  3. Problem getting the code to run with MySensors library 2.0
38 Posts 3 Posters 12.5k Views 3 Watching
  • ayoA ayo
    So I tired the blinking thing on my own Arduino setup using the MySensors 2.0 installed var the Arduino Library manager.
    The Led blinks with the mysensors library attached.
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
      pinMode(8, OUTPUT);
       digitalWrite(8, HIGH);   // turn the LED on (HIGH is the voltage level)
      wait(1000);              // wait for a second
      digitalWrite(8, LOW);    // turn the LED off by making the voltage LOW
    Maybe you can give that a short...
    palande.vaibhavP
    palande.vaibhavP
    palande.vaibhav
    @ayo
    OK. I will give this a shot.
    One more thing is installing the library 2.0 from Arduino library manager gives an error "
    CRC doesn't match. File is corrupted." I am using Arduino IDE version 1.6.12.
    I am downloading the zip from GitHub and pasting it in the Documents/Arduino/libraries folder. This is OK right??
    • ayoA ayo
        pinMode(8, OUTPUT);
      palande.vaibhavP
      palande.vaibhavP
      palande.vaibhav
      wrote on last edited by palande.vaibhav
      @ayo
      Something weird is happening right now. I am now running MySensors version 2.0. The code you gave works with library version 2.0.
      I was just experimenting with the lines of the code to see which line makes difference and I found that #define MY_GATEWAY_SERIAL line makes difference.
      If I just add that line to my Blink code, it works with MySensors.h
      I don't know why this happens.
      //// Enable debug prints to serial monitor
      //// Enable and select radio type attached
      ////#define MY_RADIO_RFM69
      //// Set LOW transmit power level as default, if you have an amplified NRF-module and
      //// power your radio separately with a good regulator you can turn up PA level.
      //// Enable serial gateway
      //// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
      //#if F_CPU == 8000000L
      //#define MY_BAUD_RATE 38400
      //#endif
      //// Flash leds on rx/tx/err
      //#define MY_LEDS_BLINKING_FEATURE
      //// Set blinking period
      //// Inverses the behavior of leds
      ////#define MY_WITH_LEDS_BLINKING_INVERSE
      //// Enable inclusion mode
      //// Enable Inclusion mode button on gateway
      //// Inverses behavior of inclusion button (if using external pullup)
      ////#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
      //// Set inclusion mode duration (in seconds)
      //// Digital pin used for inclusion mode button
        pinMode(8, OUTPUT);
        delay(1000);              // wait for a second
      This code works but only if I have #define MY_GATEWAY_SERIAL line included. Can you try this on your setup?
      In my code which was not working previously, If I just add #define MY_GATEWAY_SERIAL , it works.
      In your Blink code, if you just comment out the line #define MY_GATEWAY_SERIAL, it won't work. Can you try this?
      palande.vaibhavP 1 Reply Last reply
      • palande.vaibhavP palande.vaibhav
        @ayo
        //#endif
          pinMode(8, OUTPUT);
        palande.vaibhavP
        palande.vaibhavP
        palande.vaibhav
        @mfalkvidd
        Any idea why this is happening?
        Cause I can't use MY_GATEWAY_SERIAL for a node. Right?
        • ayoA
          ayoA
          ayo
          Okay....so you are really having a strange problem here.
          Am using the Arduino version 1.6.8,
          Can you consider upgrading your arduino version maybe that could fix the CRC thing...
          palande.vaibhavP 2 Replies Last reply
            @mfalkvidd
            Yes you can. But I read that there is a bug in MySensors 2.0 that causes the presentation function to not run, so you'll need the latest code from the MySensors development branch on Github.
            palande.vaibhavP 4 Replies Last reply
            • ayoA ayo
              palande.vaibhavP
              palande.vaibhavP
              palande.vaibhav
              @ayo
              1.6.8 is the older version. 1.6.12 is the latest version.
              And the CRC error is the known bug. So, if your IDE and MySensors work then don't change anything.
              • ayoA ayo
                palande.vaibhavP
                palande.vaibhavP
                palande.vaibhav
                @ayo
                did you try commenting #define MY_GATEWAY_SERIAL and running your Blink code?
                Can you please try that?
                ayoA 1 Reply Last reply
                  palande.vaibhavP
                  palande.vaibhavP
                  palande.vaibhav
                  But am I right that for MySensors version 2.0, we must have #define MY_GATEWAY_SERIAL line in order for the code to work? OR is it just me?
                  And I don't even have anything in the presentation function. I think my problem is loop function not working if I don;t have #define MY_GATEWAY_SERIAL line in the code.
                    palande.vaibhavP
                    palande.vaibhavP
                    palande.vaibhav
                    I tried with the library from Development branch on GitHub. It still doesn't work.
