  2. Announcements
  3. 💬 Light Level Sensor - LM393
19 Posts 6 Posters 8.6k Views 6 Watching
  • hekH Offline
    hekH Offline
    This thread contains comments for the article "Light Level Sensor - LM393" posted on MySensors.org.
    ramoncarranzaR 1 Reply Last reply
    • Fat FlyF Offline
      Fat FlyF Offline
      Fat Fly
      Hi.
      Can i use photoresistor instead of lm393 ?
      • Fat FlyF Fat Fly
        Hi.
        @Fat-Fly yes. Create a voltage divider by adding a resistor that matches your ldr and expected light levels.
        • Fat FlyF Offline
          Fat FlyF Offline
          Fat Fly
          With 100k resistor like this ?
          • Fat FlyF Fat Fly
            @Fat-Fly In general, yes. But the appropriate value of the resisor depends on which ldr you are using and the light levels you want to measure. Some LDRs are 1Mohm, some are 10kohm. Easiest way might be to experiment with different resistors.
            • Fat FlyF Offline
              Fat FlyF Offline
              Fat Fly
              I need measure resistance. If i use 3,3v and 1M photo resistor what size is resistor for measure day light. I want to turn solar panels.
              • A Offline
                A Offline
                AndreD
                how to connect 2-5 lm393.
                • A AndreD
                  Use the other analog pins (A1 to A7)
                  • A Offline
                    A Offline
                    AndreD
                    It's clear. I do not know what variables need to assign additional.
                      ramoncarranzaR Offline
                      ramoncarranza
                      @hek hi, I've been searching to see if I can find anything on th LM393 Sound sensor, I know I saw one but can't find it, looking to build a simple soundsensor with the LM393 unit.
                      • hekH Offline
                        hekH Offline
                        @ramoncarranza said:
                        LM393
                        google on "LM393 datasheet"
                        ramoncarranzaR 2 Replies Last reply
                          LM393
                          ramoncarranza
                          @hek I found this sketch, but how do I incorporate it to my sensors library and serial gateway?
                            LM393
                            ramoncarranza
                            @hek
                            int soundDetectedPin = 10; // Use Pin 10 as our Input
                            int soundDetectedVal = HIGH; // This is where we record our Sound Measurement
                            boolean bAlarm = false;
                            unsigned long lastSoundDetectTime; // Record the time that we measured a sound
                            int soundAlarmTime = 500; // Number of milli seconds to keep the sound alarm high
                            void setup ()
                            Serial.begin(9600);
                            pinMode (soundDetectedPin, INPUT) ; // input from the Sound Detection Module
                            void loop ()
                            soundDetectedVal = digitalRead (soundDetectedPin) ; // read the sound alarm time
                            if (soundDetectedVal == LOW) // If we hear a sound
                            lastSoundDetectTime = millis(); // record the time of the sound alarm
                            // The following is so you don't scroll on the output screen
                            if (!bAlarm){
                              Serial.println("LOUD, LOUD");
                              bAlarm = true;
                            if( (millis()-lastSoundDetectTime) > soundAlarmTime && bAlarm){
                            Serial.println("quiet");
                            bAlarm = false;
                            • hekH Offline
                              hekH Offline
                              Not sure I understand what you mean by "incorporate".
                              Suggerst sending a TRIPPED value 1 when sound is detected for the a SOUND child sensor.
                                ramoncarranza
                                @hek what extra code do I need to add to the sketch so tha it sends the tripped value to my gateway?
                                • hekH Offline
                                  hekH Offline
                                  Look at the motion sensor as an example.
                                    ramoncarranza
                                    @hek will do thanks
                                    • pgregg88P Offline
                                      pgregg88P Offline
                                      pgregg88
                                      Hello. I need a sensor that can sense the green status led on an audio amplifier and report state via MQTT. The goal is an accurate source of Power State (ON/OFF) for the audio amp. The light is a fairly dim led. The sensor could mount directly on it. Is the LM393 appropriate for this type of requirement?
                                      Here is the problem... Home theater setup. TV and sound app both start at the same time. However, the audio amp has a "feature" where it cuts it's power off if it doesn't sense audio for more than two minutes. As soon as you mute the TV for an advertisement, the audio amp shuts down (while the remote control thinks the audio amps state is ON). Then, everything is out of sync and my wife and kids start calling me names. Bad ones.
                                      • hekH Offline
                                        hekH Offline
                                        Oh, what a crappy thing. 2 minutes is nothing. You can't fix this by bypassing the circuitry that shuts the thing down?
                                        The only way of knowing is to mount a photo resistor over the led and see if you get any reading when it is on. Use the trimpot to adjust the binary output.
