  2. Announcements
  • R raulandresmoch
    Can you use the RP as gateway and also as controller?
    NiklasON
    NiklasON
    NiklasO
    wrote on last edited by NiklasO
    #36
    @raulandresmoch
    Sure. I use this with Domoticz on my Pi.
    "MySensors Gateway with LAN interface" as hardware pointing to 127.0.0.1:5003
    Also, I can connect with other controller software like MYSController from my other computers to my Pi-IP at port 5003.
    • b0rmannB b0rmann
      what's about RS485 transport on raspberry pi? especially from wired RS485 mysensors network to MQTT
      marceloaqno
      Code Contributor
      @b0rmann I could add support for RS485, but I'll need your help to test because I don't have the hardware.
      b0rmannB 1 Reply Last reply
      • DrJeffD
        DrJeffD
        DrJeff
        The line above
        ./examples_linux/mysGatewaymsyGateway -h
        needs to be corrected to
        ./examples_linux/mysGateway -h
        Thanks for all the hard work! Awesome!
        • DrJeffD DrJeff
          The line above
          @DrJeff Thanks for noticing. It should be fixed now.
          • M marceloaqno
            b0rmannB
            b0rmannB
            b0rmann
            @marceloaqno
            i am ready. after compiled and upload example node sketch i have on rs485 to usb convertor (/dev/ttyUSB0) output nice mysensors data:
            01 FF 00 58 07 02 FF FF - FF 02 03 07 FF 03 66 04
            testing playground photo: 0_1476563966730_playground.jpg
              mvader
              wrote on last edited by mvader
              #41
              I noticed the "improve rf24" section was added. and it mentioned high cpu.
              i set mine up a few weeks ago and am not using an interrupt on my radio.
              my cpu is only 2-3%
              I'm curious if the high cpu problem is seen by many?
              also a 2nd question.
              if i were to add an interrupt. how can i "re-configure" my setup to include that new -switch
              or do i have to remove everything and re-clone from git hub and start over?
              • shfgS
                shfgS
                shfg
                Thanks for this excellent port. I'm having an issue running it as an MQTT gateway on the RPi (Model A). It compiles without hassles, but cant make a successful MQTT connection. I get the following:
                mysGateway: Starting gateway...
                mysGateway: Protocol version - 2.0.1-beta
                mysGateway: MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                mysGateway: TSF:LRT:OK
                mysGateway: TSM:INIT
                mysGateway: TSM:INIT:TSP OK
                mysGateway: TSM:INIT:GW MODE
                mysGateway: TSM:READY
                mysGateway: MCO:REG:NOT NEEDED
                mysGateway: MCO:BGN:STP
                mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                mysGateway: Attempting MQTT connection...
                mysGateway: connected to 127.0.0.1
                ... those attempts recurring every 15 seconds or so, and in that time, no other activity is processed.
                From the code, I would have expected 'MQTT connected' rather than 'connected to 127.0.0.1'?
                I have mosquitto running on the pi in this case - which is working perfectly in other tests. Both serial and ethernet gateway modes compile and run perfectly, only the mqtt mode not working.
                Has anyone else had a similar issue?
                • E
                  E
                  ericvdb
                  @marceloaqno what about gpio interrupts, is that supported?
                  I'm thinking to use a RPi as a pulse counter for water, electricity and gas with no radio, just ethernet or mqtt.
                  In combination with a I2C display, this could be a nice project ;)
                  Greetz,
                  Eric
                  • Christian SimonsenC
                    Christian SimonsenC
                    Christian Simonsen
                    I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. And I have followed the steps under "install and build", which seem to have worked fine. I didn't make any changes to the conf file. However now Im stuck. How do I setup the Raspberry Pi with the NRF24L01+ as a gateway in the MyController Gateway setup page in Safari?
                    • shfgS shfg
                      marceloaqno
                      Code Contributor
                      wrote on last edited by marceloaqno
                      #45
                      @shfg There were some reports about this problem in the past, do you see any error messages in your mosquitto log?
                      @ericvdb yes, you can attach a function to handle an interruption like this:
                      uint8_t mode = FALLING;	// Valid options are: CHANGE, FALLING, RISING
                      uint8_t physPin = 16;	// Choose a pin that fits your needs
                      void irqHandler(void)
                      	// Process the interrupt
                      	attachInterrupt(physPin, irqHandler, mode);
                      Support for I2C was added in the latest version.
                      shfgS 2 Replies Last reply
                      • Christian SimonsenC Christian Simonsen
                        marceloaqno
                        Code Contributor
                        @Christian-Simonsen If you are using the default build options for the RPi gateway, in MyController (Resources -> Add gateway) choose Ethernet for the type and enter your RPi ip address in the Host name field.
                        Christian SimonsenC 1 Reply Last reply
                        • T
                          Toyman
                          Is it compatible with pre-2.0 versions eg 1.5?
