  3. [Solved] MQTT gateway problem
ethernetmysensors 2.0.0mqttmosquitto
13 Posts 5 Posters 7.7k Views 5 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    wrote on last edited by Martin Tellblom
    Can you connect to the MQTT server using MQTT-SPY?
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
    pinkkoffP 1 Reply Last reply
    • Martin TellblomM Martin Tellblom
      pinkkoffP
      pinkkoffP
      pinkkoff
      @Martin-Tellblom Yes, it work normally, how it seems to me.
      • pinkkoffP pinkkoff
        Hi all!
        I am not native english speaker, sorry for my text.
        I have:
        • arduino mega
        • ethernet shield
        • mosquitto on linux (192.168.1.75:1883)
        • mysensors 2.0
        • arduino ide 1.6.12
        • MQTT gateway
        Code of MQTT Gateway:
         * Version 1.0 - Henrik Ekblad
         * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
         * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
         * LED purposes:
         * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
          * Inclusion mode button:
        #define MY_MQTT_PUBLISH_TOPIC_PREFIX "ms_mqtt_gw-out"
        #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "ms_mqtt_gw-in"
        // Set MQTT client id
        #define MY_MQTT_CLIENT_ID "mqtt_gw_1"
        // Security Signing
        #define MY_SIGNING_SOFT //!< Software signing
        //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
        // Enable node whitelisting
        //#define MY_W5100_SPI_EN 4
        // radio on the same spi bus.
          #define MY_SOFTSPI
          #define MY_SOFT_SPI_SCK_PIN 54
          #define MY_SOFT_SPI_MISO_PIN 56
          #define MY_SOFT_SPI_MOSI_PIN 55
        #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
        #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
        #define MY_IP_ADDRESS 192,168,1,76
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 75
        #define MY_PORT 1883
        // Flash leds on rx/tx/err
        // Set blinking period
        // Enable inclusion mode
        #include <Ethernet.h>
        And i have this trouble:
        0;255;3;0;9;Starting gateway (RNNGAS, 2.0.0)
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:RADIO:OK
        0;255;3;0;9;TSM:GW MODE
        0;255;3;0;9;TSM:READY
        IP: 192.168.1.76
        IP: 192.168.1.76
        IP: 192.168.1.76
        IP: 192.168.1.76
        0;255;3;0;9;TSP:SANCHK:OK
        IP: 192.168.1.76
        IP: 192.168.1.76
        IP: 192.168.1.76
        IP: 192.168.1.76
        I try to use mosquitto_sub and pub + mqtt-spy, and mqtt broker is work.
        I replase mega -> uno, one ethernet shield to another, nothing change.
        ping between client and brocker is ok.
        I don't know what else to do, can anybody help me?
        @pinkkoff what version of mosquitto are you running?
        • YveauxY Yveaux
          pinkkoffP
          pinkkoffP
          pinkkoff
          @Yveaux
          mosquitto is an MQTT v3.1 broker.
          Version: 0.15-2ubuntu1
          Run on Odroid C1+ with ubuntu 14.04
            @Yveaux
            @pinkkoff iirr the mqtt implementation in mysensors is 3.1.1
            Try upgrading your mosquitto version
            • YveauxY Yveaux
              pinkkoffP
              pinkkoffP
              pinkkoff
              @Yveaux Thank you!!! It working!
              Problem is in version of mosquitto in ubuntu repository. If someone want to use mqtt, better way is follow step-by-step guide
              blaceyB 1 Reply Last reply
                blaceyB
                blaceyB
                blacey
                @pinkkoff
                FYI, I've had better luck using the mosquitto ppa. Tested on RPI2 and RPI3 running Ubuntu.
                • ikkeTI
                  ikkeTI
                  ikkeT
                  wrote on last edited by ikkeT
                  I'm also trying mqtt. somehow I can't see the messages:
                  MySensors $ ./configure --my-gateway=mqtt --my-controller-ip-address=192,168,1,32 --my-port=1883 --my-mqtt-client-id=22 --my-mqtt-publish-topic-prefix=mysensors-from --my-mqtt-subscribe-topic-prefix=mysensors-to --my-rf24-pa-level=RF24_PA_LOW
                  MySensors $ sudo make install
                  MySensors $ sudo mysGateway -d
                  mysGateway: Attempting MQTT connection...
                  mysGateway: connected to 192.168.1.32
                  mysGateway: TSF:MSG:READ,8-8-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  mysGateway: !TSF:MSG:SEND,0-0-8-8,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                  mysGateway: TSF:MSG:READ,8-8-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.1-beta
                  mysGateway: TSF:MSG:READ,8-8-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  So GW attempts to send some stuff to mqtt server elsewhere, like that version string. But this on the server prints nothing:
                  $ mosquitto_sub -t mysensors-from/*
                  I also tried with # instead of *
                  I've verified mqtt works, if I pub that from mqtt client, it works.
                  • ikkeTI
                    ikkeTI
                    ikkeT
                    so this works:
                    MySensors $ mosquitto_pub -h 192.168.1.32 -t mysensors-from/0/1 -m "MySensors MQTT hello world from raspi to odroid"
                    mqtt-host $ mosquitto_sub -t mysensors-from/#
                    • ikkeTI
                      ikkeTI
                      ikkeT
                      My mosquitto is mosquitto 3.1 - 0.15-2ubuntu1 (from ppa) and mysensors is up to date devel branch from github.
                      • ikkeTI
                        ikkeTI
                        ikkeT
                        after upgrading to above mentioned 3.1.1 version from wheezy, the mysensors start to print out it sends stuff. can't see it on subs yet though.
                        • ikkeTI
                          ikkeTI
                          ikkeT
                          nevermind. now after all upgrades AND BATTERY CHANGE to sensebender it's all fine :)
