:
                    #define MY_REPEATER_FEATURE
                    #include <Stepper.h>
                    #define CURTAIN_CLOSED 1000  // wartosc gdy kurtyna zamknieta
                    #define CURTAIN_OPEN -1000         // wartosc gdy kurtyna otwarta
                    #define CHILD_ID 1
                    // definicje MySensors
                    MyMessage message(CHILD_ID, S_COVER);
                    int in1Pin = 3;
                    int in2Pin = 4;
                    int in3Pin = 5;
                    int in4Pin = 6;
                    int lastState;
                    // liczba kroków na jeden obrót
                    #define stepsPerRevolution 200
                    //ustawienie szybkości silnika
                    int motorSpeed = 40;
                    Stepper myStepper(stepsPerRevolution, in1Pin, in2Pin, in3Pin, in4Pin);
                    // ustawienie pinów jako wyjście
                      pinMode(in1Pin, OUTPUT);
                      pinMode(in2Pin, OUTPUT);
                      pinMode(in3Pin, OUTPUT);
                      pinMode(in4Pin, OUTPUT);
                    // ustawienie szybkosci silnika
                      myStepper.setSpeed(motorSpeed);
                      // Wyslanie informacji o wersji programu
                      sendSketchInfo("Program kurtyna", "1.0");
                      if (message.type==V_UP) {
                         myStepper.step(CURTAIN_OPEN);
                         // Store state in eeprom
                     if (message.type==V_DOWN) {
                         myStepper.step(CURTAIN_CLOSED);
                    I use MySensors Library 2.0
                    Youtube film
                    https://www.youtube.com/embed/gm0r2kDXrt4
                    • franzelareF
                      franzelareF
                      franzelare
                      your wiring diagram is not accessable:
                      Error (403)
                      It seems you don't belong here! You should probably sign in. Check out our Help Center and forums for help, or head back to home.
                      i use a DC motor so can't help with stepper motors, but can you share an image of how you setup your rails?
                      • R
                        R
                        romeok01
                        Now the wiring diagram should be visible.
                        • R
                          R
                          romeok01
                          I write program with AccelStepper library
                          / Enable debug prints to serial monitor
                          #include <AccelStepper.h>      //import biblioteki AccelStepper
                          #define HALFSTEP 8
                          #define CURTAIN_CLOSED 2000  // wartosc gdy kurtyna zamknieta
                          #define CURTAIN_OPEN 0       // wartosc gdy kurtyna otwarta
                          #define CHILD_ID 1
                          // Definicja pinow silnika
                          #define IN1  3     // IN1 - zielony
                          #define IN2  4     // IN2 - czarny
                          #define IN3  5     // IN3 - niebieski
                          #define IN4  6     // IN4 - czerwony
                          AccelStepper stepper1(HALFSTEP, IN1, IN2, IN3, IN4);
                            stepper1.setMaxSpeed(200.0);
                            stepper1.setAcceleration(1000.0);
                            stepper1.setSpeed(200);
                            stepper1.run();  //Start
                              if (message.type==V_STOP) {
                                  stepper1.setCurrentPosition(0);
                                  request(CHILD_ID, V_STOP, 0); // request new values from controller
                          I use MySensors library 2.0
                          Now i working.
                          • J
                            J
                            jacikaas
                            I trying to adopt the code for 28BYJ-48 stepper motor with ULN2003 driver board for roller blinds control. Code is working, but when the stepper motor is always on - it gets hot. Because of it also its consumes more energy. So thats why I want to turn on ULN2003 board only when new action is started, and after that it should be shuted down again. I could do it, because ULN2003 has On/Off jumper:
                            Question #1: I trying to use relay for that On/Off. Could I do it without relay and control On/Off jumper directly from arduino? Does relay is the best solution?
