  3. [Solved] MQTT gateway problem
ethernetmysensors 2.0.0mqttmosquitto
13 Posts 5 Posters 7.5k Views 5 Watching
  • pinkkoffP Offline
    pinkkoffP Offline
    pinkkoff
    wrote on last edited by pinkkoff
    Hi all!
    I am not native english speaker, sorry for my text.
    I have:
    • arduino mega
    • ethernet shield
    • mosquitto on linux (192.168.1.75:1883)
    • mysensors 2.0
    • arduino ide 1.6.12
    • MQTT gateway
    Code of MQTT Gateway:
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "ms_mqtt_gw-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "ms_mqtt_gw-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "mqtt_gw_1"
    // Security Signing
    #define MY_SIGNING_SOFT //!< Software signing
    //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
    // Enable node whitelisting
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN 54
      #define MY_SOFT_SPI_MISO_PIN 56
      #define MY_SOFT_SPI_MOSI_PIN 55
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,1,76
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 75
    #define MY_PORT 1883
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #include <Ethernet.h>
    And i have this trouble:
    0;255;3;0;9;Starting gateway (RNNGAS, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.76
    IP: 192.168.1.76
    IP: 192.168.1.76
    IP: 192.168.1.76
    0;255;3;0;9;TSP:SANCHK:OK
    IP: 192.168.1.76
    IP: 192.168.1.76
    IP: 192.168.1.76
    IP: 192.168.1.76
    I try to use mosquitto_sub and pub + mqtt-spy, and mqtt broker is work.
    I replase mega -> uno, one ethernet shield to another, nothing change.
    ping between client and brocker is ok.
    I don't know what else to do, can anybody help me?
    Y 1 Reply Last reply
    • M Offline
      M Offline
      Martin Tellblom
      wrote on last edited by Martin Tellblom
      Can you connect to the MQTT server using MQTT-SPY?
      MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
      pinkkoffP 1 Reply Last reply
      • M Martin Tellblom
        pinkkoffP Offline
        pinkkoffP Offline
        pinkkoff
        @Martin-Tellblom Yes, it work normally, how it seems to me.
        • pinkkoffP pinkkoff
          Hi all!
          I have:
          • arduino mega
          • ethernet shield
          • mysensors 2.0
          • MQTT gateway
           * LED purposes:
           * nRF24L01+  ESP8266
           * VCC        VCC
           * CE         GPIO4
           * CSN/CS     GPIO15
           * SCK        GPIO14
           * MISO       GPIO12
           * MOSI       GPIO13
          // Security Signing
            #define MY_SOFTSPI
          IP: 192.168.1.76
          IP: 192.168.1.76
          IP: 192.168.1.76
          IP: 192.168.1.76
          IP: 192.168.1.76
          IP: 192.168.1.76
          IP: 192.168.1.76
          IP: 192.168.1.76
          Y Offline
          Y Offline
          @pinkkoff what version of mosquitto are you running?
          • Y Yveaux
            pinkkoffP Offline
            pinkkoffP Offline
            pinkkoff
            @Yveaux
            mosquitto is an MQTT v3.1 broker.
            Version: 0.15-2ubuntu1
            Run on Odroid C1+ with ubuntu 14.04
              @Yveaux
              Y Offline
              Y Offline
              @pinkkoff iirr the mqtt implementation in mysensors is 3.1.1
              Try upgrading your mosquitto version
              • Y Yveaux
                pinkkoffP Offline
                pinkkoffP Offline
                pinkkoff
                @Yveaux Thank you!!! It working!
                Problem is in version of mosquitto in ubuntu repository. If someone want to use mqtt, better way is follow step-by-step guide
                B 1 Reply Last reply
                  B Offline
                  B Offline
                  blacey
                  @pinkkoff
                  FYI, I've had better luck using the mosquitto ppa. Tested on RPI2 and RPI3 running Ubuntu.
                  • ikkeTI Offline
                    ikkeTI Offline
                    ikkeT
                    wrote on last edited by ikkeT
                    I'm also trying mqtt. somehow I can't see the messages:
                    MySensors $ ./configure --my-gateway=mqtt --my-controller-ip-address=192,168,1,32 --my-port=1883 --my-mqtt-client-id=22 --my-mqtt-publish-topic-prefix=mysensors-from --my-mqtt-subscribe-topic-prefix=mysensors-to --my-rf24-pa-level=RF24_PA_LOW
                    MySensors $ sudo make install
                    MySensors $ sudo mysGateway -d
                    mysGateway: Attempting MQTT connection...
                    mysGateway: connected to 192.168.1.32
                    mysGateway: TSF:MSG:READ,8-8-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    mysGateway: !TSF:MSG:SEND,0-0-8-8,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                    mysGateway: TSF:MSG:READ,8-8-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta
                    mysGateway: TSF:MSG:READ,8-8-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    So GW attempts to send some stuff to mqtt server elsewhere, like that version string. But this on the server prints nothing:
                    $ mosquitto_sub -t mysensors-from/*
                    I also tried with # instead of *
                    I've verified mqtt works, if I pub that from mqtt client, it works.
                    • ikkeTI Offline
                      ikkeTI Offline
                      ikkeT
                      so this works:
                      MySensors $ mosquitto_pub -h 192.168.1.32 -t mysensors-from/0/1 -m "MySensors MQTT hello world from raspi to odroid"
                      mqtt-host $ mosquitto_sub -t mysensors-from/#
                      • ikkeTI Offline
                        ikkeTI Offline
                        ikkeT
                        My mosquitto is mosquitto 3.1 - 0.15-2ubuntu1 (from ppa) and mysensors is up to date devel branch from github.
                        • ikkeTI Offline
                          ikkeTI Offline
                          ikkeT
                          after upgrading to above mentioned 3.1.1 version from wheezy, the mysensors start to print out it sends stuff. can't see it on subs yet though.
                          • ikkeTI Offline
                            ikkeTI Offline
                            ikkeT
                            nevermind. now after all upgrades AND BATTERY CHANGE to sensebender it's all fine :)
                            12.1k
