  3. Energy Meter - not sending at expected
18 Posts 4 Posters 6.4k Views 3 Watching
  • F
    F
    flopp
    I don't know if I don't understand the way it should work or maybe my Nano have wrong MHz.
    This is my code
    #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your light sensor. (Only 2 and 3 generates interrupt!)
    #define PULSE_FACTOR 10000 // Nummber of blinks per KWH of your meeter
    #define SLEEP_MODE false // Watt-value can only be reported when sleep mode is false.
    #define MAX_WATT 15000 // Max watt value to report. This filetrs outliers.
    #define CHILD_ID 1 // Id of the sensor child
    unsigned long SEND_FREQUENCY = 5*60000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
    double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
    boolean pcReceived = false;
    unsigned long oldPulseCount = 0;
    unsigned long oldWatt = 0;
    double oldKwh;
    unsigned long lastSend;
    MyMessage wattMsg(CHILD_ID,V_WATT);
    MyMessage kwhMsg(CHILD_ID,V_KWH);
    MyMessage pcMsg(CHILD_ID,V_VAR1);
    gw.begin(incomingMessage);
    gw.sendSketchInfo("Energy Meter", "1.0");
    gw.present(CHILD_ID, S_POWER);
    gw.request(CHILD_ID, V_VAR1);
    attachInterrupt(INTERRUPT, onPulse, RISING);
    lastSend=millis();
    unsigned long now = millis();
    if (pcReceived && (SLEEP_MODE || sendTime)) {
    if (!SLEEP_MODE && watt != oldWatt) {
    if (watt<((unsigned long)MAX_WATT)) {
    gw.send(wattMsg.set(watt)); // Send watt value to gw
    Serial.print("Watt:");
    Serial.println(watt);
    oldWatt = watt;
    // Pulse cout has changed
    if (pulseCount != oldPulseCount) {
    gw.send(pcMsg.set(pulseCount)); // Send pulse count value to gw
    double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
    oldPulseCount = pulseCount;
    if (kwh != oldKwh) {
    gw.send(kwhMsg.set(kwh, 4)); // Send kwh value to gw
    oldKwh = kwh;
    lastSend = now;
    } else if (sendTime && !pcReceived) {
    // No count received. Try requesting it again
    lastSend=now;
    if (SLEEP_MODE) {
    gw.sleep(SEND_FREQUENCY);
    if (message.type==V_VAR1) {
    pulseCount = oldPulseCount = message.getLong();
    Serial.print("Received last pulse count from gw:");
    Serial.println(pulseCount);
    pcReceived = true;
    void onPulse()
    if (!SLEEP_MODE) {
    unsigned long interval = newBlink-lastBlink;
    if (interval<10000L) { // Sometimes we get interrupt on RISING
    return;
    watt = (3600000000.0 /interval) / ppwh;
    lastBlink = newBlink;
    pulseCount++;
    My VAR1 value is 1845100000
    I except it to report every 20 second but it can be 2 minutes or 20 seconds and right now it was 15 minutes ago.
    Am I right if the Watt needs to be change otherwise it will not send Watt update?
    Same for kWh, also need to change before updating.
    This Meter is for my heating system and right now it is not working so much.
    I also have a second Nano measuring my whole house, that one is sending every 5 minutes as I expect. But there will almost never be same Watt and kWh is changing much quicker.
    • F flopp
      This is my code
      double oldKwh;
      lastSend=millis();
      oldWatt = watt;
      oldKwh = kwh;
      lastSend = now;
      lastSend=now;
      if (SLEEP_MODE) {
      pcReceived = true;
      void onPulse()
      if (!SLEEP_MODE) {
      return;
      pulseCount++;
      @flopp could you post serial output from the node, including the startup phase after a reset?
