  3. Domoticz
  4. lost serial gateway after un plug power Rpi
45 Posts 8 Posters 20.0k Views 7 Watching
  • R
    R
    Reza
    wrote on last edited by Reza
    hi guys
    after un plug raspberry pi and plug in power again , my serial gateway (mysensors) is lost , so i must disconnect USB cable (serial gateway) and connect again every time. . . !!!
    where problem !?
    • R
      R
      Reza
      anybody test this issue !? and have same problem !
      • nagelcN
        nagelcN
        nagelc
        I have this exact problem. I have 2 gateways, a moteino USB for RFM69 radios and a nano for an NRF24 radios.
        Domoticz running on a raspberry pi.
        If I reboot the pi, or power down and restart, the moteino connects back up automatically.
        For the nano, I have to unplug and reconnect it after the pi has booted up, or it won't be detected.
        • tbowmoT
          tbowmoT
          tbowmo
          I have never experienced this. I'm using a nano with nrf24.
          Could be a hardware issue with your arduino.
          • R
            R
            Reza
            i think that this problem is related to startup . when plug in power (rasspberry pi ) , the serial gateway is faster to startup than rasspberry. so when raspberry pi is startup dont detect serial gateway !!! are there any ways for this ? for example a delay for turn on gateway or startup until first raspberry pi started!
            • AWIA
              AWIA
              AWI
              wrote on last edited by AWI
              The possible cause is that the Raspberry-Pi has no consistency in assigning USB port numbers. This occurs mainly when you have more than 1 USB port in use. Read for a solution..
              Btw I never experienced it running 3 PI's with each a serial gateway.
              R 1 Reply Last reply
              • AWIA AWI
                R
                R
                Reza
                @AWI
                i test this but dont work.
                AWIA 1 Reply Last reply
                • R Reza
                  @AWI
                  AWIA
                  AWIA
                  AWI
                  @Reza What does not work?
                  • AWIA AWI
                    R
                    R
                    Reza
                    @AWI
                    after turn off Rpi ,lost serial gateway yet
                    • R Reza
                      @AWI
                      AWIA
                      AWIA
                      AWI
                      @Reza Do you reboot or just unplug the PI? You can also try to enable the "Data Timeout" in Domoticz, that way it searches actively when not found in first instance
                      • AWIA AWI
                        R
                        R
                        Reza
                        @AWI
                        first i reboot and lost serial. i test once unplug. in both serial gateway is lost... data timeout must disable !!!!
                        • R Reza
                          @AWI
                          AWIA
                          AWIA
                          AWI
                          Whatever :confused:
                          If you are using a good quality Nano with default sketch I am out of options.
                          • AWIA AWI
                            Whatever :confused:
                            R
                            R
                            Reza
                            @AWI
                            • R Reza
                              @AWI
                              AWIA
                              AWIA
                              AWI
                              @Reza 0_1474892836376_upload-73dba86d-b2df-491d-af4b-132b615acf8f
                              • AWIA AWI
                                R
                                R
                                Reza
                                @AWI
                                I'm tired for this problem :/
                                thank you
                                • R
                                  R
                                  Reza
                                  i think if Rpi gateway complete and test... this is can resolved this problem ! is that correct? so i must wait...
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Reza
                                    I assume that you have tried to look at lsusb, dmesg, and /dev population, when the device is not turning up in Domoticz?
                                    Does any of those indicate something bad / interesting?
                                    • tbowmoT tbowmo
                                      @Reza
                                      R
                                      R
                                      Reza
                                      @tbowmo
                                      I can not understand what you mean !!!
                                      but after all my try , after reset (Rpi) or turn off .... my serial gateway is lost and i must unplug usb cable and plug in again.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        after you have powered on your raspberry, you log in
                                        then at the command prompt you type:
                                        lsusb
                                        -> provide the output
                                        unplug / plug the usb device
                                        once more in your terminal
                                        lsusb
                                        -> provide output
                                        the same for dmesg. In a terminal type "dmesg" hit return, and provide the output, both before you unplug a device that is not working, and after you have done it, and it is working.
                                        R 3 Replies Last reply
                                        • tbowmoT tbowmo
                                          lsusb
                                          lsusb
                                          -> provide output
                                          R
                                          R
                                          Reza
                                          "the same for dmesg. In a terminal type "dmesg" hit return, and provide the output, both before you unplug a device that is not working, and after you have done it, and it is working."
                                          for this , what am i do ?
