  3. Problem getting the code to run with MySensors library 2.0
38 Posts 3 Posters 12.4k Views 3 Watching
  • palande.vaibhavP
    palande.vaibhavP
    palande.vaibhav
    wrote on last edited by palande.vaibhav
    Hello guys,
    I am trying to write a simple code using the MySensors library 2.0. Its a simple switch. I am generating interrupt on pin 2 of Arduino Uno. Switch is connected between Pin 2 and GND. The interrupt is invoked when I change the state of the switch and then LED on pin 13 toggles.
    First I wrote the code without MySensors library. Just a simple Arduino code to make sure this thing works. It works flawlessly.
    Below is the code for this without MySensors library: This code works. I have commented out the lines which involve use o MySensors library.
    const byte ledPin = 13;
    volatile byte state = LOW;
    //MySensors
    // Enable debug prints
    //#define MY_RADIO_NRF24
    //#include <SPI.h>
    //#include <MySensors.h>
    const byte DIGITAL_INPUT_SENSOR = 2;
    //#define CHILD_ID 1   // ID of the sensor child
    // Initialize message
    //MyMessage msg(CHILD_ID, V_LIGHT);
      pinMode(ledPin, OUTPUT);
      pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), state_change, CHANGE);
    //void presentation()  {
    //  // Send the sketch version information to the gateway and Controller
    //  sendSketchInfo("Switch", "1.0");
    //  // Register all sensors to gw (they will be created as child devices)
    //  present(CHILD_ID, S_LIGHT);
     // boolean status = digitalRead(DIGITAL_INPUT_SENSOR);
      digitalWrite(ledPin, state);
      //Serial.println(digitalRead(ledPin));
      //Serial.println(status);
      //send(msg.set((status)?"1":"0"));  //Send status value to the GW
    void state_change() {
      Serial.println(state);
      state = !state;
    The problem starts is when I add the line #include<MySensors.h>. When I add this line to the code, LED doesn't toggle when I flip the switch. I don't know what the problem is.
    I really appreciate the help.
    Thank You,
    Vaibhav
    • palande.vaibhavP palande.vaibhav
      Hello guys,
      //MySensors
      //#include <SPI.h>
        state = !state;
      Thank You,
      Vaibhav
      @palande.vaibhav does the problem start when you only uncomment include MySensors.h, or does it start if you uncomment more than that line?
      If you activate the MySensors radio functions (by uncommenting MY_RADIO_NRF24) pin 13 will be used for communicating with the radio. See https://www.mysensors.org/build/connect_radio
      palande.vaibhavP 1 Reply Last reply
        palande.vaibhavP
        palande.vaibhavP
        palande.vaibhav
        @mfalkvidd @ayo Thanks for the reply.
        I have tried changing the pin to Pin8.
        I now have tried a Arduino library LED blink code. I attached the LED to Pin 8. It blinks without the #include<MySensors.h> line. But when I add #define MY_RADIO_NRF24 and #include <MySensors.h>, it stops working.
        I have to add #define MY_RADIO_NRF24 because if I don't it throws an error saying if I don't have a radio then adding MySensors.h is pointless. And I get it, its pointless.
        So, problem starts after uncommenting #include<Mysensors.h> and #define MY_RADIO_NRF24.
          Blink
          Turns on an LED on for one second, then off for one second, repeatedly.
          Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
          it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN takes care
          of use the correct LED pin whatever is the board used.
          If you want to know what pin the on-board LED is connected to on your Arduino model, check
          the Technical Specs of your board  at https://www.arduino.cc/en/Main/Products
          This example code is in the public domain.
          modified 8 May 2014
          by Scott Fitzgerald
          modified 2 Sep 2016
          by Arturo Guadalupi
        // the setup function runs once when you press reset or power the board
          // initialize digital pin LED_BUILTIN as an output.
          pinMode(8, OUTPUT);
        // the loop function runs over and over again forever
          digitalWrite(8, HIGH);   // turn the LED on (HIGH is the voltage level)
          delay(500);                       // wait for a second
          digitalWrite(8, LOW);    // turn the LED off by making the voltage LOW
        • ayoA
          ayoA
          ayo
          I believe the problem is a result of the pin 13 you are using for the Led. The Mysensor & SPI both require pin 13 (Pin 13 is SCK pin for SPI) for the radio communication. Try and move your Led Pin to another pin from Pin 8 downward.
          • ayoA ayo
            palande.vaibhavP
            palande.vaibhavP
            palande.vaibhav
            @ayo
            I did. The problem is still there. I also tried simplest of the simple LED blink code. Check my new post.
            Thank You
            • palande.vaibhavP
              palande.vaibhavP
              palande.vaibhav
              @palande.vaibhav said:
              @mfalkvidd @ayo
              Even uncommenting #define MY_RADIO_NRF24 WORKS.
              So the problem starts when I uncomment #include <MySensors.h>.
              • palande.vaibhavP
                palande.vaibhavP
                palande.vaibhav
                @mfalkvidd @ayo
                I just tested with older library version 1.5.4.
                Both Blink and my Switch code work with MySensors library version 1.5.4 but doesn't work with version 2.0.
                • ayoA
                  ayoA
                  ayo
                  So I tired the blinking thing on my own Arduino setup using the MySensors 2.0 installed var the Arduino Library manager.
                  The Led blinks with the mysensors library attached.