                          • M marceloaqno
                            Christian SimonsenC
                            Christian SimonsenC
                            Christian Simonsen
                            Thanks that did the trick
                              Christian SimonsenC
                              Christian Simonsen
                              wrote on last edited by Christian Simonsen
                              #49
                              Background: I have a raspberry Pi 2 that I've installed MyController on. This works fine, I can access it via the browser. I have also wired up an NRF24L01+ module to the GPIO pins on the Raspberry Pi. I have also set up the raspberry pi as a gateway in the MyController Gateway setup page in Safari. It found it and it seem to work.
                              However to my question. How do I know if the Raspberry Pi gateway with NRF24L01 work? How can I monitor what the Raspberry Pi gateway receive? Is there a similar way as the "Serial Monitor" that I use in the Arduino application, when accessing Arduino Uno via USB?
                              If there is I need to monitor this via OSX Terminal.
                              jerseyguy1996J 1 Reply Last reply
                              • E
                                E
                                ericvdb
                                @marceloaqno
                                Today i tried to use the sketch Water Meter Pulse Sensor in mysGateway.cpp but i run into alot of errors, you have any idea?
                                mysGateway.cpp:
                                 * Created by Marcelo Aquino <marceloaqno@gmail.org>
                                 * Copyleft (c) 2016, Marcelo Aquino
                                #include <iostream>
                                #include <cstdio>
                                #include <unistd.h>
                                // For more options run ./configure --help
                                // Config file
                                //#define MY_LINUX_CONFIG_FILE "/etc/mysensors.dat"
                                #define MY_GATEWAY_MAX_CLIENTS 10
                                // Serial config
                                // Enable this if you are using an Arduino connected to the USB
                                //#define MY_LINUX_SERIAL_PORT "/dev/ttyACM0"
                                // Enable this if you need to connect to a controller running on the same device
                                //#define MY_IS_SERIAL_PTY
                                // Choose a symlink name for the PTY device
                                //#define MY_LINUX_SERIAL_PTY "/dev/ttyMySensorsGateway"
                                // Grant access to the specified system group for the serial device
                                //#define MY_LINUX_SERIAL_GROUPNAME "tty"
                                // MQTT options
                                //#define MY_PORT 1883
                                //#define MY_MQTT_CLIENT_ID "mysensors-1"
                                //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
                                //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
                                // Flash leds on rx/tx/err
                                //#define MY_DEFAULT_ERR_LED_PIN 12  // Error LED pin
                                //#define MY_DEFAULT_RX_LED_PIN  16  // Receive LED pin
                                //#define MY_DEFAULT_TX_LED_PIN  18  // Transmit LED pin
                                // Inverse the blinking feature
                                #define DIGITAL_INPUT_SENSOR 26                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
                                #define PULSE_FACTOR 1000                       // Nummber of blinks per m3 of your meter (One rotation/liter)
                                #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
                                #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
                                #define CHILD_ID 1                              // Id of the sensor child
                                unsigned long SEND_FREQUENCY = 30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                                MyMessage flowMsg(CHILD_ID,V_FLOW);
                                MyMessage volumeMsg(CHILD_ID,V_VOLUME);
                                MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                                double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
                                volatile double flow = 0;
                                bool pcReceived = false;
                                unsigned long oldPulseCount = 0;
                                unsigned long newBlink = 0;
                                double oldflow = 0;
                                double volume =0;
                                double oldvolume =0;
                                unsigned long lastSend =0;
                                unsigned long lastPulse =0;
                                void onPulse()
                                  if (!SLEEP_MODE)
                                    unsigned long interval = newBlink-lastBlink;
                                    if (interval!=0)
                                      lastPulse = millis();
                                      if (interval<500000L) {
                                        // Sometimes we get interrupt on RISING,  500000 = 0.5sek debounce ( max 120 l/min)
                                        return;
                                      flow = (60000000.0 /interval) / ppl;
                                    lastBlink = newBlink;
                                  pulseCount++;
                                  attachInterrupt(DIGITAL_INPUT_SENSOR, onPulse, FALLING);
                                  sendSketchInfo("Water Meter", "1.1");
                                  // Register this device as Waterflow sensor
                                  present(CHILD_ID, S_WATER);
                                  unsigned long currentTime = millis();
                                  if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY))
                                    lastSend=currentTime;
                                    if (!pcReceived) {
                                      //Last Pulsecount not yet received from controller, request it again
                                      request(CHILD_ID, V_VAR1);
                                      return;
                                    if (!SLEEP_MODE && flow != oldflow) {
                                      oldflow = flow;
                                      Serial.print("l/min:");
                                      Serial.println(flow);
                                      // Check that we dont get unresonable large flow value.
                                      if (flow<((unsigned long)MAX_FLOW)) {
                                        send(flowMsg.set(flow, 2));                   // Send flow value to gw
                                    // No Pulse count received in 2min
                                    if(currentTime - lastPulse > 120000){
                                      flow = 0;
                                    // Pulse count has changed
                                    if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                                      oldPulseCount = pulseCount;
                                      Serial.print("pulsecount:");
                                      Serial.println(pulseCount);
                                      send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                                      double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                                      if ((volume != oldvolume)||(!SLEEP_MODE)) {
                                        oldvolume = volume;
                                        Serial.print("volume:");
                                        Serial.println(volume, 3);
                                        send(volumeMsg.set(volume, 3));               // Send volume value to gw
                                  if (SLEEP_MODE) {
                                    sleep(SEND_FREQUENCY);
                                ./configure --my-debug=enable --my-gateway=ethernet --my-radio=none --my-port=5003
                                [OK] machine detected: SoC=BCM2835, Type=RPi, CPU=armv6l, REV=000e.
