  3. Sensor Node V2.0
Sensor Node V2.0
23 Posts 9 Posters 14.4k Views 6 Watching
  • H Offline
    H Offline
    hari
    Can't wait to grab a lot of these when they're available:
    http://www.seeedstudio.com/wiki/DevDuino_Sensor_Node_V2.0_(ATmega_328)
    J 1 Reply Last reply
    • H hari
      J Offline
      J Offline
      jendrush
      @hari Nice product. I wonder why they used MCP9700 temperature sensor instead of DS18B20. Accuracy of ± 2 ° C isn't very impressive.
      • A Offline
        A Offline
        axillent
        DS18B20 is not designed for battery operation
        It consumes too much
        sense and drive
        • A Offline
          A Offline
          axillent
          We are going to have a set of Mysensors PCB for different purposes. The first one will be powered from a single AAA alkaline battery and will also have MCP9700 on board
          Regardless DevDuino it will have radio on board and will have some more benefits
          It is a good time now before the production to change something. There is no problem to install a precise and low power I2C temperature sensor on board.
          But are you ready to pay $1-1.5 more for the board to get ± 0.5 ° C precision instead of ± 2 ° C?
          sense and drive
          J C 2 Replies Last reply
          • A axillent
            J Offline
            J Offline
            jendrush
            @axillent I am ready to pay more for better precision. I'm assuming that ± 2 ° C is max accuracy error. So i am wondering what is typical accuracy.
            • H Offline
              H Offline
              hari
              I'd prefer the hi-res sensor
              • A Offline
                A Offline
                axillent
                OK, thanks for the feedback
                are you talking about default etc. embedded sensor?
                you will also have custom connectors to connect any kind of sensor
                what else in your view should be the default option for MySensors.Battery?
                sense and drive
                • A axillent
                  J Offline
                  J Offline
                  jendrush
                  @axillent I think that default sensor should be with good precision. In my case i would buy aprox 15 devices like this, and use this over a long period of time(at least few years) so ~20 usd difference in price isn't big. Maybe is worth to think about installing temp and humidity sensor(maybe antother model of device). How do you think - how long it could work on single battery when i need to read temp with 1 or 10 minutes period?
                  • A Offline
                    A Offline
                    axillent
                    software side is of the sensor is as important for the long run as a hardware side
                    In my assumption if all will be done correctly the average current sourced from the battery will be about 200mkA
                    this is in assumption of using one sensor for measurement each 1 minute and sending radio for each measurement
                    for 1A * H battery (should be common for alkaline AAA) it is about 5000 hours or 208 days.
                    discounting this we should have stable 6 months run time
                    but only real practice will give us real figures. We plan to have a test run as soon as prototypes will be ready.
                    also this board is have an optional solar power as a second power
                    with solar power attached battery life can be increased by 30-50%
                    sense and drive
                    • A axillent
                      J Offline
                      J Offline
                      jendrush
                      @axillent I've noticed solar power pins:) This would be great for outdoor sensors. I think that when suitable solar panel will be used our sensor could work almost without changing battery. Ofcourse until battery really need to be replaced because of phisical damage.
                      • F Offline
                        F Offline
                        filiphag
                        @axillent
                        What chip are you using as step-up from the singel cell battery source.
                        Looks like The pcb antenna of The nrf module is located in The midle of the pcb. Have you tried out The RF range in that placement?
                        • D Offline
                          Dennis van Velzen
                          Nice PCB design...
                          Suggested boards:
                          • 4 PWM logic FETs (dimming RGB W LED strips, 12V lights) Some FETs are easily capable of doing 8 amps and have almost no excess heat.
                          • 230V AC triac dimmer module (200w that fits in a EU wall box) EU net frequency.
                          • 0-10V input module (that fits behind a 0-10V dimmer in a wall box. Round max 60mm, thick approx. 15mm) power from 230VAC line.
                          • 0-10V output module.
                          • 1..4 channel opto input 3-250v module.
                          • 1..2 channel solid state relay module.
                          Can add nice usable parts, example schema's later... main goal good/better cheap(er) open source products!
                          • T Offline
                            T Offline
                            Tommy Sharp
                            Being able to buy something like this that is "all in one" will be great for us newbies! A more accurate temperature sensor would be ideal and worth the extra dollar!
                            A 1 Reply Last reply
                            • T Tommy Sharp
                              A Offline
                              A Offline
                              axillent
                              @Tommy-Sharp "all in one" is one of our goal while working on the project boards
                              Thanks all for ideas. We plan to have several project specific boards.
                              First one will be the battery operated board designed for wireless sensors.
                              Bellow is updated picture, should look better now.
                              Sensor will be the digital one with precision 0.5C or better and very low power consumption
                              Should we seriously support 5V from battery? For many applications 3.3V are sufficient and it will consume much less power from the battery.
                              Relays, dimmers, SSRs will be managed by another board.
                              sense and drive
                              • A axillent
                                C Offline
                                C Offline
                                clippermiami
                                @axillent How is this project coming along? Looking forward to a standardized PCB version.
                                • C clippermiami
                                  A Offline
                                  A Offline
                                  axillent
                                  @clippermiami we are currently in discussion with possible partners, we discussing production of the PCB and assembled PCB
                                  in parallel I'm doing a prototyping of the battery operated board
                                  Battery operated board will came first, later we plan to release a set of stackable boards ready be used for switching, dimming and integration behind a wall switch
                                  sense and drive
                                  C B 2 Replies Last reply
                                  • A axillent
                                    C Offline
                                    C Offline
                                    clippermiami
                                    @axillent LOOKING forward to it, a nice PCB makes a good clean project.
                                    • A axillent
                                      B Offline
                                      B Offline
                                      BulldogLowell
                                      North American wall switch?:ballot_box_with_check:
                                      • B BulldogLowell
                                        A Offline
                                        A Offline
                                        axillent
                                        @BulldogLowell from electrical side it is a clear plan to be universal between 110/220V 60/50Hz etc. to support both US and EU standard
                                        from the form factor point of view I have a view to EU standard but not US.. Hopefully we can be universal too but I will need your input on this.
                                        Even I'm not sure what is "North American" stands for :) is it common for US only or for Canada too?
                                        While for battery board the design is almost 95% clear the wall board is still under discussion.
                                        Most likely it will be stackable form factor with universal MCU -board and many different power&switch&dimm sub-boards
                                        All feel free to provide your inputs, to share ideas or wishes.
                                        sense and drive
                                        C 1 Reply Last reply
                                        • A axillent
                                          C Offline
                                          C Offline
                                          clippermiami
                                          @axillent North American standard is common to both US and Canada.
                                          12.2k
