  3. Driving electrical heater
6 Posts 5 Posters 2.0k Views 5 Watching
  • phil77560P Offline
    phil77560P Offline
    phil77560
    Would it be possible to drive electrical heater with "mysensors" and Domoticz ?
    I'd need to have two outputs to use something like : This
    ( sorry it's in french)
    Thank you
    T A alexsh1A 3 Replies Last reply
    • phil77560P phil77560
      Thank you
      T Offline
      T Offline
      TheoL
      @phil77560 It's hard for me to read, because google didn't do a great job on the translation. But I guess it would be possible. It might help if you post the schematics off that schematics on this forum.
        Thank you
        A Offline
        A Offline
        AWI
        @phil77560 That would be very well possible. You can drive the led's in the optocouplers from the arduino digital outputs and use a remote "switch" to drive the outputs.
        0_1472736175277_upload-186c892b-e0c6-41bc-bca5-5e124f58b026
          phil77560P Offline
          phil77560
          Very good idea... thank you
          • B Offline
            B Offline
            bjacobse
            Maybe this sketch can be used, since this will read incoming commands, and activate a relay, but for your need as AWI writes, you use the Arduino output direct to your above circuit (Then you don't have to listen to relay click)
            https://github.com/mysensors/MySensors/blob/master/examples/RelayActuator/RelayActuator.ino
              Thank you
              alexsh1A Offline
              alexsh1A Offline
              alexsh1
              @phil77560 yes, it is possible - I have a SSR switching on a 3kWatt tent with a help of a simple 433Mhz switch controlled by Domoticz. No MySensors in this setup.
              12.1k
