  3. MySensors Raspberry port suggestions
96 Posts 14 Posters 66.3k Views 17 Watching
  • alexsh1A alexsh1
    @emc2 said:
    ./configure --my-serial-pty=/dev/ttyUSBMySensorsGateway
    Exallent fix! Thanks
    @marceloaqno I can confirm that the Ethernet GW works fine without --my-controller-ip-address
    MAny thanks for your port and help!
    E
    E
    emc2
    Just a guess, I see on your previous post that you used --my-controller-ip-address=127,0,0,1 it may have been a typo here, but did you try with --my-controller-ip-address=127.0.0.1? (dots instead of commas in the IP)?
    alexsh1A 1 Reply Last reply
    • E emc2
      alexsh1A
      alexsh1A
      alexsh1
      @emc2 No, this is not a typo. This is a format. And yes, I have tried it with dots (127.0.0.1) - it did not compile.
      • E
        E
        emc2
        Good to know then, thanks!
        • alexsh1A
          alexsh1A
          alexsh1
          BTW, I am using a nice adapter for nrf24l01+ LNA+PA designed by @GertSanders :
          https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01
          Works nicely with this port and RPi 3.
          • E
            E
            emc2
            wrote on last edited by emc2
            #68
            Same, I had one Pi with GertSanders adapter and now switched to the SMD versions to fit nicely in my case.
            https://www.openhardware.io/view/105/MySRaspiGW
            https://www.openhardware.io/view/116/MySRaspiGW-PALNA
            Interestingly the regular one is working better than the PA+LNA version since moved to 2.0, at least in term of sending commands. Receiving is fine. Compiling with --my-rf24-pa-level=RF24_PA_LOW helps a lot. It seems 2.0 is really more power hungry, any hope to optimize this?
            Which remind me of one thing, sorry to bother you again @marceloaqno (how) is the --my-rf24-irq-pin=<PIN> working?
            I installed wiringpi to get rid of the wiringPiISR: Can't find gpio program but I'm not sure if it's supposed to do anything in the long term.
            I was thinking updating the design of my PCB to link BCM 24 (pin 18) to the IRQ pin of the radio module but it's unclear to me if the IRQ will ever actually be used on the gateway.
              marceloaqno
              Code Contributor
              Those are cool adapters, I need to build one for me.
              @emc2 It's no bother at all!
              Using nrf24 IRQ pin can give you more throughput and less chance of losing messages. It makes more sense to use if you have many sensors or need to transfer binary data (https://forum.mysensors.org/topic/3594/solar-powered-observation-nesting-box-network/).
              --my-serial-is-pty will simulate a serial port and create a symbolic link to it instead of using a real one.
              E 1 Reply Last reply
              • M marceloaqno
                E
                E
                emc2
                #70
                @marceloaqno Thanks for the heads up.
                I'm totally happy with the ethernet version, but as it seems @hek is in the process of writing guides on https://www.mysensors.org/build/raspberry I did a few tests.
                If I understood correctly (and it seems to work), to "replace" the 1.x serial gateway with the new one running the following command should work as is (/dev/ttyUSBMySensorsGateway can be renamed to /dev/ttyMySensorsGateway to be exactly as in 1.x or /dev/ttyUSB20 to bypass the symlink step)
                ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway --my-rf24-pa-level=RF24_PA_LOW
                --my-rf24-pa-level=RF24_PA_LOW can be omitted, especially if not using a PA+LNA module, but it seems 2.0 is really more power hungry than 1.4.
                If you are interested by the SMD ones, PM me your address and I will happily send you something!
                • H
                  H
                  hawk_2050
                  @marceloaqno The mechanism for assigning the pty serial port the specified group ownership doesn't appear to be working. The pty port is always created with root:root ownership. Can you (or anyone else) confirm whether this is working for you? I'm on a Raspberry Pi 2 running Raspian Jessie. Thanks.
                  • H hawk_2050
                    marceloaqno
                    Code Contributor
                    wrote on last edited by marceloaqno
                    #72
                    @emc2 I appreciate the offer for the adapter, but my country's post is a little complicated (to say the least).
