  2. Bug Reports
  3. #define MY_DISABLED_SERIAL not stopping all serial data
8 Posts 3 Posters 3.6k Views 3 Watching
  • delinendD
    delinendD
    delinend
    wrote on last edited by delinend
    It looks like, that the #define MY_DISABLED_SERIAL not is stoping all serial data, from showing up on the serial port, on my GatewaySerial.ino.
    I have used:
    But I have a temperatur sensor, that is sending data, to my GW, and it still show data on my GW serial port.
    Ex. temperatur from NODE 6:
    6;0;1;0;0,24.5
    6;0;1;0;0,24.6
    6;0;1;0;0,24.5
    6;0;1;0;0,24.4
    6;0;1;0;0,24.5
    How do I stop this, so that I can use my serial port, on the GatewaySerial, to other things.
    Btw. I only want to "grab" data, via the "void receive()" function.
    My setup:
    Last Mysensor 2.0.1-beta
    2 Arduino Mini Pro (8Mhz) 3.3V version
    2 NRF24l01+ with 47uF caps
    Use a 3.6V LiPo battery on both setup's.
    IDE 1.6.12
      The whole purpose of the serial gateways is to output incoming messages on the serial line.
      Why not create a none-gateway node?
      delinendD mfalkviddM 3 Replies Last reply
        delinendD
        delinendD
        delinend
        @hek
        I was thinking of the same. Can you put me in a direction of an sketch, that I can use for that ?
          Or at least a non-serial gateway. Like ethernet gateway or mqtt gateway.
          delinendD 1 Reply Last reply
            delinendD
            delinendD
            delinend
            @mfalkvidd
            Dose it has to be a Gateway to "grab" the incomming data, from my sensor, or just a RepeaterNode ? Like a Sensor->Repeater only setup ? Have tryed this, but can't get it to work.
            • delinendD delinend
              @mfalkvidd
              @delinend a gateway sees all messages in a MySensors network. A repeater sees all messages passing through it. A node sees all messages sent to that node.
                delinendD
                delinendD
                delinend
                @mfalkvidd
                So before 2 NODE's only setup, can talk together, I have to remove the REGISTRATION_FEATURE ?
                  delinendD
                  delinendD
                  delinend
                  @hek
                  Can 2 NODE's talk together, without a Repeater or a Gateway ? I have tryed many things, but I can't get any data in the void receive() :-( I use the #defined MY_TRANSPORT_DONT_CARE_MODE, and the MY_PARENT_NODE_ID and MY_PARENT_NODE_IS_STATIC command setup (NODE ID 6 and 7).
                  12.5k
