  3. Temp Sensor and iobroker on rasPi3
25 Posts 4 Posters 9.9k Views 3 Watching
  • mysensors-6043M mysensors-6043
    Hi community, I am new to mySensors, found it through iobroker on rasPi3. There's an Adapter for mySensors :-)
    iobroker is linked to my Homematic ccu2. I'd like to measure a temperature and Report it back to ccu2.
    The hardware should be as small as possible, low power consumtion and communicate via WLAN.
    What exactly do I Need to have a temp Sensor ?
    Thanks in advance ... jr
    Welcome to the MySensors community @mysensors-6043 !
    You'll find component lists and wiring guides for ESP8266 gateway here: https://www.mysensors.org/build/esp8266_gateway
    The same for a temperature sensor is available at https://www.mysensors.org/build/temp
    Example sketches are included in the MySensors library and at https://github.com/mysensors/MySensorsArduinoExamples
    • mysensors-6043M
      mysensors-6043M
      mysensors-6043
      Hey thank' a lot.
      And by using the ESP8266 and connecting to the WAN, I'm able to attach iobroker mysensors Instance ?
      cheers .. jr
      • mysensors-6043M
        mysensors-6043M
        mysensors-6043
        sorry, of course I mean WLAN :-)
          @mysensors-6043 I have never used iobroker so I don't know unfortunately. But if iobroker supports MySensors ethernet gateway you should be fine.
          • mysensors-6043M
            mysensors-6043M
            mysensors-6043
            Hi again
            I got stuck somewhere. Have my Arduino nano up and running, blink example works fine.
            As soon as choose the GatewayESP8266 sketch, while compiling I get the error
            Arduino: 1.6.11 (Windows 10), Board: "Arduino Nano, ATmega328"
            Z:\Arduino\MySensors-master\examples\GatewayESP8266\GatewayESP8266.ino:136:27: fatal error: ESP8266WiFi.h: No such file or directory
            #include <ESP8266WiFi.h ^
            compilation terminated.
            exit status 1
            The library WiFiEsp by bportaluri V2.1.2 and MySensors 2.0.0 is installed
            • mysensors-6043M
              mysensors-6043M
              mysensors-6043
              C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\juerg\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\juerg\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries Z:\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10611 -build-path C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose Z:\Arduino\MySensors-master\examples\GatewayESP8266\GatewayESP8266.ino
              C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\juerg\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\juerg\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries Z:\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10611 -build-path C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose Z:\Arduino\MySensors-master\examples\GatewayESP8266\GatewayESP8266.ino
              Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
              Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
              Detecting libraries used...
              "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\sketch\GatewayESP8266.ino.cpp" -o "nul"
              "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\sketch\GatewayESP8266.ino.cpp" -o "nul"
              "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\sketch\GatewayESP8266.ino.cpp" -o "nul"
              "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\sketch\GatewayESP8266.ino.cpp" -o "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
              #include <ESP8266WiFi.h>
              Using library EEPROM at version 2.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM
              Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
              exit status 1
                exit status 1
                @mysensors-6043
                this means that the Arduino IDE is trying to compile the code for an Arduino Nano. Since the gateway sketch is for ESP8266, it will fail to compile for Arduino nano.
                Select the ESP8266 in the Tools->Board menu. Follow the instructions on https://github.com/esp8266/Arduino#installing-with-boards-manager if you haven't installed the ESP8266 board.
                • mysensors-6043M
                  mysensors-6043M
                  mysensors-6043
                  Hi Thank's
                  I changed Board Type to ESP8266, but now I get
                  Sketch uses 243,757 bytes (56%) of program storage space. Maximum is 434,160 bytes.
                  Global variables use 34,440 bytes (42%) of dynamic memory, leaving 47,480 bytes for local variables. Maximum is 81,920 bytes.
                  warning: espcomm_sync failed
                  error: espcomm_open failed
                  error: espcomm_upload_mem failed
                  and the serial monitor say's wifi shield not present -> yes this is true not connected yet
                  • mysensors-6043M
                    mysensors-6043M
                    mysensors-6043
                    https://www.google.ch/search?q=arduino+nano+wifi&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjXsMHIxPvOAhUENxQKHcIwAUoQ_AUICCgB&biw=1680&bih=933#imgrc=yNkJrmEzEp2z2M%3A
                    That's my WiFi shield
                    • mysensors-6043M
                      mysensors-6043M
                      mysensors-6043
                      is this the correct cabling ?
                      https://www.google.ch/search?q=arduino+nano+wifi&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjXsMHIxPvOAhUENxQKHcIwAUoQ_AUICCgB&biw=1680&bih=933#imgrc=Rk6oZ2LAUQDc6M%3A
                        @mysensors-6043 sorry, I didn't realize you were using the esp as wifi shield. The esp gateway sketch is meant to run directly on an esp board such as nodemcu, adafruit huzza, wemos d1 mini, esp-12 and similar.