      F 1 Reply Last reply
        F
        F
        flopp
        wrote on last edited by flopp
        @mfalkvidd
        1.5.1
        send: 17-17-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
        send: 17-17-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        read: 0-0-17 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        sensor started, id=17, parent=0, distance=1
        send: 17-17-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=ok:Energy Meter
        send: 17-17-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
        send: 17-17-0-0 s=1,c=0,t=13,pt=0,l=0,sg=0,st=ok:
        send: 17-17-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
        read: 0-0-17 s=1,c=2,t=24,pt=0,l=10,sg=0:1845100810
        Received last pulse count from gw:1845100810
        send: 17-17-0-0 s=1,c=1,t=17,pt=5,l=4,sg=0,st=ok:64
        Watt:64
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100814
        send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:184510.0800
        send: 17-17-0-0 s=1,c=1,t=17,pt=5,l=4,sg=0,st=ok:63
        Watt:63
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100817
        Watt:64
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100821
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100824
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100828
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100831
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100835
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100839
        Watt:63
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100842
        Watt:64
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:1845100846
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=fail:1845100813
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=fail:1845100817
        send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=fail:1845100820
        looks strange, why does ask for VAR1 again
        Domoticz Log
        2016-09-07 06:57:04.773 MySensors: Node: 17, Sketch Name: Energy Meter
        2016-09-07 06:57:04.845 MySensors: Node: 17, Sketch Version: 1.0
        2016-09-07 06:57:25.013 (MySensors USB) General/kWh (PannaMeter)
        2016-09-07 06:57:25.142 (MySensors USB) General/kWh (PannaMeter)
        2016-09-07 06:57:45.013 (MySensors USB) General/kWh (PannaMeter)
        2016-09-07 06:58:05.012 (MySensors USB) General/kWh (PannaMeter)
        2016-09-07 06:58:35.651 (MySensors USB) Temp (KökTbx_T)
        2016-09-07 06:58:35.712 (MySensors USB) Temp (UppTbx_T)
        2016-09-07 06:58:35.756 (MySensors USB) Temp (KökUt_T)
        2016-09-07 06:58:35.797 (MySensors USB) Temp (ToaUt_T)
        2016-09-07 06:58:35.838 (MySensors USB) Temp (EfterPump_T)
        2016-09-07 06:58:35.878 (MySensors USB) Temp (HallTbx_T)
        2016-09-07 06:58:35.918 (MySensors USB) Temp (UppUt_T)
        2016-09-07 06:58:35.958 (MySensors USB) Temp (ToaTbx_T)
        2016-09-07 06:58:35.997 (MySensors USB) Temp (Kök_T)
        2016-09-07 06:58:36.036 (MySensors USB) Temp (PannaKomp_T)
        2016-09-07 06:58:36.075 (MySensors USB) Temp (HallUt_T)
        2016-09-07 06:58:36.115 (MySensors USB) Temp (Tvätt_T)
        2016-09-07 06:58:36.154 (MySensors USB) Temp (T12_T)
        2016-09-07 06:58:36.193 (MySensors USB) Temp (VMellan_T)
        2016-09-07 06:58:36.233 (MySensors USB) Temp (Hallen_T)
        2016-09-07 06:58:36.272 (MySensors USB) Temp (PannaEl_T)
        2016-09-07 06:58:36.311 (MySensors USB) Temp (ToaNere_T)
        2016-09-07 06:58:36.350 (MySensors USB) Temp (VarmVatten_T)
        2016-09-07 06:58:40.106 (MySensors USB) Temp (KylUppe_T)
        2016-09-07 06:58:41.190 (MySensors USB) Temp (KylMitten_T)
        2016-09-07 06:58:41.230 (MySensors USB) Temp (KylNere_T)
        2016-09-07 06:58:41.269 (MySensors USB) Temp (FrysUppe_T)
        2016-09-07 06:58:41.309 (MySensors USB) Temp (KylBakom_T)
        2016-09-07 06:58:41.387 (MySensors USB) Temp (Allrum_T)
        2016-09-07 06:58:41.465 (MySensors USB) Temp (SovrumOW_T)
        2016-09-07 07:00:02.496 Starting automatic database backup procedure...
        2016-09-07 07:00:18.899 Ending automatic database backup procedure...
