  3. MySensors Raspberry port suggestions
96 Posts 14 Posters 66.3k Views 17 Watching
    marceloaqno
    Code Contributor
    @alexsh1 You must be root to run the gateway:
    $ sudo mysGateway
    It seems that you are not using the latest version, -h should have shown you the options list.
    alexsh1A 1 Reply Last reply
    • M marceloaqno
      $ sudo mysGateway
      alexsh1A
      alexsh1A
      alexsh1
      #59
      @marceloaqno I have the latest version (downloaded yesterday). Thanks very much for your help. I got the following:
      pi@m:~/MySensors/examples_linux $ sudo mysGateway -h
      MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
      TSM:INIT
      TSM:INIT:TSP OK
      TSM:INIT:GW MODE
      TSM:READY
      MCO:REG:NOT NEEDED
      MCO:BGN:STP
      MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
      In Domoticz:
      2016-09-09 09:32:26.032 TCP: Reconnecting...
      2016-09-09 09:32:26.032 MySensors: connected to: 127.0.0.1:5003
      I added MySensors with LAN in Domoticz (port 5003), but here a problem. I can see the node and the GW communicating:
      GW:
      TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
      Client 0: 0;0;3;0;18;PING
      Starting sensor (RNNNA-, 2.0.0-beta)
      Radio init successful.
      req id
      req id
      req id
      req id
      Init complete, id=255, parent=0, distance=1
      requesting time
      req id
      requesting time
      req id
      requesting time
      req id
      requesting time
      req id
      requesting time
      req id
      The RF communication is fine, but I do not understand why Domoticz is not assigning ID.......
      EDIT: I can see in Domoticz in the Hardware section:
      MySensors Gateway with LAN interface
      Version: ? Setup
      Typically ? comes up when the controller is not recognised or not connected
      EDIT2:Deleted and started fresh. Unfortunately, now the log file is flooded with the following:
      mysGateway: Max number of ethernet clients reached.
      • alexsh1A alexsh1
        TSM:INIT
        TSM:INIT:TSP OK
        TSM:INIT:GW MODE
        TSM:READY
        MCO:REG:NOT NEEDED
        MCO:BGN:STP
        In Domoticz:
        GW:
        req id
        req id
        req id
        req id
        requesting time
        req id
        requesting time
        req id
        requesting time
        req id
        requesting time
        req id
        requesting time
        req id
        Version: ? Setup
        marceloaqno
        Code Contributor
        @alexsh1 There is a bug with --my-controller-ip-address, I'm not sure if it's your case, but try to avoid it.
        I tried Domoticz here and everything seems fine:
        Version: 2.0.1-beta (Setup)
        I recommend you to start from scratch, re-download the gateway from here:
        https://github.com/marceloaqno/MySensors/tree/dev-raspberrypi
        • M marceloaqno
          alexsh1A
          alexsh1A
          alexsh1
          @marceloaqno OK, this must be the reason. I have tried the serial setup and it worked with a little tweak:
          /dev/ttyUSB20 -> /dev/ttyMySensorsGateway
          For whatever reason Domoticz did not see ttyMySensorsGateway so I had to create ttyUSB20
          E 1 Reply Last reply
          • alexsh1A alexsh1
            E
            E
            emc2
            Domoticz seems to only look for ttyUSB* interfaces. One easy trick is to run ./configure with this option so you don't have to worry with symlinking
            ./configure --my-serial-pty=/dev/ttyUSBMySensorsGateway
            BTW @marceloaqno , what does the option --my-serial-is-pty exactly do?
            So far I've been running the gateway in ethernet mode for a little while and it's working flawlessly, thanks a lot for this port.
            • E emc2
              alexsh1A
              alexsh1A
              alexsh1
              Exallent fix! Thanks
              @marceloaqno I can confirm that the Ethernet GW works fine without --my-controller-ip-address
              MAny thanks for your port and help!
              • alexsh1A alexsh1
                E
                E
                emc2
                Just a guess, I see on your previous post that you used --my-controller-ip-address=127,0,0,1 it may have been a typo here, but did you try with --my-controller-ip-address=127.0.0.1? (dots instead of commas in the IP)?
                • E emc2
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @emc2 No, this is not a typo. This is a format. And yes, I have tried it with dots (127.0.0.1) - it did not compile.
                  • E
                    E
                    emc2
                    Good to know then, thanks!
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      BTW, I am using a nice adapter for nrf24l01+ LNA+PA designed by @GertSanders :
                      https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01
                      Works nicely with this port and RPi 3.
                      • E
                        E
                        emc2
                        wrote on last edited by emc2
                        #68
                        Same, I had one Pi with GertSanders adapter and now switched to the SMD versions to fit nicely in my case.
                        https://www.openhardware.io/view/105/MySRaspiGW
                        https://www.openhardware.io/view/116/MySRaspiGW-PALNA
                        Interestingly the regular one is working better than the PA+LNA version since moved to 2.0, at least in term of sending commands. Receiving is fine. Compiling with --my-rf24-pa-level=RF24_PA_LOW helps a lot. It seems 2.0 is really more power hungry, any hope to optimize this?
