  2. Announcements
  3. 💬 MYSController
💬 MYSController
58 Posts 24 Posters 32.8k Views 23 Watching
    wrote on last edited by hek
    This thread contains comments for the article "MYSController" posted on MySensors.org.
      shabba
      What is URL for this project?
      • Q
        Q
        Qu3Uk
        Don't know if it has a project website but it can be found here https://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors
        • CrankyCoderC
          CrankyCoderC
          CrankyCoder
          Tekka, is this working for 2.0 and mqttclientgateway? if so, this could be a dream come true for keeping tabs on what's out in my network and versioning ect.
          Home Automation Tinkerer
          www.CrankyCoder.net
          Gateway: MQTTClientGateway
          MySensors: 2.3
          • AndurilA
            AndurilA
            Anduril
            @Jason-Brunk it's working with MySensors 2.0, but not for mqtt
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              Dang, the ota update is something i am looking for big time, but it seems using mqtt is killing that option for me. I went mqtt route since I have a fault tolerant openhab system and it's easier to fail over services than physical connections.
              www.CrankyCoder.net
              MySensors: 2.3
              • AndurilA
                AndurilA
                Anduril
                As far as I know tekka is working on a mqtt support and there is also MyController, which also has OTA support and mqtt. Maybe you can have a look at it.
                CrankyCoderC 1 Reply Last reply
                • AndurilA Anduril
                  CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  @Anduril very cool. I will check on mycontroller. I probably won't need most of the functionality but if it can do the ota for mqtt for now it might work. I like tekka's project so I am hoping that gets the mqtt ota support. Thanks!
                  www.CrankyCoder.net
                  MySensors: 2.3
                  • BartB
                    BartB
                    Bart
                    Is it possible to use this app when using RS485 transport? I have one of these usb (ftdi based) adapters connected with 2 Arduino MEGA on a RS485 bus:
                    http://www.banggood.com/USB-To-RS485-TTL-Serial-Converter-Adapter-FTDI-Interface-FT232RL-75176-p-961537.html
                    Tried it but I don't see any messages. Connecting serial monitor does show a traffic.
                    AWIA 1 Reply Last reply
                    • BartB Bart
                      AWIA
                      AWIA
                      AWI
                      @Bart You should not connect MYSContoller to the RS485 bus but to the serial (or LAN) gateway connection. In other words, MYScontroller works as a controller not a bus monitor.
                      • maghacM
                        maghacM
                        maghac
                        Any news regarding OTA for MQTT gatways?
                        I have a MQTT GW running on a NodeMCU and I can upload new versions of the GW sketch to it using ArduinoOTA. It would be great to be able to also update the sensors connected to it without having to connect it to my computer.
                        • D
                          dakipro
                          Just wanted to support the support for MQTT, that would really be awesome (especially since MyController can do ota over mqtt :) )
                          • J
                            J
                            juanmrodrigues
                            Hi all,
                            Thanks again for the great work.
                            Simple question: Is still MQTT support in the roadmap? Will it be possible to do FOTA over an MQTT Gateway?
                            Regards! Merry Xmas and Happy New Year!
                            • RajendraR
                              RajendraR
                              Rajendra
                              Myscontroller latest version 1.0.0.3316 shows trojan at virustotal
                              is this ok?
                              https://www.virustotal.com/#/file/6082b86e6a56783e692afaa7c6d79e5af0d6ca58476ef7e180a39594ce441cd7/detection
                              Whats the reason for it
                              Rajendra
                              tekkaT 1 Reply Last reply
                              • RajendraR Rajendra
                                is this ok?
                                tekkaT
                                tekkaT
                                tekka
                                @iocare-research-team False alarm (4 out of 67), most likely due to the executable being packed with UPX.
                                RajendraR 1 Reply Last reply
                                • tekkaT tekka
                                  RajendraR
                                  RajendraR
                                  Rajendra
                                  @tekka ok.. hope so!
                                  Rajendra
                                  • RajendraR
                                    RajendraR
                                    Rajendra
                                    Is there any chance of making this tool Open source. Its great tool.
                                    Making it open could lead to its porting to various platforms like android and ios
                                    and other desktop OS and also make it more stable.
                                    just a suggestion.!
                                    Rajendra
                                    • L
                                      L
                                      ludoarchi
                                      Nice app ! Is there any How To for the begeners i m not able to connect my network. Thinks
                                        Sasquatch
                                        latest version I can find is 1.0.0 beta... but i've seen screenshots of 1.2.2. where can i get it from?
                                        • G
                                          G
                                          Guillermo Schimmel
                                          Absolutely great work! Just discovering the extent of the work done with mysensors. Amazing. Thanks