                                [OK] init system detected: systemd
                                [OK] Finished.
                                make:
                                root@raspberrypi:/downloads/MySensors# make
                                cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SoftEeprom.o drivers/Linux/SoftEeprom.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
                                g++ -DMY_GATEWAY_LINUX -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=5003  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
                                examples_linux/mysGateway.cpp: In function âvoid onPulse()â:
                                examples_linux/mysGateway.cpp:96:37: error: âmicrosâ was not declared in this scope
                                examples_linux/mysGateway.cpp: In function âvoid loop()â:
                                examples_linux/mysGateway.cpp:166:41: error: call of overloaded âset(volatile long unsigned int&)â is ambiguous
                                examples_linux/mysGateway.cpp:166:41: note: candidates are:
                                In file included from ./MySensors.h:319:0,
                                                 from examples_linux/mysGateway.cpp:60:
                                ./core/MyMessage.cpp:222:12: note: MyMessage& MyMessage::set(const char*) <near match>
                                 MyMessage& MyMessage::set(const char* value) {
                                ./core/MyMessage.cpp:222:12: note:   no known conversion for argument 1 from âvolatile long unsigned intâ to âconst char*â
                                ./core/MyMessage.cpp:234:12: note: MyMessage& MyMessage::set(bool)
                                 MyMessage& MyMessage::set(bool value) {
                                ./core/MyMessage.cpp:241:12: note: MyMessage& MyMessage::set(uint8_t)
                                 MyMessage& MyMessage::set(uint8_t value) {
                                ./core/MyMessage.cpp:256:12: note: MyMessage& MyMessage::set(uint32_t)
                                 MyMessage& MyMessage::set(uint32_t value) {
                                ./core/MyMessage.cpp:263:12: note: MyMessage& MyMessage::set(int32_t)
                                 MyMessage& MyMessage::set(int32_t value) {
                                ./core/MyMessage.cpp:270:12: note: MyMessage& MyMessage::set(uint16_t)
                                 MyMessage& MyMessage::set(uint16_t value) {
                                ./core/MyMessage.cpp:277:12: note: MyMessage& MyMessage::set(int16_t)
                                 MyMessage& MyMessage::set(int16_t value) {
                                examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(long unsigned int&)â is ambiguous
                                examples_linux/mysGateway.cpp:180:25: note: candidates are:
                                In file included from examples_linux/mysGateway.cpp:22:0:
                                /usr/include/unistd.h:444:21: note: unsigned int sleep(unsigned int)
                                 extern unsigned int sleep (unsigned int __seconds);
                                In file included from ./MySensors.h:320:0,
                                ./core/MySensorsCore.cpp:543:8: note: int8_t sleep(uint32_t, bool)
                                 int8_t sleep(const uint32_t sleepingMS, const bool smartSleep) {
                                Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                                make: *** [examples_linux/mysGateway.o] Error 1
                                • E
                                  E
                                  ericvdb
                                  @marceloaqno
                                  i was able to get a bit further by replacing all "unsigned long" declarations with "uint"
                                  Remains unsolved:
                                  examples_linux/mysGateway.cpp:96:28: error: âmicrosâ was not declared in this scope
                                       uint newBlink = micros();
                                  examples_linux/mysGateway.cpp:180:25: error: call of overloaded âsleep(uint&)â is ambiguous
                                  • T
                                    Toyman
                                    I probably miss something, but why are trying to compile the arduino sketch on Raspberry Pi???
                                      @ericvdb
                                      As @Toyman implies, we haven't ported the full Arduino environment here. This should mainly be used for running the Serial/Ethernet gateway directly on your RPi.
                                      You cannot just run any MySensors example without risking to make heavy adaptations/implementation on your own.
                                      • E ericvdb
                                        @marceloaqno
                                        Remains unsolved:
                                        marceloaqno
                                        Code Contributor
                                        #54
                                        @ericvdb micros() hasn't been ported, use:
                                        millis() /1000;
                                        for sleep(), replace:
                                        with
                                        sleep(SEND_FREQUENCY, false);
                                        Also, if you want to print something don't use Serial.print() or Serial.println(), use printf() or debug().
                                        should be:
                                        debug("l/min: %f\n", flow);
                                        as @hek said, the main focus now is to be used as a gateway, with time adding sensors will become less problematic.
                                        • E
                                          E
                                          ericvdb
                                          @marceloaqno
                                          I have it almost working. Regarding the interrupt, I have to pull-up to 3.3V the io pin through a resistor of 10k?
                                          Right now the interrupt isn't firing