                            Question #2: I suck at programming, but I trying to add theese lines to my code to control the relay SIL05-1A72-71D, which controls the ULN2003 driver board:
                            int powerPin = 7; //before SETUP
                            pinMode(powerPin, OUTPUT); // In SETUP
                            digitalWrite(powerPin, LOW); // In SETUP
                            digitalWrite(powerPin, HIGH); // In void receive function
                            delay(CURTAIN_CLOSED); // In void receive function
                            digitalWrite(powerPin, LOW); // In void receive function
                            digitalWrite(powerPin, HIGH); - I think is in right position, but I don't know how to turn off relay when action is done. Please advise for coding, because I not good in it. Thank You! Below is the code:
                            #define MY_NODE_ID 10
                            //#define MY_REPEATER_FEATURE
                            #define HALFSTEP 8
                            #define CURTAIN_CLOSED 10000  // wartosc gdy kurtyna zamknieta
                            #define CHILD_ID 1
                            int powerPin = 7;
                            AccelStepper stepper1(HALFSTEP, IN1, IN3, IN2, IN4);
                              stepper1.setMaxSpeed(1000.0);
                              stepper1.setAcceleration(100.0);
                              sendSketchInfo("Roller blinds", "1.0");
                             //   delay(CURTAIN_CLOSED);
                             //   digitalWrite(powerPin, LOW);
                            Suresh MaliS 1 Reply Last reply
                            • J jacikaas
                              #define HALFSTEP 8
                              #define CHILD_ID 1
                              int powerPin = 7;
                              Suresh MaliS
                              Suresh MaliS
                              Suresh Mali
                              @jacikaas said in Curtain Control Node.:
                              You can enable and disable outputs and try. In the following function:
                              //add the following at the begining of the function
                              stepper1.enableOutputs ()
                              //and add the following at the end in the same function.
                              stepper1.disableOutputs ()
                              I hope this helps haven't tried it myself.
                              J 1 Reply Last reply
                              • Suresh MaliS Suresh Mali
                                J
                                J
                                jacikaas
                                @suresh-mali Thank You Suresh for Your answer!
                                I disconnect relay and delete it lines from the code.
                                I add lines to code like You said:
                                stepper1.enableOutputs ();
                                 // rest of code
                                stepper1.disableOutputs ();
                                It looks like it have to work because it is simple solution, but it doesn't... On driver board ULN2003, when motor is not rotating, A Led is always on. I think if command with disableOutputs would be activated, then the LED should not be on?
                                • J jacikaas
                                   // rest of code
                                  Suresh MaliS
                                  Suresh MaliS
                                  Suresh Mali
                                  wrote on last edited by Suresh Mali
                                  #39
                                  @jacikaas Ok.
                                  //Remove this line from loop function
                                  stepper1.run();
                                  //Change this line
                                  //to
                                  stepper1.runToPosition(CURTAIN_CLOSED);
                                  I hope this works. Also make similar changes in block which closes curtains.
                                  Refernce article: https://www.pjrc.com/teensy/td_libs_AccelStepper.html
                                  • J
                                    J
                                    jacikaas
                                    @suresh-mali
                                    I now reading about that funktions in http://www.airspayce.com/mikem/arduino/AccelStepper/classAccelStepper.html#a344f58fef8cc34ac5aa75ba4b665d21c
                                    Did what You said, but getting error: no matching function for call to 'AccelStepper::runToPosition(int)'
                                    I paste here all code, but I think I did everything without mistakes:
                                    #define HALFSTEP 8
                                    #define CHILD_ID 1
                                    // int powerPin = 7;
                                      //stepper1.run();  //Start
                                    skywatchS 1 Reply Last reply
                                    • J jacikaas
                                      @suresh-mali
                                      #define HALFSTEP 8
                                      #define CHILD_ID 1
                                      skywatchS
                                      skywatchS
                                      skywatch
                                      @jacikaas Sorry to revive an old thread, but did you get this resolved and if so how?
                                      I just 3D printed my first motorised roller blind mounts and have tested with arduino stepper only.
                                      Next is to go mysensors with it, but which way is best? Standard arduino stepper or accelstepper?
                                      • xydixX
                                        xydixX
                                        xydix
                                        Okey. This is an old thread but I hope it's ok I keep it alive.
                                        I just printed som parts for my blinds.
                                        I use a stepper motor (28BYJ-48 with ULN2003 Driver board) and this sketch found in this thread.
                                        The sketch is awesome.
                                        To my quiestion.
                                        I want to run 2 blinds at the same time from ONE node. Synchronized or maybe individual.
                                        Is this possible?
                                        There isn't any digital pins over for this when using button(s).
                                        I think i saw someone using analog pin connected to the ULN2003 someware.
                                        Is it possible to run 2 motors on one board?
                                        Really hope somone can answer som of my question.
                                        What modifications is needed in the sketch if this is possible.
                                        This is the sketch I use.
