  3. MySensors Raspberry port suggestions
96 Posts 14 Posters 66.3k Views 17 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    OK, I manage to install it finally.
    However, again I have a problem:
    ./configure --my-gateway=ethernet --my-rf24-channel=1 --my-rf24-pa-level=RF24_PA_MAX --my-controller-ip-address=127,0,0,1
    when I start it I have the following in the log:
    failed to bind
    accept: Bad file descriptor
      marceloaqno
      Code Contributor
      wrote on last edited by marceloaqno
      #55
      Add some options to the gateway execution:
      # ./examples_linux/mysGateway -h
      Usage: mysGateway [options]
      Options:
      -h            Display a short summary of all program options.
      -d            Enable debug.
      -b            Become a daemon.
      Debug is now disabled by default.
      You can't run it as a linux daemon if debug is enabled.
      When daemonized all messages will be print to syslog.
      b0rmannB alexsh1A 2 Replies Last reply
      • M marceloaqno
        Options:
        -d            Enable debug.
        -b            Become a daemon.
        b0rmannB
        b0rmannB
        b0rmann
        • M marceloaqno
          Options:
          -d            Enable debug.
          -b            Become a daemon.
          alexsh1A
          alexsh1A
          alexsh1
          #57
          @marceloaqno Interesting. When I execute "mysGateway -h" I get the following:
          pi@m:~/MySensors/examples_linux $ mysGateway -h
          MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
          TSM:INIT
          Segmentation fault
          What does "Segmentation fault' mean please?
            marceloaqno
            Code Contributor
            @alexsh1 You must be root to run the gateway:
            $ sudo mysGateway
            It seems that you are not using the latest version, -h should have shown you the options list.
            alexsh1A 1 Reply Last reply
            • M marceloaqno
              $ sudo mysGateway
              alexsh1A
              alexsh1A
              alexsh1
              #59
              @marceloaqno I have the latest version (downloaded yesterday). Thanks very much for your help. I got the following:
              pi@m:~/MySensors/examples_linux $ sudo mysGateway -h
              TSM:INIT
              TSM:INIT:TSP OK
              TSM:INIT:GW MODE
              TSM:READY
              MCO:REG:NOT NEEDED
              MCO:BGN:STP
              MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
              In Domoticz:
              2016-09-09 09:32:26.032 TCP: Reconnecting...
              2016-09-09 09:32:26.032 MySensors: connected to: 127.0.0.1:5003
              I added MySensors with LAN in Domoticz (port 5003), but here a problem. I can see the node and the GW communicating:
              GW:
              TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
              Client 0: 0;0;3;0;18;PING
              Starting sensor (RNNNA-, 2.0.0-beta)
              Radio init successful.
              req id
              req id
              req id
              req id
              Init complete, id=255, parent=0, distance=1
              requesting time
              req id
              requesting time
              req id
              requesting time
              req id
              requesting time
              req id
              requesting time
              req id
              The RF communication is fine, but I do not understand why Domoticz is not assigning ID.......
              EDIT: I can see in Domoticz in the Hardware section:
              MySensors Gateway with LAN interface
              Version: ? Setup
              Typically ? comes up when the controller is not recognised or not connected
              EDIT2:Deleted and started fresh. Unfortunately, now the log file is flooded with the following:
              mysGateway: Max number of ethernet clients reached.
              • alexsh1A alexsh1
                TSM:INIT
                TSM:INIT:TSP OK
                TSM:INIT:GW MODE
                TSM:READY
                MCO:REG:NOT NEEDED
                MCO:BGN:STP
                In Domoticz:
                GW:
                req id
                req id
                req id
                req id
                requesting time
                req id
                requesting time
                req id
                requesting time
                req id
                requesting time
                req id
                requesting time
                req id
                Version: ? Setup
                marceloaqno
                Code Contributor
                @alexsh1 There is a bug with --my-controller-ip-address, I'm not sure if it's your case, but try to avoid it.
                I tried Domoticz here and everything seems fine:
                Version: 2.0.1-beta (Setup)
                I recommend you to start from scratch, re-download the gateway from here:
                https://github.com/marceloaqno/MySensors/tree/dev-raspberrypi
                • M marceloaqno
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @marceloaqno OK, this must be the reason. I have tried the serial setup and it worked with a little tweak:
                  /dev/ttyUSB20 -> /dev/ttyMySensorsGateway
                  For whatever reason Domoticz did not see ttyMySensorsGateway so I had to create ttyUSB20
                  E 1 Reply Last reply
                  • alexsh1A alexsh1
                    E
                    E
                    emc2
                    Domoticz seems to only look for ttyUSB* interfaces. One easy trick is to run ./configure with this option so you don't have to worry with symlinking
                    ./configure --my-serial-pty=/dev/ttyUSBMySensorsGateway
                    BTW @marceloaqno , what does the option --my-serial-is-pty exactly do?