                    I must have #define MY_GATEWAY_SERIAL line in the code for the code to work with MySensors.h.
                    Library version:
                    Code below doesn't work cause I have commented #define MY_GATEWAY_SERIAL: Just uncomment it and the same code works
                    //MySensors
                    //#define MY_GATEWAY_SERIAL
                    const byte DIGITAL_INPUT_SENSOR = 3;   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                    //#define CHILD_ID 1   // Id of the sensor child
                    // Initialize motion message
                    //MyMessage msg(1, V_LIGHT);
                      pinMode(8, OUTPUT);
                      palande.vaibhavP
                      palande.vaibhavP
                      palande.vaibhav
                      @mfalkvidd
                      I saw the post about the presentation function not working in 2.0. But that has been fixed in development version.
                      My problem is still there that code doesn't work at all. To which I think my loop function stops working if I don't have #define MY_GATEWAY_SERIAL line in the code.
                        @mfalkvidd
                        @palande.vaibhav what does the debug output say?
                        You can also add a few Serial.println in the code to see where the execution stops.
                          palande.vaibhavP
                          palande.vaibhavP
                          palande.vaibhav
                          @mfalkvidd
                          Thanx for the suggestion. It's worse than I thought.
                          Here is the code:
                          //MySensors
                            pinMode(8, OUTPUT);
                            Serial.println("Setup runs");
                           Serial.println("presentation runs");
                            Serial.println("loop runs");
                          This is the output with #define MY_GATEWAY_SERIAL line.
                          Without #define MY_GATEWAY_SERIAL, it doesn't show anything on the serial monitor.
                            @ayo
                            ayoA
                            ayoA
                            ayo
                            I don't have access to my computer now I will try it when I have it.
                            @ayo
                              @mfalkvidd
                              Here is the code:
                              //MySensors
                                pinMode(8, OUTPUT);
                              palande.vaibhavP
                              palande.vaibhavP
                              palande.vaibhav
                              #23
                              @mfalkvidd
                              Here is the code:
                              //MySensors
                                pinMode(8, OUTPUT);
                              @mfalkvidd Any update on this?
                                @mfalkvidd
                                Here is the code:
                                //MySensors
                                  pinMode(8, OUTPUT);
                                @palande.vaibhav no, I haven't got any ideas on what could be wrong. Sorry.
                                • ayoA ayo
                                  @ayo
                                  palande.vaibhavP
                                  palande.vaibhavP
                                  palande.vaibhav
                                  @ayo Did you try running the code?
                                    palande.vaibhavP
                                    palande.vaibhavP
                                    palande.vaibhav
                                    @mfalkvidd
                                    Is it only me?
                                    Can you please try this on your setup as time permits?
                                    I have a manual install of the library 2.0
                                    I want to use this for one of my projects and I am dead stuck.
                                      palande.vaibhavP
                                      palande.vaibhavP
                                      palande.vaibhav
                                      #27
                                      @mfalkvidd
                                      I have to keep #define MY_GATEWAY_SERIAL line in the code for both gateway and sensor nodes.
                                      Now since I have #define MY_GATEWAY_SERIAL line in the code for both gateway and sensor node, both of them are initializing as gateways.
                                      And this causes them not to be able to communicate with each other.
                                      Please help
                                        ayoA
                                        ayoA
                                        ayo
                                        So I tried the whole code thing again as you have requested and I notice something weird happening to the device.
                                        This is the code below
                                          pinMode(8, OUTPUT);
                                         Serial.println("Presentation Runs");
                                          Serial.println("Loop is running");
                                        After I commented out #define MY_GATEWAY_SERIAL nothing really happens on the serial monitor as you have said.
                                        No blinking nor display on the monitor.
                                        So I went back to the code and enable #define MY_DEBUG to see what was actually happening....
                                        THEN..I figured out what was happening
                                        I uploaded the new code with #define MY_Debug uncomment and #define MY_Gateway_Serial still commented out I got this one the serial monitor
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        From the result, the device is working as a node and trying to communicate with the parent/gateway and it enters an endless retry loop that keeps trying to communicate with the gateway. This is the reason i suppose nothing seems to be working because it is stuck trying to connect to the parent.
                                        The Addition of #define MY_GATEWAY_SERIAL makes it already a gateway/parent device and avoids that endless loop thing.
                                        • ayoA
                                          ayoA
                                          ayo
                                          I think one way to go about making it work is to edit that element of the mysensor main code that makes it enter an infinite retry loop is to is to make it retry for about maybe 3 times if no connection still it should raise a flag and leaves the loop and continue into the main code.
                                          12.5k