        2016-09-07 07:00:05.013 (MySensors USB) General/kWh (PannaMeter)
        2016-09-07 07:00:25.014 (MySensors USB) General/kWh (PannaMeter)
        2016-09-07 07:01:01.239 (MySensors USB) General/Voltage (VinglasSkapet_V)
        2016-09-07 07:01:01.353 (MySensors USB) Temp + Humidity (VinglasSkapet_T)
        2016-09-07 07:01:01.428 (MySensors USB) Temp + Humidity (VinglasSkapet_T)
        2016-09-07 07:01:06.073 (MySensors USB) Rain (Hyundai)
        2016-09-07 07:01:08.160 (MySensors USB) Rain (Hyundai)
        2016-09-07 07:01:16.177 (MySensors USB) General/kWh (MeterHuset)
        2016-09-07 07:01:16.242 (MySensors USB) General/kWh (MeterHuset)
        2016-09-07 07:01:59.706 (MySensors USB) General/Voltage (BadrumNere_V)
        2016-09-07 07:01:59.828 (MySensors USB) Temp (Temp)
        2016-09-07 07:01:59.908 (MySensors USB) Humidity (Hum)
        2016-09-07 07:02:05.016 (MySensors USB) Temp (AppleTV_T)
        2016-09-07 07:02:05.115 (MySensors USB) Temp (PS3_T)
        2016-09-07 07:02:05.229 (MySensors USB) Temp (Stereo_T)
        Yes I a lot of temp senors :)
        • F
          F
          flopp
          after I changed pulseCount to be 100000 it looks better
          serial output
          read: 0-0-17 s=1,c=2,t=24,pt=0,l=6,sg=0:100000
          Received last pulse count from gw:100000
          send: 17-17-0-0 s=1,c=1,t=17,pt=5,l=4,sg=0,st=ok:62
          Watt:62
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100004
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0004
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100007
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0007
          Watt:63
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100010
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0010
          Watt:62
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100014
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0014
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100017
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0017
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100021
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0021
          Watt:63
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100024
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0024
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100028
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0028
          Watt:62
          send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100031
          send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0031
          DZ log
          2016-09-07 08:30:15.154 MySensors Node 17 Sketch Name Energy Meter
          2016-09-07 08:30:15.223 MySensors Node 17 Sketch Version 1.0
          2016-09-07 08:30:35.397 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:30:35.526 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:30:55.461 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:31:15.398 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:31:15.524 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:31:16.867 (MySensors USB) General/kWh (MeterHuset)
          2016-09-07 08:31:16.924 (MySensors USB) General/kWh (MeterHuset)
          2016-09-07 08:31:35.398 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:31:35.529 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:31:55.462 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:32:15.459 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:32:35.397 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:32:35.527 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:32:55.463 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:33:15.397 (MySensors USB) General/kWh (PannaMeter)
          2016-09-07 08:33:15.530 (MySensors USB) General/kWh (PannaMeter)
          • F
            F
            flopp
            after a while I got this
            send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100116
            send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0116
            Watt:62
            send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100119
            send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0119
            read: 51-51-51 s=1,c=2,t=24,pt=0,l=6,sg=0:100063
            ver mismatch
            read: 0-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0:
            ver mismatch
            Watt:63
            send: 17-17-0-0 s=1,c=1,t=24,pt=5,l=4,sg=0,st=ok:100123
            send: 17-17-0-0 s=1,c=1,t=18,pt=7,l=5,sg=0,st=ok:10.0123
            what is 51-51-51 and that is also wrong VAR value
            • F flopp
              Watt:62
              ver mismatch
              ver mismatch
              Watt:63
              sundberg84S
              sundberg84S
              @flopp pulseCount/V_VAR1 and Domoticz is something else... I have not got my finger around it but what I know is that some values in the energi meter is calculacted from V_VAR1 / day. When i tested my rain sensor (tip_bucket) i pretty much have to do 1 test each day to be sure. Also there is the possibility to edit the database but as i said, im not sure.
              If you had a pulsecount of 1000 and set it to 0 it would show -1000 in watts i think or something... but only calculated the pulse from that day.
              Sorry, not bringing anything good to the table, just remember it was a bit hard to get my head around.
              • F
                F
                flopp
                a few thing that can be my error.
                1. I had one beginner mistake, no cap on NRF thats why it was getting Failed a few times, this happened after 0-10 minutes and during my first setup it was 5 minutes to send.