                                         PROJECT: MY Sensors curtain controller
                                         PROGRAMMER: AWI
                                         DATE: march 11, 2016
                                         FILE: AWI stepper1.ino
                                         LICENSE: Public domain
                                         Hardware: ATMega328p board w/ NRF24l01
                                        	and MySensors 2.0 (Development)
                                        Special:
                                        	uses AccelStepper library
                                        Summary:
                                        	Curtain control with stepper motor.
                                        	Manual operation with 1 push button
                                        	Calibration with manual button
                                        Remarks:
                                        	Fixed node-id
                                        Change log:
                                        20160312 - Cleanup
                                        #define MY_NODE_ID 13											// fixed node number
                                        #define MY_RADIO_RF24
                                        // stepper library
                                        #include <AccelStepper.h>										// http://www.airspayce.com/mikem/arduino/AccelStepper/
                                        #define HALFSTEP 8  											// Stepper uses "Halfstep" mode
                                        // button library
                                        // used for:
                                        // - manual open close - single click: close/ stop/ open/ stop
                                        // - calibration  - after long press: open calibarion- until single press - closed calibration - until single press (stop)
                                        #include <Button.h>												// https://github.com/JChristensen/Button
                                        #define SN "Curtain control 13"
                                        #define SV "1.0"
                                        #define buttonPin1 7  											// Arduino pin connected to buttonPin1
                                        #define buttonPin2 A0  											// Arduino pin connected to buttonPin2 (fixed to ground)
                                        const unsigned long heartbeatInterval = 1 * 3600UL * 1000UL ;	// heartbeatinterval
                                        unsigned long heartbeatCounter = 0 ;
                                        // helper routines to store and retrieve long in mysensors EEPROM
                                        union {															// used to convert long to bytes for EEPROM storage
                                        	long longInt;
                                        	uint8_t LongByte[4];
                                        	} convLongInt ;
                                        void saveStateL(int EEposition, long StateL){
                                        	convLongInt.longInt = StateL ;
                                        	for (int y = 0; y < 4 ; y++){								// convert to bytes
                                        		saveState(EEposition + y , convLongInt.LongByte[y]) ;
                                        	Serial.print("State saved: "); Serial.println(StateL);
                                        long loadStateL(int EEposition){
                                        	for (int y = 0; y < 4 ; y++){								// convert from bytes
                                        		convLongInt.LongByte[y] = loadState(EEposition + y) ;
                                        	Serial.print("State read: "); Serial.println(convLongInt.longInt);
                                        	return convLongInt.longInt ;
                                        AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
                                        // Initialize button active low, debounce and internal pull-up
                                        Button myBtn(buttonPin1, true, true, 40);						// Initiate the button (pin, pull_up, invert, debounce_ms)
                                        MyMessage percentageMsg(CHILD_ID, V_PERCENTAGE);				// used to send updates to controller
                                        const long maxRun = 4000000L ;									// maximum runway
                                        long setPosition = 0 ; 											// remembers set position, need to be saved in EEPROM
                                        const int setPositionEE = 4 ;									// eeprom location
                                        long openPosition = 0 ; 										// Position at open, need to be saved in EEPROM?
                                        const int openPositionEE = setPositionEE + 4 ;					// eeprom location
                                        long closedPosition = 120000UL ; 								// Position at full close, need to be saved in EEPROM
                                        const int closedPositionEE = openPositionEE + 4 ;				// eeprom location
                                        unsigned long idleTimer = millis() ;							// return to idle timer
                                        unsigned long idleTime = 100000UL ;								// return to idle after 100 secs
                                        unsigned long printTimer = millis() ;							// print timer
                                        unsigned long printTime = 1000UL ;								// print after 1 secs
                                        enum position_t {Open, Close, Idle, Running} ;
                                        position_t lastDirection = Open ; 								// lastDirection only for buttonpress
                                        position_t runStatus = Idle ;									// indicates current status for running motor. used for status reporting to controller
                                        enum State_t {sIdle, sCalibrateOpen, sCalibrateClose} ;
                                        State_t State = sIdle ;
                                        	// setup buttons
                                        	pinMode(buttonPin1, OUTPUT);
                                        	stepper1.setMaxSpeed(2000.0);
                                        	//saveStateL(closedPositionEE, closedPosition) ; 			// INIT: save closed position in EEPROM
                                        	closedPosition = loadStateL(closedPositionEE) ;				// need to get last values from EEPROM and assume the current position is correct
                                        	setPosition = loadStateL(setPositionEE) ;
                                        	stepper1.setCurrentPosition(setPosition );
                                          present(CHILD_ID, S_COVER, "Curtain");						// Window Cover sub-type, commands: V_UP, V_DOWN, V_STOP
                                          // Register the LED Dimmable Light with the gateway
                                          sendSketchInfo(SN, SV);
                                        unsigned int now = millis() ;								// current time for loop
                                        // simple state machine for button press
                                        	myBtn.read();
                                        	switch (State) {
                                                // Idle state, waiting for some action
                                        		// - button press
                                        		// - idleTimer
                                                case sIdle:
                                                    if (myBtn.wasReleased()){						// idle
                                        				Serial.println("Button release") ;
                                        				// if running stop
                                        				if (stepper1.isRunning()){
                                        					setPosition = stepper1.currentPosition();
                                        					stepper1.moveTo(setPosition) ;			// move to current position (was already there..)
