  3. Can't compile Humidity sketch 2.0 .. What DHT library do I need?
19 Posts 9 Posters 20.4k Views 7 Watching
  • AWIA AWI
    @chuckconnors this is what I found as a working example on my system. I still don't understand why the DHT keeps being so popular. There are much better temp/hum sensors around..... But anyway, this one should work.
    Installation
    Place the [DHT][download] library folder in your `<arduinosketchfolder>/libraries/` folder. You may need to create the `libraries` subfolder if its your first library. Restart the Arduino IDE.
    [download]: https://github.com/markruys/arduino-DHT/archive/master.zip "Download DHT library"
    [example]: https://github.com/markruys/arduino-DHT/blob/master/examples/DHT_Test/DHT_Test.pde "Show DHT example"
    [header]: https://github.com/markruys/arduino-DHT/blob/master/DHT.h "Show header file"```
    C
    C
    chuckconnors
    Installation
    Thanks for the reply. I'm pretty sure that's one of the ones I tried. I ended up finding an old install I had and copied the library from there and it's working now.
    • tbowmoT
      tbowmoT
      tbowmo
      @chuckconnors
      if you look at the "examples" repository, it both examples folder, and libraries that should work with the enclosed examples. Copy the library, that you want to use, to Arduino/libraries/... and the example to Arduino/... and try to compile them.
      C 1 Reply Last reply
      • tbowmoT tbowmo
        @chuckconnors
        C
        C
        chuckconnors
        @tbowmo said:
        @chuckconnors
        HOLY SMOKES! I totally missed the libraries directory. Thank you and sorry for the troubles.
        • sundberg84S sundberg84
          @AWI probably because its mentioned in the build page? But i agree - I now know as well there is better out there.
          C
          C
          chuckconnors
          Can you tell me what better sensors are out there? These DHT11's I have vary wildly with regards to relative humidity.
          • sundberg84S
            sundberg84S
            @chuckconnors - BMP180 or Bmp280 for example.
              C
              C
              chuckconnors
              Those appear to be atmospheric pressure sensors. Looking for humidity sensors other than the DHT11/DHT22.
              • Nca78N
                wrote on last edited by Nca78
                DHT22 is already much better than DHT11 which I think is complete garbage: wild variations in both temp and humidity between sensors, too unprecise and it's getting worse with time.
                I heave read somewhere (sorry don't remember where but it was a guy testing a lot of temp/humidity sensors) that the best one for humidity is BME280. It has also atmospheric pressure and temperature (but is not really good for temp) like BMP180/280.
                The Si7020 like on the sensebender micro seems pretty good too.
                Just don't expect the same price level :D
                AWIA 1 Reply Last reply
                • Nca78N Nca78
                  AWIA
                  AWIA
                  AWI
                  wrote on last edited by AWI
                  :confused: Si7021 can be found for €2.65 (DHT22 €2.43) on ali-express. BME280 €4.07 including barometeric pressure.
                  A link to a comparison in this post
                  • karl261K
                    karl261K
                    karl261
                    Yes, BME280 seems pretty good for T, P, H. I did not have much luck with DHT22 and SI7021.
                    • R
                      R
                      r-nox
                      I'm dead in the water with the same issue. Downloading the lib from the location above yielded the same result.
                      • R r-nox
                        @r-nox did you download the library from MySensors or did you follow the link in the readme and download the upstream version of the library? Only the former will work.
                        R 1 Reply Last reply
                          R
                          R
                          r-nox
                          @mfalkvidd
                          I can't tell what I'm using anymore. Been at it all afternoon installing and un installing. I think I'm using these now (https://github.com/mysensors/MySensorsArduinoExamples/tree/master/libraries/DHT).
                          Where do I start please?
                          • R
                            R
                            r-nox
                            This one worked for me.
                            What a frustrating time that was.
                            • joaoabsJ
                              joaoabsJ
                              joaoabs
                              wrote on last edited by joaoabs
                              I really like mysensors.org, but I've always had difficulties with the site organization. In my opinion, is not intuitive at all, although it has a great and appealing theme.
                              Well, maybe it shouldn't, but this sets me back when trying to build anything... I know this excellent initiative for a couple of years now, and from time to time I try to do something but I end up de-motivated because it takes too long to find simple answers/solutions. At the moment, I have nothing built although I have all the equipment I need, including SenserBenders. Yes, frustrating like r-nox commented 2 years ago.
                              Anyway, my point is: For the ones looking for a library that makes this DHT sketch work, mysensors have compiled a set of libraries that include this DHT.h and many others. Just go to https://www.mysensors.org/about/arduino#optional---install-external-mysensors-examples (yes, the name is not intuitive, maybe the keyword library would make it more obvious?), or jump directly to here and follow the standard library instructions. It took me two hours to find this, hope it saves time for future followers of mysensors like myself.
                              Good luck!