                    @hawk_2050 /dev/ttyUSBMySensorsGateway (or any other parameter you pass to --my-serial-pty) is a symbolic link:
                    $ ls -lah /dev/ttyMySensorsGateway
                    lrwxrwxrwx 1 root root 10 Sep 16 12:39 /dev/ttyMySensorsGateway -> /dev/pts/2
                    In this case it is pointing to /dev/pts/2 but can vary, and it's the one who holds the specified group ownership.
                    • M marceloaqno
                      E
                      E
                      emc2
                      @marceloaqno Up to you. I don't mind giving it a shot, if I send you the pcb alone it will fit in a regular letter and should not even have to go through customs etc. Worst case scenario it won't reach you.
                      • M marceloaqno
                        @ericvdb That's right. I hope to add support for RFM69, Serial and software signing very soon.
                        To use, clone the raspberryPi port for MySensors 2.0:
                        git clone https://github.com/marceloaqno/MySensors.git
                        cd MySensors
                        To configure it, take a look at the options available within configure:
                        ./configure --help
                        For other options, you may have to edit the sample file example_linux/mysGateway.cpp, and uncoment what you need.
                        Once done, run:
                        make
                        sudo make install
                        To run the gateway you need to be root or use sudo:
                        sudo msyGateway -h
                        For wiring, follow this guide:
                        https://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway-mysensors-1-x
                        ikkeTI
                        ikkeTI
                        ikkeT
                        @marceloaqno , I assume your link for the wiring pinout behind the link is for Raspi 1 A+ with 26 pin header? Or for which version?
                        I'd like to try this with raspi 2 B, would you have instructions how to wire it?
                        Raspi2:
                        raspi2 pinout
                        Raspi1:
                        raspi1 pinout
                        • ikkeTI
                          ikkeTI
                          ikkeT
                          No, looking it again, it's vice versa, so yours is for Raspi2, right?
                          • ikkeTI
                            ikkeTI
                            ikkeT
                            So this 1.6 pinout would still apply? https://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway-mysensors-1-x
                            pinout
                            • ikkeTI ikkeT
                              marceloaqno
                              Code Contributor
                              @ikkeT yes, these are the default pins.
                              (SCK = 23, MISO = 21, MOSI = 19, CS = 24, CE = 22)
                              • ikkeTI
                                ikkeTI
                                ikkeT
                                Yahooo! It works, finally. I bet my problem was Raspi1 all along. I never realized the pinouts in github were for raspi with 40 pins, b+/2/3. Thanks!
                                • ikkeTI ikkeT
                                  marceloaqno
                                  Code Contributor
                                  @ikkeT it should also work for Raspi1, I got one running fine here.
                                  • ikkeTI
                                    ikkeTI
                                    ikkeT
                                    OK, then I just screwed up something. Thanks for the info, so I know I can do this also with my old raspi one day.
                                      marceloaqno
                                      Code Contributor
                                      #81
                                      Update: Added support for status leds (RX/TX/ERR), you can enable it in examples_linux/mysGateway.cpp file.
                                      • ikkeTI
                                        ikkeTI
                                        ikkeT
                                        Continuing the learning here, new questions... Thanks so far, I've now got the temp/hum/door messages sent and received from sensebender micro to raspi2. The next thing I would like to do is to send the messages as mqtt to the next box hosting some controller.
                                        How to get the mysGateway to send the stuff forward as mqtt? I tried to look into Makefile, MyConfig.h and such, but didn't quite figure out yet how to do that. Any pointers?
                                        So I'd like to have the following: sensebender -> radio -> raspi2 -> some box hosting the controller. Perhaps even outside of home, so routable traffic e.g. to OpenShift.com.
                                        Should I now somehow configure and build mysGateway to send stuff as MQTT, or pipe the traffic somehow to mqtt like mosqitto? How is this normally done if the controller server is not running on the gateway Raspi?
                                        Thanks for the patience, I'm just getting into all this interesting stuff :)
                                        mfalkviddM H 2 Replies Last reply
                                        • ikkeTI ikkeT
                                          @ikkeT I haven't tried but using nodered should be fairly simple and very flexible. This discussion might be useful: https://forum.mysensors.org/topic/2802/flow-to-turn-serialgateway-into-mqtt-serialgateway/