                                        				} else if (lastDirection == Open) {
                                        					stepper1.moveTo(closedPosition) ;
                                        					lastDirection = Close ;
                                        				} else {									// lastDirection == Close
                                        					stepper1.moveTo(openPosition) ;
                                        			} else if (myBtn.pressedFor(3000)){				// move to calibratete state with long press
                                        				Serial.println("Button press long") ;
                                        				idleTimer = now ;							// return to idle after ...
                                        				State = sCalibrateOpen ;
                                        				stepper1.move(-maxRun) ;					// let the stepper open with maximum
                                        			break ;
                                        		// if not running and last action was open close ;  else open
                                        		// if longpress Calibrate open
                                                case sCalibrateOpen:           						// calibration going on
                                        			if (myBtn.wasPressed()){
                                        				stepper1.setCurrentPosition(0 );		// set new 0 position ??
                                        				openPosition = setPosition = 0 ;
                                        				State = sCalibrateClose ;					// next is close calibarion
                                        				stepper1.move(maxRun) ;						// let the stepper close with maximum
                                        			} else if (now > idleTimer + idleTime) {		// timer expired -> abort calibration
                                        				State = sIdle ;
                                        			break ;
                                                case sCalibrateClose:								// calibrate closed position, end with keypress
                                        			if (myBtn.wasPressed())	{
                                        				closedPosition = setPosition = stepper1.currentPosition() ;
                                        				saveStateL(closedPositionEE, closedPosition) ; // save closed position in EEPROM
                                        				State = sIdle ;
                                        				stepper1.moveTo(openPosition) ;				// return to open after calibration
                                        				State = sIdle ;
                                        			break ;
                                        		default :
                                        			break ;
                                        	// power off stepper if not running (no need to reenable))
                                        	if (!stepper1.isRunning()){
                                        		if (runStatus != Idle){								// there was a change in runningstatus, so report to controller
                                        			setPosition = stepper1.currentPosition() ;		// store in EEPROM and report ready to controller
                                        			saveStateL(setPositionEE, setPosition) ;
                                        			send( percentageMsg.set((100 * setPosition)/(closedPosition - openPosition))) ;
                                        			runStatus = Idle ;
                                        		stepper1.disableOutputs();
                                        		runStatus = Running ;
                                        	stepper1.run();
                                        	if (printTimer++ > now + printTime){
                                        		printTimer = now ;
                                        		Serial.println(stepper1.currentPosition());
                                          switch (message.type) {
                                        	case V_PERCENTAGE:
                                        	stepper1.moveTo(message.getInt() * (closedPosition - openPosition)/100);
                                        	Serial.print("Message: "); Serial.print(message.sensor); Serial.print(" , value: % "); Serial.println( message.getInt());
                                        	Serial.print("Moving to: "); Serial.println(message.getInt() * (closedPosition - openPosition)/100);
                                        	break ;
                                        	case V_STATUS:
                                        	// Curtain should be opened or closed full
                                        	stepper1.moveTo((message.getInt() == HIGH)?openPosition:closedPosition);
                                        	break ;
                                        	default :
                                        	break ;
                                        TON RIJNAARDT xydixX 2 Replies Last reply
                                        • TheoLT
                                          TheoLT
                                          TheoL
                                          You can use an I/O expander like an MCP23017 which is a 16 port expander or a 8 port expander. They're cheap. Keep in mind they consume 1 mAmp. I'm currently working on a product to overcome that power issue for a battery powered Node. Will try to post about it in a while