                    So far I've been running the gateway in ethernet mode for a little while and it's working flawlessly, thanks a lot for this port.
                    • E emc2
                      alexsh1A
                      alexsh1A
                      alexsh1
                      Exallent fix! Thanks
                      @marceloaqno I can confirm that the Ethernet GW works fine without --my-controller-ip-address
                      MAny thanks for your port and help!
                      • alexsh1A alexsh1
                        E
                        E
                        emc2
                        Just a guess, I see on your previous post that you used --my-controller-ip-address=127,0,0,1 it may have been a typo here, but did you try with --my-controller-ip-address=127.0.0.1? (dots instead of commas in the IP)?
                        • E emc2
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @emc2 No, this is not a typo. This is a format. And yes, I have tried it with dots (127.0.0.1) - it did not compile.
                          • E
                            E
                            emc2
                            Good to know then, thanks!
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              BTW, I am using a nice adapter for nrf24l01+ LNA+PA designed by @GertSanders :
                              https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01
                              Works nicely with this port and RPi 3.
                              • E
                                E
                                emc2
                                wrote on last edited by emc2
                                #68
                                Same, I had one Pi with GertSanders adapter and now switched to the SMD versions to fit nicely in my case.
                                https://www.openhardware.io/view/105/MySRaspiGW
                                https://www.openhardware.io/view/116/MySRaspiGW-PALNA
                                Interestingly the regular one is working better than the PA+LNA version since moved to 2.0, at least in term of sending commands. Receiving is fine. Compiling with --my-rf24-pa-level=RF24_PA_LOW helps a lot. It seems 2.0 is really more power hungry, any hope to optimize this?
                                Which remind me of one thing, sorry to bother you again @marceloaqno (how) is the --my-rf24-irq-pin=<PIN> working?
                                I installed wiringpi to get rid of the wiringPiISR: Can't find gpio program but I'm not sure if it's supposed to do anything in the long term.
                                I was thinking updating the design of my PCB to link BCM 24 (pin 18) to the IRQ pin of the radio module but it's unclear to me if the IRQ will ever actually be used on the gateway.
                                  marceloaqno
                                  Code Contributor
                                  Those are cool adapters, I need to build one for me.
                                  @emc2 It's no bother at all!
                                  Using nrf24 IRQ pin can give you more throughput and less chance of losing messages. It makes more sense to use if you have many sensors or need to transfer binary data (https://forum.mysensors.org/topic/3594/solar-powered-observation-nesting-box-network/).
                                  --my-serial-is-pty will simulate a serial port and create a symbolic link to it instead of using a real one.
                                  • M marceloaqno
                                    E
                                    E
                                    emc2
                                    #70
                                    @marceloaqno Thanks for the heads up.
                                    I'm totally happy with the ethernet version, but as it seems @hek is in the process of writing guides on https://www.mysensors.org/build/raspberry I did a few tests.
                                    If I understood correctly (and it seems to work), to "replace" the 1.x serial gateway with the new one running the following command should work as is (/dev/ttyUSBMySensorsGateway can be renamed to /dev/ttyMySensorsGateway to be exactly as in 1.x or /dev/ttyUSB20 to bypass the symlink step)
                                    ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway --my-rf24-pa-level=RF24_PA_LOW
                                    --my-rf24-pa-level=RF24_PA_LOW can be omitted, especially if not using a PA+LNA module, but it seems 2.0 is really more power hungry than 1.4.
                                    If you are interested by the SMD ones, PM me your address and I will happily send you something!
                                    • H
                                      H
                                      hawk_2050
                                      @marceloaqno The mechanism for assigning the pty serial port the specified group ownership doesn't appear to be working. The pty port is always created with root:root ownership. Can you (or anyone else) confirm whether this is working for you? I'm on a Raspberry Pi 2 running Raspian Jessie. Thanks.
                                      • H hawk_2050
                                        marceloaqno
                                        Code Contributor
                                        #72
                                        @emc2 I appreciate the offer for the adapter, but my country's post is a little complicated (to say the least).
                                        @hawk_2050 /dev/ttyUSBMySensorsGateway (or any other parameter you pass to --my-serial-pty) is a symbolic link:
                                        $ ls -lah /dev/ttyMySensorsGateway
                                        lrwxrwxrwx 1 root root 10 Sep 16 12:39 /dev/ttyMySensorsGateway -> /dev/pts/2
                                        In this case it is pointing to /dev/pts/2 but can vary, and it's the one who holds the specified group ownership.
                                        • M marceloaqno
                                          E
                                          E
                                          emc2
                                          @marceloaqno Up to you. I don't mind giving it a shot, if I send you the pcb alone it will fit in a regular letter and should not even have to go through customs etc. Worst case scenario it won't reach you.