                  // Enable serial gateway
                  #define MY_GATEWAY_SERIAL
                  #if F_CPU == 8000000L
                  #define MY_BAUD_RATE 38400
                  // Flash leds on rx/tx/err
                  // Set blinking period
                  // Enable inclusion mode
                    pinMode(8, OUTPUT);
                    wait(1000);              // wait for a second
                  Maybe you can give that a short...
                  palande.vaibhavP 2 Replies Last reply
                  • palande.vaibhavP
                    palande.vaibhavP
                    palande.vaibhav
                    • ayoA ayo
                        pinMode(8, OUTPUT);
                      palande.vaibhavP
                      palande.vaibhavP
                      palande.vaibhav
                      @ayo
                      OK. I will give this a shot.
                      One more thing is installing the library 2.0 from Arduino library manager gives an error "
                      CRC doesn't match. File is corrupted." I am using Arduino IDE version 1.6.12.
                      I am downloading the zip from GitHub and pasting it in the Documents/Arduino/libraries folder. This is OK right??
                      • ayoA ayo
                          pinMode(8, OUTPUT);
                        palande.vaibhavP
                        palande.vaibhavP
                        palande.vaibhav
                        @ayo
                        Something weird is happening right now. I am now running MySensors version 2.0. The code you gave works with library version 2.0.
                        I was just experimenting with the lines of the code to see which line makes difference and I found that #define MY_GATEWAY_SERIAL line makes difference.
                        If I just add that line to my Blink code, it works with MySensors.h
                        I don't know why this happens.
                        //// Enable debug prints to serial monitor
                        //// Enable and select radio type attached
                        ////#define MY_RADIO_RFM69
                        //// Set LOW transmit power level as default, if you have an amplified NRF-module and
                        //// power your radio separately with a good regulator you can turn up PA level.
                        //// Enable serial gateway
                        //// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
                        //#if F_CPU == 8000000L
                        //#define MY_BAUD_RATE 38400
                        //#endif
                        //// Flash leds on rx/tx/err
                        //#define MY_LEDS_BLINKING_FEATURE
                        //// Set blinking period
                        //// Inverses the behavior of leds
                        ////#define MY_WITH_LEDS_BLINKING_INVERSE
                        //// Enable inclusion mode
                        //// Enable Inclusion mode button on gateway
                        //// Inverses behavior of inclusion button (if using external pullup)
                        ////#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
                        //// Set inclusion mode duration (in seconds)
                        //// Digital pin used for inclusion mode button
                          pinMode(8, OUTPUT);
                          delay(1000);              // wait for a second
                        This code works but only if I have #define MY_GATEWAY_SERIAL line included. Can you try this on your setup?
                        In my code which was not working previously, If I just add #define MY_GATEWAY_SERIAL , it works.
                        In your Blink code, if you just comment out the line #define MY_GATEWAY_SERIAL, it won't work. Can you try this?
                          @ayo
                          //#endif
                            pinMode(8, OUTPUT);
                          palande.vaibhavP
                          palande.vaibhavP
                          palande.vaibhav
                          @mfalkvidd
                          Any idea why this is happening?
                          Cause I can't use MY_GATEWAY_SERIAL for a node. Right?
                          • ayoA
                            ayoA
                            ayo
                            Okay....so you are really having a strange problem here.
                            Am using the Arduino version 1.6.8,
                            Can you consider upgrading your arduino version maybe that could fix the CRC thing...
                              @mfalkvidd
                              Yes you can. But I read that there is a bug in MySensors 2.0 that causes the presentation function to not run, so you'll need the latest code from the MySensors development branch on Github.
                              palande.vaibhavP 4 Replies Last reply
                              • ayoA ayo
                                palande.vaibhavP
                                palande.vaibhavP
                                palande.vaibhav
                                @ayo
                                1.6.8 is the older version. 1.6.12 is the latest version.
                                And the CRC error is the known bug. So, if your IDE and MySensors work then don't change anything.
                                • ayoA ayo
                                  palande.vaibhavP
                                  palande.vaibhavP
                                  palande.vaibhav
                                  @ayo
                                  did you try commenting #define MY_GATEWAY_SERIAL and running your Blink code?
                                  Can you please try that?
                                  ayoA 1 Reply Last reply
                                    palande.vaibhavP
                                    palande.vaibhavP
                                    palande.vaibhav
                                    But am I right that for MySensors version 2.0, we must have #define MY_GATEWAY_SERIAL line in order for the code to work? OR is it just me?
                                    And I don't even have anything in the presentation function. I think my problem is loop function not working if I don;t have #define MY_GATEWAY_SERIAL line in the code.
                                      palande.vaibhavP
                                      palande.vaibhavP
                                      palande.vaibhav
                                      I tried with the library from Development branch on GitHub. It still doesn't work.
                                      I must have #define MY_GATEWAY_SERIAL line in the code for the code to work with MySensors.h.
                                      Library version:
                                      Code below doesn't work cause I have commented #define MY_GATEWAY_SERIAL: Just uncomment it and the same code works
                                      //MySensors
                                      //#define MY_GATEWAY_SERIAL
                                      const byte DIGITAL_INPUT_SENSOR = 3;   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                                      //#define CHILD_ID 1   // Id of the sensor child
                                      // Initialize motion message
                                      //MyMessage msg(1, V_LIGHT);
                                        pinMode(8, OUTPUT);
                                        palande.vaibhavP
                                        palande.vaibhavP
                                        palande.vaibhav
                                        @mfalkvidd
                                        I saw the post about the presentation function not working in 2.0. But that has been fixed in development version.
                                        My problem is still there that code doesn't work at all. To which I think my loop function stops working if I don't have #define MY_GATEWAY_SERIAL line in the code.
                                          @mfalkvidd
                                          @palande.vaibhav what does the debug output say?
                                          You can also add a few Serial.println in the code to see where the execution stops.