                  New NRF and Cap seems to solve one issue. Sorry
                2. I noticed if the Watt is sent it will update Domoticz. If VAR is sent it will not update Domoticz. If kwh is sent it will update Domoticz.
                3. skectch is checking if kwh was same as old, the check is only handling 2 decimals(what is can see in SerialPrint) so I needed a lot of watts to change second decimal. 1845110734 is my VAR but the IF code is only seeing 184511.07
                summary
                Bad NRF, it was working a few minutes. Biggest error
                My watt was same, heating system and right now it doesn't heat = dont send
                My kwh was increasing slowly = don't send
                I think I will remove the check if value is old and send it every 5 minutes even if watt, kwh, pulsecount is same as old
                • sundberg84S sundberg84
                  F
                  F
                  flopp
                  @sundberg84
                  i also had a lot of problem with my Rain data in Domoticz.
                  read more here https://www.domoticz.com/forum/viewtopic.php?f=28&t=11088
                  if your Sensor timeout is 2 hours you need to send rain VAR within 2 hours otherwise your graph will look strange.
                  Yes, if you change the VAR during the day to a lower value you will get minus value. Took me a few days to understand how Domoticz DB file was working.
                  Keep up the good work :punch:
                  • F
                    F
                    flopp
                    It was working for a few hours then not sending any data, even with my new sketch. I changed to Arduino UNO and since then it has been working perfect. So it was my NRF(maybe) and my Nano that was not working correctly.
                    • F
                      F
                      flopp
                      But I found something weird about the division
                      Why doesn't it send the exact value?
                      My pulseCount is 1845124894 and it is sent to Controller correct, then it will use below function
                      My PULSE_FACTOR is 10000
                      and send the divided value to Controller, but it doesn't send correct value, it is missing the two last numbers "94" it is absolutely not a big problem but why send 4 decimals when the two last it always 0(zero)
                      Look at last row, 1845125113 = 184512.5200?
                      Is this because double values is rounding up? But 5113 should be 5100.
                      • F flopp
                        @flopp could be because 'double' is actually float on Arduino, and therefore precision is limited. Have to do so maths though to know for sure.
                        • YveauxY Yveaux
                          F
                          F
                          flopp
                          @Yveaux
                          OK thanks
                          • F
                            F
                            flopp
                            still working with UNO.
                            this is the sketch i am running
                            double oldKwh;
                              gw.sendSketchInfo("Energy Meter", "1.1");
                              //1.1 no check for old value, always send
                              lastSend=millis();
                                oldWatt = watt;
                                  oldKwh = kwh;
                                lastSend = now;
                                lastSend=now;
                              if (SLEEP_MODE) {
                                pcReceived = true;
                            void onPulse()
                              if (!SLEEP_MODE) {
                                  return;
                              pulseCount++;
                            • F
                              F
                              flopp
                              There must be something wrong with my code. Since 1 February my Arduino is 3 kWh before the real energy value for my house.
                              My second Arduino is measuring kWh on my heating system and that one is running correct.
                              For my house I use Nano(clone) for heating system I use UNO(original)
                              Can the hardware be the bad guy here?
                              It should be same code in both Arduino but tomorrow I will use an UNO(org) for my house and wait 1 week.
                              • F flopp
                                @flopp how do you count the pulses from your meter? Could that be the issue?
                                • YveauxY Yveaux
                                  F
                                  F
                                  flopp
                                  @Yveaux
                                  I don't know the name but I think it is a photo resistor, which I have connected to a LM393 then Arduino counts the interrupts.
                                  Same hardware for both House and Heating.
                                  Same sketch.
                                  • F
                                    F
                                    flopp
                                    I changed to a UNO now my Watt is showing the same value!!
                                    EDIT: this was because the WATT was above 15000 and then it didn't send any data to Controller. I had values up to 110000.
                                    It must be something with the Watt calculation. Anyone seen this before?
                                    • F
                                      F
                                      flopp
                                      I think I found it.
                                            return;
                                      It seems to be that my interrupt is to quick. above code is default if I change to
                                      if (interval<35000L) { // Sometimes we get interrupt on RISING
                                            return;
                                      it will calculate Watt as I think it should be.
                                      I will let it run for a week and see if kWh is OK now.
                                      12.5k