                        You could see if @Tagore-PDE got something working in this thread: https://forum.mysensors.org/topic/4374/arduino-uno-esp8266/
                        • Tagore.PDET
                          Tagore.PDET
                          Tagore.PDE
                          not yet, but in some days i will get that running.
                          regards.
                          • mysensors-6043M
                            mysensors-6043M
                            mysensors-6043
                            newby question, sorry ;-)
                            I got stuck somehow. Built my Arduino Nano with NRF24L01 board. This is working with RF24 Library/examples between two Arduinos.
                            I'd like to attach one sensor to iobroker/mysensors instance. So I took the tempsensor sketch from mysensors Homepage. https://www.mysensors.org/build/temp
                            While compiling the sketch I get
                            "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IZ:\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IZ:\Arduino\libraries\DallasTemperature" "-IZ:\Arduino\libraries\OneWire" "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\sketch\TempSensorRIJ.ino.cpp" -o "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                            In file included from Z:\Arduino\MySensors-master\examples\TempSensor\TempSensorRIJ\TempSensorRIJ.ino:29:0:
                            Z:\Arduino\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                            Using library MySensors at version 2.0.0 in folder: Z:\Arduino\libraries\MySensors
                            Using library DallasTemperature at version 3.7.6 in folder: Z:\Arduino\libraries\DallasTemperature
                            Using library OneWire at version 2.3.2 in folder: Z:\Arduino\libraries\OneWire
                            exit status 1
                            Best regards and I appreciate any help :-)
                              exit status 1
                              sundberg84S
                              sundberg84S
                              @mysensors-6043 - it looks like there is something wrong with your library i think. Maybe you have library in two different places. Check your sketchfolder and your application(arduino) folder.
                              mysensors-6043M 2 Replies Last reply
                              • sundberg84S sundberg84
                                mysensors-6043M
                                mysensors-6043M
                                mysensors-6043
                                @sundberg84
                                Hi thank's a lot for Your answer. Did a reinstall of the IDE, now only one library Installation. Now I get another error
                                In file included from C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:30:0:
                                C:\Users\juerg\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                                C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:32:31: fatal error: DallasTemperature.h: No such file or directory
                                exit status 1
                                  mysensors-6043M
                                  mysensors-6043M
                                  mysensors-6043
                                  @sundberg84
                                  where do I have to define SSID and wireless key for the WiFi Connection ?
                                    @sundberg84
                                    sundberg84S
                                    sundberg84S
                                    @mysensors-6043 - good question, never used wifi for MySensors.
                                    if you are using 2.0 I found this in github:
                                    #define MY_ESP8266_SSID "MySSID"
                                    #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
                                    mysensors-6043M 1 Reply Last reply
                                      mysensors-6043M
                                      mysensors-6043M
                                      mysensors-6043
                                      @sundberg84
                                      Hi again, many thank's get closer. I had to install two more libraries (Dallas, OneWire).
                                      After adding the two definitions above, this is still the error
                                      exit status 1
                                      • mysensors-6043M
                                        mysensors-6043M
                                        mysensors-6043
                                        Hey guys
                                        Getting closer and closer :-)
                                        I had to set this in Dallas Temperature.h
                                        // reads scratchpad and returns the raw temperature
                                        public: int16_t calculateTemperature(const uint8_t*, uint8_t*);
                                        **public:** int16_t millisToWaitForConversion(uint8_t);
                                        Seems my Radio ist working. Please see Serial Monitor :+1:
                                        0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
                                        0;255;3;0;9;TSM:INIT
                                        0;255;3;0;9;TSM:RADIO:OK
                                        0;255;3;0;9;TSM:GW MODE
                                        0;255;3;0;9;TSM:READY
                                        0;255;0;0;18;2.0.0
                                        0;255;3;0;11;Relay + Temp
                                        0;255;3;0;12;1.0
                                        0;1;0;0;3;
                                        0;2;0;0;3;
                                        Now, since I'm use iobroker with a mysensors.0 instance, I'd like to read Temperature within iobroker.
                                        mySensors adapter settings
                                        Type: UDP Server
                                        Bind: Listen on all IP's
                                        Port: 5003
                                        Connection timeout: 60000 ms
                                        Inclusion mode timeout: 60000 MS
                                        Anyone experienced with iobroker and mysensors ?
                                          Hey guys
                                          0;255;0;0;18;2.0.0
                                          0;255;3;0;12;1.0
                                          0;1;0;0;3;
                                          0;2;0;0;3;
                                          Type: UDP Server
                                          Port: 5003
                                          mysensors-6043M
                                          mysensors-6043M
                                          mysensors-6043
                                          @mysensors-6043
                                          Got some more debug Messages
                                          0;255;3;0;9;TSP:SANCHK:OK
                                          0;255;3;0;9;TSP:MSG:READ 0-0-0 s=255,c=3,t=14,pt=0,l=25,sg=0:Gateway startup complete.
                                          0;255;3;0;9;!TSP:MSG:PVER mismatch