                        Which remind me of one thing, sorry to bother you again @marceloaqno (how) is the --my-rf24-irq-pin=<PIN> working?
                        I installed wiringpi to get rid of the wiringPiISR: Can't find gpio program but I'm not sure if it's supposed to do anything in the long term.
                        I was thinking updating the design of my PCB to link BCM 24 (pin 18) to the IRQ pin of the radio module but it's unclear to me if the IRQ will ever actually be used on the gateway.
                          marceloaqno
                          Code Contributor
                          Those are cool adapters, I need to build one for me.
                          @emc2 It's no bother at all!
                          Using nrf24 IRQ pin can give you more throughput and less chance of losing messages. It makes more sense to use if you have many sensors or need to transfer binary data (https://forum.mysensors.org/topic/3594/solar-powered-observation-nesting-box-network/).
                          --my-serial-is-pty will simulate a serial port and create a symbolic link to it instead of using a real one.
                          • M marceloaqno
                            E
                            E
                            emc2
                            #70
                            @marceloaqno Thanks for the heads up.
                            I'm totally happy with the ethernet version, but as it seems @hek is in the process of writing guides on https://www.mysensors.org/build/raspberry I did a few tests.
                            If I understood correctly (and it seems to work), to "replace" the 1.x serial gateway with the new one running the following command should work as is (/dev/ttyUSBMySensorsGateway can be renamed to /dev/ttyMySensorsGateway to be exactly as in 1.x or /dev/ttyUSB20 to bypass the symlink step)
                            ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway --my-rf24-pa-level=RF24_PA_LOW
                            --my-rf24-pa-level=RF24_PA_LOW can be omitted, especially if not using a PA+LNA module, but it seems 2.0 is really more power hungry than 1.4.
                            If you are interested by the SMD ones, PM me your address and I will happily send you something!
                            • H
                              H
                              hawk_2050
                              @marceloaqno The mechanism for assigning the pty serial port the specified group ownership doesn't appear to be working. The pty port is always created with root:root ownership. Can you (or anyone else) confirm whether this is working for you? I'm on a Raspberry Pi 2 running Raspian Jessie. Thanks.
                              • H hawk_2050
                                marceloaqno
                                Code Contributor
                                wrote on last edited by marceloaqno
                                #72
                                @emc2 I appreciate the offer for the adapter, but my country's post is a little complicated (to say the least).
                                @hawk_2050 /dev/ttyUSBMySensorsGateway (or any other parameter you pass to --my-serial-pty) is a symbolic link:
                                $ ls -lah /dev/ttyMySensorsGateway
                                lrwxrwxrwx 1 root root 10 Sep 16 12:39 /dev/ttyMySensorsGateway -> /dev/pts/2
                                In this case it is pointing to /dev/pts/2 but can vary, and it's the one who holds the specified group ownership.
                                • M marceloaqno
                                  E
                                  E
                                  emc2
                                  @marceloaqno Up to you. I don't mind giving it a shot, if I send you the pcb alone it will fit in a regular letter and should not even have to go through customs etc. Worst case scenario it won't reach you.
                                  • M marceloaqno
                                    @ericvdb That's right. I hope to add support for RFM69, Serial and software signing very soon.
                                    To use, clone the raspberryPi port for MySensors 2.0:
                                    git clone https://github.com/marceloaqno/MySensors.git
                                    cd MySensors
                                    To configure it, take a look at the options available within configure:
                                    ./configure --help
                                    For other options, you may have to edit the sample file example_linux/mysGateway.cpp, and uncoment what you need.
                                    Once done, run:
                                    make
                                    sudo make install
                                    To run the gateway you need to be root or use sudo:
                                    sudo msyGateway -h
                                    For wiring, follow this guide:
                                    https://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway-mysensors-1-x
                                    ikkeTI
                                    ikkeTI
                                    ikkeT
                                    @marceloaqno , I assume your link for the wiring pinout behind the link is for Raspi 1 A+ with 26 pin header? Or for which version?
                                    I'd like to try this with raspi 2 B, would you have instructions how to wire it?
                                    Raspi2:
                                    raspi2 pinout
                                    Raspi1:
                                    raspi1 pinout
                                    • ikkeTI
                                      ikkeTI
                                      ikkeT
                                      No, looking it again, it's vice versa, so yours is for Raspi2, right?
                                      • ikkeTI
                                        ikkeTI
                                        ikkeT
                                        So this 1.6 pinout would still apply? https://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway-mysensors-1-x
                                        pinout
                                        • ikkeTI ikkeT
                                          marceloaqno
                                          Code Contributor
                                          @ikkeT yes, these are the default pins.
                                          (SCK = 23, MISO = 21, MOSI = 19, CS = 24, CE = 22)
