  3. [SOLVED ... partially] Ethernet gateway without radio don't present local sensors to domoticz
16 Posts 5 Posters 6.0k Views 4 Watching
  • TheoLT TheoL
    @tonin I'm following this with much curiosity. My first guess was that it can't work. Because the gateway shouldn't startup, in my mind at will stop the bootup sequence because there's it can't initialize the radio. At least that's what I expected.
    toninT
    toninT
    tonin
    @TheoL No, in mysensors 2.0 you can have gateways with local sensors or relays without radio only commenting all radio #define's
    • toninT tonin
      Mystery solved ....
      I was using client mode gateway because in server mode my arduino mega reset every time that send an ethernet packet. In client mode as I say, domoticz connect to the arduino but there is no traffic from arduino to RPI domoticz presenting my relays. I read that client mode is buggy at this time, so I try to get server mode without the resets.
      To avoid resets in my chinese arduino mega 2560 & chinese w5100 I need to downgrade de AVR library from 1.6.13 to 1.6.11. So all works Ok with my to gateways (usb & ethernet() connected to my RPI domoticz controller.
      TheoLT
      TheoLT
      TheoL
      @tonin Great to hear you've solved it.
      • TmasterT
        TmasterT
        Tmaster
        wrote on last edited by Tmaster
        Hi. I have the same problem with my serialgateway. its usb conected to VERA 3
        (ui7).
        There are no inclusion on vera. Normally i use the software arduino gateway start button on vera to include ,and reset the sensor be detected. Now my buzzer(relay based sketch) it's on gateway.
        What i do now for vera include my buzzer???? :disappointed:
        i even dont know if the scketch work but i need inclusion first...
        #define CHILD_ID 5
          sendSketchInfo("BUZZER", "1.0");
            present(CHILD_ID,S_DOOR);
          if (message.type==V_TRIPPED)
            tone(2, 2500, 1000) ;
        i'm a arduino fan .Even sometimes don't undestanding how to use it :P
        • toninT
          toninT
          tonin
          Try to call the presentation function in setup. I remembered that i needed to do it on usb gateway, the ethernet gateway has a patched code to call presentation after connection to the controller.
          • TmasterT
            TmasterT
            Tmaster
            Not worked. I think maybe i need an include button or some function that preset that sensor after gateway was already running and waiting for messages..I don't now. This new feature on gateway was one of my requests but still a mistery for me how it work :P
            • toninT
              toninT
              tonin
              This code
              //Comento la siguiente linea para que no necesite radio
              //#define MY_RADIO_NRF24
              // Enable serial gateway
              #define MY_GATEWAY_SERIAL
              #if F_CPU == 8000000L
              #define MY_BAUD_RATE 38400
              // Flash leds on rx/tx/err
              // Set blinking period
              // Enable inclusion mode
              //Para el sensor de temperatura
              #ifdef TEMP
               #include <OneWire.h>
               #define ONE_WIRE_BUS 2
               MyMessage msg(0,V_TEMP);
              //Structura de reles
              typedef struct  {
               int  pin;
               char desc[20];
               bool ON;
               bool OFF;
              } sRELE;
              sRELE Rele [] = { {13 , "LED", HIGH, LOW},
                               {31 , "RELE ASPERSOR PORCHE", LOW, HIGH},
                               {33 , "RELE TURBINAS", LOW, HIGH},
                               {35 , "RELE GOTEROS BAJOS", LOW, HIGH}
              #ifdef TEMP
               sensors.begin();
               //Para los reles
                 Serial.println("start call Setup");
               for (int sensor=0 ; sensor<NUMBER_OF_RELAYS;sensor++) {
                 // Poner el rele en output mode
                 pinMode(Rele[sensor].pin, OUTPUT);
                 // Poner el rele en el ultimo estado conocido (usando eeprom storage)
                 digitalWrite(Rele[sensor].pin, loadState(sensor)?Rele[sensor].ON:Rele[sensor].OFF);
                 Serial.println("End call Setup");
                 presentation();
               // Presentar los sensores y actuadores locales
               Serial.println("start call presentation");
               // Mandar la info del sketch
               sendSketchInfo("Arduino USB", "1.0");
               //Presentar los reles
               for (int rele=0; rele<NUMBER_OF_RELAYS;rele++) {
                 // Registrar todos los reles al gw
                 present(rele, S_LIGHT,Rele[rele].desc);
               Serial.println("End call presentation");
              #ifdef TEMP
               //Presento el sensor de temperatura
               present(9,S_TEMP,"SENSOR_TEMP");
              bool STATUS;
              #ifdef TEMP
               Serial.print("Solicitando temperaturas...");
               sensors.requestTemperatures(); // Send the command to get temperatures
               float temperatura = sensors.getTempCByIndex(0);
               send(msg.setSensor(9).set(temperatura,1));
               Serial.println("DONE");
               sleep(2000);
               // Solo esperamos mensajes V_LIGTH de momento, pero lo chequeamos por si acaso.
               if (message.type==V_LIGHT) {
                  // Cambiar estado del rele
                  digitalWrite(Rele[message.sensor].pin, message.getBool()?Rele[message.sensor].ON:Rele[message.sensor].OFF);
                  // Almacenar estado en la eeprom
                  // Escribir informacion de debug
                  Serial.print("Cambio entrante para sensor:");
                  Serial.print(", Nuevo status: ");
              works ok for me. As you can see I define the relays in an structure to do it configurable. The only trick for me is to call the presentation function in the setup function. In the ethernet gateway it isn't needed.
              A note for the structure sRELE. yo can see the pin, description and the state of the pin that mean ON or OFF. It's so because my relay boards have an inverse logic. When the pin is in low state, the relay is on. This relay boards are opto coupled and have an isolated circuit between arduino pins and relays, this is the reason for that.
              The sample code also have some lines to read temperature from a dallas sensor.
              I hope that this help you.
              • TmasterT
                TmasterT
                Tmaster
                Viva la espanã:p :palm_tree: . gracias.
                Tankyou.I will try tomorow. :+1:
                • TmasterT
                  TmasterT
                  Tmaster
                  hi. i just add presentation function on setup but still the same. No sign of the sensor on vera. maybe yor sketch its sending back another call in some other line ... i can't make it work.
                  changes:
                    presentation();
                       // Change relay state
                       //digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                       // Store state in eeprom
                       //saveState(message.sensor, message.getBool());
                    This was fixed in development back in august but has not yet made it to master branch (which you might be using if you downloaded through library manager).
                    https://github.com/mysensors/MySensors/pull/532
                    • TmasterT
                      TmasterT
                      Tmaster
                      So i need install the devbranch. . i will try...
                      thankyou
                      12.5k
